--- ray/src/util/rad.c 2010/10/10 15:36:18 2.103 +++ ray/src/util/rad.c 2011/08/26 22:39:56 2.107 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rad.c,v 2.103 2010/10/10 15:36:18 greg Exp $"; +static const char RCSid[] = "$Id: rad.c,v 2.107 2011/08/26 22:39:56 greg Exp $"; #endif /* * Executive program for oconv, rpict and pfilt @@ -772,7 +772,7 @@ lowqopts( /* low quality rendering options */ d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 6 -lw .01"); + op = addarg(op, "-lr 6 -lw .003"); } @@ -850,7 +850,7 @@ medqopts( /* medium quality rendering options */ d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 8 -lw .002"); + op = addarg(op, "-lr 8 -lw 1e-4"); } @@ -926,7 +926,7 @@ hiqopts( /* high quality rendering options */ d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 12 -lw .0005"); + op = addarg(op, "-lr 12 -lw 1e-5"); } @@ -1254,6 +1254,32 @@ rvu( /* run rvu with first view */ } +static int +syncf_done( /* check if an rpiece sync file is complete */ + char *sfname +) +{ + FILE *fp = fopen(sfname, "r"); + int todo = 1; + int x, y; + + if (fp == NULL) + return(0); + if (fscanf(fp, "%d %d", &x, &y) != 2) + goto checked; + todo = x*y; /* total number of tiles */ + if (fscanf(fp, "%d %d", &x, &y) != 2 || (x != 0) | (y != 0)) + goto checked; + /* XXX assume no redundant tiles */ + while (fscanf(fp, "%d %d", &x, &y) == 2) + if (!--todo) + break; +checked: + fclose(fp); + return(!todo); +} + + static void rpict( /* run rpict and pfilt for each view */ char *opts, @@ -1270,6 +1296,9 @@ rpict( /* run rpict and pfilt for each view */ int vn, mult; FILE *fp; time_t rfdt, pfdt; + int xres, yres; + double aspect; + int n; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ @@ -1284,24 +1313,19 @@ rpict( /* run rpict and pfilt for each view */ mult = 3; break; } - { - int xres, yres; - double aspect; - int n; - n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect); - if (n == 3) - sprintf(res, "-x %d -y %d -pa %.3f", - mult*xres, mult*yres, aspect); - else if (n) { - if (n == 1) yres = xres; - sprintf(res, "-x %d -y %d", mult*xres, mult*yres); - } else - badvalue(RESOLUTION); - } + n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect); + if (n == 3) + sprintf(res, "-x %d -y %d -pa %.3f", + mult*xres, mult*yres, aspect); + else if (n) { + aspect = 1.; + if (n == 1) yres = xres; + sprintf(res, "-x %d -y %d", mult*xres, mult*yres); + } else + badvalue(RESOLUTION); rep[0] = '\0'; if (vdef(REPORT)) { double minutes; - int n; n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile); if (n == 2) sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile); @@ -1363,7 +1387,7 @@ rpict( /* run rpict and pfilt for each view */ int xdiv = 8+nprocs/3, ydiv = 8+nprocs/3; if (rfdt >= oct1date) { fprintf(stderr, - "%s: partial output not created with rpiece\n", rawfile); + "%s: partial output not created with %s\n", rawfile, c_rpiece); quit(1); } if (rfdt) { /* start fresh */ @@ -1452,11 +1476,21 @@ rpict( /* run rpict and pfilt for each view */ if (do_rpiece) { /* need to finish raw, first */ finish_process(); wait_process(1); - /* XXX should check sync file to see if really done? */ + if (!syncf_done(sfile)) { + fprintf(stderr, + "%s: %s did not complete rendering of view %s\n", + progname, c_rpiece, vs); + quit(1); + } } if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) { /* build pfilt command */ - if (mult > 1) + if (do_rpiece) + sprintf(combuf, + "%s%s -x %d -y %d -p %.3f %s > %s", + c_pfilt, pfopts, xres, yres, aspect, + rawfile, picfile); + else if (mult > 1) sprintf(combuf, "%s%s -x /%d -y /%d %s > %s", c_pfilt, pfopts, mult, mult, rawfile, picfile);
