--- ray/src/util/rad.c 2013/12/04 20:07:07 2.110 +++ ray/src/util/rad.c 2020/04/07 00:49:09 2.127 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rad.c,v 2.110 2013/12/04 20:07:07 greg Exp $"; +static const char RCSid[] = "$Id: rad.c,v 2.127 2020/04/07 00:49:09 greg Exp $"; #endif /* * Executive program for oconv, rpict and pfilt @@ -9,6 +9,7 @@ static const char RCSid[] = "$Id: rad.c,v 2.110 2013/1 #include #include +#include #include "platform.h" #include "rtprocess.h" @@ -16,7 +17,7 @@ static const char RCSid[] = "$Id: rad.c,v 2.110 2013/1 #include "paths.h" #include "vars.h" -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) #define DELCMD "del" #define RENAMECMD "rename" #else @@ -24,6 +25,7 @@ static const char RCSid[] = "$Id: rad.c,v 2.110 2013/1 #define RENAMECMD "mv" #include #include + #include #endif /* variables (alphabetical by name) */ @@ -35,28 +37,31 @@ static const char RCSid[] = "$Id: rad.c,v 2.110 2013/1 #define INDIRECT 5 /* indirection in lighting */ #define MATERIAL 6 /* material files */ #define MKILLUM 7 /* mkillum options */ -#define OBJECT 8 /* object files */ -#define OCONV 9 /* oconv options */ -#define OCTREE 10 /* octree file name */ -#define OPTFILE 11 /* rendering options file */ -#define PENUMBRAS 12 /* shadow penumbras are desired */ -#define PFILT 13 /* pfilt options */ -#define PICTURE 14 /* picture file root name */ -#define QUALITY 15 /* desired rendering quality */ -#define RAWFILE 16 /* raw picture file root name */ -#define RENDER 17 /* rendering options */ -#define REPORT 18 /* report frequency and errfile */ -#define RESOLUTION 19 /* maximum picture resolution */ -#define RPICT 20 /* rpict parameters */ -#define RVU 21 /* rvu parameters */ -#define SCENE 22 /* scene files */ -#define UP 23 /* view up (X, Y or Z) */ -#define VARIABILITY 24 /* level of light variability */ -#define VIEWS 25 /* view(s) for picture(s) */ -#define ZFILE 26 /* distance file root name */ -#define ZONE 27 /* simulation zone */ +#define MKPMAP 8 /* mkpmap options */ +#define OBJECT 9 /* object files */ +#define OCONV 10 /* oconv options */ +#define OCTREE 11 /* octree file name */ +#define OPTFILE 12 /* rendering options file */ +#define PCMAP 13 /* caustic photon map */ +#define PENUMBRAS 14 /* shadow penumbras are desired */ +#define PFILT 15 /* pfilt options */ +#define PGMAP 16 /* global photon map */ +#define PICTURE 17 /* picture file root name */ +#define QUALITY 18 /* desired rendering quality */ +#define RAWFILE 19 /* raw picture file root name */ +#define RENDER 20 /* rendering options */ +#define REPORT 21 /* report frequency and errfile */ +#define RESOLUTION 22 /* maximum picture resolution */ +#define RPICT 23 /* rpict parameters */ +#define RVU 24 /* rvu parameters */ +#define SCENE 25 /* scene files */ +#define UP 26 /* view up (X, Y or Z) */ +#define VARIABILITY 27 /* level of light variability */ +#define VIEWS 28 /* view(s) for picture(s) */ +#define ZFILE 29 /* distance file root name */ +#define ZONE 30 /* simulation zone */ /* total number of variables */ -int NVARS = 28; +int NVARS = 31; VARIABLE vv[] = { /* variable-value pairs */ {"AMBFILE", 3, 0, NULL, onevalue}, @@ -67,12 +72,15 @@ VARIABLE vv[] = { /* variable-value pairs */ {"INDIRECT", 3, 0, NULL, intvalue}, {"materials", 3, 0, NULL, catvalues}, {"mkillum", 3, 0, NULL, catvalues}, + {"mkpmap", 3, 0, NULL, catvalues}, {"objects", 3, 0, NULL, catvalues}, {"oconv", 3, 0, NULL, catvalues}, {"OCTREE", 3, 0, NULL, onevalue}, {"OPTFILE", 3, 0, NULL, onevalue}, + {"PCMAP", 2, 0, NULL, onevalue}, {"PENUMBRAS", 3, 0, NULL, boolvalue}, {"pfilt", 2, 0, NULL, catvalues}, + {"PGMAP", 2, 0, NULL, onevalue}, {"PICTURE", 3, 0, NULL, onevalue}, {"QUALITY", 3, 0, NULL, qualvalue}, {"RAWFILE", 3, 0, NULL, onevalue}, @@ -107,6 +115,11 @@ time_t oct0date; /* date of pre-mkillum octree */ char *oct1name; /* name of post-mkillum octree */ time_t oct1date; /* date of post-mkillum octree (>= matdate) */ +char *pgmapname; /* name of global photon map */ +time_t pgmapdate; /* date of global photon map (>= oct1date) */ +char *pcmapname; /* name of caustic photon map */ +time_t pcmapdate; /* date of caustic photon map (>= oct1date) */ + int nowarn = 0; /* no warnings */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ @@ -121,6 +134,7 @@ char *viewselect = NULL; /* specific view only */ /* command paths */ char c_oconv[256] = "oconv"; char c_mkillum[256] = "mkillum"; +char c_mkpmap[256] = "mkpmap"; char c_rvu[256] = "rvu"; char c_rpict[256] = DEF_RPICT_PATH; char c_rpiece[] = "rpiece"; @@ -144,9 +158,11 @@ static void checkfiles(void); static void getoctcube(double org[3], double *sizp); static void setdefaults(void); static void oconv(void); +static void mkpmap(void); static char * addarg(char *op, char *arg); static void oconvopts(char *oo); static void mkillumopts(char *mo); +static void mkpmapopts(char *mo); static void checkambfile(void); static double ambval(void); static void renderopts(char *op, char *po); @@ -243,6 +259,8 @@ main( printvars(stdout); /* build octree (and run mkillum) */ oconv(); + /* run mkpmap if indicated */ + mkpmap(); /* check date on ambient file */ checkambfile(); /* run simulation */ @@ -335,6 +353,7 @@ newfname( /* create modified file name */ static void checkfiles(void) /* check for existence and modified times */ { + char fntemp[256]; time_t objdate; if (!vdef(OCTREE)) { @@ -364,6 +383,26 @@ checkfiles(void) /* check for existence and modified vnam(OCTREE), vnam(SCENE), vnam(ILLUM)); quit(1); } + if (vdef(PGMAP)) { + if (!*sskip2(vval(PGMAP),1)) { + fprintf(stderr, "%s: '%s' missing # photons argument\n", + progname, vnam(PGMAP)); + quit(1); + } + atos(fntemp, sizeof(fntemp), vval(PGMAP)); + pgmapname = savqstr(fntemp); + pgmapdate = fdate(pgmapname); + } + if (vdef(PCMAP)) { + if (!*sskip2(vval(PCMAP),1)) { + fprintf(stderr, "%s: '%s' missing # photons argument\n", + progname, vnam(PCMAP)); + quit(1); + } + atos(fntemp, sizeof(fntemp), vval(PCMAP)); + pcmapname = savqstr(fntemp); + pcmapdate = fdate(pcmapname); + } matdate = checklast(vval(MATERIAL)); } @@ -517,9 +556,10 @@ oconv(void) /* run oconv and mkillum if necessary * return; /* make octree0 */ if ((oct0date < scenedate) | (oct0date < illumdate)) { - if (touchonly && oct0date) - touch(oct0name); - else { /* build command */ + if (touchonly && (oct0date || oct1date)) { + if (oct0date) + touch(oct0name); + } else { /* build command */ if (octreedate) sprintf(combuf, "%s%s -i %s %s > %s", c_oconv, ocopts, vval(OCTREE), @@ -544,7 +584,7 @@ oconv(void) /* run oconv and mkillum if necessary * oct0date = octreedate; if (oct0date < illumdate) /* ditto */ oct0date = illumdate; - } + } if (touchonly && oct1date) touch(oct1name); else { @@ -585,6 +625,73 @@ oconv(void) /* run oconv and mkillum if necessary * } +static void +mkpmap(void) /* run mkpmap if indicated */ +{ + char combuf[2048], *cp; + time_t tnow; + /* nothing to do? */ + if ((pgmapname == NULL) | (pgmapdate >= oct1date) && + (pcmapname == NULL) | (pcmapdate >= oct1date)) + return; + /* just update existing file dates? */ + if (touchonly && (pgmapname == NULL) | (pgmapdate > 0) && + (pcmapname == NULL) | (pcmapdate > 0)) { + if (pgmapname != NULL) + touch(pgmapname); + if (pcmapname != NULL) + touch(pcmapname); + } else { /* else need to (re)run pkpmap */ + strcpy(combuf, c_mkpmap); + for (cp = combuf; *cp; cp++) + ; + mkpmapopts(cp); + /* force file overwrite */ + cp = addarg(cp, "-fo+"); + if (vdef(REPORT)) { + char errfile[256]; + int n; + double minutes; + n = sscanf(vval(REPORT), "%lf %s", &minutes, errfile); + if (n == 2) + sprintf(cp, " -t %d -e %s", (int)(minutes*60), errfile); + else if (n == 1) + sprintf(cp, " -t %d", (int)(minutes*60)); + else + badvalue(REPORT); + } + if (pgmapname != NULL && pgmapdate < oct1date) { + cp = addarg(cp, "-apg"); + addarg(cp, vval(PGMAP)); + cp = sskip(sskip(cp)); /* remove any bandwidth */ + *cp = '\0'; + } + if (pcmapname != NULL && pcmapdate < oct1date) { + cp = addarg(cp, "-apc"); + addarg(cp, vval(PCMAP)); + cp = sskip(sskip(cp)); /* remove any bandwidth */ + *cp = '\0'; + } + cp = addarg(cp, oct1name); + if (runcom(combuf)) { + fprintf(stderr, "%s: error running %s\n", + progname, c_mkpmap); + if (pgmapname != NULL && pgmapdate < oct1date) + unlink(pgmapname); + if (pcmapname != NULL && pcmapdate < oct1date) + unlink(pcmapname); + quit(1); + } + } + tnow = time((time_t *)NULL); + if (pgmapname != NULL) + pgmapdate = tnow; + if (pcmapname != NULL) + pcmapdate = tnow; + oct1date = tnow; /* trigger ambient file removal if needed */ +} + + static char * addarg( /* append argument and advance pointer */ char *op, @@ -608,12 +715,13 @@ oconvopts( /* get oconv options */ /* BEWARE: This may be called via setdefaults(), so no assumptions */ *oo = '\0'; - if (vdef(OCONV)) - if (vval(OCONV)[0] != '-') { - atos(c_oconv, sizeof(c_oconv), vval(OCONV)); - oo = addarg(oo, sskip2(vval(OCONV), 1)); - } else - oo = addarg(oo, vval(OCONV)); + if (!vdef(OCONV)) + return; + if (vval(OCONV)[0] != '-') { + atos(c_oconv, sizeof(c_oconv), vval(OCONV)); + oo = addarg(oo, sskip2(vval(OCONV), 1)); + } else + oo = addarg(oo, vval(OCONV)); } @@ -628,16 +736,38 @@ mkillumopts( /* get mkillum options */ sprintf(mo, " -n %d", nprocs); else *mo = '\0'; - if (vdef(MKILLUM)) - if (vval(MKILLUM)[0] != '-') { - atos(c_mkillum, sizeof(c_mkillum), vval(MKILLUM)); - mo = addarg(mo, sskip2(vval(MKILLUM), 1)); - } else - mo = addarg(mo, vval(MKILLUM)); + if (!vdef(MKILLUM)) + return; + if (vval(MKILLUM)[0] != '-') { + atos(c_mkillum, sizeof(c_mkillum), vval(MKILLUM)); + mo = addarg(mo, sskip2(vval(MKILLUM), 1)); + } else + mo = addarg(mo, vval(MKILLUM)); } static void +mkpmapopts( /* get mkpmap options */ + char *mo +) +{ + /* BEWARE: This may be called via setdefaults(), so no assumptions */ + + if (nprocs > 1) + sprintf(mo, " -n %d", nprocs); + else + *mo = '\0'; + if (!vdef(MKPMAP)) + return; + if (vval(MKPMAP)[0] != '-') { + atos(c_mkpmap, sizeof(c_mkpmap), vval(MKPMAP)); + mo = addarg(mo, sskip2(vval(MKPMAP), 1)); + } else + mo = addarg(mo, vval(MKPMAP)); +} + + +static void checkambfile(void) /* check date on ambient file */ { time_t afdate; @@ -678,6 +808,15 @@ renderopts( /* set rendering options */ char *po ) { + char pmapf[256], *bw; + + if (vdef(PGMAP)) { + *op = '\0'; + bw = sskip2(vval(PGMAP), 2); + atos(pmapf, sizeof(pmapf), vval(PGMAP)); + op = addarg(addarg(op, "-ap"), pmapf); + if (atoi(bw) > 0) op = addarg(op, bw); + } switch(vscale(QUALITY)) { case LOW: lowqopts(op, po); @@ -689,22 +828,34 @@ renderopts( /* set rendering options */ hiqopts(op, po); break; } - if (vdef(RENDER)) + if (vdef(PCMAP)) { + bw = sskip2(vval(PCMAP), 2); + atos(pmapf, sizeof(pmapf), vval(PCMAP)); + op = addarg(addarg(op, "-ap"), pmapf); + if (atoi(bw) > 0) op = addarg(op, bw); + } + if (vdef(RENDER)) { op = addarg(op, vval(RENDER)); + bw = strstr(vval(RENDER), "-aa "); + if (bw != NULL && atof(bw+4) <= FTINY) + overture = 0; + } if (rvdevice != NULL) { - if (vdef(RVU)) + if (vdef(RVU)) { if (vval(RVU)[0] != '-') { atos(c_rvu, sizeof(c_rvu), vval(RVU)); po = addarg(po, sskip2(vval(RVU), 1)); } else po = addarg(po, vval(RVU)); + } } else { - if (vdef(RPICT)) + if (vdef(RPICT)) { if (vval(RPICT)[0] != '-') { atos(c_rpict, sizeof(c_rpict), vval(RPICT)); po = addarg(po, sskip2(vval(RPICT), 1)); } else po = addarg(po, vval(RPICT)); + } } } @@ -931,7 +1082,7 @@ hiqopts( /* high quality rendering options */ } -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) static void setenv( /* set an environment variable */ char *vname, @@ -978,7 +1129,7 @@ xferopts( /* transfer options if indicated */ syserr(vval(OPTFILE)); sprintf(ro, " @%s", vval(OPTFILE)); } -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) else if (n > 50) { setenv("ROPT", ro+1); strcpy(ro, " $ROPT"); @@ -1005,12 +1156,13 @@ pfiltopts( /* get pfilt options */ po = addarg(po, "-m .25"); break; } - if (vdef(PFILT)) + if (vdef(PFILT)) { if (vval(PFILT)[0] != '-') { atos(c_pfilt, sizeof(c_pfilt), vval(PFILT)); po = addarg(po, sskip2(vval(PFILT), 1)); } else po = addarg(po, vval(PFILT)); + } } @@ -1155,7 +1307,7 @@ specview( /* get proper view spec from vs */ if (cp == viewopts) /* append any additional options */ vs++; /* skip prefixed space if unneeded */ strcpy(cp, vs); -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) if (strlen(viewopts) > 40) { setenv("VIEW", viewopts); return("$VIEW"); @@ -1201,7 +1353,7 @@ getview( /* get view n, or NULL if none */ } numview: mv = nvalue(VIEWS, n); /* use view n */ - if ((vn != NULL) & (mv != NULL)) + if ((vn != NULL) & (mv != NULL)) { if (*mv != '-') { char *mv2 = mv; while (*mv2 && !isspace(*mv2)) @@ -1209,7 +1361,7 @@ numview: *vn = '\0'; } else sprintf(vn, "%d", n+1); - + } return(specview(mv)); } @@ -1223,14 +1375,14 @@ myprintview( /* print out selected view */ VIEW vwr; char buf[128]; char *cp; -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) /* XXX Should we allow something like this for all platforms? */ /* XXX Or is it still required at all? */ again: #endif if (vopts == NULL) return(-1); -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) if (vopts[0] == '$') { vopts = getenv(vopts+1); goto again; @@ -1377,6 +1529,7 @@ rpict( /* run rpict and pfilt for each view */ fprintf(stderr, "%s: cannot create\n", pfile); quit(1); } + pfile[-5] = '\0'; pfile = NULL; } }
