--- ray/src/util/rad.c 1993/06/25 17:35:49 2.12 +++ ray/src/util/rad.c 1993/08/13 09:19:30 2.18 @@ -626,7 +626,7 @@ register char *op; op = addarg(op, "-ds .4"); else op = addarg(op, "-ds 0"); - op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .7"); + op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5"); if (vdef(AMBFILE)) { sprintf(op, " -af %s", vval(AMBFILE)); op += strlen(op); @@ -634,13 +634,13 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .4 -ad 32"); + op = addarg(op, "-aa .4 -ad 64"); break; case MEDIUM: - op = addarg(op, "-aa .3 -ad 64"); + op = addarg(op, "-aa .3 -ad 128"); break; case HIGH: - op = addarg(op, "-aa .25 -ad 128"); + op = addarg(op, "-aa .25 -ad 256"); break; } op = addarg(op, "-as 0"); @@ -690,7 +690,7 @@ register char *op; op = addarg(op, "-ds .2 -dj .35"); else op = addarg(op, "-ds .3"); - op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .15"); + op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1"); if (overture = vint(INDIRECT)) { sprintf(op, " -ab %d", overture); op += strlen(op); @@ -702,13 +702,13 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .25 -ad 128 -as 0"); + op = addarg(op, "-aa .25 -ad 196 -as 0"); break; case MEDIUM: - op = addarg(op, "-aa .2 -ad 300 -as 64"); + op = addarg(op, "-aa .2 -ad 400 -as 64"); break; case HIGH: - op = addarg(op, "-aa .15 -ad 500 -as 128"); + op = addarg(op, "-aa .15 -ad 768 -as 196"); break; } d = ambval(); @@ -757,7 +757,7 @@ register char *op; op = addarg(op, "-ds .1 -dj .7"); else op = addarg(op, "-ds .2"); - op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .03"); + op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01"); sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); op += strlen(op); if (vdef(AMBFILE)) { @@ -767,13 +767,13 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .15 -ad 200 -as 0"); + op = addarg(op, "-aa .15 -ad 256 -as 0"); break; case MEDIUM: - op = addarg(op, "-aa .125 -ad 512 -as 128"); + op = addarg(op, "-aa .125 -ad 512 -as 256"); break; case HIGH: - op = addarg(op, "-aa .08 -ad 850 -as 256"); + op = addarg(op, "-aa .08 -ad 1024 -as 512"); break; } d = ambval(); @@ -804,7 +804,7 @@ char *ro; fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666); if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0) syserr(vval(OPTFILE)); - sprintf(ro, " \"^%s\"", vval(OPTFILE)); + sprintf(ro, " @%s", vval(OPTFILE)); } #ifdef MSDOS else if (n > 50) { @@ -828,7 +828,7 @@ register char *po; po = addarg(po, "-r 1"); break; case HIGH: - po = addarg(po, "-m .15"); + po = addarg(po, "-m .25"); break; } if (vdef(PFILT)) @@ -971,6 +971,7 @@ int n; char *vn; /* returned view name */ { register char *mv = NULL; + register int i; if (viewselect != NULL) { /* command-line selected */ if (n) /* only do one */ @@ -993,9 +994,9 @@ char *vn; /* returned view name */ } mv = nvalue(vv+VIEW, n); /* use view n */ if (vn != NULL & mv != NULL) { - if (*mv != '-') - while (*mv && !isspace(*mv)) - *vn++ = *mv++; + if (mv[i=0] != '-') + while (mv[i] && !isspace(mv[i])) + *vn++ = mv[i++]; *vn = '\0'; } return(specview(mv)); @@ -1026,6 +1027,7 @@ char *opts; char pfopts[128]; char vs[32], *vw; int vn, mult; + long lastdate; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ @@ -1056,6 +1058,8 @@ char *opts; else badvalue(REPORT); } + /* get update time */ + lastdate = octreedate > matdate ? octreedate : matdate; /* do each view */ vn = 0; while ((vw = getview(vn++, vs)) != NULL) { @@ -1063,7 +1067,7 @@ char *opts; sprintf(vs, "%d", vn); sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); /* check date on picture */ - if (fdate(picfile) >= octreedate) + if (fdate(picfile) >= lastdate) continue; /* build rpict command */ sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
