--- ray/src/util/rad.c 1993/03/11 17:23:33 2.3 +++ ray/src/util/rad.c 1993/04/06 17:21:04 2.7 @@ -94,6 +94,13 @@ int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; #define renderopts (*setqopts[vscale(QUALITY)]) + /* overture calculation file */ +#ifdef NIX +char overfile[] = "overture.raw"; +#else +char overfile[] = "/dev/null"; +#endif + extern long fdate(), time(); long scenedate; /* date of latest scene or object file */ @@ -159,8 +166,11 @@ char *argv[]; /* print all values if requested */ if (explicate) printvals(); - /* run simulation */ + /* build octree */ oconv(); + /* check date on ambient file */ + checkambfile(); + /* run simulation */ renderopts(ropts); xferopts(ropts); if (rvdevice != NULL) @@ -195,7 +205,7 @@ load(rfname) /* load Radiance simulation file */ char *rfname; { FILE *fp; - char buf[256]; + char buf[512]; register char *cp; if (rfname == NULL) @@ -212,6 +222,8 @@ char *rfname; case '#': *cp = '\0'; break; + default: + continue; } break; } @@ -260,12 +272,15 @@ register char *ass; exit(1); } /* assign new value */ - cp = vp->value; i = vp->nass; - while (i--) - while (*cp++) - ; - i = cp - vp->value; - vp->value = realloc(vp->value, i+n+1); + if (i = vp->nass) { + cp = vp->value; + while (i--) + while (*cp++) + ; + i = cp - vp->value; + vp->value = realloc(vp->value, i+n+1); + } else + vp->value = malloc(n+1); if (vp->value == NULL) syserr(progname); strcpy(vp->value+i, ass); @@ -369,7 +384,8 @@ register char *fnames; while (*fnames) { while (isspace(*fnames)) fnames++; cp = thisfile; - while (*fnames && !isspace(*fnames)) *cp++ = *fnames++; + while (*fnames && !isspace(*fnames)) + *cp++ = *fnames++; *cp = '\0'; if ((thisdate = fdate(thisfile)) < 0) syserr(thisfile); @@ -488,8 +504,8 @@ printvals() /* print variable values */ register int i, j; for (i = 0; i < NVARS; i++) - for (j = 0; j < vv[i].nass; j++) - printf("%s= %s\n", vv[i].name, nvalue(vv+i, j)); + for (j = 0; j < vdef(i); j++) + printf("%s= %s\n", vnam(i), nvalue(vv+i, j)); fflush(stdout); } @@ -502,16 +518,14 @@ oconv() /* run oconv if necessary */ return; /* build command */ oconvopts(ocopts); - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vdef(MATERIAL) ? vval(MATERIAL) : "", - vval(SCENE), vval(OCTREE)); - if (!silent) { /* echo it */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (noaction) - return; - if (system(combuf)) { /* run it */ + if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(SCENE), vval(OCTREE)); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(SCENE), vval(OCTREE)); + + if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error generating octree\n\t%s removed\n", progname, vval(OCTREE)); unlink(vval(OCTREE)); @@ -543,6 +557,18 @@ register char *oo; } +checkambfile() /* check date on ambient file */ +{ + long afdate; + + if (vdef(AMBFILE)) { + afdate = fdate(vval(AMBFILE)); + if (afdate >= 0 & octreedate > afdate) + rmfile(vval(AMBFILE)); + } +} + + double ambval() /* compute ambient value */ { @@ -575,20 +601,17 @@ register char *op; d *= 3./(siz[0]+siz[1]+siz[2]); switch (vscale(DETAIL)) { case LOW: - op = addarg(op, "-ps 16"); - op = addarg(op, "-dp 16"); + op = addarg(op, "-ps 16 -dp 16"); sprintf(op, " -ar %d", (int)(4*d)); op += strlen(op); break; case MEDIUM: - op = addarg(op, "-ps 8"); - op = addarg(op, "-dp 32"); + op = addarg(op, "-ps 8 -dp 32"); sprintf(op, " -ar %d", (int)(8*d)); op += strlen(op); break; case HIGH: - op = addarg(op, "-ps 4"); - op = addarg(op, "-dp 64"); + op = addarg(op, "-ps 4 -dp 64"); sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); break; @@ -596,12 +619,9 @@ register char *op; op = addarg(op, "-pt .16"); if (vbool(PENUMBRAS)) op = addarg(op, "-ds .4"); - op = addarg(op, "-dt .2"); - op = addarg(op, "-dc .25"); - op = addarg(op, "-dr 0"); - op = addarg(op, "-sj 0"); - op = addarg(op, "-st .7"); - op = addarg(op, "-ab 0"); + else + op = addarg(op, "-ds 0"); + op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .7"); if (vdef(AMBFILE)) { sprintf(op, " -af %s", vval(AMBFILE)); op += strlen(op); @@ -609,24 +629,20 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .4"); - op = addarg(op, "-ad 32"); + op = addarg(op, "-aa .4 -ad 32"); break; case MEDIUM: - op = addarg(op, "-aa .3"); - op = addarg(op, "-ad 64"); + op = addarg(op, "-aa .3 -ad 64"); break; case HIGH: - op = addarg(op, "-aa .25"); - op = addarg(op, "-ad 128"); + op = addarg(op, "-aa .25 -ad 128"); break; } op = addarg(op, "-as 0"); d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 3"); - op = addarg(op, "-lw .02"); + op = addarg(op, "-lr 3 -lw .02"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -665,18 +681,15 @@ register char *op; break; } op = addarg(op, "-pt .08"); - if (vbool(PENUMBRAS)) { - op = addarg(op, "-ds .2"); - op = addarg(op, "-dj .35"); - } else + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .2 -dj .35"); + else op = addarg(op, "-ds .3"); - op = addarg(op, "-dt .1"); - op = addarg(op, "-dc .5"); - op = addarg(op, "-dr 1"); - op = addarg(op, "-sj .7"); - op = addarg(op, "-st .15"); - sprintf(op, " -ab %d", overture=vint(INDIRECT)); - op += strlen(op); + op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .15"); + if (overture = vint(INDIRECT)) { + sprintf(op, " -ab %d", overture); + op += strlen(op); + } if (vdef(AMBFILE)) { sprintf(op, " -af %s", vval(AMBFILE)); op += strlen(op); @@ -684,26 +697,19 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .25"); - op = addarg(op, "-ad 128"); - op = addarg(op, "-as 0"); + op = addarg(op, "-aa .25 -ad 128 -as 0"); break; case MEDIUM: - op = addarg(op, "-aa .2"); - op = addarg(op, "-ad 300"); - op = addarg(op, "-as 64"); + op = addarg(op, "-aa .2 -ad 300 -as 64"); break; case HIGH: - op = addarg(op, "-aa .15"); - op = addarg(op, "-ad 500"); - op = addarg(op, "-as 128"); + op = addarg(op, "-aa .15 -ad 500 -as 128"); break; } d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 6"); - op = addarg(op, "-lw .002"); + op = addarg(op, "-lr 6 -lw .002"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -742,16 +748,11 @@ register char *op; break; } op = addarg(op, "-pt .04"); - if (vbool(PENUMBRAS)) { - op = addarg(op, "-ds .1"); - op = addarg(op, "-dj .7"); - } else + if (vbool(PENUMBRAS)) + op = addarg(op, "-ds .1 -dj .7"); + else op = addarg(op, "-ds .2"); - op = addarg(op, "-dt .05"); - op = addarg(op, "-dc .75"); - op = addarg(op, "-dr 3"); - op = addarg(op, "-sj 1"); - op = addarg(op, "-st .03"); + op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .03"); sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); op += strlen(op); if (vdef(AMBFILE)) { @@ -761,26 +762,19 @@ register char *op; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .15"); - op = addarg(op, "-ad 200"); - op = addarg(op, "-as 0"); + op = addarg(op, "-aa .15 -ad 200 -as 0"); break; case MEDIUM: - op = addarg(op, "-aa .125"); - op = addarg(op, "-ad 512"); - op = addarg(op, "-as 128"); + op = addarg(op, "-aa .125 -ad 512 -as 128"); break; case HIGH: - op = addarg(op, "-aa .08"); - op = addarg(op, "-ad 850"); - op = addarg(op, "-as 256"); + op = addarg(op, "-aa .08 -ad 850 -as 256"); break; } d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 12"); - op = addarg(op, "-lw .0005"); + op = addarg(op, "-lr 12 -lw .0005"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } @@ -801,9 +795,7 @@ char *ro; syserr(vval(OPTFILE)); write(fd, "\n", 1); close(fd); - ro[0] = ' '; - ro[1] = '^'; - strcpy(ro+2, vval(OPTFILE)); + sprintf(ro, " \"^%s\"", vval(OPTFILE)); } #ifdef MSDOS else if (n > 50) { @@ -948,8 +940,9 @@ register char *vs; break; } } else { - while (*vs && !isspace(*vs)) /* else skip id */ - vs++; + while (!isspace(*vs)) /* else skip id */ + if (!*vs++) + return(NULL); if (upax) { /* specify up vector */ strcpy(cp, vup[upax+3]); cp += strlen(cp); @@ -1006,13 +999,7 @@ char *opts; if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); strcat(combuf, vval(OCTREE)); - if (!silent) { /* echo it */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (noaction) - return; - if (system(combuf)) { /* run it */ + if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error running rview\n", progname); exit(1); } @@ -1057,20 +1044,6 @@ char *opts; else badvalue(REPORT); } - /* check date on ambient file */ - if (vdef(AMBFILE)) { - long afdate = fdate(vval(AMBFILE)); - if (afdate >= 0 & octreedate > afdate) { - if (!silent) -#ifdef MSDOS - printf("\tdel %s\n", vval(AMBFILE)); -#else - printf("\trm %s\n", vval(AMBFILE)); -#endif - if (!noaction) - unlink(vval(AMBFILE)); - } - } /* do each view */ vn = 0; while ((vw = getview(vn++, vs)) != NULL) { @@ -1090,28 +1063,22 @@ char *opts; sprintf(combuf, "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s", rep, vw, opts, - vval(OCTREE), rawfile); - if (!silent) { - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { + vval(OCTREE), overfile); + if (runcom(combuf)) { fprintf(stderr, - "%s: error in overture for view %s\n\t%s removed\n", - progname, vs, rawfile); - unlink(rawfile); + "%s: error in overture for view %s\n", + progname, vs); exit(1); } +#ifdef NIX + rmfile(overfile); +#endif } sprintf(combuf, "rpict%s %s %s%s %s > %s", rep, vw, res, opts, vval(OCTREE), rawfile); } - if (!silent) { /* echo rpict command */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { /* run rpict */ + if (runcom(combuf)) { /* run rpict */ fprintf(stderr, "%s: error rendering view %s\n", progname, vs); exit(1); @@ -1123,11 +1090,7 @@ char *opts; else sprintf(combuf, "pfilt%s %s > %s", pfopts, rawfile, picfile); - if (!silent) { /* echo pfilt command */ - printf("\t%s\n", combuf); - fflush(stdout); - } - if (!noaction && system(combuf)) { /* run pfilt */ + if (runcom(combuf)) { /* run pfilt */ fprintf(stderr, "%s: error filtering view %s\n\t%s removed\n", progname, vs, picfile); @@ -1135,15 +1098,35 @@ char *opts; exit(1); } /* remove raw file */ - if (!silent) + rmfile(rawfile); + } +} + + +runcom(cs) /* run command */ +char *cs; +{ + if (!silent) /* echo it */ + printf("\t%s\n", cs); + if (noaction) + return(0); + fflush(stdout); /* flush output and pass to shell */ + return(system(cs)); +} + + +rmfile(fn) /* remove a file */ +char *fn; +{ + if (!silent) #ifdef MSDOS - printf("\tdel %s\n", rawfile); + printf("\tdel %s\n", fn); #else - printf("\trm %s\n", rawfile); + printf("\trm -f %s\n", fn); #endif - if (!noaction) - unlink(rawfile); - } + if (noaction) + return(0); + return(unlink(fn)); }
