Revision 2.135 - (view) (download) (annotate) - [select for diffs]
Sat Jun 7 05:09:46 2025 UTC (7 weeks, 4 days ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.134: +1 -2 lines
Diff to previous 2.134 , to selected 2.99
Revision 2.134 - (view) (download) (annotate) - [select for diffs]
Tue Jun 3 21:31:51 2025 UTC (8 weeks ago) by greg
Changes since 2.133: +3 -4 lines
Diff to previous 2.133 , to selected 2.99
Revision 2.133 - (view) (download) (annotate) - [select for diffs]
Mon Dec 23 01:39:27 2024 UTC (7 months ago) by greg
Changes since 2.132: +4 -3 lines
Diff to previous 2.132 , to selected 2.99
feat(rad): Increased command-line length limits
Revision 2.132 - (view) (download) (annotate) - [select for diffs]
Thu Nov 16 23:37:29 2023 UTC (20 months, 1 week ago) by greg
Changes since 2.131: +3 -3 lines
Diff to previous 2.131 , to selected 2.99
fix(rad): added "rpict" options to overture calculation as needed for hyperspectral ambient file
Revision 2.131 - (view) (download) (annotate) - [select for diffs]
Sat Jun 10 15:49:55 2023 UTC (2 years, 1 month ago) by greg
Changes since 2.130: +9 -9 lines
Diff to previous 2.130 , to selected 2.99
feat(rad,ranimate): Improved handling of quoted strings for file names
Revision 2.130 - (view) (download) (annotate) - [select for diffs]
Tue Jan 24 21:54:49 2023 UTC (2 years, 6 months ago) by greg
Changes since 2.129: +3 -3 lines
Diff to previous 2.129 , to selected 2.99
Revision 2.129 - (view) (download) (annotate) - [select for diffs]
Sun Feb 6 17:19:55 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.128: +10 -4 lines
Diff to previous 2.128 , to selected 2.99
feat(rad): added report of unknown setting on command line
Revision 2.128 - (view) (download) (annotate) - [select for diffs]
Thu Jan 21 21:36:28 2021 UTC (4 years, 6 months ago) by greg
Changes since 2.127: +3 -3 lines
Diff to previous 2.127 , to selected 2.99
perf: changed default setting of ambient value
Revision 2.127 - (view) (download) (annotate) - [select for diffs]
Tue Apr 7 00:49:09 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.126: +6 -2 lines
Diff to previous 2.126 , to selected 2.99
Disable overture calculation if -aa 0 set in render options
Revision 2.126 - (view) (download) (annotate) - [select for diffs]
Tue Feb 26 23:31:11 2019 UTC (6 years, 5 months ago) by greg
Changes since 2.125: +6 -5 lines
Diff to previous 2.125 , to selected 2.99
Stop build of unneeded intermediate octree for mkillum
Revision 2.125 - (view) (download) (annotate) - [select for diffs]
Tue Jun 7 16:53:19 2016 UTC (9 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.124: +5 -2 lines
Diff to previous 2.124 , to selected 2.99
Added -n option to mkpmap
Revision 2.124 - (view) (download) (annotate) - [select for diffs]
Sun Mar 6 01:13:18 2016 UTC (9 years, 4 months ago) by schorsch
Changes since 2.123: +7 -7 lines
Diff to previous 2.123 , to selected 2.99
Revision 2.123 - (view) (download) (annotate) - [select for diffs]
Wed Oct 28 02:52:17 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.122: +4 -3 lines
Diff to previous 2.122 , to selected 2.99
Fixed potential problem following mktemp() failure
Revision 2.122 - (view) (download) (annotate) - [select for diffs]
Thu Oct 22 18:09:37 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.121: +2 -1 lines
Diff to previous 2.121 , to selected 2.99
Fixed problem with global photon map argument (garbage characters)
Revision 2.121 - (view) (download) (annotate) - [select for diffs]
Wed Sep 2 18:59:26 2015 UTC (9 years, 10 months ago) by greg
Changes since 2.120: +7 -7 lines
Diff to previous 2.120 , to selected 2.99
Changed ordering of options to put caustic photon map ahead of -ab setting
Revision 2.120 - (view) (download) (annotate) - [select for diffs]
Sun Aug 2 01:32:15 2015 UTC (10 years ago) by greg
Changes since 2.119: +7 -4 lines
Diff to previous 2.119 , to selected 2.99
Minor compiler warnings fixed
Revision 2.119 - (view) (download) (annotate) - [select for diffs]
Sat Aug 1 23:27:04 2015 UTC (10 years ago) by greg
Changes since 2.118: +2 -1 lines
Diff to previous 2.118 , to selected 2.99
Revision 2.118 - (view) (download) (annotate) - [select for diffs]
Wed May 27 14:32:35 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.117: +3 -5 lines
Diff to previous 2.117 , to selected 2.99
Changed to using mkpmap -fo+ option (duh!)
Revision 2.117 - (view) (download) (annotate) - [select for diffs]
Wed May 27 14:26:04 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.116: +5 -3 lines
Diff to previous 2.116 , to selected 2.99
Need to report photon map removal
Revision 2.116 - (view) (download) (annotate) - [select for diffs]
Wed May 27 14:22:02 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.115: +3 -1 lines
Diff to previous 2.115 , to selected 2.99
Need to remove photon maps prior to updating
Revision 2.115 - (view) (download) (annotate) - [select for diffs]
Wed May 27 14:12:09 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.114: +3 -3 lines
Diff to previous 2.114 , to selected 2.99
Only remove photon map(s) related to job
Revision 2.114 - (view) (download) (annotate) - [select for diffs]
Wed May 27 13:29:57 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.113: +1 -4 lines
Diff to previous 2.113 , to selected 2.99
Removed warning about setting PCMAP without PGMAP
Revision 2.113 - (view) (download) (annotate) - [select for diffs]
Wed May 27 12:50:46 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.112: +4 -4 lines
Diff to previous 2.112 , to selected 2.99
Made a little smarter about only generating photon maps that are out of date
Revision 2.112 - (view) (download) (annotate) - [select for diffs]
Tue May 26 10:00:47 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.111: +173 -34 lines
Diff to previous 2.111 , to selected 2.99
Revision 2.111 - (view) (download) (annotate) - [select for diffs]
Sun Oct 26 17:35:53 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.110: +2 -1 lines
Diff to previous 2.110 , to selected 2.99
Wed Dec 4 20:07:07 2013 UTC (11 years, 7 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Changes since 2.109: +3 -3 lines
Diff to previous 2.109 , to selected 2.99
Fri Nov 8 18:08:07 2013 UTC (11 years, 8 months ago) by greg
Changes since 2.108: +47 -43 lines
Diff to previous 2.108 , to selected 2.99
Minor fixes that should not affect operation
Mon Aug 12 21:01:00 2013 UTC (11 years, 11 months ago) by greg
Changes since 2.107: +2 -1 lines
Diff to previous 2.107 , to selected 2.99
Remove intermediate octree for mkillum run
Fri Aug 26 22:39:56 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.106: +4 -4 lines
Diff to previous 2.106 , to selected 2.99
Minor changes
Wed Aug 24 05:54:42 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.105: +33 -2 lines
Diff to previous 2.105 , to selected 2.99
Added check of incomplete rendering from rpiece
Fri Feb 25 06:51:51 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.104: +4 -4 lines
Diff to previous 2.104 , to selected 2.99
Decreased -lw default
Sat Jan 29 16:44:20 2011 UTC (14 years, 6 months ago) by greg
Changes since 2.103: +20 -17 lines
Diff to previous 2.103 , to selected 2.99
Corrected problem with image size when using rpiece
Sun Oct 10 15:36:18 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.102: +5 -2 lines
Diff to previous 2.102 , to selected 2.99
Need to remove outdated rpiece output
Sun Oct 10 09:25:45 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.101: +11 -4 lines
Diff to previous 2.101 , to selected 2.99
Avoid possible overwrite of previous partial output by rpiece
Sat Oct 9 17:14:01 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.100: +13 -16 lines
Diff to previous 2.100 , to selected 2.99
Changed overture calculation with rpiece to use single process
Fri Oct 8 23:06:53 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.99: +3 -3 lines
Diff to previous 2.99
Increased specular sampling for high quality setting
Revision 2.99 - (view) (download) (annotate) - [selected]
Fri Oct 8 22:11:57 2010 UTC (14 years, 9 months ago) by greg
Changes since 2.98: +4 -4 lines
Diff to previous 2.98
Changed -sj option to -ss
Sun Sep 12 18:42:40 2010 UTC (14 years, 10 months ago) by greg
Changes since 2.97: +10 -11 lines
Diff to previous 2.97 , to selected 2.99
Minor code clean-up -- should not affect behavior
Fri May 28 17:29:14 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.96: +9 -1 lines
Diff to previous 2.96 , to selected 2.99
Added multi-processing for single-view overture calculation
Tue May 18 18:57:27 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.95: +2 -2 lines
Diff to previous 2.95 , to selected 2.99
Minor fix to last change
Tue May 18 18:54:35 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.94: +6 -2 lines
Diff to previous 2.94 , to selected 2.99
Added echo of writing to sync file for rpiece
Tue May 18 04:24:17 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.93: +8 -12 lines
Diff to previous 2.93 , to selected 2.99
Minor tweaks to last change with -N and rpiece
Tue May 18 00:01:02 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.92: +83 -33 lines
Diff to previous 2.92 , to selected 2.99
Mon Feb 9 16:41:29 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.91: +16 -10 lines
Diff to previous 2.91 , to selected 2.99
Thu Dec 18 23:26:57 2008 UTC (16 years, 7 months ago) by greg
Changes since 2.90: +92 -55 lines
Diff to previous 2.90 , to selected 2.99
Fri Dec 12 15:49:48 2008 UTC (16 years, 7 months ago) by greg
Diff to previous 2.89 , to selected 2.99
Corrected new setting of -dj for PEN=T and QUA=Hi
Sat Dec 6 01:08:53 2008 UTC (16 years, 7 months ago) by greg
Changes since 2.88: +2 -2 lines
Diff to previous 2.88 , to selected 2.99
Fri Dec 5 00:51:59 2008 UTC (16 years, 7 months ago) by greg
Diff to previous 2.87 , to selected 2.99
Fixed resetting of number of processes with view passed to rvu
Mon Nov 10 19:08:19 2008 UTC (16 years, 8 months ago) by greg
Changes since 2.86: +3 -3 lines
Diff to previous 2.86 , to selected 2.99
Thu Aug 21 07:05:59 2008 UTC (16 years, 11 months ago) by greg
Changes since 2.85: +3 -1 lines
Diff to previous 2.85 , to selected 2.99
Mon Apr 21 07:31:30 2008 UTC (17 years, 3 months ago) by schorsch
Changes since 2.84: +5 -4 lines
Diff to previous 2.84 , to selected 2.99
Scons update for mingw.
Tue Mar 11 12:42:07 2008 UTC (17 years, 4 months ago) by greg
Changes since 2.83: +19 -9 lines
Diff to previous 2.83 , to selected 2.99
Switched to using defined view types
Tue Mar 11 02:21:47 2008 UTC (17 years, 4 months ago) by greg
Diff to previous 2.82 , to selected 2.99
Thu Dec 8 17:06:11 2005 UTC (19 years, 7 months ago) by greg
Changes since 2.81: +5 -7 lines
Diff to previous 2.81 , to selected 2.99
Added some additional (and probably unnecessary) fflush() calls
Mon Sep 12 14:40:13 2005 UTC (19 years, 10 months ago) by schorsch
Changes since 2.80: +5 -5 lines
Diff to previous 2.80 , to selected 2.99
Using RT_PID instead of int.
Sat Oct 23 18:55:53 2004 UTC (20 years, 9 months ago) by schorsch
Diff to previous 2.79 , to selected 2.99
Mon Oct 4 04:42:33 2004 UTC (20 years, 10 months ago) by greg
Diff to previous 2.78 , to selected 2.99
Fri Sep 17 21:43:50 2004 UTC (20 years, 10 months ago) by greg
Diff to previous 2.77 , to selected 2.99
Thu Sep 9 20:08:21 2004 UTC (20 years, 10 months ago) by greg
Diff to previous 2.76 , to selected 2.99
Fri Mar 26 21:36:19 2004 UTC (21 years, 4 months ago) by schorsch
Diff to previous 2.75 , to selected 2.99
Continued ANSIfication.
Thu Jan 1 19:31:46 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 2.74 , to selected 2.99
Mon Oct 27 10:32:06 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.73 , to selected 2.99
Sat Oct 18 04:46:24 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.72 , to selected 2.99
Minor comment changes
Wed Sep 24 14:55:54 2003 UTC (21 years, 10 months ago) by greg
Diff to previous 2.71 , to selected 2.99
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Diff to previous 2.70 , to selected 2.99
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Diff to previous 2.69 , to selected 2.99
Mon Jul 14 20:02:30 2003 UTC (22 years ago) by schorsch
Diff to previous 2.68 , to selected 2.99
Thu Jul 3 22:41:45 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.67 , to selected 2.99
Thu Jul 3 18:03:58 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.66 , to selected 2.99
Thu Jul 3 15:00:19 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.65 , to selected 2.99
Mon Jun 30 14:59:13 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.64 , to selected 2.99
Thu Jun 26 00:58:11 2003 UTC (22 years, 1 month ago) by schorsch
Diff to previous 2.63 , to selected 2.99
Thu Jun 5 19:29:35 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 2.62 , to selected 2.99
Fri Mar 21 18:48:46 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 2.61 , to selected 2.99
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.60 , to selected 2.99
Tue Feb 2 08:57:56 1999 UTC (26 years, 6 months ago) by gwlarson
Diff to previous 2.59 , to selected 2.99
Tue Jan 19 17:46:13 1999 UTC (26 years, 6 months ago) by gwlarson
Diff to previous 2.58 , to selected 2.99
Mon Oct 19 16:21:41 1998 UTC (26 years, 9 months ago) by gwlarson
Diff to previous 2.57 , to selected 2.99
Wed Jun 10 17:51:06 1998 UTC (27 years, 1 month ago) by gwlarson
Diff to previous 2.56 , to selected 2.99
Wed Jun 3 16:37:51 1998 UTC (27 years, 2 months ago) by gwlarson
Diff to previous 2.55 , to selected 2.99
Fri Jan 23 17:17:32 1998 UTC (27 years, 6 months ago) by gregl
Diff to previous 2.54 , to selected 2.99
Fri Jan 23 15:15:59 1998 UTC (27 years, 6 months ago) by gregl
Diff to previous 2.53 , to selected 2.99
Thu Mar 20 12:50:07 1997 UTC (28 years, 4 months ago) by greg
Diff to previous 2.52 , to selected 2.99
Wed Feb 14 16:34:05 1996 UTC (29 years, 5 months ago) by greg
Diff to previous 2.51 , to selected 2.99
Wed Jan 17 10:22:06 1996 UTC (29 years, 6 months ago) by greg
Diff to previous 2.50 , to selected 2.99
changed parameter to nvalue()
Fri Jan 5 14:43:03 1996 UTC (29 years, 7 months ago) by greg
Diff to previous 2.49 , to selected 2.99
added vflt() macro
Tue Dec 12 15:13:32 1995 UTC (29 years, 7 months ago) by greg
Diff to previous 2.48 , to selected 2.99
Tue Dec 12 13:30:14 1995 UTC (29 years, 7 months ago) by greg
Diff to previous 2.47 , to selected 2.99
Fri Dec 8 19:55:50 1995 UTC (29 years, 7 months ago) by greg
Diff to previous 2.46 , to selected 2.99
Tue Nov 7 18:22:24 1995 UTC (29 years, 8 months ago) by greg
Diff to previous 2.45 , to selected 2.99
Mon Aug 28 10:12:40 1995 UTC (29 years, 11 months ago) by greg
Diff to previous 2.44 , to selected 2.99
added ZFILE variable to rad
Fri Aug 18 10:39:56 1995 UTC (29 years, 11 months ago) by greg
Diff to previous 2.43 , to selected 2.99
added cylindrical view type
Thu Jul 6 12:15:40 1995 UTC (30 years, 1 month ago) by greg
Diff to previous 2.42 , to selected 2.99
Fri Dec 23 09:20:06 1994 UTC (30 years, 7 months ago) by greg
Diff to previous 2.41 , to selected 2.99
Mon Oct 24 13:49:16 1994 UTC (30 years, 9 months ago) by greg
Diff to previous 2.40 , to selected 2.99
added -t (touch) option
Thu Apr 21 12:22:44 1994 UTC (31 years, 3 months ago) by greg
Diff to previous 2.39 , to selected 2.99
Thu Mar 24 12:28:22 1994 UTC (31 years, 4 months ago) by greg
Diff to previous 2.38 , to selected 2.99
Sat Jan 1 12:12:32 1994 UTC (31 years, 7 months ago) by greg
Diff to previous 2.37 , to selected 2.99
Sat Jan 1 09:16:50 1994 UTC (31 years, 7 months ago) by greg
Diff to previous 2.36 , to selected 2.99
Thu Dec 30 08:20:45 1993 UTC (31 years, 7 months ago) by greg
Diff to previous 2.35 , to selected 2.99
Tue Nov 23 09:26:38 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.34 , to selected 2.99
compatibility fixes
Thu Nov 18 13:28:30 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.33 , to selected 2.99
fixed PC bug in time() call
Thu Nov 18 10:00:21 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.32 , to selected 2.99
fixed minor compiler warning
Tue Nov 16 11:44:08 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.31 , to selected 2.99
Thu Nov 11 13:17:01 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.30 , to selected 2.99
Thu Nov 11 10:20:06 1993 UTC (31 years, 8 months ago) by greg
Diff to previous 2.29 , to selected 2.99
Sat Oct 30 10:47:05 1993 UTC (31 years, 9 months ago) by greg
Diff to previous 2.28 , to selected 2.99
added -pe option to rview
Thu Oct 28 11:48:29 1993 UTC (31 years, 9 months ago) by greg
Diff to previous 2.27 , to selected 2.99
Sat Sep 25 13:21:35 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.26 , to selected 2.99
Fri Sep 24 16:49:02 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.25 , to selected 2.99
Wed Sep 15 15:11:47 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.24 , to selected 2.99
Thu Sep 9 13:07:13 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.23 , to selected 2.99
fixed view echoing for MS-DOS
Tue Sep 7 11:57:04 1993 UTC (31 years, 10 months ago) by greg
Diff to previous 2.22 , to selected 2.99
Wed Aug 25 13:48:37 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.21 , to selected 2.99
added -R option to rview
Tue Aug 24 22:14:21 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.20 , to selected 2.99
Tue Aug 24 21:44:55 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.19 , to selected 2.99
Tue Aug 24 20:29:22 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.18 , to selected 2.99
Fri Aug 13 09:19:30 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.17 , to selected 2.99
Mon Aug 9 17:50:09 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.16 , to selected 2.99
Thu Jul 22 12:39:51 1993 UTC (32 years ago) by greg
Diff to previous 2.15 , to selected 2.99
Fri Jul 16 12:41:21 1993 UTC (32 years ago) by greg
Diff to previous 2.14 , to selected 2.99
Thu Jul 15 18:32:57 1993 UTC (32 years ago) by greg
Diff to previous 2.13 , to selected 2.99
Fri Jul 2 14:50:49 1993 UTC (32 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.99
Fri Jun 25 17:35:49 1993 UTC (32 years, 1 month ago) by greg
Diff to previous 2.11 , to selected 2.99
Mon Jun 14 10:49:08 1993 UTC (32 years, 1 month ago) by greg
Diff to previous 2.10 , to selected 2.99
Thu May 27 17:41:46 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 2.99
Wed May 26 11:37:42 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.8 , to selected 2.99
Tue May 18 13:07:56 1993 UTC (32 years, 2 months ago) by greg
Diff to previous 2.7 , to selected 2.99
Tue Apr 6 17:21:04 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.6 , to selected 2.99
Tue Mar 30 13:16:26 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.5 , to selected 2.99
Sat Mar 13 09:33:17 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.4 , to selected 2.99
Fri Mar 12 13:37:03 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.3 , to selected 2.99
Thu Mar 11 17:23:33 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.2 , to selected 2.99
Thu Mar 11 11:39:48 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 2.99
Thu Mar 11 09:11:00 1993 UTC (32 years, 4 months ago) by greg
Diff to selected 2.99
