--- ray/src/util/rad.c 2004/01/01 19:31:46 2.75 +++ ray/src/util/rad.c 2004/09/17 21:43:50 2.78 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rad.c,v 2.75 2004/01/01 19:31:46 greg Exp $"; +static const char RCSid[] = "$Id: rad.c,v 2.78 2004/09/17 21:43:50 greg Exp $"; #endif /* * Executive program for oconv, rpict and pfilt @@ -22,6 +22,8 @@ static const char RCSid[] = "$Id: rad.c,v 2.75 2004/01 #else #define DELCMD "rm -f" #define RENAMECMD "mv" + #include + #include #endif /* variables (alphabetical by name) */ @@ -121,10 +123,46 @@ char radname[PATH_MAX]; /* root Radiance file name */ #define inchild() (children_running < 0) +static void rootname(char *rn, char *fn); +static time_t checklast(char *fnames); +static char * newfname(char *orig, int pred); +static void checkfiles(void); +static void getoctcube(double org[3], double *sizp); +static void setdefaults(void); +static void oconv(void); +static char * addarg(char *op, char *arg); +static void oconvopts(char *oo); +static void mkillumopts(char *mo); +static void checkambfile(void); +static double ambval(void); +static void renderopts(char *op, char *po); +static void lowqopts(char *op, char *po); +static void medqopts(char *op, char *po); +static void hiqopts(char *op, char *po); +static void xferopts(char *ro); +static void pfiltopts(char *po); +static int matchword(char *s1, char *s2); +static char * specview(char *vs); +static char * getview(int n, char *vn); +static int myprintview(char *vopts, FILE *fp); +static void rvu(char *opts, char *po); +static void rpict(char *opts, char *po); +static int touch(char *fn); +static int runcom(char *cs); +static int rmfile(char *fn); +static int mvfile(char *fold, char *fnew); +static int next_process(void); +static void wait_process(int all); +static void finish_process(void); +static void badvalue(int vc); +static void syserr(char *s); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { char ropts[512]; char popts[64]; @@ -209,11 +247,15 @@ userr: "Usage: %s [-w][-s][-n|-N npr][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); quit(1); + return 1; /* pro forma return */ } -rootname(rn, fn) /* remove tail from end of fn */ -register char *rn, *fn; +static void +rootname( /* remove tail from end of fn */ + register char *rn, + register char *fn +) { char *tp, *dp; @@ -227,9 +269,10 @@ register char *rn, *fn; } -time_t -checklast(fnames) /* check files and find most recent */ -register char *fnames; +static time_t +checklast( /* check files and find most recent */ + register char *fnames +) { char thisfile[PATH_MAX]; time_t thisdate, lastdate = 0; @@ -238,8 +281,11 @@ register char *fnames; return(0); while ((fnames = nextword(thisfile, PATH_MAX, fnames)) != NULL) { if (thisfile[0] == '!' || - (thisfile[0] == '\\' && thisfile[1] == '!')) + (thisfile[0] == '\\' && thisfile[1] == '!')) { + if (!lastdate) + lastdate = 1; continue; + } if (!(thisdate = fdate(thisfile))) syserr(thisfile); if (thisdate > lastdate) @@ -249,10 +295,11 @@ register char *fnames; } -char * -newfname(orig, pred) /* create modified file name */ -char *orig; -int pred; +static char * +newfname( /* create modified file name */ + char *orig, + int pred +) { register char *cp; register int n; @@ -274,7 +321,8 @@ int pred; } -checkfiles() /* check for existence and modified times */ +static void +checkfiles(void) /* check for existence and modified times */ { time_t objdate; @@ -309,8 +357,11 @@ checkfiles() /* check for existence and modified tim } -getoctcube(org, sizp) /* get octree bounding cube */ -double org[3], *sizp; +static void +getoctcube( /* get octree bounding cube */ + double org[3], + double *sizp +) { static double oorg[3], osiz = 0.; double min[3], max[3]; @@ -359,7 +410,8 @@ double org[3], *sizp; } -setdefaults() /* set default values for unassigned var's */ +static void +setdefaults(void) /* set default values for unassigned var's */ { double org[3], lim[3], size; char buf[128]; @@ -416,10 +468,11 @@ setdefaults() /* set default values for unassigned v } -oconv() /* run oconv and mkillum if necessary */ +static void +oconv(void) /* run oconv and mkillum if necessary */ { static char illumtmp[] = "ilXXXXXX"; - char combuf[PATH_MAX], ocopts[64], mkopts[64]; + char combuf[PATH_MAX], ocopts[64], mkopts[1024]; oconvopts(ocopts); /* get options */ if (octreedate < scenedate) { /* check date on original octree */ @@ -518,9 +571,11 @@ oconv() /* run oconv and mkillum if necessary */ } -char * -addarg(op, arg) /* add argument and advance pointer */ -register char *op, *arg; +static char * +addarg( /* add argument and advance pointer */ +register char *op, +register char *arg +) { *op = ' '; while ( (*++op = *arg++) ) @@ -529,8 +584,10 @@ register char *op, *arg; } -oconvopts(oo) /* get oconv options */ -register char *oo; +static void +oconvopts( /* get oconv options */ + register char *oo +) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ @@ -540,18 +597,26 @@ register char *oo; } -mkillumopts(mo) /* get mkillum options */ -register char *mo; +static void +mkillumopts( /* get mkillum options */ + char *mo +) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ - *mo = '\0'; + if (nprocs > 1) { + sprintf(mo, " -n %d", nprocs); + while (*mo) + mo++; + } else + *mo = '\0'; if (vdef(MKILLUM)) addarg(mo, vval(MKILLUM)); } -checkambfile() /* check date on ambient file */ +static void +checkambfile(void) /* check date on ambient file */ { time_t afdate; @@ -568,8 +633,8 @@ checkambfile() /* check date on ambient file */ } -double -ambval() /* compute ambient value */ +static double +ambval(void) /* compute ambient value */ { if (vdef(EXPOSURE)) { if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') @@ -581,11 +646,15 @@ ambval() /* compute ambient value */ if (vlet(ZONE) == 'I') return(.01); badvalue(ZONE); + return 0; /* pro forma return */ } -renderopts(op, po) /* set rendering options */ -char *op, *po; +static void +renderopts( /* set rendering options */ + char *op, + char *po +) { switch(vscale(QUALITY)) { case LOW: @@ -601,9 +670,11 @@ char *op, *po; } -lowqopts(op, po) /* low quality rendering options */ -register char *op; -char *po; +static void +lowqopts( /* low quality rendering options */ + register char *op, + char *po +) { double d, org[3], siz[3]; @@ -669,9 +740,11 @@ char *po; } -medqopts(op, po) /* medium quality rendering options */ -register char *op; -char *po; +static void +medqopts( /* medium quality rendering options */ + register char *op, + char *po +) { double d, org[3], siz[3], asz; @@ -747,9 +820,11 @@ char *po; } -hiqopts(op, po) /* high quality rendering options */ -register char *op; -char *po; +static void +hiqopts( /* high quality rendering options */ + register char *op, + char *po +) { double d, org[3], siz[3], asz; @@ -823,8 +898,10 @@ char *po; } -xferopts(ro) /* transfer options if indicated */ -char *ro; +static void +xferopts( /* transfer options if indicated */ + char *ro +) { int fd, n; register char *cp; @@ -854,8 +931,10 @@ char *ro; } -pfiltopts(po) /* get pfilt options */ -register char *po; +static void +pfiltopts( /* get pfilt options */ + register char *po +) { *po = '\0'; if (vdef(EXPOSURE)) { @@ -875,8 +954,11 @@ register char *po; } -matchword(s1, s2) /* match white-delimited words */ -register char *s1, *s2; +static int +matchword( /* match white-delimited words */ + register char *s1, + register char *s2 +) { while (isspace(*s1)) s1++; while (isspace(*s2)) s2++; @@ -887,9 +969,10 @@ register char *s1, *s2; } -char * -specview(vs) /* get proper view spec from vs */ -register char *vs; +static char * +specview( /* get proper view spec from vs */ + register char *vs +) { static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0", "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"}; @@ -1011,10 +1094,11 @@ register char *vs; } -char * -getview(n, vn) /* get view n, or NULL if none */ -int n; -char *vn; /* returned view name */ +static char * +getview( /* get view n, or NULL if none */ + int n, + char *vn /* returned view name */ +) { register char *mv; @@ -1052,15 +1136,15 @@ char *vn; /* returned view name */ } -int -myprintview(vopts, fp) /* print out selected view */ -register char *vopts; -FILE *fp; +static int +myprintview( /* print out selected view */ + register char *vopts, + FILE *fp +) { VIEW vwr; char buf[128]; register char *cp; -again: if (vopts == NULL) return(-1); #ifdef _WIN32 @@ -1083,8 +1167,11 @@ again: } -rvu(opts, po) /* run rvu with first view */ -char *opts, *po; +static void +rvu( /* run rvu with first view */ + char *opts, + char *po +) { char *vw; char combuf[PATH_MAX]; @@ -1106,8 +1193,11 @@ char *opts, *po; } -rpict(opts, po) /* run rpict and pfilt for each view */ -char *opts, *po; +static void +rpict( /* run rpict and pfilt for each view */ + char *opts, + char *po +) { char combuf[PATH_MAX]; char rawfile[PATH_MAX], picfile[PATH_MAX]; @@ -1284,8 +1374,10 @@ rperror: } -touch(fn) /* update a file */ -char *fn; +static int +touch( /* update a file */ + char *fn +) { if (!silent) printf("\ttouch %s\n", fn); @@ -1300,8 +1392,10 @@ char *fn; } -runcom(cs) /* run command */ -char *cs; +static int +runcom( /* run command */ + char *cs +) { if (!silent) /* echo it */ printf("\t%s\n", cs); @@ -1312,8 +1406,10 @@ char *cs; } -rmfile(fn) /* remove a file */ -char *fn; +static int +rmfile( /* remove a file */ + char *fn +) { if (!silent) printf("\t%s %s\n", DELCMD, fn); @@ -1323,8 +1419,11 @@ char *fn; } -mvfile(fold, fnew) /* move a file */ -char *fold, *fnew; +static int +mvfile( /* move a file */ + char *fold, + char *fnew +) { if (!silent) printf("\t%s %s %s\n", RENAMECMD, fold, fnew); @@ -1335,8 +1434,8 @@ char *fold, *fnew; #ifdef RHAS_FORK_EXEC -int -next_process() /* fork the next process (max. nprocs) */ +static int +next_process(void) /* fork the next process (max. nprocs) */ { int child_pid; @@ -1363,8 +1462,10 @@ next_process() /* fork the next process (max. nprocs return(0); } -wait_process(all) /* wait for process(es) to finish */ -int all; +static void +wait_process( /* wait for process(es) to finish */ + int all +) { int ourstatus = 0; int pid, status; @@ -1391,11 +1492,12 @@ int all; quit(ourstatus); /* bad status from child */ } #else /* ! RHAS_FORK_EXEC */ -int -next_process() +static int +next_process(void) { return(0); /* cannot start new process */ } +static void wait_process(all) int all; { @@ -1409,7 +1511,8 @@ int pid, sig; } #endif /* ! RHAS_FORK_EXEC */ -finish_process() /* exit a child process */ +static void +finish_process(void) /* exit a child process */ { if (!inchild()) return; /* in parent -- noop */ @@ -1436,8 +1539,10 @@ char *vname, *value; #endif -badvalue(vc) /* report bad variable value and exit */ -int vc; +static void +badvalue( /* report bad variable value and exit */ + int vc +) { fprintf(stderr, "%s: bad value for variable '%s'\n", progname, vnam(vc)); @@ -1445,8 +1550,10 @@ int vc; } -syserr(s) /* report a system error and exit */ -char *s; +static void +syserr( /* report a system error and exit */ + char *s +) { perror(s); quit(1);
