--- ray/src/util/rad.c 1993/10/28 11:48:29 2.28 +++ ray/src/util/rad.c 1993/11/11 10:20:06 2.30 @@ -21,7 +21,8 @@ typedef struct { int (*fixval)(); /* assignment checking function */ } VARIABLE; -int onevalue(), catvalues(); +int onevalue(), catvalues(), boolvalue(), + qualvalue(), fltvalue(), intvalue(); /* variables */ #define OBJECT 0 /* object files */ @@ -61,24 +62,23 @@ VARIABLE vv[NVARS] = { /* variable-value pairs */ {"pfilt", 2, 0, NULL, catvalues}, {"view", 2, 0, NULL, NULL}, {"ZONE", 2, 0, NULL, onevalue}, - {"QUALITY", 3, 0, NULL, onevalue}, + {"QUALITY", 3, 0, NULL, qualvalue}, {"OCTREE", 3, 0, NULL, onevalue}, {"PICTURE", 3, 0, NULL, onevalue}, {"AMBFILE", 3, 0, NULL, onevalue}, {"OPTFILE", 3, 0, NULL, onevalue}, - {"EXPOSURE", 3, 0, NULL, onevalue}, + {"EXPOSURE", 3, 0, NULL, fltvalue}, {"RESOLUTION", 3, 0, NULL, onevalue}, {"UP", 2, 0, NULL, onevalue}, - {"INDIRECT", 3, 0, NULL, onevalue}, - {"DETAIL", 3, 0, NULL, onevalue}, - {"PENUMBRAS", 3, 0, NULL, onevalue}, - {"VARIABILITY", 3, 0, NULL, onevalue}, + {"INDIRECT", 3, 0, NULL, intvalue}, + {"DETAIL", 3, 0, NULL, qualvalue}, + {"PENUMBRAS", 3, 0, NULL, boolvalue}, + {"VARIABILITY", 3, 0, NULL, qualvalue}, {"REPORT", 3, 0, NULL, onevalue}, }; VARIABLE *matchvar(); char *nvalue(); -int vscale(); #define UPPER(c) ((c)&~0x20) /* ASCII trick */ @@ -87,17 +87,13 @@ int vscale(); #define vval(vc) (vv[vc].value) #define vint(vc) atoi(vval(vc)) #define vlet(vc) UPPER(vval(vc)[0]) +#define vscale vlet #define vbool(vc) (vlet(vc)=='T') -#define HIGH 2 -#define MEDIUM 1 -#define LOW 0 +#define HIGH 'H' +#define MEDIUM 'M' +#define LOW 'L' -int lowqopts(), medqopts(), hiqopts(); -int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; - -#define renderopts (*setqopts[vscale(QUALITY)]) - /* overture calculation file */ #ifdef NIX char overfile[] = "overture.raw"; @@ -348,22 +344,6 @@ register int n; } -int -vscale(vc) /* return scale for variable vc */ -int vc; -{ - switch(vlet(vc)) { - case 'H': - return(HIGH); - case 'M': - return(MEDIUM); - case 'L': - return(LOW); - } - badvalue(vc); -} - - checkvalues() /* check assignments */ { register int i; @@ -402,6 +382,84 @@ register VARIABLE *vp; } +int +badmatch(tv, cv) /* case insensitive truncated comparison */ +register char *tv, *cv; +{ + if (!*tv) return(1); /* null string cannot match */ + do + if (UPPER(*tv) != *cv++) + return(1); + while (*++tv); + return(0); /* OK */ +} + + +boolvalue(vp) /* check boolean for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + switch (UPPER(vp->value[0])) { + case 'T': + if (badmatch(vp->value, "TRUE")) break; + return; + case 'F': + if (badmatch(vp->value, "FALSE")) break; + return; + } + fprintf(stderr, "%s: illegal value for boolean variable '%s'\n", + progname, vp->name); + exit(1); +} + + +qualvalue(vp) /* check qualitative var. for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + switch (UPPER(vp->value[0])) { + case 'L': + if (badmatch(vp->value, "LOW")) break; + return; + case 'M': + if (badmatch(vp->value, "MEDIUM")) break; + return; + case 'H': + if (badmatch(vp->value, "HIGH")) break; + return; + } + fprintf(stderr, "%s: illegal value for qualitative variable '%s'\n", + progname, vp->name); + exit(1); +} + + +intvalue(vp) /* check integer variable for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + if (isint(vp->value)) return; + fprintf(stderr, "%s: illegal value for integer variable '%s'\n", + progname, vp->name); + exit(1); +} + + +fltvalue(vp) /* check float variable for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + if (isflt(vp->value)) return; + fprintf(stderr, "%s: illegal value for real variable '%s'\n", + progname, vp->name); + exit(1); +} + + unsigned long checklast(fnames) /* check files and find most recent */ register char *fnames; @@ -723,8 +781,6 @@ double ambval() /* compute ambient value */ { if (vdef(EXPOSURE)) { - if (!isflt(vval(EXPOSURE))) - badvalue(EXPOSURE); if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') return(.5/pow(2.,atof(vval(EXPOSURE)))); return(.5/atof(vval(EXPOSURE))); @@ -737,6 +793,23 @@ ambval() /* compute ambient value */ } +renderopts(op) /* set rendering options */ +char *op; +{ + switch(vscale(QUALITY)) { + case LOW: + lowqopts(op); + break; + case MEDIUM: + medqopts(op); + break; + case HIGH: + lowqopts(op); + break; + } +} + + lowqopts(op) /* low quality rendering options */ register char *op; { @@ -1223,6 +1296,8 @@ char *opts; sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname); if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); + if (vdef(EXPOSURE)) + sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE)); strcat(combuf, oct1name); if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error running rview\n", progname); @@ -1303,7 +1378,7 @@ char *opts; } sprintf(combuf, "rpict%s %s %s%s %s > %s", rep, vw, res, opts, - oct1name, rawfile); + oct1name, rawfile); } if (runcom(combuf)) { /* run rpict */ fprintf(stderr, "%s: error rendering view %s\n",
