Revision: 2.50
Committed: Fri Jan 5 14:43:03 1996 UTC (28 years, 5 months ago) by greg
added vflt() macro
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include "vars.h"
14 #include <ctype.h>
15 #include <sys/types.h>
16
17 /* variables */
18 #define OBJECT 0 /* object files */
19 #define SCENE 1 /* scene files */
20 #define MATERIAL 2 /* material files */
21 #define ILLUM 3 /* mkillum input files */
22 #define MKILLUM 4 /* mkillum options */
23 #define RENDER 5 /* rendering options */
24 #define OCONV 6 /* oconv options */
25 #define PFILT 7 /* pfilt options */
26 #define VIEW 8 /* view(s) for picture(s) */
27 #define ZONE 9 /* simulation zone */
28 #define QUALITY 10 /* desired rendering quality */
29 #define OCTREE 11 /* octree file name */
30 #define PICTURE 12 /* picture file root name */
31 #define AMBFILE 13 /* ambient file name */
32 #define OPTFILE 14 /* rendering options file */
33 #define EXPOSURE 15 /* picture exposure setting */
34 #define RESOLUTION 16 /* maximum picture resolution */
35 #define UP 17 /* view up (X, Y or Z) */
36 #define INDIRECT 18 /* indirection in lighting */
37 #define DETAIL 19 /* level of scene detail */
38 #define PENUMBRAS 20 /* shadow penumbras are desired */
39 #define VARIABILITY 21 /* level of light variability */
40 #define REPORT 22 /* report frequency and errfile */
41 #define RAWFILE 23 /* raw picture file root name */
42 #define ZFILE 24 /* distance file root name */
43 /* total number of variables */
44 int NVARS = 25;
45
46 VARIABLE vv[] = { /* variable-value pairs */
47 {"objects", 3, 0, NULL, catvalues},
48 {"scene", 3, 0, NULL, catvalues},
49 {"materials", 3, 0, NULL, catvalues},
50 {"illum", 3, 0, NULL, catvalues},
51 {"mkillum", 3, 0, NULL, catvalues},
52 {"render", 3, 0, NULL, catvalues},
53 {"oconv", 3, 0, NULL, catvalues},
54 {"pfilt", 2, 0, NULL, catvalues},
55 {"view", 2, 0, NULL, NULL},
56 {"ZONE", 2, 0, NULL, onevalue},
57 {"QUALITY", 3, 0, NULL, qualvalue},
58 {"OCTREE", 3, 0, NULL, onevalue},
59 {"PICTURE", 3, 0, NULL, onevalue},
60 {"AMBFILE", 3, 0, NULL, onevalue},
61 {"OPTFILE", 3, 0, NULL, onevalue},
62 {"EXPOSURE", 3, 0, NULL, fltvalue},
63 {"RESOLUTION", 3, 0, NULL, onevalue},
64 {"UP", 2, 0, NULL, onevalue},
65 {"INDIRECT", 3, 0, NULL, intvalue},
66 {"DETAIL", 3, 0, NULL, qualvalue},
67 {"PENUMBRAS", 3, 0, NULL, boolvalue},
68 {"VARIABILITY", 3, 0, NULL, qualvalue},
69 {"REPORT", 3, 0, NULL, onevalue},
70 {"RAWFILE", 3, 0, NULL, onevalue},
71 {"ZFILE", 2, 0, NULL, onevalue},
72 };
73
74 /* overture calculation file */
75 #ifdef NIX
76 char overfile[] = "overture.unf";
77 #else
78 char overfile[] = "/dev/null";
79 #endif
80
81 extern time_t fdate(), time();
82
83 time_t scenedate; /* date of latest scene or object file */
84 time_t octreedate; /* date of octree */
85 time_t matdate; /* date of latest material file */
86 time_t illumdate; /* date of last illum file */
87
88 char *oct0name; /* name of pre-mkillum octree */
89 time_t oct0date; /* date of pre-mkillum octree */
90 char *oct1name; /* name of post-mkillum octree */
91 time_t oct1date; /* date of post-mkillum octree (>= matdate) */
92
93 int nowarn = 0; /* no warnings */
94 int explicate = 0; /* explicate variables */
95 int silent = 0; /* do work silently */
96 int touchonly = 0; /* touch files only */
97 int noaction = 0; /* don't do anything */
98 int sayview = 0; /* print view out */
99 char *rvdevice = NULL; /* rview output device */
100 char *viewselect = NULL; /* specific view only */
101
102 int overture = 0; /* overture calculation needed */
103
104 char *progname; /* global argv[0] */
105 char *rifname; /* global rad input file name */
106
107 char radname[MAXPATH]; /* root Radiance file name */
108
109
110 main(argc, argv)
111 int argc;
112 char *argv[];
113 {
114 char ropts[512];
115 char popts[64];
116 int i;
117
118 progname = argv[0];
119 /* get options */
120 for (i = 1; i < argc && argv[i][0] == '-'; i++)
121 switch (argv[i][1]) {
122 case 's':
123 silent++;
124 break;
125 case 'n':
126 noaction++;
127 break;
128 case 't':
129 touchonly++;
130 break;
131 case 'e':
132 explicate++;
133 break;
134 case 'o':
135 rvdevice = argv[++i];
136 break;
137 case 'V':
138 sayview++;
139 break;
140 case 'v':
141 viewselect = argv[++i];
142 break;
143 case 'w':
144 nowarn++;
145 break;
146 default:
147 goto userr;
148 }
149 if (i >= argc)
150 goto userr;
151 rifname = argv[i];
152 /* assign Radiance root file name */
153 rootname(radname, rifname);
154 /* load variable values */
155 loadvars(rifname);
156 /* get any additional assignments */
157 for (i++; i < argc; i++)
158 setvariable(argv[i]);
159 /* check assignments */
160 checkvalues();
161 /* check files and dates */
162 checkfiles();
163 /* set default values as necessary */
164 setdefaults();
165 /* print all values if requested */
166 if (explicate)
167 printvars(stdout);
168 /* build octree (and run mkillum) */
169 oconv();
170 /* check date on ambient file */
171 checkambfile();
172 /* run simulation */
173 renderopts(ropts, popts);
174 xferopts(ropts);
175 if (rvdevice != NULL)
176 rview(ropts, popts);
177 else
178 rpict(ropts, popts);
179 exit(0);
180 userr:
181 fprintf(stderr,
182 "Usage: %s [-s][-n][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
183 progname);
184 exit(1);
185 }
186
187
188 rootname(rn, fn) /* remove tail from end of fn */
189 register char *rn, *fn;
190 {
191 char *tp, *dp;
192
193 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
194 if (ISDIRSEP(*rn))
195 dp = rn;
196 else if (*rn == '.')
197 tp = rn;
198 if (tp != NULL && tp > dp)
199 *tp = '\0';
200 }
201
202
203 time_t
204 checklast(fnames) /* check files and find most recent */
205 register char *fnames;
206 {
207 char thisfile[MAXPATH];
208 time_t thisdate, lastdate = 0;
209 register char *cp;
210
211 if (fnames == NULL)
212 return(0);
213 while (*fnames) {
214 while (isspace(*fnames)) fnames++;
215 cp = thisfile;
216 while (*fnames && !isspace(*fnames))
217 *cp++ = *fnames++;
218 *cp = '\0';
219 if (!(thisdate = fdate(thisfile)))
220 syserr(thisfile);
221 if (thisdate > lastdate)
222 lastdate = thisdate;
223 }
224 return(lastdate);
225 }
226
227
228 char *
229 newfname(orig, pred) /* create modified file name */
230 char *orig;
231 int pred;
232 {
233 extern char *rindex();
234 register char *cp;
235 register int n;
236 int suffix;
237
238 n = 0; cp = orig; suffix = -1; /* suffix position, length */
239 while (*cp) {
240 if (*cp == '.') suffix = n;
241 else if (ISDIRSEP(*cp)) suffix = -1;
242 cp++; n++;
243 }
244 if (suffix == -1) suffix = n;
245 if ((cp = bmalloc(n+2)) == NULL)
246 syserr(progname);
247 strncpy(cp, orig, suffix);
248 cp[suffix] = pred; /* root name + pred + suffix */
249 strcpy(cp+suffix+1, orig+suffix);
250 return(cp);
251 }
252
253
254 checkfiles() /* check for existence and modified times */
255 {
256 time_t objdate;
257
258 if (!vdef(OCTREE)) {
259 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
260 syserr(progname);
261 sprintf(vval(OCTREE), "%s.oct", radname);
262 vdef(OCTREE)++;
263 }
264 octreedate = fdate(vval(OCTREE));
265 if (vdef(ILLUM)) { /* illum requires secondary octrees */
266 oct0name = newfname(vval(OCTREE), '0');
267 oct1name = newfname(vval(OCTREE), '1');
268 oct0date = fdate(oct0name);
269 oct1date = fdate(oct1name);
270 } else
271 oct0name = oct1name = vval(OCTREE);
272 if ((scenedate = checklast(vval(SCENE))) &&
273 (objdate = checklast(vval(OBJECT))) > scenedate)
274 scenedate = objdate;
275 illumdate = checklast(vval(ILLUM));
276 if (!octreedate & !scenedate & !illumdate) {
277 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
278 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
279 exit(1);
280 }
281 matdate = checklast(vval(MATERIAL));
282 }
283
284
285 getoctcube(org, sizp) /* get octree bounding cube */
286 double org[3], *sizp;
287 {
288 extern FILE *popen();
289 static double oorg[3], osiz = 0.;
290 double min[3], max[3];
291 char buf[1024];
292 FILE *fp;
293 register int i;
294
295 if (osiz <= FTINY)
296 if (noaction && fdate(oct1name) <
297 (scenedate>illumdate?scenedate:illumdate)) {
298 /* run getbbox */
299 sprintf(buf, "getbbox -w -h %s",
300 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
301 if ((fp = popen(buf, "r")) == NULL)
302 syserr("getbbox");
303 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
304 &min[0], &max[0], &min[1], &max[1],
305 &min[2], &max[2]) != 6) {
306 fprintf(stderr,
307 "%s: error reading bounding box from getbbox\n",
308 progname);
309 exit(1);
310 }
311 for (i = 0; i < 3; i++)
312 if (max[i] - min[i] > osiz)
313 osiz = max[i] - min[i];
314 for (i = 0; i < 3; i++)
315 oorg[i] = (max[i]+min[i]-osiz)*.5;
316 pclose(fp);
317 } else { /* from octree */
318 oconv(); /* does nothing if done already */
319 sprintf(buf, "getinfo -d < %s", oct1name);
320 if ((fp = popen(buf, "r")) == NULL)
321 syserr("getinfo");
322 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
323 &oorg[2], &osiz) != 4) {
324 fprintf(stderr,
325 "%s: error reading bounding cube from getinfo\n",
326 progname);
327 exit(1);
328 }
329 pclose(fp);
330 }
331 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
332 }
333
334
335 setdefaults() /* set default values for unassigned var's */
336 {
337 double org[3], size;
338 char buf[128];
339
340 if (!vdef(ZONE)) {
341 getoctcube(org, &size);
342 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
343 org[1], org[1]+size, org[2], org[2]+size);
344 vval(ZONE) = savqstr(buf);
345 vdef(ZONE)++;
346 }
347 if (!vdef(INDIRECT)) {
348 vval(INDIRECT) = "0";
349 vdef(INDIRECT)++;
350 }
351 if (!vdef(QUALITY)) {
352 vval(QUALITY) = "L";
353 vdef(QUALITY)++;
354 }
355 if (!vdef(RESOLUTION)) {
356 vval(RESOLUTION) = "512";
357 vdef(RESOLUTION)++;
358 }
359 if (!vdef(PICTURE)) {
360 vval(PICTURE) = radname;
361 vdef(PICTURE)++;
362 }
363 if (!vdef(VIEW)) {
364 vval(VIEW) = "X";
365 vdef(VIEW)++;
366 }
367 if (!vdef(DETAIL)) {
368 vval(DETAIL) = "M";
369 vdef(DETAIL)++;
370 }
371 if (!vdef(PENUMBRAS)) {
372 vval(PENUMBRAS) = "F";
373 vdef(PENUMBRAS)++;
374 }
375 if (!vdef(VARIABILITY)) {
376 vval(VARIABILITY) = "L";
377 vdef(VARIABILITY)++;
378 }
379 }
380
381
382 oconv() /* run oconv and mkillum if necessary */
383 {
384 static char illumtmp[] = "ilXXXXXX";
385 char combuf[1024], ocopts[64], mkopts[64];
386
387 oconvopts(ocopts); /* get options */
388 if (octreedate < scenedate) { /* check date on original octree */
389 if (touchonly && octreedate)
390 touch(vval(OCTREE));
391 else { /* build command */
392 if (vdef(MATERIAL))
393 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
394 vval(MATERIAL), vval(SCENE),
395 vval(OCTREE));
396 else
397 sprintf(combuf, "oconv%s %s > %s", ocopts,
398 vval(SCENE), vval(OCTREE));
399
400 if (runcom(combuf)) { /* run it */
401 fprintf(stderr,
402 "%s: error generating octree\n\t%s removed\n",
403 progname, vval(OCTREE));
404 unlink(vval(OCTREE));
405 exit(1);
406 }
407 }
408 octreedate = time((time_t *)NULL);
409 if (octreedate < scenedate) /* in case clock is off */
410 octreedate = scenedate;
411 }
412 if (oct1name == vval(OCTREE)) /* no mkillum? */
413 oct1date = octreedate > matdate ? octreedate : matdate;
414 if (oct1date >= octreedate & oct1date >= matdate
415 & oct1date >= illumdate) /* all done */
416 return;
417 /* make octree0 */
418 if (oct0date < scenedate | oct0date < illumdate) {
419 if (touchonly && oct0date)
420 touch(oct0name);
421 else { /* build command */
422 if (octreedate)
423 sprintf(combuf, "oconv%s -i %s %s > %s", ocopts,
424 vval(OCTREE), vval(ILLUM), oct0name);
425 else if (vdef(MATERIAL))
426 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
427 vval(MATERIAL), vval(ILLUM), oct0name);
428 else
429 sprintf(combuf, "oconv%s %s > %s", ocopts,
430 vval(ILLUM), oct0name);
431 if (runcom(combuf)) { /* run it */
432 fprintf(stderr,
433 "%s: error generating octree\n\t%s removed\n",
434 progname, oct0name);
435 unlink(oct0name);
436 exit(1);
437 }
438 }
439 oct0date = time((time_t *)NULL);
440 if (oct0date < octreedate) /* in case clock is off */
441 oct0date = octreedate;
442 if (oct0date < illumdate) /* ditto */
443 oct0date = illumdate;
444 }
445 if (touchonly && oct1date)
446 touch(oct1name);
447 else {
448 mkillumopts(mkopts); /* build mkillum command */
449 mktemp(illumtmp);
450 sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts,
451 oct0name, vval(ILLUM), illumtmp);
452 if (runcom(combuf)) { /* run it */
453 fprintf(stderr, "%s: error running mkillum\n",
454 progname);
455 unlink(illumtmp);
456 exit(1);
457 }
458 /* make octree1 (frozen) */
459 if (octreedate)
460 sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts,
461 vval(OCTREE), illumtmp, oct1name);
462 else if (vdef(MATERIAL))
463 sprintf(combuf, "oconv%s -f %s %s > %s", ocopts,
464 vval(MATERIAL), illumtmp, oct1name);
465 else
466 sprintf(combuf, "oconv%s -f %s > %s", ocopts,
467 illumtmp, oct1name);
468 if (runcom(combuf)) { /* run it */
469 fprintf(stderr,
470 "%s: error generating octree\n\t%s removed\n",
471 progname, oct1name);
472 unlink(oct1name);
473 unlink(illumtmp);
474 exit(1);
475 }
476 rmfile(illumtmp);
477 }
478 oct1date = time((time_t *)NULL);
479 if (oct1date < oct0date) /* in case clock is off */
480 oct1date = oct0date;
481 }
482
483
484 char *
485 addarg(op, arg) /* add argument and advance pointer */
486 register char *op, *arg;
487 {
488 *op = ' ';
489 while (*++op = *arg++)
490 ;
491 return(op);
492 }
493
494
495 oconvopts(oo) /* get oconv options */
496 register char *oo;
497 {
498 /* BEWARE: This may be called via setdefaults(), so no assumptions */
499
500 *oo = '\0';
501 if (vdef(OCONV))
502 addarg(oo, vval(OCONV));
503 }
504
505
506 mkillumopts(mo) /* get mkillum options */
507 register char *mo;
508 {
509 /* BEWARE: This may be called via setdefaults(), so no assumptions */
510
511 *mo = '\0';
512 if (vdef(MKILLUM))
513 addarg(mo, vval(MKILLUM));
514 }
515
516
517 checkambfile() /* check date on ambient file */
518 {
519 time_t afdate;
520
521 if (!vdef(AMBFILE))
522 return;
523 if (!(afdate = fdate(vval(AMBFILE))))
524 return;
525 if (oct1date > afdate)
526 if (touchonly)
527 touch(vval(AMBFILE));
528 else
529 rmfile(vval(AMBFILE));
530 }
531
532
533 double
534 ambval() /* compute ambient value */
535 {
536 if (vdef(EXPOSURE)) {
537 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
538 return(.5/pow(2.,vflt(EXPOSURE)));
539 return(.5/vflt(EXPOSURE));
540 }
541 if (vlet(ZONE) == 'E')
542 return(10.);
543 if (vlet(ZONE) == 'I')
544 return(.01);
545 badvalue(ZONE);
546 }
547
548
549 renderopts(op, po) /* set rendering options */
550 char *op, *po;
551 {
552 switch(vscale(QUALITY)) {
553 case LOW:
554 lowqopts(op, po);
555 break;
556 case MEDIUM:
557 medqopts(op, po);
558 break;
559 case HIGH:
560 hiqopts(op, po);
561 break;
562 }
563 }
564
565
566 lowqopts(op, po) /* low quality rendering options */
567 register char *op;
568 char *po;
569 {
570 double d, org[3], siz[3];
571
572 *op = '\0';
573 *po = '\0';
574 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
575 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
576 badvalue(ZONE);
577 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
578 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
579 badvalue(ZONE);
580 getoctcube(org, &d);
581 d *= 3./(siz[0]+siz[1]+siz[2]);
582 switch (vscale(DETAIL)) {
583 case LOW:
584 po = addarg(po, "-ps 16");
585 op = addarg(op, "-dp 64");
586 sprintf(op, " -ar %d", (int)(4*d));
587 op += strlen(op);
588 break;
589 case MEDIUM:
590 po = addarg(po, "-ps 8");
591 op = addarg(op, "-dp 128");
592 sprintf(op, " -ar %d", (int)(8*d));
593 op += strlen(op);
594 break;
595 case HIGH:
596 po = addarg(po, "-ps 4");
597 op = addarg(op, "-dp 256");
598 sprintf(op, " -ar %d", (int)(16*d));
599 op += strlen(op);
600 break;
601 }
602 po = addarg(po, "-pt .16");
603 if (vbool(PENUMBRAS))
604 op = addarg(op, "-ds .4");
605 else
606 op = addarg(op, "-ds 0");
607 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
608 if (vdef(AMBFILE)) {
609 sprintf(op, " -af %s", vval(AMBFILE));
610 op += strlen(op);
611 } else
612 overture = 0;
613 switch (vscale(VARIABILITY)) {
614 case LOW:
615 op = addarg(op, "-aa .4 -ad 64");
616 break;
617 case MEDIUM:
618 op = addarg(op, "-aa .3 -ad 128");
619 break;
620 case HIGH:
621 op = addarg(op, "-aa .25 -ad 256");
622 break;
623 }
624 op = addarg(op, "-as 0");
625 d = ambval();
626 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
627 op += strlen(op);
628 op = addarg(op, "-lr 3 -lw .02");
629 if (vdef(RENDER))
630 op = addarg(op, vval(RENDER));
631 }
632
633
634 medqopts(op, po) /* medium quality rendering options */
635 register char *op;
636 char *po;
637 {
638 double d, org[3], siz[3], asz;
639
640 *op = '\0';
641 *po = '\0';
642 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
643 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
644 badvalue(ZONE);
645 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
646 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
647 badvalue(ZONE);
648 getoctcube(org, &d);
649 asz = (siz[0]+siz[1]+siz[2])/3.;
650 d /= asz;
651 switch (vscale(DETAIL)) {
652 case LOW:
653 po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
654 op = addarg(op, "-dp 256");
655 sprintf(op, " -ar %d", (int)(8*d));
656 op += strlen(op);
657 sprintf(op, " -ms %.2g", asz/20.);
658 op += strlen(op);
659 break;
660 case MEDIUM:
661 po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
662 op = addarg(op, "-dp 512");
663 sprintf(op, " -ar %d", (int)(16*d));
664 op += strlen(op);
665 sprintf(op, " -ms %.2g", asz/40.);
666 op += strlen(op);
667 break;
668 case HIGH:
669 po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
670 op = addarg(op, "-dp 1024");
671 sprintf(op, " -ar %d", (int)(32*d));
672 op += strlen(op);
673 sprintf(op, " -ms %.2g", asz/80.);
674 op += strlen(op);
675 break;
676 }
677 po = addarg(po, "-pt .08");
678 if (vbool(PENUMBRAS))
679 op = addarg(op, "-ds .2 -dj .5");
680 else
681 op = addarg(op, "-ds .3");
682 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
683 if (overture = vint(INDIRECT)) {
684 sprintf(op, " -ab %d", overture);
685 op += strlen(op);
686 }
687 if (vdef(AMBFILE)) {
688 sprintf(op, " -af %s", vval(AMBFILE));
689 op += strlen(op);
690 } else
691 overture = 0;
692 switch (vscale(VARIABILITY)) {
693 case LOW:
694 op = addarg(op, "-aa .25 -ad 196 -as 0");
695 break;
696 case MEDIUM:
697 op = addarg(op, "-aa .2 -ad 400 -as 64");
698 break;
699 case HIGH:
700 op = addarg(op, "-aa .15 -ad 768 -as 196");
701 break;
702 }
703 d = ambval();
704 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
705 op += strlen(op);
706 op = addarg(op, "-lr 6 -lw .002");
707 if (vdef(RENDER))
708 op = addarg(op, vval(RENDER));
709 }
710
711
712 hiqopts(op, po) /* high quality rendering options */
713 register char *op;
714 char *po;
715 {
716 double d, org[3], siz[3], asz;
717
718 *op = '\0';
719 *po = '\0';
720 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
721 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
722 badvalue(ZONE);
723 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
724 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
725 badvalue(ZONE);
726 getoctcube(org, &d);
727 asz = (siz[0]+siz[1]+siz[2])/3.;
728 d /= asz;
729 switch (vscale(DETAIL)) {
730 case LOW:
731 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
732 op = addarg(op, "-dp 1024");
733 sprintf(op, " -ar %d", (int)(16*d));
734 op += strlen(op);
735 sprintf(op, " -ms %.2g", asz/40.);
736 op += strlen(op);
737 break;
738 case MEDIUM:
739 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
740 op = addarg(op, "-dp 2048");
741 sprintf(op, " -ar %d", (int)(32*d));
742 op += strlen(op);
743 sprintf(op, " -ms %.2g", asz/80.);
744 op += strlen(op);
745 break;
746 case HIGH:
747 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
748 op = addarg(op, "-dp 4096");
749 sprintf(op, " -ar %d", (int)(64*d));
750 op += strlen(op);
751 sprintf(op, " -ms %.2g", asz/160.);
752 op += strlen(op);
753 break;
754 }
755 po = addarg(po, "-pt .04");
756 if (vbool(PENUMBRAS))
757 op = addarg(op, "-ds .1 -dj .65");
758 else
759 op = addarg(op, "-ds .2");
760 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
761 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
762 op += strlen(op);
763 if (vdef(AMBFILE)) {
764 sprintf(op, " -af %s", vval(AMBFILE));
765 op += strlen(op);
766 } else
767 overture = 0;
768 switch (vscale(VARIABILITY)) {
769 case LOW:
770 op = addarg(op, "-aa .15 -ad 256 -as 0");
771 break;
772 case MEDIUM:
773 op = addarg(op, "-aa .125 -ad 512 -as 256");
774 break;
775 case HIGH:
776 op = addarg(op, "-aa .08 -ad 1024 -as 512");
777 break;
778 }
779 d = ambval();
780 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
781 op += strlen(op);
782 op = addarg(op, "-lr 12 -lw .0005");
783 if (vdef(RENDER))
784 op = addarg(op, vval(RENDER));
785 }
786
787
788 xferopts(ro) /* transfer options if indicated */
789 char *ro;
790 {
791 int fd, n;
792 register char *cp;
793
794 n = strlen(ro);
795 if (n < 2)
796 return;
797 if (vdef(OPTFILE)) {
798 for (cp = ro; cp[1]; cp++)
799 if (isspace(cp[1]) && (cp[2] == '@' ||
800 (cp[2] == '-' && isalpha(cp[3]))))
801 *cp = '\n';
802 else
803 *cp = cp[1];
804 *cp = '\n';
805 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
806 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
807 syserr(vval(OPTFILE));
808 sprintf(ro, " @%s", vval(OPTFILE));
809 }
810 #ifdef MSDOS
811 else if (n > 50) {
812 setenv("ROPT", ro+1);
813 strcpy(ro, " $ROPT");
814 }
815 #endif
816 }
817
818
819 pfiltopts(po) /* get pfilt options */
820 register char *po;
821 {
822 *po = '\0';
823 if (vdef(EXPOSURE)) {
824 po = addarg(po, "-1 -e");
825 po = addarg(po, vval(EXPOSURE));
826 }
827 switch (vscale(QUALITY)) {
828 case MEDIUM:
829 po = addarg(po, "-r 1");
830 break;
831 case HIGH:
832 po = addarg(po, "-m .25");
833 break;
834 }
835 if (vdef(PFILT))
836 po = addarg(po, vval(PFILT));
837 }
838
839
840 matchword(s1, s2) /* match white-delimited words */
841 register char *s1, *s2;
842 {
843 while (isspace(*s1)) s1++;
844 while (isspace(*s2)) s2++;
845 while (*s1 && !isspace(*s1))
846 if (*s1++ != *s2++)
847 return(0);
848 return(!*s2 || isspace(*s2));
849 }
850
851
852 char *
853 specview(vs) /* get proper view spec from vs */
854 register char *vs;
855 {
856 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
857 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
858 static char viewopts[128];
859 register char *cp;
860 int xpos, ypos, zpos, viewtype, upax;
861 register int i;
862 double cent[3], dim[3], mult, d;
863
864 if (vs == NULL || *vs == '-')
865 return(vs);
866 upax = 0; /* get the up vector */
867 if (vdef(UP)) {
868 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
869 upax = 1-'X'+UPPER(vval(UP)[1]);
870 else
871 upax = 1-'X'+vlet(UP);
872 if (upax < 1 | upax > 3)
873 badvalue(UP);
874 if (vval(UP)[0] == '-')
875 upax = -upax;
876 }
877 /* check standard view names */
878 xpos = ypos = zpos = 0;
879 if (*vs == 'X') {
880 xpos = 1; vs++;
881 } else if (*vs == 'x') {
882 xpos = -1; vs++;
883 }
884 if (*vs == 'Y') {
885 ypos = 1; vs++;
886 } else if (*vs == 'y') {
887 ypos = -1; vs++;
888 }
889 if (*vs == 'Z') {
890 zpos = 1; vs++;
891 } else if (*vs == 'z') {
892 zpos = -1; vs++;
893 }
894 viewtype = 'v';
895 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h' | *vs == 'c')
896 viewtype = *vs++;
897 cp = viewopts;
898 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
899 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
900 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
901 &cent[0], &dim[0], &cent[1], &dim[1],
902 &cent[2], &dim[2]) != 6)
903 badvalue(ZONE);
904 for (i = 0; i < 3; i++) {
905 dim[i] -= cent[i];
906 if (dim[i] <= FTINY)
907 badvalue(ZONE);
908 cent[i] += .5*dim[i];
909 }
910 mult = vlet(ZONE)=='E' ? 2. : .45 ;
911 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
912 cent[0]+xpos*mult*dim[0],
913 cent[1]+ypos*mult*dim[1],
914 cent[2]+zpos*mult*dim[2],
915 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
916 cp += strlen(cp);
917 /* redirect up axis if necessary */
918 switch (upax) {
919 case 3: /* plus or minus Z axis */
920 case -3:
921 case 0:
922 if (!(xpos|ypos))
923 upax = 2;
924 break;
925 case 2: /* plus or minus Y axis */
926 case -2:
927 if (!(xpos|zpos))
928 upax = 1;
929 break;
930 case 1: /* plus or minus X axis */
931 case -1:
932 if (!(ypos|zpos))
933 upax = 3;
934 break;
935 }
936 cp = addarg(cp, vup[upax+3]);
937 switch (viewtype) {
938 case 'v':
939 cp = addarg(cp, "-vh 45 -vv 45");
940 break;
941 case 'l':
942 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
943 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
944 cp += strlen(cp);
945 break;
946 case 'a':
947 case 'h':
948 cp = addarg(cp, "-vh 180 -vv 180");
949 break;
950 case 'c':
951 cp = addarg(cp, "-vh 180 -vv 90");
952 break;
953 }
954 } else {
955 while (!isspace(*vs)) /* else skip id */
956 if (!*vs++)
957 return(NULL);
958 if (upax) { /* specify up vector */
959 strcpy(cp, vup[upax+3]);
960 cp += strlen(cp);
961 }
962 }
963 if (cp == viewopts) /* append any additional options */
964 vs++; /* skip prefixed space if unneeded */
965 strcpy(cp, vs);
966 #ifdef MSDOS
967 if (strlen(viewopts) > 40) {
968 setenv("VIEW", viewopts);
969 return("$VIEW");
970 }
971 #endif
972 return(viewopts);
973 }
974
975
976 char *
977 getview(n, vn) /* get view n, or NULL if none */
978 int n;
979 char *vn; /* returned view name */
980 {
981 register char *mv;
982
983 if (viewselect != NULL) { /* command-line selected */
984 if (n) /* only do one */
985 return(NULL);
986 if (viewselect[0] == '-') { /* already specified */
987 if (vn != NULL) *vn = '\0';
988 return(viewselect);
989 }
990 if (vn != NULL) {
991 for (mv = viewselect; *mv && !isspace(*mv);
992 *vn++ = *mv++)
993 ;
994 *vn = '\0';
995 }
996 /* view number? */
997 if (isint(viewselect))
998 return(specview(nvalue(vv+VIEW, atoi(viewselect)-1)));
999 /* check list */
1000 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
1001 if (matchword(viewselect, mv))
1002 return(specview(mv));
1003 return(specview(viewselect)); /* standard view? */
1004 }
1005 mv = nvalue(vv+VIEW, n); /* use view n */
1006 if (vn != NULL & mv != NULL) {
1007 register char *mv2 = mv;
1008 if (*mv2 != '-')
1009 while (*mv2 && !isspace(*mv2))
1010 *vn++ = *mv2++;
1011 *vn = '\0';
1012 }
1013 return(specview(mv));
1014 }
1015
1016
1017 printview(vopts) /* print out selected view */
1018 register char *vopts;
1019 {
1020 extern char *atos(), *getenv();
1021 char buf[256];
1022 FILE *fp;
1023 register char *cp;
1024
1025 if (vopts == NULL)
1026 return(-1);
1027 fputs("VIEW=", stdout);
1028 do {
1029 if (matchword(vopts, "-vf")) { /* expand view file */
1030 vopts = sskip(vopts);
1031 if (!*atos(buf, sizeof(buf), vopts))
1032 return(-1);
1033 if ((fp = fopen(buf, "r")) == NULL)
1034 return(-1);
1035 for (buf[sizeof(buf)-2] = '\n';
1036 fgets(buf, sizeof(buf), fp) != NULL &&
1037 buf[0] != '\n';
1038 buf[sizeof(buf)-2] = '\n') {
1039 if (buf[sizeof(buf)-2] != '\n') {
1040 ungetc(buf[sizeof(buf)-2], fp);
1041 buf[sizeof(buf)-2] = '\0';
1042 }
1043 if (matchword(buf, "VIEW=") ||
1044 matchword(buf, "rview")) {
1045 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1046 putchar(*cp);
1047 }
1048 }
1049 fclose(fp);
1050 vopts = sskip(vopts);
1051 } else {
1052 while (isspace(*vopts))
1053 vopts++;
1054 putchar(' ');
1055 #ifdef MSDOS
1056 if (*vopts == '$') { /* expand env. var. */
1057 if (!*atos(buf, sizeof(buf), vopts+1))
1058 return(-1);
1059 if ((cp = getenv(buf)) == NULL)
1060 return(-1);
1061 fputs(cp, stdout);
1062 vopts = sskip(vopts);
1063 } else
1064 #endif
1065 while (*vopts && !isspace(*vopts))
1066 putchar(*vopts++);
1067 }
1068 } while (*vopts++);
1069 putchar('\n');
1070 return(0);
1071 }
1072
1073
1074 rview(opts, po) /* run rview with first view */
1075 char *opts, *po;
1076 {
1077 char *vw;
1078 char combuf[512];
1079 /* build command */
1080 if (touchonly || (vw = getview(0, NULL)) == NULL)
1081 return;
1082 if (sayview)
1083 printview(vw);
1084 sprintf(combuf, "rview %s%s%s -R %s ", vw, po, opts, rifname);
1085 if (rvdevice != NULL)
1086 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1087 if (vdef(EXPOSURE))
1088 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1089 strcat(combuf, oct1name);
1090 if (runcom(combuf)) { /* run it */
1091 fprintf(stderr, "%s: error running rview\n", progname);
1092 exit(1);
1093 }
1094 }
1095
1096
1097 rpict(opts, po) /* run rpict and pfilt for each view */
1098 char *opts, *po;
1099 {
1100 char combuf[1024];
1101 char rawfile[MAXPATH], picfile[MAXPATH];
1102 char zopt[MAXPATH+4], rep[MAXPATH+16], res[32];
1103 char pfopts[128];
1104 char vs[32], *vw;
1105 int vn, mult;
1106 time_t rfdt, pfdt;
1107 /* get pfilt options */
1108 pfiltopts(pfopts);
1109 /* get resolution, reporting */
1110 switch (vscale(QUALITY)) {
1111 case LOW:
1112 mult = 1;
1113 break;
1114 case MEDIUM:
1115 mult = 2;
1116 break;
1117 case HIGH:
1118 mult = 3;
1119 break;
1120 }
1121 {
1122 int xres, yres;
1123 double aspect;
1124 int n;
1125 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1126 if (n == 3)
1127 sprintf(res, "-x %d -y %d -pa %.3f",
1128 mult*xres, mult*yres, aspect);
1129 else if (n) {
1130 if (n == 1) yres = xres;
1131 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1132 } else
1133 badvalue(RESOLUTION);
1134 }
1135 rep[0] = '\0';
1136 if (vdef(REPORT)) {
1137 double minutes;
1138 int n;
1139 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1140 if (n == 2)
1141 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1142 else if (n == 1)
1143 sprintf(rep, " -t %d", (int)(minutes*60));
1144 else
1145 badvalue(REPORT);
1146 }
1147 /* do each view */
1148 vn = 0;
1149 while ((vw = getview(vn++, vs)) != NULL) {
1150 if (sayview)
1151 printview(vw);
1152 if (!vs[0])
1153 sprintf(vs, "%d", vn);
1154 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1155 if (vdef(ZFILE))
1156 sprintf(zopt, " -z %s_%s.zbf", vval(ZFILE), vs);
1157 else
1158 zopt[0] = '\0';
1159 /* check date on picture */
1160 pfdt = fdate(picfile);
1161 if (pfdt >= oct1date)
1162 continue;
1163 /* get raw file name */
1164 sprintf(rawfile, "%s_%s.unf",
1165 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE), vs);
1166 rfdt = fdate(rawfile);
1167 if (touchonly) { /* update times only */
1168 if (rfdt) {
1169 if (rfdt < oct1date)
1170 touch(rawfile);
1171 } else if (pfdt && pfdt < oct1date)
1172 touch(picfile);
1173 continue;
1174 }
1175 /* build rpict command */
1176 if (rfdt >= oct1date) /* recover */
1177 sprintf(combuf, "rpict%s%s%s%s -ro %s %s",
1178 rep, po, opts, zopt, rawfile, oct1name);
1179 else {
1180 if (overture) { /* run overture calculation */
1181 sprintf(combuf,
1182 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1183 rep, vw, opts,
1184 oct1name, overfile);
1185 if (runcom(combuf)) {
1186 fprintf(stderr,
1187 "%s: error in overture for view %s\n",
1188 progname, vs);
1189 exit(1);
1190 }
1191 #ifdef NIX
1192 rmfile(overfile);
1193 #endif
1194 }
1195 sprintf(combuf, "rpict%s %s %s%s%s%s %s > %s",
1196 rep, vw, res, po, opts, zopt,
1197 oct1name, rawfile);
1198 }
1199 if (runcom(combuf)) { /* run rpict */
1200 fprintf(stderr, "%s: error rendering view %s\n",
1201 progname, vs);
1202 exit(1);
1203 }
1204 if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) {
1205 /* build pfilt command */
1206 if (mult > 1)
1207 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1208 pfopts, mult, mult, rawfile, picfile);
1209 else
1210 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1211 rawfile, picfile);
1212 if (runcom(combuf)) { /* run pfilt */
1213 fprintf(stderr,
1214 "%s: error filtering view %s\n\t%s removed\n",
1215 progname, vs, picfile);
1216 unlink(picfile);
1217 exit(1);
1218 }
1219 }
1220 /* remove/rename raw file */
1221 if (vdef(RAWFILE)) {
1222 sprintf(combuf, "%s_%s.pic", vval(RAWFILE), vs);
1223 mvfile(rawfile, combuf);
1224 } else
1225 rmfile(rawfile);
1226 }
1227 }
1228
1229
1230 touch(fn) /* update a file */
1231 char *fn;
1232 {
1233 if (!silent)
1234 printf("\ttouch %s\n", fn);
1235 if (noaction)
1236 return(0);
1237 #ifdef notused
1238 if (access(fn, F_OK) == -1) /* create it */
1239 if (close(open(fn, O_WRONLY|O_CREAT, 0666)) == -1)
1240 return(-1);
1241 #endif
1242 return(setfdate(fn, time((time_t *)NULL)));
1243 }
1244
1245
1246 runcom(cs) /* run command */
1247 char *cs;
1248 {
1249 if (!silent) /* echo it */
1250 printf("\t%s\n", cs);
1251 if (noaction)
1252 return(0);
1253 fflush(stdout); /* flush output and pass to shell */
1254 return(system(cs));
1255 }
1256
1257
1258 rmfile(fn) /* remove a file */
1259 char *fn;
1260 {
1261 if (!silent)
1262 #ifdef MSDOS
1263 printf("\tdel %s\n", fn);
1264 #else
1265 printf("\trm -f %s\n", fn);
1266 #endif
1267 if (noaction)
1268 return(0);
1269 return(unlink(fn));
1270 }
1271
1272
1273 mvfile(fold, fnew) /* move a file */
1274 char *fold, *fnew;
1275 {
1276 if (!silent)
1277 #ifdef MSDOS
1278 printf("\trename %s %s\n", fold, fnew);
1279 #else
1280 printf("\tmv %s %s\n", fold, fnew);
1281 #endif
1282 if (noaction)
1283 return(0);
1284 return(rename(fold, fnew));
1285 }
1286
1287
1288 #ifdef MSDOS
1289 setenv(vname, value) /* set an environment variable */
1290 char *vname, *value;
1291 {
1292 register char *evp;
1293
1294 evp = bmalloc(strlen(vname)+strlen(value)+2);
1295 if (evp == NULL)
1296 syserr(progname);
1297 sprintf(evp, "%s=%s", vname, value);
1298 if (putenv(evp) != 0) {
1299 fprintf(stderr, "%s: out of environment space\n", progname);
1300 exit(1);
1301 }
1302 if (!silent)
1303 printf("set %s\n", evp);
1304 }
1305 #endif
1306
1307
1308 badvalue(vc) /* report bad variable value and exit */
1309 int vc;
1310 {
1311 fprintf(stderr, "%s: bad value for variable '%s'\n",
1312 progname, vnam(vc));
1313 exit(1);
1314 }
1315
1316
1317 syserr(s) /* report a system error and exit */
1318 char *s;
1319 {
1320 perror(s);
1321 exit(1);
1322 }
