Revision: 2.54
Committed: Fri Jan 23 15:15:59 1998 UTC (27 years, 6 months ago) by gregl
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include "vars.h"
14 #include <ctype.h>
15 #include <sys/types.h>
16
17 /* variables */
18 #define OBJECT 0 /* object files */
19 #define SCENE 1 /* scene files */
20 #define MATERIAL 2 /* material files */
21 #define ILLUM 3 /* mkillum input files */
22 #define MKILLUM 4 /* mkillum options */
23 #define RENDER 5 /* rendering options */
24 #define OCONV 6 /* oconv options */
25 #define PFILT 7 /* pfilt options */
26 #define VIEW 8 /* view(s) for picture(s) */
27 #define ZONE 9 /* simulation zone */
28 #define QUALITY 10 /* desired rendering quality */
29 #define OCTREE 11 /* octree file name */
30 #define PICTURE 12 /* picture file root name */
31 #define AMBFILE 13 /* ambient file name */
32 #define OPTFILE 14 /* rendering options file */
33 #define EXPOSURE 15 /* picture exposure setting */
34 #define RESOLUTION 16 /* maximum picture resolution */
35 #define UP 17 /* view up (X, Y or Z) */
36 #define INDIRECT 18 /* indirection in lighting */
37 #define DETAIL 19 /* level of scene detail */
38 #define PENUMBRAS 20 /* shadow penumbras are desired */
39 #define VARIABILITY 21 /* level of light variability */
40 #define REPORT 22 /* report frequency and errfile */
41 #define RAWFILE 23 /* raw picture file root name */
42 #define ZFILE 24 /* distance file root name */
43 /* total number of variables */
44 int NVARS = 25;
45
46 VARIABLE vv[] = { /* variable-value pairs */
47 {"objects", 3, 0, NULL, catvalues},
48 {"scene", 3, 0, NULL, catvalues},
49 {"materials", 3, 0, NULL, catvalues},
50 {"illum", 3, 0, NULL, catvalues},
51 {"mkillum", 3, 0, NULL, catvalues},
52 {"render", 3, 0, NULL, catvalues},
53 {"oconv", 3, 0, NULL, catvalues},
54 {"pfilt", 2, 0, NULL, catvalues},
55 {"view", 2, 0, NULL, NULL},
56 {"ZONE", 2, 0, NULL, onevalue},
57 {"QUALITY", 3, 0, NULL, qualvalue},
58 {"OCTREE", 3, 0, NULL, onevalue},
59 {"PICTURE", 3, 0, NULL, onevalue},
60 {"AMBFILE", 3, 0, NULL, onevalue},
61 {"OPTFILE", 3, 0, NULL, onevalue},
62 {"EXPOSURE", 3, 0, NULL, fltvalue},
63 {"RESOLUTION", 3, 0, NULL, onevalue},
64 {"UP", 2, 0, NULL, onevalue},
65 {"INDIRECT", 3, 0, NULL, intvalue},
66 {"DETAIL", 3, 0, NULL, qualvalue},
67 {"PENUMBRAS", 3, 0, NULL, boolvalue},
68 {"VARIABILITY", 3, 0, NULL, qualvalue},
69 {"REPORT", 3, 0, NULL, onevalue},
70 {"RAWFILE", 3, 0, NULL, onevalue},
71 {"ZFILE", 2, 0, NULL, onevalue},
72 };
73
74 /* overture calculation file */
75 #ifdef NIX
76 char overfile[] = "overture.unf";
77 #else
78 char overfile[] = "/dev/null";
79 #endif
80
81 extern time_t fdate(), time();
82
83 time_t scenedate; /* date of latest scene or object file */
84 time_t octreedate; /* date of octree */
85 time_t matdate; /* date of latest material file */
86 time_t illumdate; /* date of last illum file */
87
88 char *oct0name; /* name of pre-mkillum octree */
89 time_t oct0date; /* date of pre-mkillum octree */
90 char *oct1name; /* name of post-mkillum octree */
91 time_t oct1date; /* date of post-mkillum octree (>= matdate) */
92
93 int nowarn = 0; /* no warnings */
94 int explicate = 0; /* explicate variables */
95 int silent = 0; /* do work silently */
96 int touchonly = 0; /* touch files only */
97 int noaction = 0; /* don't do anything */
98 int sayview = 0; /* print view out */
99 char *rvdevice = NULL; /* rview output device */
100 char *viewselect = NULL; /* specific view only */
101
102 int overture = 0; /* overture calculation needed */
103
104 char *progname; /* global argv[0] */
105 char *rifname; /* global rad input file name */
106
107 char radname[MAXPATH]; /* root Radiance file name */
108
109
110 main(argc, argv)
111 int argc;
112 char *argv[];
113 {
114 char ropts[512];
115 char popts[64];
116 int i;
117
118 progname = argv[0];
119 /* get options */
120 for (i = 1; i < argc && argv[i][0] == '-'; i++)
121 switch (argv[i][1]) {
122 case 's':
123 silent++;
124 break;
125 case 'n':
126 noaction++;
127 break;
128 case 't':
129 touchonly++;
130 break;
131 case 'e':
132 explicate++;
133 break;
134 case 'o':
135 rvdevice = argv[++i];
136 break;
137 case 'V':
138 sayview++;
139 break;
140 case 'v':
141 viewselect = argv[++i];
142 break;
143 case 'w':
144 nowarn++;
145 break;
146 default:
147 goto userr;
148 }
149 if (i >= argc)
150 goto userr;
151 rifname = argv[i];
152 /* assign Radiance root file name */
153 rootname(radname, rifname);
154 /* load variable values */
155 loadvars(rifname);
156 /* get any additional assignments */
157 for (i++; i < argc; i++)
158 if (setvariable(argv[i], matchvar) < 0) {
159 fprintf(stderr, "%s: unknown variable: %s\n",
160 progname, argv[i]);
161 quit(1);
162 }
163 /* check assignments */
164 checkvalues();
165 /* check files and dates */
166 checkfiles();
167 /* set default values as necessary */
168 setdefaults();
169 /* print all values if requested */
170 if (explicate)
171 printvars(stdout);
172 /* build octree (and run mkillum) */
173 oconv();
174 /* check date on ambient file */
175 checkambfile();
176 /* run simulation */
177 renderopts(ropts, popts);
178 xferopts(ropts);
179 if (rvdevice != NULL)
180 rview(ropts, popts);
181 else
182 rpict(ropts, popts);
183 quit(0);
184 userr:
185 fprintf(stderr,
186 "Usage: %s [-s][-n][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
187 progname);
188 quit(1);
189 }
190
191
192 rootname(rn, fn) /* remove tail from end of fn */
193 register char *rn, *fn;
194 {
195 char *tp, *dp;
196
197 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
198 if (ISDIRSEP(*rn))
199 dp = rn;
200 else if (*rn == '.')
201 tp = rn;
202 if (tp != NULL && tp > dp)
203 *tp = '\0';
204 }
205
206
207 time_t
208 checklast(fnames) /* check files and find most recent */
209 register char *fnames;
210 {
211 char thisfile[MAXPATH];
212 time_t thisdate, lastdate = 0;
213 register char *cp;
214
215 if (fnames == NULL)
216 return(0);
217 while (*fnames) {
218 while (isspace(*fnames)) fnames++;
219 cp = thisfile;
220 while (*fnames && !isspace(*fnames))
221 *cp++ = *fnames++;
222 *cp = '\0';
223 if (!(thisdate = fdate(thisfile)))
224 syserr(thisfile);
225 if (thisdate > lastdate)
226 lastdate = thisdate;
227 }
228 return(lastdate);
229 }
230
231
232 char *
233 newfname(orig, pred) /* create modified file name */
234 char *orig;
235 int pred;
236 {
237 extern char *rindex();
238 register char *cp;
239 register int n;
240 int suffix;
241
242 n = 0; cp = orig; suffix = -1; /* suffix position, length */
243 while (*cp) {
244 if (*cp == '.') suffix = n;
245 else if (ISDIRSEP(*cp)) suffix = -1;
246 cp++; n++;
247 }
248 if (suffix == -1) suffix = n;
249 if ((cp = bmalloc(n+2)) == NULL)
250 syserr(progname);
251 strncpy(cp, orig, suffix);
252 cp[suffix] = pred; /* root name + pred + suffix */
253 strcpy(cp+suffix+1, orig+suffix);
254 return(cp);
255 }
256
257
258 checkfiles() /* check for existence and modified times */
259 {
260 time_t objdate;
261
262 if (!vdef(OCTREE)) {
263 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
264 syserr(progname);
265 sprintf(vval(OCTREE), "%s.oct", radname);
266 vdef(OCTREE)++;
267 }
268 octreedate = fdate(vval(OCTREE));
269 if (vdef(ILLUM)) { /* illum requires secondary octrees */
270 oct0name = newfname(vval(OCTREE), '0');
271 oct1name = newfname(vval(OCTREE), '1');
272 oct0date = fdate(oct0name);
273 oct1date = fdate(oct1name);
274 } else
275 oct0name = oct1name = vval(OCTREE);
276 if ((scenedate = checklast(vval(SCENE))) &&
277 (objdate = checklast(vval(OBJECT))) > scenedate)
278 scenedate = objdate;
279 illumdate = checklast(vval(ILLUM));
280 if (!octreedate & !scenedate & !illumdate) {
281 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
282 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
283 quit(1);
284 }
285 matdate = checklast(vval(MATERIAL));
286 }
287
288
289 getoctcube(org, sizp) /* get octree bounding cube */
290 double org[3], *sizp;
291 {
292 extern FILE *popen();
293 static double oorg[3], osiz = 0.;
294 double min[3], max[3];
295 char buf[1024];
296 FILE *fp;
297 register int i;
298
299 if (osiz <= FTINY)
300 if (noaction && fdate(oct1name) <
301 (scenedate>illumdate?scenedate:illumdate)) {
302 /* run getbbox */
303 sprintf(buf, "getbbox -w -h %s",
304 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
305 if ((fp = popen(buf, "r")) == NULL)
306 syserr("getbbox");
307 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
308 &min[0], &max[0], &min[1], &max[1],
309 &min[2], &max[2]) != 6) {
310 fprintf(stderr,
311 "%s: error reading bounding box from getbbox\n",
312 progname);
313 quit(1);
314 }
315 for (i = 0; i < 3; i++)
316 if (max[i] - min[i] > osiz)
317 osiz = max[i] - min[i];
318 for (i = 0; i < 3; i++)
319 oorg[i] = (max[i]+min[i]-osiz)*.5;
320 pclose(fp);
321 } else { /* from octree */
322 oconv(); /* does nothing if done already */
323 sprintf(buf, "getinfo -d < %s", oct1name);
324 if ((fp = popen(buf, "r")) == NULL)
325 syserr("getinfo");
326 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
327 &oorg[2], &osiz) != 4) {
328 fprintf(stderr,
329 "%s: error reading bounding cube from getinfo\n",
330 progname);
331 quit(1);
332 }
333 pclose(fp);
334 }
335 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
336 }
337
338
339 setdefaults() /* set default values for unassigned var's */
340 {
341 double org[3], size;
342 char buf[128];
343
344 if (!vdef(ZONE)) {
345 getoctcube(org, &size);
346 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
347 org[1], org[1]+size, org[2], org[2]+size);
348 vval(ZONE) = savqstr(buf);
349 vdef(ZONE)++;
350 }
351 if (!vdef(INDIRECT)) {
352 vval(INDIRECT) = "0";
353 vdef(INDIRECT)++;
354 }
355 if (!vdef(QUALITY)) {
356 vval(QUALITY) = "L";
357 vdef(QUALITY)++;
358 }
359 if (!vdef(RESOLUTION)) {
360 vval(RESOLUTION) = "512";
361 vdef(RESOLUTION)++;
362 }
363 if (!vdef(PICTURE)) {
364 vval(PICTURE) = radname;
365 vdef(PICTURE)++;
366 }
367 if (!vdef(VIEW)) {
368 vval(VIEW) = "X";
369 vdef(VIEW)++;
370 }
371 if (!vdef(DETAIL)) {
372 vval(DETAIL) = "M";
373 vdef(DETAIL)++;
374 }
375 if (!vdef(PENUMBRAS)) {
376 vval(PENUMBRAS) = "F";
377 vdef(PENUMBRAS)++;
378 }
379 if (!vdef(VARIABILITY)) {
380 vval(VARIABILITY) = "L";
381 vdef(VARIABILITY)++;
382 }
383 }
384
385
386 oconv() /* run oconv and mkillum if necessary */
387 {
388 static char illumtmp[] = "ilXXXXXX";
389 char combuf[1024], ocopts[64], mkopts[64];
390
391 oconvopts(ocopts); /* get options */
392 if (octreedate < scenedate) { /* check date on original octree */
393 if (touchonly && octreedate)
394 touch(vval(OCTREE));
395 else { /* build command */
396 if (vdef(MATERIAL))
397 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
398 vval(MATERIAL), vval(SCENE),
399 vval(OCTREE));
400 else
401 sprintf(combuf, "oconv%s %s > %s", ocopts,
402 vval(SCENE), vval(OCTREE));
403
404 if (runcom(combuf)) { /* run it */
405 fprintf(stderr,
406 "%s: error generating octree\n\t%s removed\n",
407 progname, vval(OCTREE));
408 unlink(vval(OCTREE));
409 quit(1);
410 }
411 }
412 octreedate = time((time_t *)NULL);
413 if (octreedate < scenedate) /* in case clock is off */
414 octreedate = scenedate;
415 }
416 if (oct1name == vval(OCTREE)) /* no mkillum? */
417 oct1date = octreedate > matdate ? octreedate : matdate;
418 if (oct1date >= octreedate & oct1date >= matdate
419 & oct1date >= illumdate) /* all done */
420 return;
421 /* make octree0 */
422 if (oct0date < scenedate | oct0date < illumdate) {
423 if (touchonly && oct0date)
424 touch(oct0name);
425 else { /* build command */
426 if (octreedate)
427 sprintf(combuf, "oconv%s -i %s %s > %s", ocopts,
428 vval(OCTREE), vval(ILLUM), oct0name);
429 else if (vdef(MATERIAL))
430 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
431 vval(MATERIAL), vval(ILLUM), oct0name);
432 else
433 sprintf(combuf, "oconv%s %s > %s", ocopts,
434 vval(ILLUM), oct0name);
435 if (runcom(combuf)) { /* run it */
436 fprintf(stderr,
437 "%s: error generating octree\n\t%s removed\n",
438 progname, oct0name);
439 unlink(oct0name);
440 quit(1);
441 }
442 }
443 oct0date = time((time_t *)NULL);
444 if (oct0date < octreedate) /* in case clock is off */
445 oct0date = octreedate;
446 if (oct0date < illumdate) /* ditto */
447 oct0date = illumdate;
448 }
449 if (touchonly && oct1date)
450 touch(oct1name);
451 else {
452 mkillumopts(mkopts); /* build mkillum command */
453 mktemp(illumtmp);
454 sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts,
455 oct0name, vval(ILLUM), illumtmp);
456 if (runcom(combuf)) { /* run it */
457 fprintf(stderr, "%s: error running mkillum\n",
458 progname);
459 unlink(illumtmp);
460 quit(1);
461 }
462 /* make octree1 (frozen) */
463 if (octreedate)
464 sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts,
465 vval(OCTREE), illumtmp, oct1name);
466 else if (vdef(MATERIAL))
467 sprintf(combuf, "oconv%s -f %s %s > %s", ocopts,
468 vval(MATERIAL), illumtmp, oct1name);
469 else
470 sprintf(combuf, "oconv%s -f %s > %s", ocopts,
471 illumtmp, oct1name);
472 if (runcom(combuf)) { /* run it */
473 fprintf(stderr,
474 "%s: error generating octree\n\t%s removed\n",
475 progname, oct1name);
476 unlink(oct1name);
477 unlink(illumtmp);
478 quit(1);
479 }
480 rmfile(illumtmp);
481 }
482 oct1date = time((time_t *)NULL);
483 if (oct1date < oct0date) /* in case clock is off */
484 oct1date = oct0date;
485 }
486
487
488 char *
489 addarg(op, arg) /* add argument and advance pointer */
490 register char *op, *arg;
491 {
492 *op = ' ';
493 while (*++op = *arg++)
494 ;
495 return(op);
496 }
497
498
499 oconvopts(oo) /* get oconv options */
500 register char *oo;
501 {
502 /* BEWARE: This may be called via setdefaults(), so no assumptions */
503
504 *oo = '\0';
505 if (vdef(OCONV))
506 addarg(oo, vval(OCONV));
507 }
508
509
510 mkillumopts(mo) /* get mkillum options */
511 register char *mo;
512 {
513 /* BEWARE: This may be called via setdefaults(), so no assumptions */
514
515 *mo = '\0';
516 if (vdef(MKILLUM))
517 addarg(mo, vval(MKILLUM));
518 }
519
520
521 checkambfile() /* check date on ambient file */
522 {
523 time_t afdate;
524
525 if (!vdef(AMBFILE))
526 return;
527 if (!(afdate = fdate(vval(AMBFILE))))
528 return;
529 if (oct1date > afdate)
530 if (touchonly)
531 touch(vval(AMBFILE));
532 else
533 rmfile(vval(AMBFILE));
534 }
535
536
537 double
538 ambval() /* compute ambient value */
539 {
540 if (vdef(EXPOSURE)) {
541 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
542 return(.5/pow(2.,vflt(EXPOSURE)));
543 return(.5/vflt(EXPOSURE));
544 }
545 if (vlet(ZONE) == 'E')
546 return(10.);
547 if (vlet(ZONE) == 'I')
548 return(.01);
549 badvalue(ZONE);
550 }
551
552
553 renderopts(op, po) /* set rendering options */
554 char *op, *po;
555 {
556 switch(vscale(QUALITY)) {
557 case LOW:
558 lowqopts(op, po);
559 break;
560 case MEDIUM:
561 medqopts(op, po);
562 break;
563 case HIGH:
564 hiqopts(op, po);
565 break;
566 }
567 }
568
569
570 lowqopts(op, po) /* low quality rendering options */
571 register char *op;
572 char *po;
573 {
574 double d, org[3], siz[3];
575
576 *op = '\0';
577 *po = '\0';
578 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
579 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
580 badvalue(ZONE);
581 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
582 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
583 badvalue(ZONE);
584 getoctcube(org, &d);
585 d *= 3./(siz[0]+siz[1]+siz[2]);
586 switch (vscale(DETAIL)) {
587 case LOW:
588 po = addarg(po, "-ps 16");
589 op = addarg(op, "-dp 64");
590 sprintf(op, " -ar %d", (int)(4*d));
591 op += strlen(op);
592 break;
593 case MEDIUM:
594 po = addarg(po, "-ps 8");
595 op = addarg(op, "-dp 128");
596 sprintf(op, " -ar %d", (int)(8*d));
597 op += strlen(op);
598 break;
599 case HIGH:
600 po = addarg(po, "-ps 4");
601 op = addarg(op, "-dp 256");
602 sprintf(op, " -ar %d", (int)(16*d));
603 op += strlen(op);
604 break;
605 }
606 po = addarg(po, "-pt .16");
607 if (vbool(PENUMBRAS))
608 op = addarg(op, "-ds .4");
609 else
610 op = addarg(op, "-ds 0");
611 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
612 if (vdef(AMBFILE)) {
613 sprintf(op, " -af %s", vval(AMBFILE));
614 op += strlen(op);
615 } else
616 overture = 0;
617 switch (vscale(VARIABILITY)) {
618 case LOW:
619 op = addarg(op, "-aa .4 -ad 64");
620 break;
621 case MEDIUM:
622 op = addarg(op, "-aa .3 -ad 128");
623 break;
624 case HIGH:
625 op = addarg(op, "-aa .25 -ad 256");
626 break;
627 }
628 op = addarg(op, "-as 0");
629 d = ambval();
630 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
631 op += strlen(op);
632 op = addarg(op, "-lr 3 -lw .02");
633 if (vdef(RENDER))
634 op = addarg(op, vval(RENDER));
635 }
636
637
638 medqopts(op, po) /* medium quality rendering options */
639 register char *op;
640 char *po;
641 {
642 double d, org[3], siz[3], asz;
643
644 *op = '\0';
645 *po = '\0';
646 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
647 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
648 badvalue(ZONE);
649 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
650 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
651 badvalue(ZONE);
652 getoctcube(org, &d);
653 asz = (siz[0]+siz[1]+siz[2])/3.;
654 d /= asz;
655 switch (vscale(DETAIL)) {
656 case LOW:
657 po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
658 op = addarg(op, "-dp 256");
659 sprintf(op, " -ar %d", (int)(8*d));
660 op += strlen(op);
661 sprintf(op, " -ms %.2g", asz/20.);
662 op += strlen(op);
663 break;
664 case MEDIUM:
665 po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
666 op = addarg(op, "-dp 512");
667 sprintf(op, " -ar %d", (int)(16*d));
668 op += strlen(op);
669 sprintf(op, " -ms %.2g", asz/40.);
670 op += strlen(op);
671 break;
672 case HIGH:
673 po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
674 op = addarg(op, "-dp 1024");
675 sprintf(op, " -ar %d", (int)(32*d));
676 op += strlen(op);
677 sprintf(op, " -ms %.2g", asz/80.);
678 op += strlen(op);
679 break;
680 }
681 po = addarg(po, "-pt .08");
682 if (vbool(PENUMBRAS))
683 op = addarg(op, "-ds .2 -dj .5");
684 else
685 op = addarg(op, "-ds .3");
686 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
687 if (overture = vint(INDIRECT)) {
688 sprintf(op, " -ab %d", overture);
689 op += strlen(op);
690 }
691 if (vdef(AMBFILE)) {
692 sprintf(op, " -af %s", vval(AMBFILE));
693 op += strlen(op);
694 } else
695 overture = 0;
696 switch (vscale(VARIABILITY)) {
697 case LOW:
698 op = addarg(op, "-aa .25 -ad 196 -as 0");
699 break;
700 case MEDIUM:
701 op = addarg(op, "-aa .2 -ad 400 -as 64");
702 break;
703 case HIGH:
704 op = addarg(op, "-aa .15 -ad 768 -as 196");
705 break;
706 }
707 d = ambval();
708 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
709 op += strlen(op);
710 op = addarg(op, "-lr 6 -lw .002");
711 if (vdef(RENDER))
712 op = addarg(op, vval(RENDER));
713 }
714
715
716 hiqopts(op, po) /* high quality rendering options */
717 register char *op;
718 char *po;
719 {
720 double d, org[3], siz[3], asz;
721
722 *op = '\0';
723 *po = '\0';
724 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
725 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
726 badvalue(ZONE);
727 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
728 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
729 badvalue(ZONE);
730 getoctcube(org, &d);
731 asz = (siz[0]+siz[1]+siz[2])/3.;
732 d /= asz;
733 switch (vscale(DETAIL)) {
734 case LOW:
735 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
736 op = addarg(op, "-dp 1024");
737 sprintf(op, " -ar %d", (int)(16*d));
738 op += strlen(op);
739 sprintf(op, " -ms %.2g", asz/40.);
740 op += strlen(op);
741 break;
742 case MEDIUM:
743 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
744 op = addarg(op, "-dp 2048");
745 sprintf(op, " -ar %d", (int)(32*d));
746 op += strlen(op);
747 sprintf(op, " -ms %.2g", asz/80.);
748 op += strlen(op);
749 break;
750 case HIGH:
751 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
752 op = addarg(op, "-dp 4096");
753 sprintf(op, " -ar %d", (int)(64*d));
754 op += strlen(op);
755 sprintf(op, " -ms %.2g", asz/160.);
756 op += strlen(op);
757 break;
758 }
759 po = addarg(po, "-pt .04");
760 if (vbool(PENUMBRAS))
761 op = addarg(op, "-ds .1 -dj .65");
762 else
763 op = addarg(op, "-ds .2");
764 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
765 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
766 op += strlen(op);
767 if (vdef(AMBFILE)) {
768 sprintf(op, " -af %s", vval(AMBFILE));
769 op += strlen(op);
770 } else
771 overture = 0;
772 switch (vscale(VARIABILITY)) {
773 case LOW:
774 op = addarg(op, "-aa .15 -ad 256 -as 0");
775 break;
776 case MEDIUM:
777 op = addarg(op, "-aa .125 -ad 512 -as 256");
778 break;
779 case HIGH:
780 op = addarg(op, "-aa .08 -ad 1024 -as 512");
781 break;
782 }
783 d = ambval();
784 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
785 op += strlen(op);
786 op = addarg(op, "-lr 12 -lw .0005");
787 if (vdef(RENDER))
788 op = addarg(op, vval(RENDER));
789 }
790
791
792 xferopts(ro) /* transfer options if indicated */
793 char *ro;
794 {
795 int fd, n;
796 register char *cp;
797
798 n = strlen(ro);
799 if (n < 2)
800 return;
801 if (vdef(OPTFILE)) {
802 for (cp = ro; cp[1]; cp++)
803 if (isspace(cp[1]) && (cp[2] == '@' ||
804 (cp[2] == '-' && isalpha(cp[3]))))
805 *cp = '\n';
806 else
807 *cp = cp[1];
808 *cp = '\n';
809 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
810 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
811 syserr(vval(OPTFILE));
812 sprintf(ro, " @%s", vval(OPTFILE));
813 }
814 #ifdef MSDOS
815 else if (n > 50) {
816 setenv("ROPT", ro+1);
817 strcpy(ro, " $ROPT");
818 }
819 #endif
820 }
821
822
823 pfiltopts(po) /* get pfilt options */
824 register char *po;
825 {
826 *po = '\0';
827 if (vdef(EXPOSURE)) {
828 po = addarg(po, "-1 -e");
829 po = addarg(po, vval(EXPOSURE));
830 }
831 switch (vscale(QUALITY)) {
832 case MEDIUM:
833 po = addarg(po, "-r 1");
834 break;
835 case HIGH:
836 po = addarg(po, "-m .25");
837 break;
838 }
839 if (vdef(PFILT))
840 po = addarg(po, vval(PFILT));
841 }
842
843
844 matchword(s1, s2) /* match white-delimited words */
845 register char *s1, *s2;
846 {
847 while (isspace(*s1)) s1++;
848 while (isspace(*s2)) s2++;
849 while (*s1 && !isspace(*s1))
850 if (*s1++ != *s2++)
851 return(0);
852 return(!*s2 || isspace(*s2));
853 }
854
855
856 char *
857 specview(vs) /* get proper view spec from vs */
858 register char *vs;
859 {
860 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
861 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
862 static char viewopts[128];
863 register char *cp;
864 int xpos, ypos, zpos, viewtype, upax;
865 register int i;
866 double cent[3], dim[3], mult, d;
867
868 if (vs == NULL || *vs == '-')
869 return(vs);
870 upax = 0; /* get the up vector */
871 if (vdef(UP)) {
872 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
873 upax = 1-'X'+UPPER(vval(UP)[1]);
874 else
875 upax = 1-'X'+vlet(UP);
876 if (upax < 1 | upax > 3)
877 badvalue(UP);
878 if (vval(UP)[0] == '-')
879 upax = -upax;
880 }
881 /* check standard view names */
882 xpos = ypos = zpos = 0;
883 if (*vs == 'X') {
884 xpos = 1; vs++;
885 } else if (*vs == 'x') {
886 xpos = -1; vs++;
887 }
888 if (*vs == 'Y') {
889 ypos = 1; vs++;
890 } else if (*vs == 'y') {
891 ypos = -1; vs++;
892 }
893 if (*vs == 'Z') {
894 zpos = 1; vs++;
895 } else if (*vs == 'z') {
896 zpos = -1; vs++;
897 }
898 viewtype = 'v';
899 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h' | *vs == 'c')
900 viewtype = *vs++;
901 cp = viewopts;
902 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
903 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
904 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
905 &cent[0], &dim[0], &cent[1], &dim[1],
906 &cent[2], &dim[2]) != 6)
907 badvalue(ZONE);
908 for (i = 0; i < 3; i++) {
909 dim[i] -= cent[i];
910 if (dim[i] <= FTINY)
911 badvalue(ZONE);
912 cent[i] += .5*dim[i];
913 }
914 mult = vlet(ZONE)=='E' ? 2. : .45 ;
915 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
916 cent[0]+xpos*mult*dim[0],
917 cent[1]+ypos*mult*dim[1],
918 cent[2]+zpos*mult*dim[2],
919 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
920 cp += strlen(cp);
921 /* redirect up axis if necessary */
922 switch (upax) {
923 case 3: /* plus or minus Z axis */
924 case -3:
925 case 0:
926 if (!(xpos|ypos))
927 upax = 2;
928 break;
929 case 2: /* plus or minus Y axis */
930 case -2:
931 if (!(xpos|zpos))
932 upax = 1;
933 break;
934 case 1: /* plus or minus X axis */
935 case -1:
936 if (!(ypos|zpos))
937 upax = 3;
938 break;
939 }
940 cp = addarg(cp, vup[upax+3]);
941 switch (viewtype) {
942 case 'v':
943 cp = addarg(cp, "-vh 45 -vv 45");
944 break;
945 case 'l':
946 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
947 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
948 cp += strlen(cp);
949 break;
950 case 'a':
951 case 'h':
952 cp = addarg(cp, "-vh 180 -vv 180");
953 break;
954 case 'c':
955 cp = addarg(cp, "-vh 180 -vv 90");
956 break;
957 }
958 } else {
959 while (!isspace(*vs)) /* else skip id */
960 if (!*vs++)
961 return(NULL);
962 if (upax) { /* specify up vector */
963 strcpy(cp, vup[upax+3]);
964 cp += strlen(cp);
965 }
966 }
967 if (cp == viewopts) /* append any additional options */
968 vs++; /* skip prefixed space if unneeded */
969 strcpy(cp, vs);
970 #ifdef MSDOS
971 if (strlen(viewopts) > 40) {
972 setenv("VIEW", viewopts);
973 return("$VIEW");
974 }
975 #endif
976 return(viewopts);
977 }
978
979
980 char *
981 getview(n, vn) /* get view n, or NULL if none */
982 int n;
983 char *vn; /* returned view name */
984 {
985 register char *mv;
986
987 if (viewselect != NULL) { /* command-line selected */
988 if (n) /* only do one */
989 return(NULL);
990 if (viewselect[0] == '-') { /* already specified */
991 if (vn != NULL) *vn = '\0';
992 return(viewselect);
993 }
994 if (vn != NULL) {
995 for (mv = viewselect; *mv && !isspace(*mv);
996 *vn++ = *mv++)
997 ;
998 *vn = '\0';
999 }
1000 /* view number? */
1001 if (isint(viewselect))
1002 return(specview(nvalue(VIEW, atoi(viewselect)-1)));
1003 /* check list */
1004 while ((mv = nvalue(VIEW, n++)) != NULL)
1005 if (matchword(viewselect, mv))
1006 return(specview(mv));
1007 return(specview(viewselect)); /* standard view? */
1008 }
1009 mv = nvalue(VIEW, n); /* use view n */
1010 if (vn != NULL & mv != NULL) {
1011 register char *mv2 = mv;
1012 if (*mv2 != '-')
1013 while (*mv2 && !isspace(*mv2))
1014 *vn++ = *mv2++;
1015 *vn = '\0';
1016 }
1017 return(specview(mv));
1018 }
1019
1020
1021 printview(vopts) /* print out selected view */
1022 register char *vopts;
1023 {
1024 extern char *atos(), *getenv();
1025 char buf[256];
1026 FILE *fp;
1027 register char *cp;
1028
1029 if (vopts == NULL)
1030 return(-1);
1031 fputs("VIEW=", stdout);
1032 do {
1033 if (matchword(vopts, "-vf")) { /* expand view file */
1034 vopts = sskip(vopts);
1035 if (!*atos(buf, sizeof(buf), vopts))
1036 return(-1);
1037 if ((fp = fopen(buf, "r")) == NULL)
1038 return(-1);
1039 for (buf[sizeof(buf)-2] = '\n';
1040 fgets(buf, sizeof(buf), fp) != NULL &&
1041 buf[0] != '\n';
1042 buf[sizeof(buf)-2] = '\n') {
1043 if (buf[sizeof(buf)-2] != '\n') {
1044 ungetc(buf[sizeof(buf)-2], fp);
1045 buf[sizeof(buf)-2] = '\0';
1046 }
1047 if (matchword(buf, "VIEW=") ||
1048 matchword(buf, "rview")) {
1049 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1050 putchar(*cp);
1051 }
1052 }
1053 fclose(fp);
1054 vopts = sskip(vopts);
1055 } else {
1056 while (isspace(*vopts))
1057 vopts++;
1058 putchar(' ');
1059 #ifdef MSDOS
1060 if (*vopts == '$') { /* expand env. var. */
1061 if (!*atos(buf, sizeof(buf), vopts+1))
1062 return(-1);
1063 if ((cp = getenv(buf)) == NULL)
1064 return(-1);
1065 fputs(cp, stdout);
1066 vopts = sskip(vopts);
1067 } else
1068 #endif
1069 while (*vopts && !isspace(*vopts))
1070 putchar(*vopts++);
1071 }
1072 } while (*vopts++);
1073 putchar('\n');
1074 return(0);
1075 }
1076
1077
1078 rview(opts, po) /* run rview with first view */
1079 char *opts, *po;
1080 {
1081 char *vw;
1082 char combuf[512];
1083 /* build command */
1084 if (touchonly || (vw = getview(0, NULL)) == NULL)
1085 return;
1086 if (sayview)
1087 printview(vw);
1088 sprintf(combuf, "rview %s%s%s -R %s ", vw, po, opts, rifname);
1089 if (rvdevice != NULL)
1090 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1091 if (vdef(EXPOSURE))
1092 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1093 strcat(combuf, oct1name);
1094 if (runcom(combuf)) { /* run it */
1095 fprintf(stderr, "%s: error running rview\n", progname);
1096 quit(1);
1097 }
1098 }
1099
1100
1101 rpict(opts, po) /* run rpict and pfilt for each view */
1102 char *opts, *po;
1103 {
1104 char combuf[1024];
1105 char rawfile[MAXPATH], picfile[MAXPATH];
1106 char zopt[MAXPATH+4], rep[MAXPATH+16], res[32];
1107 char pfopts[128];
1108 char vs[32], *vw;
1109 int vn, mult;
1110 time_t rfdt, pfdt;
1111 /* get pfilt options */
1112 pfiltopts(pfopts);
1113 /* get resolution, reporting */
1114 switch (vscale(QUALITY)) {
1115 case LOW:
1116 mult = 1;
1117 break;
1118 case MEDIUM:
1119 mult = 2;
1120 break;
1121 case HIGH:
1122 mult = 3;
1123 break;
1124 }
1125 {
1126 int xres, yres;
1127 double aspect;
1128 int n;
1129 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1130 if (n == 3)
1131 sprintf(res, "-x %d -y %d -pa %.3f",
1132 mult*xres, mult*yres, aspect);
1133 else if (n) {
1134 if (n == 1) yres = xres;
1135 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1136 } else
1137 badvalue(RESOLUTION);
1138 }
1139 rep[0] = '\0';
1140 if (vdef(REPORT)) {
1141 double minutes;
1142 int n;
1143 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1144 if (n == 2)
1145 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1146 else if (n == 1)
1147 sprintf(rep, " -t %d", (int)(minutes*60));
1148 else
1149 badvalue(REPORT);
1150 }
1151 /* do each view */
1152 vn = 0;
1153 while ((vw = getview(vn++, vs)) != NULL) {
1154 if (sayview)
1155 printview(vw);
1156 if (!vs[0])
1157 sprintf(vs, "%d", vn);
1158 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1159 if (vdef(ZFILE))
1160 sprintf(zopt, " -z %s_%s.zbf", vval(ZFILE), vs);
1161 else
1162 zopt[0] = '\0';
1163 /* check date on picture */
1164 pfdt = fdate(picfile);
1165 if (pfdt >= oct1date)
1166 continue;
1167 /* get raw file name */
1168 sprintf(rawfile, "%s_%s.unf",
1169 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE), vs);
1170 rfdt = fdate(rawfile);
1171 if (touchonly) { /* update times only */
1172 if (rfdt) {
1173 if (rfdt < oct1date)
1174 touch(rawfile);
1175 } else if (pfdt && pfdt < oct1date)
1176 touch(picfile);
1177 continue;
1178 }
1179 /* build rpict command */
1180 if (rfdt >= oct1date) /* recover */
1181 sprintf(combuf, "rpict%s%s%s%s -ro %s %s",
1182 rep, po, opts, zopt, rawfile, oct1name);
1183 else {
1184 if (overture) { /* run overture calculation */
1185 sprintf(combuf,
1186 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1187 rep, vw, opts,
1188 oct1name, overfile);
1189 if (runcom(combuf)) {
1190 fprintf(stderr,
1191 "%s: error in overture for view %s\n",
1192 progname, vs);
1193 quit(1);
1194 }
1195 #ifdef NIX
1196 rmfile(overfile);
1197 #endif
1198 }
1199 sprintf(combuf, "rpict%s %s %s%s%s%s %s > %s",
1200 rep, vw, res, po, opts, zopt,
1201 oct1name, rawfile);
1202 }
1203 if (runcom(combuf)) { /* run rpict */
1204 fprintf(stderr, "%s: error rendering view %s\n",
1205 progname, vs);
1206 quit(1);
1207 }
1208 if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) {
1209 /* build pfilt command */
1210 if (mult > 1)
1211 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1212 pfopts, mult, mult, rawfile, picfile);
1213 else
1214 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1215 rawfile, picfile);
1216 if (runcom(combuf)) { /* run pfilt */
1217 fprintf(stderr,
1218 "%s: error filtering view %s\n\t%s removed\n",
1219 progname, vs, picfile);
1220 unlink(picfile);
1221 quit(1);
1222 }
1223 }
1224 /* remove/rename raw file */
1225 if (vdef(RAWFILE)) {
1226 sprintf(combuf, "%s_%s.pic", vval(RAWFILE), vs);
1227 mvfile(rawfile, combuf);
1228 } else
1229 rmfile(rawfile);
1230 }
1231 }
1232
1233
1234 touch(fn) /* update a file */
1235 char *fn;
1236 {
1237 if (!silent)
1238 printf("\ttouch %s\n", fn);
1239 if (noaction)
1240 return(0);
1241 #ifdef notused
1242 if (access(fn, F_OK) == -1) /* create it */
1243 if (close(open(fn, O_WRONLY|O_CREAT, 0666)) == -1)
1244 return(-1);
1245 #endif
1246 return(setfdate(fn, time((time_t *)NULL)));
1247 }
1248
1249
1250 runcom(cs) /* run command */
1251 char *cs;
1252 {
1253 if (!silent) /* echo it */
1254 printf("\t%s\n", cs);
1255 if (noaction)
1256 return(0);
1257 fflush(stdout); /* flush output and pass to shell */
1258 return(system(cs));
1259 }
1260
1261
1262 rmfile(fn) /* remove a file */
1263 char *fn;
1264 {
1265 if (!silent)
1266 #ifdef MSDOS
1267 printf("\tdel %s\n", fn);
1268 #else
1269 printf("\trm -f %s\n", fn);
1270 #endif
1271 if (noaction)
1272 return(0);
1273 return(unlink(fn));
1274 }
1275
1276
1277 mvfile(fold, fnew) /* move a file */
1278 char *fold, *fnew;
1279 {
1280 if (!silent)
1281 #ifdef MSDOS
1282 printf("\trename %s %s\n", fold, fnew);
1283 #else
1284 printf("\tmv %s %s\n", fold, fnew);
1285 #endif
1286 if (noaction)
1287 return(0);
1288 return(rename(fold, fnew));
1289 }
1290
1291
1292 #ifdef MSDOS
1293 setenv(vname, value) /* set an environment variable */
1294 char *vname, *value;
1295 {
1296 register char *evp;
1297
1298 evp = bmalloc(strlen(vname)+strlen(value)+2);
1299 if (evp == NULL)
1300 syserr(progname);
1301 sprintf(evp, "%s=%s", vname, value);
1302 if (putenv(evp) != 0) {
1303 fprintf(stderr, "%s: out of environment space\n", progname);
1304 quit(1);
1305 }
1306 if (!silent)
1307 printf("set %s\n", evp);
1308 }
1309 #endif
1310
1311
1312 badvalue(vc) /* report bad variable value and exit */
1313 int vc;
1314 {
1315 fprintf(stderr, "%s: bad value for variable '%s'\n",
1316 progname, vnam(vc));
1317 quit(1);
1318 }
1319
1320
1321 syserr(s) /* report a system error and exit */
1322 char *s;
1323 {
1324 perror(s);
1325 quit(1);
1326 }
1327
1328
1329 quit(ec) /* exit program */
1330 int ec;
1331 {
1332 exit(ec);
1333 }
