--- ray/src/util/rad.c 1993/03/11 09:11:00 2.1 +++ ray/src/util/rad.c 1993/11/18 13:28:30 2.34 @@ -21,91 +21,109 @@ typedef struct { int (*fixval)(); /* assignment checking function */ } VARIABLE; -int onevalue(), catvalues(); +int onevalue(), catvalues(), boolvalue(), + qualvalue(), fltvalue(), intvalue(); /* variables */ #define OBJECT 0 /* object files */ #define SCENE 1 /* scene files */ #define MATERIAL 2 /* material files */ -#define RENDER 3 /* rendering options */ -#define OCONV 4 /* oconv options */ -#define PFILT 5 /* pfilt options */ -#define VIEW 6 /* view(s) for picture(s) */ -#define ZONE 7 /* simulation zone */ -#define QUALITY 8 /* desired rendering quality */ -#define OCTREE 9 /* octree file name */ -#define PICTURE 10 /* picture file name */ -#define AMBFILE 11 /* ambient file name */ -#define OPTFILE 12 /* rendering options file */ -#define EXPOSURE 13 /* picture exposure setting */ -#define RESOLUTION 14 /* maximum picture resolution */ -#define UP 15 /* view up (X, Y or Z) */ -#define INDIRECT 16 /* indirection in lighting */ -#define DETAIL 17 /* level of scene detail */ -#define PENUMBRAS 18 /* shadow penumbras are desired */ -#define VARIABILITY 19 /* level of light variability */ -#define REPORT 20 /* report frequency and errfile */ +#define ILLUM 3 /* mkillum input files */ +#define MKILLUM 4 /* mkillum options */ +#define RENDER 5 /* rendering options */ +#define OCONV 6 /* oconv options */ +#define PFILT 7 /* pfilt options */ +#define VIEW 8 /* view(s) for picture(s) */ +#define ZONE 9 /* simulation zone */ +#define QUALITY 10 /* desired rendering quality */ +#define OCTREE 11 /* octree file name */ +#define PICTURE 12 /* picture file name */ +#define AMBFILE 13 /* ambient file name */ +#define OPTFILE 14 /* rendering options file */ +#define EXPOSURE 15 /* picture exposure setting */ +#define RESOLUTION 16 /* maximum picture resolution */ +#define UP 17 /* view up (X, Y or Z) */ +#define INDIRECT 18 /* indirection in lighting */ +#define DETAIL 19 /* level of scene detail */ +#define PENUMBRAS 20 /* shadow penumbras are desired */ +#define VARIABILITY 21 /* level of light variability */ +#define REPORT 22 /* report frequency and errfile */ /* total number of variables */ -#define NVARS 21 +#define NVARS 23 VARIABLE vv[NVARS] = { /* variable-value pairs */ {"objects", 3, 0, NULL, catvalues}, {"scene", 3, 0, NULL, catvalues}, {"materials", 3, 0, NULL, catvalues}, + {"illum", 3, 0, NULL, catvalues}, + {"mkillum", 3, 0, NULL, catvalues}, {"render", 3, 0, NULL, catvalues}, {"oconv", 3, 0, NULL, catvalues}, {"pfilt", 2, 0, NULL, catvalues}, {"view", 2, 0, NULL, NULL}, {"ZONE", 2, 0, NULL, onevalue}, - {"QUALITY", 3, 0, NULL, onevalue}, + {"QUALITY", 3, 0, NULL, qualvalue}, {"OCTREE", 3, 0, NULL, onevalue}, {"PICTURE", 3, 0, NULL, onevalue}, {"AMBFILE", 3, 0, NULL, onevalue}, {"OPTFILE", 3, 0, NULL, onevalue}, - {"EXPOSURE", 3, 0, NULL, onevalue}, + {"EXPOSURE", 3, 0, NULL, fltvalue}, {"RESOLUTION", 3, 0, NULL, onevalue}, {"UP", 2, 0, NULL, onevalue}, - {"INDIRECT", 3, 0, NULL, onevalue}, - {"DETAIL", 3, 0, NULL, onevalue}, - {"PENUMBRAS", 3, 0, NULL, onevalue}, - {"VARIABILITY", 3, 0, NULL, onevalue}, + {"INDIRECT", 3, 0, NULL, intvalue}, + {"DETAIL", 3, 0, NULL, qualvalue}, + {"PENUMBRAS", 3, 0, NULL, boolvalue}, + {"VARIABILITY", 3, 0, NULL, qualvalue}, {"REPORT", 3, 0, NULL, onevalue}, }; VARIABLE *matchvar(); char *nvalue(); -int vscale(); +#define UPPER(c) ((c)&~0x20) /* ASCII trick */ + #define vnam(vc) (vv[vc].name) #define vdef(vc) (vv[vc].nass) #define vval(vc) (vv[vc].value) #define vint(vc) atoi(vval(vc)) -#define vlet(vc) (vval(vc)[0]&~0x20) +#define vlet(vc) UPPER(vval(vc)[0]) +#define vscale vlet #define vbool(vc) (vlet(vc)=='T') -#define HIGH 2 -#define MEDIUM 1 -#define LOW 0 +#define HIGH 'H' +#define MEDIUM 'M' +#define LOW 'L' -int lowqopts(), medqopts(), hiqopts(); -int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; + /* overture calculation file */ +#ifdef NIX +char overfile[] = "overture.raw"; +#else +char overfile[] = "/dev/null"; +#endif -#define renderopts (*setqopts[vscale(QUALITY)]) +extern unsigned long fdate(), time(); -extern long fdate(); +unsigned long scenedate; /* date of latest scene or object file */ +unsigned long octreedate; /* date of octree */ +unsigned long matdate; /* date of latest material file */ +unsigned long illumdate; /* date of last illum file */ -long scenedate; /* date of latest scene or object file */ -long octreedate; /* date of octree */ +char *oct0name; /* name of pre-mkillum octree */ +unsigned long oct0date; /* date of pre-mkillum octree */ +char *oct1name; /* name of post-mkillum octree */ +unsigned long oct1date; /* date of post-mkillum octree (>= matdate) */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ int noaction = 0; /* don't do anything */ +int sayview = 0; /* print view out */ char *rvdevice = NULL; /* rview output device */ char *viewselect = NULL; /* specific view only */ int overture = 0; /* overture calculation needed */ char *progname; /* global argv[0] */ +char *rifname; /* global rad input file name */ char radname[MAXPATH]; /* root Radiance file name */ @@ -133,6 +151,9 @@ char *argv[]; case 'o': rvdevice = argv[++i]; break; + case 'V': + sayview++; + break; case 'v': viewselect = argv[++i]; break; @@ -141,10 +162,11 @@ char *argv[]; } if (i >= argc) goto userr; + rifname = argv[i]; /* assign Radiance root file name */ - rootname(radname, argv[i]); + rootname(radname, rifname); /* load variable values */ - load(argv[i]); + load(rifname); /* get any additional assignments */ for (i++; i < argc; i++) setvariable(argv[i]); @@ -157,8 +179,11 @@ char *argv[]; /* print all values if requested */ if (explicate) printvals(); - /* run simulation */ + /* build octree (and run mkillum) */ oconv(); + /* check date on ambient file */ + checkambfile(); + /* run simulation */ renderopts(ropts); xferopts(ropts); if (rvdevice != NULL) @@ -168,7 +193,7 @@ char *argv[]; exit(0); userr: fprintf(stderr, - "Usage: %s [-s][-n][-v view][-o dev] rfile [VAR=value ..]\n", + "Usage: %s [-s][-n][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); exit(1); } @@ -189,29 +214,31 @@ register char *rn, *fn; } +#define NOCHAR 127 /* constant for character to delete */ + + load(rfname) /* load Radiance simulation file */ char *rfname; { FILE *fp; - char buf[256]; + char buf[512]; register char *cp; if (rfname == NULL) fp = stdin; - else if ((fp = fopen(rfname, "r")) == NULL) { - perror(rfname); - exit(1); - } + else if ((fp = fopen(rfname, "r")) == NULL) + syserr(rfname); while (fgetline(buf, sizeof(buf), fp) != NULL) { for (cp = buf; *cp; cp++) { switch (*cp) { case '\\': - case '\n': - *cp = ' '; + *cp++ = NOCHAR; continue; case '#': *cp = '\0'; break; + default: + continue; } break; } @@ -225,10 +252,10 @@ setvariable(ass) /* assign variable according to stri register char *ass; { char varname[32]; + int n; register char *cp; register VARIABLE *vp; register int i; - int n; while (isspace(*ass)) /* skip leading space */ ass++; @@ -242,11 +269,9 @@ register char *ass; /* trim value */ while (isspace(*ass) || *ass == '=') ass++; - cp = ass + strlen(ass); - do - *cp-- = '\0'; - while (cp >= ass && isspace(*cp)); - n = cp - ass + 1; + for (n = strlen(ass); n > 0; n--) + if (!isspace(ass[n-1])) + break; if (!n) { fprintf(stderr, "%s: warning - missing value for variable '%s'\n", progname, varname); @@ -260,17 +285,29 @@ register char *ass; exit(1); } /* assign new value */ - cp = vp->value; i = vp->nass; - while (i--) - while (*cp++) - ; - i = cp - vp->value; - vp->value = realloc(vp->value, i+n+1); - if (vp->value == NULL) { - perror(progname); - exit(1); + if (i = vp->nass) { + cp = vp->value; + while (i--) + while (*cp++) + ; + i = cp - vp->value; + vp->value = realloc(vp->value, i+n+1); + } else + vp->value = malloc(n+1); + if (vp->value == NULL) + syserr(progname); + cp = vp->value+i; /* copy value, squeezing spaces */ + *cp = *ass; + for (i = 1; i <= n; i++) { + if (ass[i] == NOCHAR) + continue; + if (isspace(*cp)) + while (isspace(ass[i])) + i++; + *++cp = ass[i]; } - strcpy(vp->value+i, ass); + if (isspace(*cp)) /* remove trailing space */ + *cp = '\0'; vp->nass++; } @@ -296,7 +333,7 @@ register int n; { register char *cp; - if (vp == NULL || n < 0 || n >= vp->nass) + if (vp == NULL | n < 0 | n >= vp->nass) return(NULL); cp = vp->value; while (n--) @@ -306,24 +343,6 @@ register int n; } -int -vscale(vc) /* return scale for variable vc */ -int vc; -{ - switch(vlet(vc)) { - case 'H': - return(HIGH); - case 'M': - return(MEDIUM); - case 'L': - return(LOW); - } - fprintf(stderr, "%s: illegal value for variable '%s' (%s)\n", - progname, vnam(vc), vval(vc)); - exit(1); -} - - checkvalues() /* check assignments */ { register int i; @@ -341,8 +360,9 @@ register VARIABLE *vp; return; fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n", progname, vp->name); - while (vp->nass-- > 1) + do vp->value += strlen(vp->value)+1; + while (--vp->nass > 1); } @@ -361,23 +381,102 @@ register VARIABLE *vp; } -long +int +badmatch(tv, cv) /* case insensitive truncated comparison */ +register char *tv, *cv; +{ + if (!*tv) return(1); /* null string cannot match */ + do + if (UPPER(*tv) != *cv++) + return(1); + while (*++tv); + return(0); /* OK */ +} + + +boolvalue(vp) /* check boolean for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + switch (UPPER(vp->value[0])) { + case 'T': + if (badmatch(vp->value, "TRUE")) break; + return; + case 'F': + if (badmatch(vp->value, "FALSE")) break; + return; + } + fprintf(stderr, "%s: illegal value for boolean variable '%s'\n", + progname, vp->name); + exit(1); +} + + +qualvalue(vp) /* check qualitative var. for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + switch (UPPER(vp->value[0])) { + case 'L': + if (badmatch(vp->value, "LOW")) break; + return; + case 'M': + if (badmatch(vp->value, "MEDIUM")) break; + return; + case 'H': + if (badmatch(vp->value, "HIGH")) break; + return; + } + fprintf(stderr, "%s: illegal value for qualitative variable '%s'\n", + progname, vp->name); + exit(1); +} + + +intvalue(vp) /* check integer variable for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + if (isint(vp->value)) return; + fprintf(stderr, "%s: illegal value for integer variable '%s'\n", + progname, vp->name); + exit(1); +} + + +fltvalue(vp) /* check float variable for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + if (isflt(vp->value)) return; + fprintf(stderr, "%s: illegal value for real variable '%s'\n", + progname, vp->name); + exit(1); +} + + +unsigned long checklast(fnames) /* check files and find most recent */ register char *fnames; { char thisfile[MAXPATH]; - long thisdate, lastdate = -1; + unsigned long thisdate, lastdate = 0; register char *cp; + if (fnames == NULL) + return(0); while (*fnames) { while (isspace(*fnames)) fnames++; cp = thisfile; - while (*fnames && !isspace(*fnames)) *cp++ = *fnames++; + while (*fnames && !isspace(*fnames)) + *cp++ = *fnames++; *cp = '\0'; - if ((thisdate = fdate(thisfile)) < 0) { - perror(thisfile); - exit(1); - } + if (!(thisdate = fdate(thisfile))) + syserr(thisfile); if (thisdate > lastdate) lastdate = thisdate; } @@ -385,72 +484,125 @@ register char *fnames; } +char * +newfname(orig, pred) /* create modified file name */ +char *orig; +int pred; +{ + extern char *rindex(); + register char *cp; + register int n; + int suffix; + + n = 0; cp = orig; suffix = -1; /* suffix position, length */ + while (*cp) { + if (*cp == '.') suffix = n; + else if (ISDIRSEP(*cp)) suffix = -1; + cp++; n++; + } + if (suffix == -1) suffix = n; + if ((cp = bmalloc(n+2)) == NULL) + syserr(progname); + strncpy(cp, orig, suffix); + cp[suffix] = pred; /* root name + pred + suffix */ + strcpy(cp+suffix+1, orig+suffix); + return(cp); +} + + checkfiles() /* check for existence and modified times */ { - long objdate; + unsigned long objdate; - octreedate = vdef(OCTREE) ? fdate(vval(OCTREE)) : -1; - scenedate = -1; - if (vdef(SCENE)) { - scenedate = checklast(vval(SCENE)); - if (vdef(OBJECT)) { - objdate = checklast(vval(OBJECT)); - if (objdate > scenedate) - scenedate = objdate; - } + if (!vdef(OCTREE)) { + if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL) + syserr(progname); + sprintf(vval(OCTREE), "%s.oct", radname); + vdef(OCTREE)++; } - if (octreedate < 0 & scenedate < 0) { - fprintf(stderr, "%s: need scene or octree\n", progname); + octreedate = fdate(vval(OCTREE)); + if (vdef(ILLUM)) { /* illum requires secondary octrees */ + oct0name = newfname(vval(OCTREE), '0'); + oct1name = newfname(vval(OCTREE), '1'); + oct0date = fdate(oct0name); + oct1date = fdate(oct1name); + } else + oct0name = oct1name = vval(OCTREE); + if ((scenedate = checklast(vval(SCENE))) && + (objdate = checklast(vval(OBJECT))) > scenedate) + scenedate = objdate; + illumdate = checklast(vval(ILLUM)); + if (!octreedate & !scenedate & !illumdate) { + fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname, + vnam(OCTREE), vnam(SCENE), vnam(ILLUM)); exit(1); } + matdate = checklast(vval(MATERIAL)); } -setdefaults() /* set default values for unassigned var's */ +getoctcube(org, sizp) /* get octree bounding cube */ +double org[3], *sizp; { - FILE *fp; - double xmin, ymin, zmin, size; + extern FILE *popen(); + static double oorg[3], osiz = 0.; + double min[3], max[3]; char buf[512]; - char *cp; + FILE *fp; + register int i; - if (!vdef(OCTREE)) { - sprintf(buf, "%s.oct", radname); - vval(OCTREE) = savqstr(buf); - vdef(OCTREE)++; - } - if (!vdef(ZONE)) { - if (scenedate > octreedate) { - sprintf(buf, "getbbox -w -h %s", vval(SCENE)); - if (!silent) { - printf("\t%s\n", buf); - fflush(stdout); - } - if ((fp = popen(buf, "r")) == NULL) { - perror("getbbox"); + if (osiz <= FTINY) + if (noaction && fdate(oct1name) < + (scenedate>illumdate?scenedate:illumdate)) { + /* run getbbox */ + sprintf(buf, "getbbox -w -h %s", + vdef(SCENE) ? vval(SCENE) : vval(ILLUM)); + if ((fp = popen(buf, "r")) == NULL) + syserr("getbbox"); + if (fscanf(fp, "%lf %lf %lf %lf %lf %lf", + &min[0], &max[0], &min[1], &max[1], + &min[2], &max[2]) != 6) { + fprintf(stderr, + "%s: error reading bounding box from getbbox\n", + progname); exit(1); } - buf[0] = 'E'; buf[1] = ' '; - fgetline(buf+2, sizeof(buf)-2, fp); + for (i = 0; i < 3; i++) + if (max[i] - min[i] > osiz) + osiz = max[i] - min[i]; + for (i = 0; i < 3; i++) + oorg[i] = (max[i]+min[i]-osiz)*.5; pclose(fp); - } else { - sprintf(buf, "getinfo -d < %s", vval(OCTREE)); - if ((fp = popen(buf, "r")) == NULL) { - perror("getinfo"); + } else { /* from octree */ + oconv(); /* does nothing if done already */ + sprintf(buf, "getinfo -d < %s", oct1name); + if ((fp = popen(buf, "r")) == NULL) + syserr("getinfo"); + if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1], + &oorg[2], &osiz) != 4) { + fprintf(stderr, + "%s: error reading bounding cube from getinfo\n", + progname); exit(1); } - fscanf(fp, "%lf %lf %lf %lf", - &xmin, &ymin, &zmin, &size); - sprintf(buf, "E %g %g %g %g %g %g", xmin, xmin+size, - ymin, ymin+size, zmin, zmin+size); pclose(fp); } + org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz; +} + + +setdefaults() /* set default values for unassigned var's */ +{ + double org[3], size; + char buf[128]; + + if (!vdef(ZONE)) { + getoctcube(org, &size); + sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size, + org[1], org[1]+size, org[2], org[2]+size); vval(ZONE) = savqstr(buf); vdef(ZONE)++; } - if (!vdef(UP)) { - vval(UP) = "Z"; - vdef(UP)++; - } if (!vdef(INDIRECT)) { vval(INDIRECT) = "0"; vdef(INDIRECT)++; @@ -467,11 +619,6 @@ setdefaults() /* set default values for unassigned v vval(PICTURE) = radname; vdef(PICTURE)++; } - if (!vdef(AMBFILE)) { - sprintf(buf, "%s.amb", radname); - vval(AMBFILE) = savqstr(buf); - vdef(AMBFILE)++; - } if (!vdef(VIEW)) { vval(VIEW) = "X"; vdef(VIEW)++; @@ -496,33 +643,90 @@ printvals() /* print variable values */ register int i, j; for (i = 0; i < NVARS; i++) - for (j = 0; j < vv[i].nass; j++) - printf("%s= %s\n", vv[i].name, nvalue(vv+i, j)); + for (j = 0; j < vdef(i); j++) + printf("%s= %s\n", vnam(i), nvalue(vv+i, j)); fflush(stdout); } -oconv() /* run oconv if necessary */ +oconv() /* run oconv and mkillum if necessary */ { - char combuf[512], ocopts[64]; + static char illumtmp[] = "ilXXXXXX"; + char combuf[512], ocopts[64], mkopts[64]; - if (octreedate > scenedate) /* check dates */ - return; - /* build command */ - oconvopts(ocopts); - sprintf(combuf, "oconv%s %s > %s", ocopts, vval(SCENE), vval(OCTREE)); - if (!silent) { /* echo it */ - printf("\t%s\n", combuf); - fflush(stdout); + oconvopts(ocopts); /* get options */ + if (octreedate < scenedate) { /* check date on original octree */ + /* build command */ + if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(SCENE), vval(OCTREE)); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(SCENE), vval(OCTREE)); + + if (runcom(combuf)) { /* run it */ + fprintf(stderr, + "%s: error generating octree\n\t%s removed\n", + progname, vval(OCTREE)); + unlink(vval(OCTREE)); + exit(1); + } + octreedate = time((unsigned long *)NULL); } - if (noaction) + if (oct1name == vval(OCTREE)) /* no mkillum? */ + oct1date = octreedate > matdate ? octreedate : matdate; + if (oct1date >= octreedate & oct1date >= matdate + & oct1date >= illumdate) /* all done */ return; - if (system(combuf)) { /* run it */ - fprintf(stderr, "%s: error generating octree\n\t%s removed\n", - progname, vval(OCTREE)); - unlink(vval(OCTREE)); + /* make octree0 */ + if (oct0date < scenedate | oct0date < illumdate) { + /* build command */ + if (octreedate) + sprintf(combuf, "oconv%s -i %s %s > %s", ocopts, + vval(OCTREE), vval(ILLUM), oct0name); + else if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(ILLUM), oct0name); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(ILLUM), oct0name); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, + "%s: error generating octree\n\t%s removed\n", + progname, oct0name); + unlink(oct0name); + exit(1); + } + oct0date = time((unsigned long *)NULL); + } + mkillumopts(mkopts); /* build mkillum command */ + mktemp(illumtmp); + sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts, + oct0name, vval(ILLUM), illumtmp); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, "%s: error running mkillum\n", progname); + unlink(illumtmp); exit(1); } + /* make octree1 (frozen) */ + if (octreedate) + sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts, + vval(OCTREE), illumtmp, oct1name); + else if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s -f %s %s > %s", ocopts, + vval(MATERIAL), illumtmp, oct1name); + else + sprintf(combuf, "oconv%s -f %s > %s", ocopts, + illumtmp, oct1name); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, + "%s: error generating octree\n\t%s removed\n", + progname, oct1name); + unlink(oct1name); + exit(1); + } + oct1date = time((unsigned long *)NULL); + rmfile(illumtmp); } @@ -538,42 +742,261 @@ register char *op, *arg; oconvopts(oo) /* get oconv options */ -char *oo; +register char *oo; { + /* BEWARE: This may be called via setdefaults(), so no assumptions */ + *oo = '\0'; if (vdef(OCONV)) addarg(oo, vval(OCONV)); } -lowqopts(ro) /* low quality rendering options */ -char *ro; +mkillumopts(mo) /* get mkillum options */ +register char *mo; { - register char *op = ro; + /* BEWARE: This may be called via setdefaults(), so no assumptions */ + *mo = '\0'; + if (vdef(MKILLUM)) + addarg(mo, vval(MKILLUM)); +} + + +checkambfile() /* check date on ambient file */ +{ + unsigned long afdate; + + if (!vdef(AMBFILE)) + return; + if (!(afdate = fdate(vval(AMBFILE)))) + return; + if (oct1date > afdate) + rmfile(vval(AMBFILE)); +} + + +double +ambval() /* compute ambient value */ +{ + if (vdef(EXPOSURE)) { + if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') + return(.5/pow(2.,atof(vval(EXPOSURE)))); + return(.5/atof(vval(EXPOSURE))); + } + if (vlet(ZONE) == 'E') + return(10.); + if (vlet(ZONE) == 'I') + return(.01); + badvalue(ZONE); +} + + +renderopts(op) /* set rendering options */ +char *op; +{ + switch(vscale(QUALITY)) { + case LOW: + lowqopts(op); + break; + case MEDIUM: + medqopts(op); + break; + case HIGH: + hiqopts(op); + break; + } +} + + +lowqopts(op) /* low quality rendering options */ +register char *op; +{ + double d, org[3], siz[3]; + *op = '\0'; + if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], + &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) + badvalue(ZONE); + siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + getoctcube(org, &d); + d *= 3./(siz[0]+siz[1]+siz[2]); + switch (vscale(DETAIL)) { + case LOW: + op = addarg(op, "-ps 16 -dp 64"); + sprintf(op, " -ar %d", (int)(4*d)); + op += strlen(op); + break; + case MEDIUM: + op = addarg(op, "-ps 8 -dp 128"); + sprintf(op, " -ar %d", (int)(8*d)); + op += strlen(op); + break; + case HIGH: + op = addarg(op, "-ps 4 -dp 256"); + sprintf(op, " -ar %d", (int)(16*d)); + op += strlen(op); + break; + } + op = addarg(op, "-pt .16"); + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .4"); + else + op = addarg(op, "-ds 0"); + op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5"); + if (vdef(AMBFILE)) { + sprintf(op, " -af %s", vval(AMBFILE)); + op += strlen(op); + } else + overture = 0; + switch (vscale(VARIABILITY)) { + case LOW: + op = addarg(op, "-aa .4 -ad 64"); + break; + case MEDIUM: + op = addarg(op, "-aa .3 -ad 128"); + break; + case HIGH: + op = addarg(op, "-aa .25 -ad 256"); + break; + } + op = addarg(op, "-as 0"); + d = ambval(); + sprintf(op, " -av %.2g %.2g %.2g", d, d, d); + op += strlen(op); + op = addarg(op, "-lr 3 -lw .02"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } -medqopts(ro) /* medium quality rendering options */ -char *ro; +medqopts(op) /* medium quality rendering options */ +register char *op; { - register char *op = ro; + double d, org[3], siz[3]; *op = '\0'; + if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], + &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) + badvalue(ZONE); + siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + getoctcube(org, &d); + d *= 3./(siz[0]+siz[1]+siz[2]); + switch (vscale(DETAIL)) { + case LOW: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8"); + op = addarg(op, "-dp 256"); + sprintf(op, " -ar %d", (int)(8*d)); + op += strlen(op); + break; + case MEDIUM: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6"); + op = addarg(op, "-dp 512"); + sprintf(op, " -ar %d", (int)(16*d)); + op += strlen(op); + break; + case HIGH: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4"); + op = addarg(op, "-dp 1024"); + sprintf(op, " -ar %d", (int)(32*d)); + op += strlen(op); + break; + } + op = addarg(op, "-pt .08"); + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .2 -dj .5"); + else + op = addarg(op, "-ds .3"); + op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1"); + if (overture = vint(INDIRECT)) { + sprintf(op, " -ab %d", overture); + op += strlen(op); + } + if (vdef(AMBFILE)) { + sprintf(op, " -af %s", vval(AMBFILE)); + op += strlen(op); + } else + overture = 0; + switch (vscale(VARIABILITY)) { + case LOW: + op = addarg(op, "-aa .25 -ad 196 -as 0"); + break; + case MEDIUM: + op = addarg(op, "-aa .2 -ad 400 -as 64"); + break; + case HIGH: + op = addarg(op, "-aa .15 -ad 768 -as 196"); + break; + } + d = ambval(); + sprintf(op, " -av %.2g %.2g %.2g", d, d, d); + op += strlen(op); + op = addarg(op, "-lr 6 -lw .002"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } -hiqopts(ro) /* high quality rendering options */ -char *ro; +hiqopts(op) /* high quality rendering options */ +register char *op; { - register char *op = ro; + double d, org[3], siz[3]; *op = '\0'; + if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], + &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) + badvalue(ZONE); + siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + getoctcube(org, &d); + d *= 3./(siz[0]+siz[1]+siz[2]); + switch (vscale(DETAIL)) { + case LOW: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8"); + op = addarg(op, "-dp 1024"); + sprintf(op, " -ar %d", (int)(16*d)); + op += strlen(op); + break; + case MEDIUM: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5"); + op = addarg(op, "-dp 2048"); + sprintf(op, " -ar %d", (int)(32*d)); + op += strlen(op); + break; + case HIGH: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3"); + op = addarg(op, "-dp 4096"); + sprintf(op, " -ar %d", (int)(64*d)); + op += strlen(op); + break; + } + op = addarg(op, "-pt .04"); + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .1 -dj .7"); + else + op = addarg(op, "-ds .2"); + op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01"); + sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); + op += strlen(op); + if (vdef(AMBFILE)) { + sprintf(op, " -af %s", vval(AMBFILE)); + op += strlen(op); + } else + overture = 0; + switch (vscale(VARIABILITY)) { + case LOW: + op = addarg(op, "-aa .15 -ad 256 -as 0"); + break; + case MEDIUM: + op = addarg(op, "-aa .125 -ad 512 -as 256"); + break; + case HIGH: + op = addarg(op, "-aa .08 -ad 1024 -as 512"); + break; + } + d = ambval(); + sprintf(op, " -av %.2g %.2g %.2g", d, d, d); + op += strlen(op); + op = addarg(op, "-lr 12 -lw .0005"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -583,35 +1006,26 @@ xferopts(ro) /* transfer options if indicated */ char *ro; { int fd, n; + register char *cp; n = strlen(ro); if (n < 2) return; if (vdef(OPTFILE)) { - if ((fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) { - perror(vval(OPTFILE)); - exit(1); - } - if (write(fd, ro+1, n-1) != n-1) { - perror(vval(OPTFILE)); - exit(1); - } - write(fd, "\n", 1); - close(fd); - ro[0] = ' '; - ro[1] = '^'; - strcpy(ro+2, vval(OPTFILE)); + for (cp = ro; cp[1]; cp++) + if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3])) + *cp = '\n'; + else + *cp = cp[1]; + *cp = '\n'; + fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666); + if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0) + syserr(vval(OPTFILE)); + sprintf(ro, " @%s", vval(OPTFILE)); } #ifdef MSDOS else if (n > 50) { - register char *evp = bmalloc(n+6); - if (evp == NULL) { - perror(progname); - exit(1); - } - strcpy(evp, "ROPT="); - strcat(evp, ro); - putenv(evp); + setenv("ROPT", ro+1); strcpy(ro, " $ROPT"); } #endif @@ -626,8 +1040,14 @@ register char *po; po = addarg(po, "-1 -e"); po = addarg(po, vval(EXPOSURE)); } - if (vscale(QUALITY) == HIGH) - po = addarg(po, "-r .65"); + switch (vscale(QUALITY)) { + case MEDIUM: + po = addarg(po, "-r 1"); + break; + case HIGH: + po = addarg(po, "-m .25"); + break; + } if (vdef(PFILT)) po = addarg(po, vval(PFILT)); } @@ -649,17 +1069,29 @@ char * specview(vs) /* get proper view spec from vs */ register char *vs; { + static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0", + "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"}; static char viewopts[128]; register char *cp; - int xpos, ypos, zpos, viewtype; - int exterior; + int xpos, ypos, zpos, viewtype, upax; + register int i; double cent[3], dim[3], mult, d; if (vs == NULL || *vs == '-') return(vs); + upax = 0; /* get the up vector */ + if (vdef(UP)) { + if (vval(UP)[0] == '-' || vval(UP)[0] == '+') + upax = 1-'X'+UPPER(vval(UP)[1]); + else + upax = 1-'X'+vlet(UP); + if (upax < 1 | upax > 3) + badvalue(UP); + if (vval(UP)[0] == '-') + upax = -upax; + } /* check standard view names */ xpos = ypos = zpos = 0; - viewtype = 0; if (*vs == 'X') { xpos = 1; vs++; } else if (*vs == 'x') { @@ -675,55 +1107,47 @@ register char *vs; } else if (*vs == 'z') { zpos = -1; vs++; } + viewtype = 'v'; if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h') viewtype = *vs++; - else if (!*vs || isspace(*vs)) - viewtype = 'v'; cp = viewopts; - if (viewtype && (xpos|ypos|zpos)) { /* got standard view */ + if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */ *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype; if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", ¢[0], &dim[0], ¢[1], &dim[1], - ¢[2], &dim[2]) != 6) { - fprintf(stderr, "%s: bad zone specification\n", - progname); - exit(1); + ¢[2], &dim[2]) != 6) + badvalue(ZONE); + for (i = 0; i < 3; i++) { + dim[i] -= cent[i]; + cent[i] += .5*dim[i]; } - dim[0] -= cent[0]; - dim[1] -= cent[1]; - dim[2] -= cent[2]; - exterior = vlet(ZONE) == 'E'; - mult = exterior ? 2. : .45 ; + mult = vlet(ZONE)=='E' ? 2. : .45 ; sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g", cent[0]+xpos*mult*dim[0], cent[1]+ypos*mult*dim[1], cent[2]+zpos*mult*dim[2], -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]); cp += strlen(cp); - switch (vlet(UP)) { - case 'Z': - if (xpos|ypos) { - cp = addarg(cp, "-vu 0 0 1"); - break; - } - /* fall through */ - case 'Y': - if (xpos|zpos) { - cp = addarg(cp, "-vu 0 1 0"); - break; - } - /* fall through */ - case 'X': - if (ypos|zpos) - cp = addarg(cp, "-vu 1 0 0"); - else - cp = addarg(cp, "-vu 0 0 1"); + /* redirect up axis if necessary */ + switch (upax) { + case 3: /* plus or minus Z axis */ + case -3: + case 0: + if (!(xpos|ypos)) + upax = 2; break; - default: - fprintf(stderr, "%s: illegal value for variable '%s'\n", - progname, vnam(UP)); - exit(1); + case 2: /* plus or minus Y axis */ + case -2: + if (!(xpos|zpos)) + upax = 1; + break; + case 1: /* plus or minus X axis */ + case -1: + if (!(ypos|zpos)) + upax = 3; + break; } + cp = addarg(cp, vup[upax+3]); switch (viewtype) { case 'v': cp = addarg(cp, "-vh 45 -vv 45"); @@ -738,12 +1162,24 @@ register char *vs; cp = addarg(cp, "-vh 180 -vv 180"); break; } - } else - while (*vs && !isspace(*vs)) /* else skip id */ - vs++; - /* append any additional options */ - while (isspace(*vs)) vs++; + } else { + while (!isspace(*vs)) /* else skip id */ + if (!*vs++) + return(NULL); + if (upax) { /* specify up vector */ + strcpy(cp, vup[upax+3]); + cp += strlen(cp); + } + } + if (cp == viewopts) /* append any additional options */ + vs++; /* skip prefixed space if unneeded */ strcpy(cp, vs); +#ifdef MSDOS + if (strlen(viewopts) > 40) { + setenv("VIEW", viewopts); + return("$VIEW"); + } +#endif return(viewopts); } @@ -751,11 +1187,11 @@ register char *vs; char * getview(n, vn) /* get view n, or NULL if none */ int n; -char *vn; +char *vn; /* returned view name */ { register char *mv; - if (viewselect != NULL) { + if (viewselect != NULL) { /* command-line selected */ if (n) /* only do one */ return(NULL); if (viewselect[0] == '-') { /* already specified */ @@ -768,38 +1204,101 @@ char *vn; ; *vn = '\0'; } + /* view number? */ + if (isint(viewselect)) + return(specview(nvalue(vv+VIEW, atoi(viewselect)-1))); /* check list */ while ((mv = nvalue(vv+VIEW, n++)) != NULL) if (matchword(viewselect, mv)) return(specview(mv)); return(specview(viewselect)); /* standard view? */ } - if (vn != NULL && (mv = nvalue(vv+VIEW, n)) != NULL) { - if (*mv != '-') - while (*mv && !isspace(*mv)) - *vn++ = *mv++; + mv = nvalue(vv+VIEW, n); /* use view n */ + if (vn != NULL & mv != NULL) { + register char *mv2 = mv; + if (*mv2 != '-') + while (*mv2 && !isspace(*mv2)) + *vn++ = *mv2++; *vn = '\0'; } - return(specview(nvalue(vv+VIEW, n))); /* use view n */ + return(specview(mv)); } +printview(vopts) /* print out selected view */ +register char *vopts; +{ + extern char *atos(), *getenv(); + char buf[256]; + FILE *fp; + register char *cp; + + if (vopts == NULL) + return(-1); + fputs("VIEW=", stdout); + do { + if (matchword(vopts, "-vf")) { /* expand view file */ + vopts = sskip(vopts); + if (!*atos(buf, sizeof(buf), vopts)) + return(-1); + if ((fp = fopen(buf, "r")) == NULL) + return(-1); + for (buf[sizeof(buf)-2] = '\n'; + fgets(buf, sizeof(buf), fp) != NULL && + buf[0] != '\n'; + buf[sizeof(buf)-2] = '\n') { + if (buf[sizeof(buf)-2] != '\n') { + ungetc(buf[sizeof(buf)-2], fp); + buf[sizeof(buf)-2] = '\0'; + } + if (matchword(buf, "VIEW=") || + matchword(buf, "rview")) { + for (cp = sskip(buf); *cp && *cp != '\n'; cp++) + putchar(*cp); + } + } + fclose(fp); + vopts = sskip(vopts); + } else { + while (isspace(*vopts)) + vopts++; + putchar(' '); +#ifdef MSDOS + if (*vopts == '$') { /* expand env. var. */ + if (!*atos(buf, sizeof(buf), vopts+1)) + return(-1); + if ((cp = getenv(buf)) == NULL) + return(-1); + fputs(cp, stdout); + vopts = sskip(vopts); + } else +#endif + while (*vopts && !isspace(*vopts)) + putchar(*vopts++); + } + } while (*vopts++); + putchar('\n'); + return(0); +} + + rview(opts) /* run rview with first view */ char *opts; { + char *vw; char combuf[512]; /* build command */ - sprintf(combuf, "rview %s%s ", getview(0, NULL), opts); + if ((vw = getview(0, NULL)) == NULL) + return; + if (sayview) + printview(vw); + sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname); if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); - strcat(combuf, vval(OCTREE)); - if (!silent) { /* echo it */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (noaction) - return; - if (system(combuf)) { /* run it */ + if (vdef(EXPOSURE)) + sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE)); + strcat(combuf, oct1name); + if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error running rview\n", progname); exit(1); } @@ -809,15 +1308,25 @@ char *opts; rpict(opts) /* run rpict and pfilt for each view */ char *opts; { - char combuf[512]; - char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH], res[32]; - char pfopts[64]; + char combuf[1024]; + char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32]; + char pfopts[128]; char vs[32], *vw; int vn, mult; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ - mult = vscale(QUALITY)+1; + switch (vscale(QUALITY)) { + case LOW: + mult = 1; + break; + case MEDIUM: + mult = 2; + break; + case HIGH: + mult = 3; + break; + } { int xres, yres; double aspect; @@ -829,11 +1338,8 @@ char *opts; else if (n) { if (n == 1) yres = xres; sprintf(res, "-x %d -y %d", mult*xres, mult*yres); - } else { - fprintf(stderr, "%s: bad value for variable '%s'\n", - progname, vnam(RESOLUTION)); - exit(1); - } + } else + badvalue(RESOLUTION); } rep[0] = '\0'; if (vdef(REPORT)) { @@ -844,53 +1350,46 @@ char *opts; sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile); else if (n == 1) sprintf(rep, " -t %d", (int)(minutes*60)); - else { - fprintf(stderr, "%s: bad value for variable '%s'\n", - progname, vnam(REPORT)); - exit(1); - } + else + badvalue(REPORT); } /* do each view */ vn = 0; while ((vw = getview(vn++, vs)) != NULL) { + if (sayview) + printview(vw); if (!vs[0]) sprintf(vs, "%d", vn); sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); /* check date on picture */ - if (fdate(picfile) > octreedate) + if (fdate(picfile) >= oct1date) continue; /* build rpict command */ sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs); - if (fdate(rawfile) > octreedate) /* recover */ + if (fdate(rawfile) >= oct1date) /* recover */ sprintf(combuf, "rpict%s%s -ro %s %s", - rep, opts, rawfile, vval(OCTREE)); + rep, opts, rawfile, oct1name); else { if (overture) { /* run overture calculation */ sprintf(combuf, "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s", rep, vw, opts, - vval(OCTREE), rawfile); - if (!silent) { - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { + oct1name, overfile); + if (runcom(combuf)) { fprintf(stderr, - "%s: error in overture for view %s\n\t%s removed\n", - progname, vs, rawfile); - unlink(rawfile); + "%s: error in overture for view %s\n", + progname, vs); exit(1); } +#ifdef NIX + rmfile(overfile); +#endif } sprintf(combuf, "rpict%s %s %s%s %s > %s", rep, vw, res, opts, - vval(OCTREE), rawfile); + oct1name, rawfile); } - if (!silent) { /* echo rpict command */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { /* run rpict */ + if (runcom(combuf)) { /* run rpict */ fprintf(stderr, "%s: error rendering view %s\n", progname, vs); exit(1); @@ -902,11 +1401,7 @@ char *opts; else sprintf(combuf, "pfilt%s %s > %s", pfopts, rawfile, picfile); - if (!silent) { /* echo pfilt command */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { /* run pfilt */ + if (runcom(combuf)) { /* run pfilt */ fprintf(stderr, "%s: error filtering view %s\n\t%s removed\n", progname, vs, picfile); @@ -914,13 +1409,70 @@ char *opts; exit(1); } /* remove raw file */ - if (!silent) + rmfile(rawfile); + } +} + + +runcom(cs) /* run command */ +char *cs; +{ + if (!silent) /* echo it */ + printf("\t%s\n", cs); + if (noaction) + return(0); + fflush(stdout); /* flush output and pass to shell */ + return(system(cs)); +} + + +rmfile(fn) /* remove a file */ +char *fn; +{ + if (!silent) #ifdef MSDOS - printf("\tdel %s\n", rawfile); + printf("\tdel %s\n", fn); #else - printf("\trm %s\n", rawfile); + printf("\trm -f %s\n", fn); #endif - if (!noaction) - unlink(rawfile); + if (noaction) + return(0); + return(unlink(fn)); +} + + +#ifdef MSDOS +setenv(vname, value) /* set an environment variable */ +char *vname, *value; +{ + register char *evp; + + evp = bmalloc(strlen(vname)+strlen(value)+2); + if (evp == NULL) + syserr(progname); + sprintf(evp, "%s=%s", vname, value); + if (putenv(evp) != 0) { + fprintf(stderr, "%s: out of environment space\n", progname); + exit(1); } + if (!silent) + printf("set %s\n", evp); +} +#endif + + +badvalue(vc) /* report bad variable value and exit */ +int vc; +{ + fprintf(stderr, "%s: bad value for variable '%s'\n", + progname, vnam(vc)); + exit(1); +} + + +syserr(s) /* report a system error and exit */ +char *s; +{ + perror(s); + exit(1); }
