--- ray/src/util/rad.c 1993/03/11 17:23:33 2.3 +++ ray/src/util/rad.c 1993/08/13 09:19:30 2.18 @@ -94,10 +94,18 @@ int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; #define renderopts (*setqopts[vscale(QUALITY)]) + /* overture calculation file */ +#ifdef NIX +char overfile[] = "overture.raw"; +#else +char overfile[] = "/dev/null"; +#endif + extern long fdate(), time(); long scenedate; /* date of latest scene or object file */ long octreedate; /* date of octree */ +long matdate; /* date of latest material file */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ @@ -159,8 +167,11 @@ char *argv[]; /* print all values if requested */ if (explicate) printvals(); - /* run simulation */ + /* build octree */ oconv(); + /* check date on ambient file */ + checkambfile(); + /* run simulation */ renderopts(ropts); xferopts(ropts); if (rvdevice != NULL) @@ -195,7 +206,7 @@ load(rfname) /* load Radiance simulation file */ char *rfname; { FILE *fp; - char buf[256]; + char buf[512]; register char *cp; if (rfname == NULL) @@ -212,6 +223,8 @@ char *rfname; case '#': *cp = '\0'; break; + default: + continue; } break; } @@ -260,12 +273,15 @@ register char *ass; exit(1); } /* assign new value */ - cp = vp->value; i = vp->nass; - while (i--) - while (*cp++) - ; - i = cp - vp->value; - vp->value = realloc(vp->value, i+n+1); + if (i = vp->nass) { + cp = vp->value; + while (i--) + while (*cp++) + ; + i = cp - vp->value; + vp->value = realloc(vp->value, i+n+1); + } else + vp->value = malloc(n+1); if (vp->value == NULL) syserr(progname); strcpy(vp->value+i, ass); @@ -369,7 +385,8 @@ register char *fnames; while (*fnames) { while (isspace(*fnames)) fnames++; cp = thisfile; - while (*fnames && !isspace(*fnames)) *cp++ = *fnames++; + while (*fnames && !isspace(*fnames)) + *cp++ = *fnames++; *cp = '\0'; if ((thisdate = fdate(thisfile)) < 0) syserr(thisfile); @@ -407,6 +424,9 @@ checkfiles() /* check for existence and modified tim vnam(OCTREE), vnam(SCENE)); exit(1); } + matdate = -1; + if (vdef(MATERIAL)) + matdate = checklast(vval(MATERIAL)); } @@ -488,8 +508,8 @@ printvals() /* print variable values */ register int i, j; for (i = 0; i < NVARS; i++) - for (j = 0; j < vv[i].nass; j++) - printf("%s= %s\n", vv[i].name, nvalue(vv+i, j)); + for (j = 0; j < vdef(i); j++) + printf("%s= %s\n", vnam(i), nvalue(vv+i, j)); fflush(stdout); } @@ -502,16 +522,14 @@ oconv() /* run oconv if necessary */ return; /* build command */ oconvopts(ocopts); - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vdef(MATERIAL) ? vval(MATERIAL) : "", - vval(SCENE), vval(OCTREE)); - if (!silent) { /* echo it */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (noaction) - return; - if (system(combuf)) { /* run it */ + if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(SCENE), vval(OCTREE)); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(SCENE), vval(OCTREE)); + + if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error generating octree\n\t%s removed\n", progname, vval(OCTREE)); unlink(vval(OCTREE)); @@ -543,6 +561,19 @@ register char *oo; } +checkambfile() /* check date on ambient file */ +{ + long afdate; + + if (!vdef(AMBFILE)) + return; + if ((afdate = fdate(vval(AMBFILE))) < 0) + return; + if (octreedate > afdate | matdate > afdate) + rmfile(vval(AMBFILE)); +} + + double ambval() /* compute ambient value */ { @@ -575,20 +606,17 @@ register char *op; d *= 3./(siz[0]+siz[1]+siz[2]); switch (vscale(DETAIL)) { case LOW: - op = addarg(op, "-ps 16"); - op = addarg(op, "-dp 16"); + op = addarg(op, "-ps 16 -dp 16"); sprintf(op, " -ar %d", (int)(4*d)); op += strlen(op); break; case MEDIUM: - op = addarg(op, "-ps 8"); - op = addarg(op, "-dp 32"); + op = addarg(op, "-ps 8 -dp 32"); sprintf(op, " -ar %d", (int)(8*d)); op += strlen(op); break; case HIGH: - op = addarg(op, "-ps 4"); - op = addarg(op, "-dp 64"); + op = addarg(op, "-ps 4 -dp 64"); sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); break; @@ -596,12 +624,9 @@ register char *op; op = addarg(op, "-pt .16"); if (vbool(PENUMBRAS)) op = addarg(op, "-ds .4"); - op = addarg(op, "-dt .2"); - op = addarg(op, "-dc .25"); - op = addarg(op, "-dr 0"); - op = addarg(op, "-sj 0"); - op = addarg(op, "-st .7"); - op = addarg(op, "-ab 0"); + else + op = addarg(op, "-ds 0"); + op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5"); if (vdef(AMBFILE)) { sprintf(op, " -af %s", vval(AMBFILE)); op += strlen(op); @@ -609,24 +634,20 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .4"); - op = addarg(op, "-ad 32"); + op = addarg(op, "-aa .4 -ad 64"); break; case MEDIUM: - op = addarg(op, "-aa .3"); - op = addarg(op, "-ad 64"); + op = addarg(op, "-aa .3 -ad 128"); break; case HIGH: - op = addarg(op, "-aa .25"); - op = addarg(op, "-ad 128"); + op = addarg(op, "-aa .25 -ad 256"); break; } op = addarg(op, "-as 0"); d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 3"); - op = addarg(op, "-lw .02"); + op = addarg(op, "-lr 3 -lw .02"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -665,18 +686,15 @@ register char *op; break; } op = addarg(op, "-pt .08"); - if (vbool(PENUMBRAS)) { - op = addarg(op, "-ds .2"); - op = addarg(op, "-dj .35"); - } else + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .2 -dj .35"); + else op = addarg(op, "-ds .3"); - op = addarg(op, "-dt .1"); - op = addarg(op, "-dc .5"); - op = addarg(op, "-dr 1"); - op = addarg(op, "-sj .7"); - op = addarg(op, "-st .15"); - sprintf(op, " -ab %d", overture=vint(INDIRECT)); - op += strlen(op); + op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1"); + if (overture = vint(INDIRECT)) { + sprintf(op, " -ab %d", overture); + op += strlen(op); + } if (vdef(AMBFILE)) { sprintf(op, " -af %s", vval(AMBFILE)); op += strlen(op); @@ -684,26 +702,19 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .25"); - op = addarg(op, "-ad 128"); - op = addarg(op, "-as 0"); + op = addarg(op, "-aa .25 -ad 196 -as 0"); break; case MEDIUM: - op = addarg(op, "-aa .2"); - op = addarg(op, "-ad 300"); - op = addarg(op, "-as 64"); + op = addarg(op, "-aa .2 -ad 400 -as 64"); break; case HIGH: - op = addarg(op, "-aa .15"); - op = addarg(op, "-ad 500"); - op = addarg(op, "-as 128"); + op = addarg(op, "-aa .15 -ad 768 -as 196"); break; } d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 6"); - op = addarg(op, "-lw .002"); + op = addarg(op, "-lr 6 -lw .002"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -742,16 +753,11 @@ register char *op; break; } op = addarg(op, "-pt .04"); - if (vbool(PENUMBRAS)) { - op = addarg(op, "-ds .1"); - op = addarg(op, "-dj .7"); - } else + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .1 -dj .7"); + else op = addarg(op, "-ds .2"); - op = addarg(op, "-dt .05"); - op = addarg(op, "-dc .75"); - op = addarg(op, "-dr 3"); - op = addarg(op, "-sj 1"); - op = addarg(op, "-st .03"); + op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01"); sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); op += strlen(op); if (vdef(AMBFILE)) { @@ -761,26 +767,19 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .15"); - op = addarg(op, "-ad 200"); - op = addarg(op, "-as 0"); + op = addarg(op, "-aa .15 -ad 256 -as 0"); break; case MEDIUM: - op = addarg(op, "-aa .125"); - op = addarg(op, "-ad 512"); - op = addarg(op, "-as 128"); + op = addarg(op, "-aa .125 -ad 512 -as 256"); break; case HIGH: - op = addarg(op, "-aa .08"); - op = addarg(op, "-ad 850"); - op = addarg(op, "-as 256"); + op = addarg(op, "-aa .08 -ad 1024 -as 512"); break; } d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 12"); - op = addarg(op, "-lw .0005"); + op = addarg(op, "-lr 12 -lw .0005"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -790,33 +789,26 @@ xferopts(ro) /* transfer options if indicated */ char *ro; { int fd, n; + register char *cp; n = strlen(ro); if (n < 2) return; if (vdef(OPTFILE)) { - if ((fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) + for (cp = ro; cp[1]; cp++) + if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3])) + *cp = '\n'; + else + *cp = cp[1]; + *cp = '\n'; + fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666); + if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0) syserr(vval(OPTFILE)); - if (write(fd, ro+1, n-1) != n-1) - syserr(vval(OPTFILE)); - write(fd, "\n", 1); - close(fd); - ro[0] = ' '; - ro[1] = '^'; - strcpy(ro+2, vval(OPTFILE)); + sprintf(ro, " @%s", vval(OPTFILE)); } #ifdef MSDOS else if (n > 50) { - register char *evp = bmalloc(n+6); - if (evp == NULL) - syserr(progname); - strcpy(evp, "ROPT="); - strcat(evp, ro); - if (putenv(evp) != 0) { - fprintf(stderr, "%s: out of environment space\n", - progname); - exit(1); - } + setenv("ROPT", ro+1); strcpy(ro, " $ROPT"); } #endif @@ -831,8 +823,14 @@ register char *po; po = addarg(po, "-1 -e"); po = addarg(po, vval(EXPOSURE)); } - if (vscale(QUALITY) == HIGH) - po = addarg(po, "-r .65"); + switch (vscale(QUALITY)) { + case MEDIUM: + po = addarg(po, "-r 1"); + break; + case HIGH: + po = addarg(po, "-m .25"); + break; + } if (vdef(PFILT)) po = addarg(po, vval(PFILT)); } @@ -948,15 +946,21 @@ register char *vs; break; } } else { - while (*vs && !isspace(*vs)) /* else skip id */ - vs++; + while (!isspace(*vs)) /* else skip id */ + if (!*vs++) + return(NULL); if (upax) { /* specify up vector */ strcpy(cp, vup[upax+3]); cp += strlen(cp); } } - /* append any additional options */ - strcpy(cp, vs); + strcpy(cp, vs); /* append any additional options */ +#ifdef MSDOS + if (strlen(viewopts) > 40) { + setenv("VIEW", viewopts); + return("$VIEW"); + } +#endif return(viewopts); } @@ -964,11 +968,12 @@ register char *vs; char * getview(n, vn) /* get view n, or NULL if none */ int n; -char *vn; +char *vn; /* returned view name */ { - register char *mv; + register char *mv = NULL; + register int i; - if (viewselect != NULL) { + if (viewselect != NULL) { /* command-line selected */ if (n) /* only do one */ return(NULL); if (viewselect[0] == '-') { /* already specified */ @@ -987,13 +992,14 @@ char *vn; return(specview(mv)); return(specview(viewselect)); /* standard view? */ } - if (vn != NULL && (mv = nvalue(vv+VIEW, n)) != NULL) { - if (*mv != '-') - while (*mv && !isspace(*mv)) - *vn++ = *mv++; + mv = nvalue(vv+VIEW, n); /* use view n */ + if (vn != NULL & mv != NULL) { + if (mv[i=0] != '-') + while (mv[i] && !isspace(mv[i])) + *vn++ = mv[i++]; *vn = '\0'; } - return(specview(nvalue(vv+VIEW, n))); /* use view n */ + return(specview(mv)); } @@ -1006,13 +1012,7 @@ char *opts; if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); strcat(combuf, vval(OCTREE)); - if (!silent) { /* echo it */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (noaction) - return; - if (system(combuf)) { /* run it */ + if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error running rview\n", progname); exit(1); } @@ -1027,6 +1027,7 @@ char *opts; char pfopts[128]; char vs[32], *vw; int vn, mult; + long lastdate; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ @@ -1057,20 +1058,8 @@ char *opts; else badvalue(REPORT); } - /* check date on ambient file */ - if (vdef(AMBFILE)) { - long afdate = fdate(vval(AMBFILE)); - if (afdate >= 0 & octreedate > afdate) { - if (!silent) -#ifdef MSDOS - printf("\tdel %s\n", vval(AMBFILE)); -#else - printf("\trm %s\n", vval(AMBFILE)); -#endif - if (!noaction) - unlink(vval(AMBFILE)); - } - } + /* get update time */ + lastdate = octreedate > matdate ? octreedate : matdate; /* do each view */ vn = 0; while ((vw = getview(vn++, vs)) != NULL) { @@ -1078,11 +1067,11 @@ char *opts; sprintf(vs, "%d", vn); sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); /* check date on picture */ - if (fdate(picfile) > octreedate) + if (fdate(picfile) >= lastdate) continue; /* build rpict command */ sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs); - if (fdate(rawfile) > octreedate) /* recover */ + if (fdate(rawfile) >= octreedate) /* recover */ sprintf(combuf, "rpict%s%s -ro %s %s", rep, opts, rawfile, vval(OCTREE)); else { @@ -1090,28 +1079,22 @@ char *opts; sprintf(combuf, "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s", rep, vw, opts, - vval(OCTREE), rawfile); - if (!silent) { - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { + vval(OCTREE), overfile); + if (runcom(combuf)) { fprintf(stderr, - "%s: error in overture for view %s\n\t%s removed\n", - progname, vs, rawfile); - unlink(rawfile); + "%s: error in overture for view %s\n", + progname, vs); exit(1); } +#ifdef NIX + rmfile(overfile); +#endif } sprintf(combuf, "rpict%s %s %s%s %s > %s", rep, vw, res, opts, vval(OCTREE), rawfile); } - if (!silent) { /* echo rpict command */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { /* run rpict */ + if (runcom(combuf)) { /* run rpict */ fprintf(stderr, "%s: error rendering view %s\n", progname, vs); exit(1); @@ -1123,11 +1106,7 @@ char *opts; else sprintf(combuf, "pfilt%s %s > %s", pfopts, rawfile, picfile); - if (!silent) { /* echo pfilt command */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { /* run pfilt */ + if (runcom(combuf)) { /* run pfilt */ fprintf(stderr, "%s: error filtering view %s\n\t%s removed\n", progname, vs, picfile); @@ -1135,16 +1114,56 @@ char *opts; exit(1); } /* remove raw file */ - if (!silent) + rmfile(rawfile); + } +} + + +runcom(cs) /* run command */ +char *cs; +{ + if (!silent) /* echo it */ + printf("\t%s\n", cs); + if (noaction) + return(0); + fflush(stdout); /* flush output and pass to shell */ + return(system(cs)); +} + + +rmfile(fn) /* remove a file */ +char *fn; +{ + if (!silent) #ifdef MSDOS - printf("\tdel %s\n", rawfile); + printf("\tdel %s\n", fn); #else - printf("\trm %s\n", rawfile); + printf("\trm -f %s\n", fn); #endif - if (!noaction) - unlink(rawfile); + if (noaction) + return(0); + return(unlink(fn)); +} + + +#ifdef MSDOS +setenv(vname, value) /* set an environment variable */ +char *vname, *value; +{ + register char *evp; + + evp = bmalloc(strlen(vname)+strlen(value)+2); + if (evp == NULL) + syserr(progname); + sprintf(evp, "%s=%s", vname, value); + if (putenv(evp) != 0) { + fprintf(stderr, "%s: out of environment space\n", progname); + exit(1); } + if (!silent) + printf("set %s\n", evp); } +#endif badvalue(vc) /* report bad variable value and exit */
