Minor changes
Added check of incomplete rendering from rpiece
Decreased -lw default
Corrected problem with image size when using rpiece
Need to remove outdated rpiece output
Avoid possible overwrite of previous partial output by rpiece
Changed overture calculation with rpiece to use single process
Increased specular sampling for high quality setting
Changed -sj option to -ss
Minor code clean-up -- should not affect behavior
Added multi-processing for single-view overture calculation
Minor fix to last change
Added echo of writing to sync file for rpiece
Minor tweaks to last change with -N and rpiece
Corrected new setting of -dj for PEN=T and QUA=Hi
Fixed resetting of number of processes with view passed to rvu
Scons update for mingw.
Switched to using defined view types
Added some additional (and probably unnecessary) fflush() calls
Using RT_PID instead of int.
Continued ANSIfication.
Minor comment changes
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Moved some more platform dependencies to common header files. Included a few necessary system headers.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed parameter to nvalue()
added vflt() macro
forgot to remove illumtmp file upon oconv failure increased command line length for oconv and getbbox in the case of many files
Changed RAWSAVE to RAWFILE (and changed meaning) added ZFILE variable to rad
added cylindrical view type
added -t (touch) option
compatibility fixes
fixed PC bug in time() call
fixed minor compiler warning
added -pe option to rview
changed fdate() return to unsigned long added illum and mkillum variables for calling mkillum program changed getoctcube() to call getbbox program with -n and no previous octree
fixed view echoing for MS-DOS
added -R option to rview
