--- ray/src/util/rad.c 1993/03/11 09:11:00 2.1 +++ ray/src/util/rad.c 1993/03/11 11:39:48 2.2 @@ -92,7 +92,7 @@ int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; #define renderopts (*setqopts[vscale(QUALITY)]) -extern long fdate(); +extern long fdate(), time(); long scenedate; /* date of latest scene or object file */ long octreedate; /* date of octree */ @@ -341,8 +341,9 @@ register VARIABLE *vp; return; fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n", progname, vp->name); - while (vp->nass-- > 1) + do vp->value += strlen(vp->value)+1; + while (--vp->nass > 1); } @@ -387,9 +388,19 @@ register char *fnames; checkfiles() /* check for existence and modified times */ { + char *cp; long objdate; - octreedate = vdef(OCTREE) ? fdate(vval(OCTREE)) : -1; + if (!vdef(OCTREE)) { + if ((cp = bmalloc(strlen(radname)+5)) == NULL) { + perror(progname); + exit(1); + } + sprintf(cp, "%s.oct", radname); + vval(OCTREE) = cp; + vdef(OCTREE)++; + } + octreedate = fdate(vval(OCTREE)); scenedate = -1; if (vdef(SCENE)) { scenedate = checklast(vval(SCENE)); @@ -400,50 +411,50 @@ checkfiles() /* check for existence and modified tim } } if (octreedate < 0 & scenedate < 0) { - fprintf(stderr, "%s: need scene or octree\n", progname); + fprintf(stderr, "%s: need '%s' or '%s'\n", progname, + vnam(OCTREE), vnam(SCENE)); exit(1); } } -setdefaults() /* set default values for unassigned var's */ +getoctcube(org, sizp) /* get octree bounding cube */ +double org[3], *sizp; { + extern FILE *popen(); + static double oorg[3], osiz = 0.; + char buf[MAXPATH+16]; FILE *fp; - double xmin, ymin, zmin, size; - char buf[512]; - char *cp; - if (!vdef(OCTREE)) { - sprintf(buf, "%s.oct", radname); - vval(OCTREE) = savqstr(buf); - vdef(OCTREE)++; + if (osiz <= FTINY) { + oconv(); /* does nothing if done already */ + sprintf(buf, "getinfo -d < %s", vval(OCTREE)); + if ((fp = popen(buf, "r")) == NULL) { + perror("getinfo"); + exit(1); + } + if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1], + &oorg[2], &osiz) != 4) { + fprintf(stderr, + "%s: error reading bounding cube from getinfo\n", + progname); + exit(1); + } + pclose(fp); } + org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz; +} + + +setdefaults() /* set default values for unassigned var's */ +{ + double org[3], size; + char buf[128]; + if (!vdef(ZONE)) { - if (scenedate > octreedate) { - sprintf(buf, "getbbox -w -h %s", vval(SCENE)); - if (!silent) { - printf("\t%s\n", buf); - fflush(stdout); - } - if ((fp = popen(buf, "r")) == NULL) { - perror("getbbox"); - exit(1); - } - buf[0] = 'E'; buf[1] = ' '; - fgetline(buf+2, sizeof(buf)-2, fp); - pclose(fp); - } else { - sprintf(buf, "getinfo -d < %s", vval(OCTREE)); - if ((fp = popen(buf, "r")) == NULL) { - perror("getinfo"); - exit(1); - } - fscanf(fp, "%lf %lf %lf %lf", - &xmin, &ymin, &zmin, &size); - sprintf(buf, "E %g %g %g %g %g %g", xmin, xmin+size, - ymin, ymin+size, zmin, zmin+size); - pclose(fp); - } + getoctcube(org, &size); + sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size, + org[1], org[1]+size, org[2], org[2]+size); vval(ZONE) = savqstr(buf); vdef(ZONE)++; } @@ -467,11 +478,6 @@ setdefaults() /* set default values for unassigned v vval(PICTURE) = radname; vdef(PICTURE)++; } - if (!vdef(AMBFILE)) { - sprintf(buf, "%s.amb", radname); - vval(AMBFILE) = savqstr(buf); - vdef(AMBFILE)++; - } if (!vdef(VIEW)) { vval(VIEW) = "X"; vdef(VIEW)++; @@ -506,11 +512,13 @@ oconv() /* run oconv if necessary */ { char combuf[512], ocopts[64]; - if (octreedate > scenedate) /* check dates */ + if (octreedate >= scenedate) /* check dates */ return; /* build command */ oconvopts(ocopts); - sprintf(combuf, "oconv%s %s > %s", ocopts, vval(SCENE), vval(OCTREE)); + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vdef(MATERIAL) ? vval(MATERIAL) : "", + vval(SCENE), vval(OCTREE)); if (!silent) { /* echo it */ printf("\t%s\n", combuf); fflush(stdout); @@ -523,6 +531,7 @@ oconv() /* run oconv if necessary */ unlink(vval(OCTREE)); exit(1); } + octreedate = time(0); } @@ -538,42 +547,260 @@ register char *op, *arg; oconvopts(oo) /* get oconv options */ -char *oo; +register char *oo; { + /* BEWARE: This may be called via setdefaults(), so no assumptions */ + *oo = '\0'; if (vdef(OCONV)) addarg(oo, vval(OCONV)); } -lowqopts(ro) /* low quality rendering options */ -char *ro; +double +ambval() /* compute ambient value */ { - register char *op = ro; + if (vdef(EXPOSURE)) + if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') + return(.5/pow(2.,atof(vval(EXPOSURE)))); + else + return(.5/atof(vval(EXPOSURE))); + if (vlet(ZONE) == 'E') + return(10.); + else + return(.01); +} + +lowqopts(op) /* low quality rendering options */ +register char *op; +{ + double d, org[3], siz[3]; + *op = '\0'; + if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], + &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) { + fprintf(stderr, "%s: bad value for variable '%s'\n", + progname, vnam(ZONE)); + exit(1); + } + siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + getoctcube(org, &d); + d *= 3./(siz[0]+siz[1]+siz[2]); + switch (vscale(DETAIL)) { + case LOW: + op = addarg(op, "-ps 16"); + op = addarg(op, "-dp 16"); + sprintf(op, " -ar %d", (int)(4*d)); + op += strlen(op); + break; + case MEDIUM: + op = addarg(op, "-ps 8"); + op = addarg(op, "-dp 32"); + sprintf(op, " -ar %d", (int)(8*d)); + op += strlen(op); + break; + case HIGH: + op = addarg(op, "-ps 4"); + op = addarg(op, "-dp 64"); + sprintf(op, " -ar %d", (int)(16*d)); + op += strlen(op); + break; + } + op = addarg(op, "-pt .16"); + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .4"); + op = addarg(op, "-dt .2"); + op = addarg(op, "-dc .25"); + op = addarg(op, "-dr 0"); + op = addarg(op, "-sj 0"); + op = addarg(op, "-st .7"); + op = addarg(op, "-ab 0"); + if (vdef(AMBFILE)) { + sprintf(op, " -af %s", vval(AMBFILE)); + op += strlen(op); + } else + overture = 0; + switch (vscale(VARIABILITY)) { + case LOW: + op = addarg(op, "-aa .4"); + op = addarg(op, "-ad 32"); + break; + case MEDIUM: + op = addarg(op, "-aa .3"); + op = addarg(op, "-ad 64"); + break; + case HIGH: + op = addarg(op, "-aa .25"); + op = addarg(op, "-ad 128"); + break; + } + op = addarg(op, "-as 0"); + d = ambval(); + sprintf(op, " -av %.2g %.2g %.2g", d, d, d); + op += strlen(op); + op = addarg(op, "-lr 3"); + op = addarg(op, "-lw .02"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } -medqopts(ro) /* medium quality rendering options */ -char *ro; +medqopts(op) /* medium quality rendering options */ +register char *op; { - register char *op = ro; + double d, org[3], siz[3]; *op = '\0'; + if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], + &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) { + fprintf(stderr, "%s: bad value for variable '%s'\n", + progname, vnam(ZONE)); + exit(1); + } + siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + getoctcube(org, &d); + d *= 3./(siz[0]+siz[1]+siz[2]); + switch (vscale(DETAIL)) { + case LOW: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8"); + op = addarg(op, "-dp 64"); + sprintf(op, " -ar %d", (int)(8*d)); + op += strlen(op); + break; + case MEDIUM: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6"); + op = addarg(op, "-dp 128"); + sprintf(op, " -ar %d", (int)(16*d)); + op += strlen(op); + break; + case HIGH: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4"); + op = addarg(op, "-dp 256"); + sprintf(op, " -ar %d", (int)(32*d)); + op += strlen(op); + break; + } + op = addarg(op, "-pt .08"); + if (vbool(PENUMBRAS)) { + op = addarg(op, "-ds .2"); + op = addarg(op, "-dj .35"); + } else + op = addarg(op, "-ds .3"); + op = addarg(op, "-dt .1"); + op = addarg(op, "-dc .5"); + op = addarg(op, "-dr 1"); + op = addarg(op, "-sj .7"); + op = addarg(op, "-st .15"); + sprintf(op, " -ab %d", overture=vint(INDIRECT)); + op += strlen(op); + if (vdef(AMBFILE)) { + sprintf(op, " -af %s", vval(AMBFILE)); + op += strlen(op); + } else + overture = 0; + switch (vscale(VARIABILITY)) { + case LOW: + op = addarg(op, "-aa .25"); + op = addarg(op, "-ad 128"); + op = addarg(op, "-as 0"); + break; + case MEDIUM: + op = addarg(op, "-aa .2"); + op = addarg(op, "-ad 300"); + op = addarg(op, "-as 64"); + break; + case HIGH: + op = addarg(op, "-aa .15"); + op = addarg(op, "-ad 500"); + op = addarg(op, "-as 128"); + break; + } + d = ambval(); + sprintf(op, " -av %.2g %.2g %.2g", d, d, d); + op += strlen(op); + op = addarg(op, "-lr 6"); + op = addarg(op, "-lw .002"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } -hiqopts(ro) /* high quality rendering options */ -char *ro; +hiqopts(op) /* high quality rendering options */ +register char *op; { - register char *op = ro; + double d, org[3], siz[3]; *op = '\0'; + if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], + &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) { + fprintf(stderr, "%s: bad value for variable '%s'\n", + progname, vnam(ZONE)); + exit(1); + } + siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + getoctcube(org, &d); + d *= 3./(siz[0]+siz[1]+siz[2]); + switch (vscale(DETAIL)) { + case LOW: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8"); + op = addarg(op, "-dp 256"); + sprintf(op, " -ar %d", (int)(16*d)); + op += strlen(op); + break; + case MEDIUM: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5"); + op = addarg(op, "-dp 512"); + sprintf(op, " -ar %d", (int)(32*d)); + op += strlen(op); + break; + case HIGH: + op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3"); + op = addarg(op, "-dp 1024"); + sprintf(op, " -ar %d", (int)(64*d)); + op += strlen(op); + break; + } + op = addarg(op, "-pt .04"); + if (vbool(PENUMBRAS)) { + op = addarg(op, "-ds .1"); + op = addarg(op, "-dj .7"); + } else + op = addarg(op, "-ds .2"); + op = addarg(op, "-dt .05"); + op = addarg(op, "-dc .75"); + op = addarg(op, "-dr 3"); + op = addarg(op, "-sj 1"); + op = addarg(op, "-st .03"); + sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); + op += strlen(op); + if (vdef(AMBFILE)) { + sprintf(op, " -af %s", vval(AMBFILE)); + op += strlen(op); + } else + overture = 0; + switch (vscale(VARIABILITY)) { + case LOW: + op = addarg(op, "-aa .15"); + op = addarg(op, "-ad 200"); + op = addarg(op, "-as 0"); + break; + case MEDIUM: + op = addarg(op, "-aa .125"); + op = addarg(op, "-ad 512"); + op = addarg(op, "-as 128"); + break; + case HIGH: + op = addarg(op, "-aa .08"); + op = addarg(op, "-ad 850"); + op = addarg(op, "-as 256"); + break; + } + d = ambval(); + sprintf(op, " -av %.2g %.2g %.2g", d, d, d); + op += strlen(op); + op = addarg(op, "-lr 12"); + op = addarg(op, "-lw .0005"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -611,7 +838,11 @@ char *ro; } strcpy(evp, "ROPT="); strcat(evp, ro); - putenv(evp); + if (putenv(evp) != 0) { + fprintf(stderr, "%s: out of environment space\n", + progname); + exit(1); + } strcpy(ro, " $ROPT"); } #endif @@ -689,9 +920,9 @@ register char *vs; progname); exit(1); } - dim[0] -= cent[0]; - dim[1] -= cent[1]; - dim[2] -= cent[2]; + dim[0] -= cent[0]; cent[0] += .5*dim[0]; + dim[1] -= cent[1]; cent[1] += .5*dim[1]; + dim[2] -= cent[2]; cent[2] += .5*dim[2]; exterior = vlet(ZONE) == 'E'; mult = exterior ? 2. : .45 ; sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g", @@ -809,7 +1040,7 @@ char *opts; rpict(opts) /* run rpict and pfilt for each view */ char *opts; { - char combuf[512]; + char combuf[1024]; char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH], res[32]; char pfopts[64]; char vs[32], *vw;
