--- ray/src/util/rad.c 2013/08/12 21:01:00 2.108 +++ ray/src/util/rad.c 2014/10/26 17:35:53 2.111 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rad.c,v 2.108 2013/08/12 21:01:00 greg Exp $"; +static const char RCSid[] = "$Id: rad.c,v 2.111 2014/10/26 17:35:53 greg Exp $"; #endif /* * Executive program for oconv, rpict and pfilt @@ -24,6 +24,7 @@ static const char RCSid[] = "$Id: rad.c,v 2.108 2013/0 #define RENAMECMD "mv" #include #include + #include #endif /* variables (alphabetical by name) */ @@ -264,8 +265,8 @@ userr: static void rootname( /* remove tail from end of fn */ - register char *rn, - register char *fn + char *rn, + char *fn ) { char *tp, *dp; @@ -282,7 +283,7 @@ rootname( /* remove tail from end of fn */ static time_t checklast( /* check files and find most recent */ - register char *fnames + char *fnames ) { char thisfile[PATH_MAX]; @@ -312,8 +313,8 @@ newfname( /* create modified file name */ int pred ) { - register char *cp; - register int n; + char *cp; + int n; int suffix; n = 0; cp = orig; suffix = -1; /* suffix position, length */ @@ -378,7 +379,7 @@ getoctcube( /* get octree bounding cube */ double min[3], max[3]; char buf[1024]; FILE *fp; - register int i; + int i; if (osiz <= FTINY) { if (!nprocs && fdate(oct1name) < @@ -587,8 +588,8 @@ oconv(void) /* run oconv and mkillum if necessary * static char * addarg( /* append argument and advance pointer */ -register char *op, -register char *arg +char *op, +char *arg ) { while (*op) @@ -602,7 +603,7 @@ register char *arg static void oconvopts( /* get oconv options */ - register char *oo + char *oo ) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ @@ -711,7 +712,7 @@ renderopts( /* set rendering options */ static void lowqopts( /* low quality rendering options */ - register char *op, + char *op, char *po ) { @@ -779,7 +780,7 @@ lowqopts( /* low quality rendering options */ static void medqopts( /* medium quality rendering options */ - register char *op, + char *op, char *po ) { @@ -857,7 +858,7 @@ medqopts( /* medium quality rendering options */ static void hiqopts( /* high quality rendering options */ - register char *op, + char *op, char *po ) { @@ -931,13 +932,36 @@ hiqopts( /* high quality rendering options */ } +#ifdef _WIN32 static void +setenv( /* set an environment variable */ + char *vname, + char *value +) +{ + char *evp; + + evp = bmalloc(strlen(vname)+strlen(value)+2); + if (evp == NULL) + syserr(progname); + sprintf(evp, "%s=%s", vname, value); + if (putenv(evp) != 0) { + fprintf(stderr, "%s: out of environment space\n", progname); + quit(1); + } + if (!silent) + printf("set %s\n", evp); +} +#endif + + +static void xferopts( /* transfer options if indicated */ char *ro ) { int fd, n; - register char *cp; + char *cp; n = strlen(ro); if (n < 2) @@ -966,7 +990,7 @@ xferopts( /* transfer options if indicated */ static void pfiltopts( /* get pfilt options */ - register char *po + char *po ) { *po = '\0'; @@ -993,8 +1017,8 @@ pfiltopts( /* get pfilt options */ static int matchword( /* match white-delimited words */ - register char *s1, - register char *s2 + char *s1, + char *s2 ) { while (isspace(*s1)) s1++; @@ -1008,15 +1032,15 @@ matchword( /* match white-delimited words */ static char * specview( /* get proper view spec from vs */ - register char *vs + char *vs ) { static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0", "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"}; static char viewopts[128]; - register char *cp; + char *cp; int xpos, ypos, zpos, viewtype, upax; - register int i; + int i; double cent[3], dim[3], mult, d; if (vs == NULL || *vs == '-') @@ -1076,7 +1100,7 @@ specview( /* get proper view spec from vs */ cent[i] += .5*dim[i]; } mult = vlet(ZONE)=='E' ? 2. : .45 ; - sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g", + sprintf(cp, " -vp %.3g %.3g %.3g -vd %.3g %.3g %.3g", cent[0]+xpos*mult*dim[0], cent[1]+ypos*mult*dim[1], cent[2]+zpos*mult*dim[2], @@ -1108,7 +1132,7 @@ specview( /* get proper view spec from vs */ break; case VT_PAR: d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]); - sprintf(cp, " -vh %.2g -vv %.2g", d, d); + sprintf(cp, " -vh %.3g -vv %.3g", d, d); cp += strlen(cp); break; case VT_ANG: @@ -1148,7 +1172,7 @@ getview( /* get view n, or NULL if none */ char *vn /* returned view name */ ) { - register char *mv; + char *mv; if (viewselect != NULL) { /* command-line selected */ if (n) /* only do one */ @@ -1180,7 +1204,7 @@ numview: mv = nvalue(VIEWS, n); /* use view n */ if ((vn != NULL) & (mv != NULL)) if (*mv != '-') { - register char *mv2 = mv; + char *mv2 = mv; while (*mv2 && !isspace(*mv2)) *vn++ = *mv2++; *vn = '\0'; @@ -1193,13 +1217,13 @@ numview: static int myprintview( /* print out selected view */ - register char *vopts, + char *vopts, FILE *fp ) { VIEW vwr; char buf[128]; - register char *cp; + char *cp; #ifdef _WIN32 /* XXX Should we allow something like this for all platforms? */ /* XXX Or is it still required at all? */ @@ -1679,25 +1703,6 @@ finish_process(void) /* exit a child process */ return; /* in parent -- noop */ exit(0); } - -#ifdef _WIN32 -setenv(vname, value) /* set an environment variable */ -char *vname, *value; -{ - register char *evp; - - evp = bmalloc(strlen(vname)+strlen(value)+2); - if (evp == NULL) - syserr(progname); - sprintf(evp, "%s=%s", vname, value); - if (putenv(evp) != 0) { - fprintf(stderr, "%s: out of environment space\n", progname); - quit(1); - } - if (!silent) - printf("set %s\n", evp); -} -#endif static void
