--- ray/src/util/rad.c 1993/09/24 16:49:02 2.26 +++ ray/src/util/rad.c 1994/01/01 09:16:50 2.37 @@ -1,4 +1,4 @@ -/* Copyright (c) 1993 Regents of the University of California */ +/* Copyright (c) 1994 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -11,6 +11,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" #include "paths.h" #include +#include typedef struct { @@ -21,7 +22,8 @@ typedef struct { int (*fixval)(); /* assignment checking function */ } VARIABLE; -int onevalue(), catvalues(); +int onevalue(), catvalues(), boolvalue(), + qualvalue(), fltvalue(), intvalue(); /* variables */ #define OBJECT 0 /* object files */ @@ -61,24 +63,23 @@ VARIABLE vv[NVARS] = { /* variable-value pairs */ {"pfilt", 2, 0, NULL, catvalues}, {"view", 2, 0, NULL, NULL}, {"ZONE", 2, 0, NULL, onevalue}, - {"QUALITY", 3, 0, NULL, onevalue}, + {"QUALITY", 3, 0, NULL, qualvalue}, {"OCTREE", 3, 0, NULL, onevalue}, {"PICTURE", 3, 0, NULL, onevalue}, {"AMBFILE", 3, 0, NULL, onevalue}, {"OPTFILE", 3, 0, NULL, onevalue}, - {"EXPOSURE", 3, 0, NULL, onevalue}, + {"EXPOSURE", 3, 0, NULL, fltvalue}, {"RESOLUTION", 3, 0, NULL, onevalue}, {"UP", 2, 0, NULL, onevalue}, - {"INDIRECT", 3, 0, NULL, onevalue}, - {"DETAIL", 3, 0, NULL, onevalue}, - {"PENUMBRAS", 3, 0, NULL, onevalue}, - {"VARIABILITY", 3, 0, NULL, onevalue}, + {"INDIRECT", 3, 0, NULL, intvalue}, + {"DETAIL", 3, 0, NULL, qualvalue}, + {"PENUMBRAS", 3, 0, NULL, boolvalue}, + {"VARIABILITY", 3, 0, NULL, qualvalue}, {"REPORT", 3, 0, NULL, onevalue}, }; VARIABLE *matchvar(); char *nvalue(); -int vscale(); #define UPPER(c) ((c)&~0x20) /* ASCII trick */ @@ -87,17 +88,13 @@ int vscale(); #define vval(vc) (vv[vc].value) #define vint(vc) atoi(vval(vc)) #define vlet(vc) UPPER(vval(vc)[0]) +#define vscale vlet #define vbool(vc) (vlet(vc)=='T') -#define HIGH 2 -#define MEDIUM 1 -#define LOW 0 +#define HIGH 'H' +#define MEDIUM 'M' +#define LOW 'L' -int lowqopts(), medqopts(), hiqopts(); -int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; - -#define renderopts (*setqopts[vscale(QUALITY)]) - /* overture calculation file */ #ifdef NIX char overfile[] = "overture.raw"; @@ -105,18 +102,19 @@ char overfile[] = "overture.raw"; char overfile[] = "/dev/null"; #endif -extern unsigned long fdate(), time(); +extern time_t fdate(), time(); -unsigned long scenedate; /* date of latest scene or object file */ -unsigned long octreedate; /* date of octree */ -unsigned long matdate; /* date of latest material file */ -unsigned long illumdate; /* date of last illum file */ +time_t scenedate; /* date of latest scene or object file */ +time_t octreedate; /* date of octree */ +time_t matdate; /* date of latest material file */ +time_t illumdate; /* date of last illum file */ char *oct0name; /* name of pre-mkillum octree */ -unsigned long oct0date; /* date of pre-mkillum octree */ +time_t oct0date; /* date of pre-mkillum octree */ char *oct1name; /* name of post-mkillum octree */ -unsigned long oct1date; /* date of post-mkillum octree (>= matdate) */ +time_t oct1date; /* date of post-mkillum octree (>= matdate) */ +int nowarn = 0; /* no warnings */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ int noaction = 0; /* don't do anything */ @@ -161,6 +159,9 @@ char *argv[]; case 'v': viewselect = argv[++i]; break; + case 'w': + nowarn++; + break; default: goto userr; } @@ -256,7 +257,6 @@ setvariable(ass) /* assign variable according to stri register char *ass; { char varname[32]; - char varval[512]; int n; register char *cp; register VARIABLE *vp; @@ -277,7 +277,7 @@ register char *ass; for (n = strlen(ass); n > 0; n--) if (!isspace(ass[n-1])) break; - if (!n) { + if (!n && !nowarn) { fprintf(stderr, "%s: warning - missing value for variable '%s'\n", progname, varname); return; @@ -348,22 +348,6 @@ register int n; } -int -vscale(vc) /* return scale for variable vc */ -int vc; -{ - switch(vlet(vc)) { - case 'H': - return(HIGH); - case 'M': - return(MEDIUM); - case 'L': - return(LOW); - } - badvalue(vc); -} - - checkvalues() /* check assignments */ { register int i; @@ -379,7 +363,9 @@ register VARIABLE *vp; { if (vp->nass < 2) return; - fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n", + if (!nowarn) + fprintf(stderr, + "%s: warning - multiple assignment of variable '%s'\n", progname, vp->name); do vp->value += strlen(vp->value)+1; @@ -402,12 +388,90 @@ register VARIABLE *vp; } -unsigned long +int +badmatch(tv, cv) /* case insensitive truncated comparison */ +register char *tv, *cv; +{ + if (!*tv) return(1); /* null string cannot match */ + do + if (UPPER(*tv) != *cv++) + return(1); + while (*++tv); + return(0); /* OK */ +} + + +boolvalue(vp) /* check boolean for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + switch (UPPER(vp->value[0])) { + case 'T': + if (badmatch(vp->value, "TRUE")) break; + return; + case 'F': + if (badmatch(vp->value, "FALSE")) break; + return; + } + fprintf(stderr, "%s: illegal value for boolean variable '%s'\n", + progname, vp->name); + exit(1); +} + + +qualvalue(vp) /* check qualitative var. for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + switch (UPPER(vp->value[0])) { + case 'L': + if (badmatch(vp->value, "LOW")) break; + return; + case 'M': + if (badmatch(vp->value, "MEDIUM")) break; + return; + case 'H': + if (badmatch(vp->value, "HIGH")) break; + return; + } + fprintf(stderr, "%s: illegal value for qualitative variable '%s'\n", + progname, vp->name); + exit(1); +} + + +intvalue(vp) /* check integer variable for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + if (isint(vp->value)) return; + fprintf(stderr, "%s: illegal value for integer variable '%s'\n", + progname, vp->name); + exit(1); +} + + +fltvalue(vp) /* check float variable for legal values */ +register VARIABLE *vp; +{ + if (!vp->nass) return; + onevalue(vp); + if (isflt(vp->value)) return; + fprintf(stderr, "%s: illegal value for real variable '%s'\n", + progname, vp->name); + exit(1); +} + + +time_t checklast(fnames) /* check files and find most recent */ register char *fnames; { char thisfile[MAXPATH]; - unsigned long thisdate, lastdate = 0; + time_t thisdate, lastdate = 0; register char *cp; if (fnames == NULL) @@ -437,9 +501,13 @@ int pred; register int n; int suffix; - suffix = n = strlen(orig); /* find start of suffix */ - if ((cp = rindex(orig, '.')) != NULL) - suffix = cp - orig; + n = 0; cp = orig; suffix = -1; /* suffix position, length */ + while (*cp) { + if (*cp == '.') suffix = n; + else if (ISDIRSEP(*cp)) suffix = -1; + cp++; n++; + } + if (suffix == -1) suffix = n; if ((cp = bmalloc(n+2)) == NULL) syserr(progname); strncpy(cp, orig, suffix); @@ -451,7 +519,7 @@ int pred; checkfiles() /* check for existence and modified times */ { - unsigned long objdate; + time_t objdate; if (!vdef(OCTREE)) { if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL) @@ -579,11 +647,32 @@ setdefaults() /* set default values for unassigned v printvals() /* print variable values */ { - register int i, j; + int i, j, clipline; + register char *cp; + register int k; - for (i = 0; i < NVARS; i++) - for (j = 0; j < vdef(i); j++) - printf("%s= %s\n", vnam(i), nvalue(vv+i, j)); + for (i = 0; i < NVARS; i++) /* print each variable */ + for (j = 0; j < vdef(i); j++) { /* print each assignment */ + fputs(vnam(i), stdout); + fputs("= ", stdout); + k = clipline = ( vv[i].fixval == catvalues ? 64 : 320 ) + - strlen(vnam(i)) ; + cp = nvalue(vv+i, j); + while (*cp) { + putchar(*cp++); + if (--k <= 0) { /* line too long */ + while (*cp && !isspace(*cp)) + putchar(*cp++); /* finish this word */ + if (*cp) { /* start new line */ + putchar('\n'); + fputs(vnam(i), stdout); + putchar('='); + k = clipline; + } + } + } + putchar('\n'); + } fflush(stdout); } @@ -610,7 +699,7 @@ oconv() /* run oconv and mkillum if necessary */ unlink(vval(OCTREE)); exit(1); } - octreedate = time(0); + octreedate = time((time_t *)NULL); } if (oct1name == vval(OCTREE)) /* no mkillum? */ oct1date = octreedate > matdate ? octreedate : matdate; @@ -636,7 +725,7 @@ oconv() /* run oconv and mkillum if necessary */ unlink(oct0name); exit(1); } - oct0date = time(0); + oct0date = time((time_t *)NULL); } mkillumopts(mkopts); /* build mkillum command */ mktemp(illumtmp); @@ -664,7 +753,7 @@ oconv() /* run oconv and mkillum if necessary */ unlink(oct1name); exit(1); } - oct1date = time(0); + oct1date = time((time_t *)NULL); rmfile(illumtmp); } @@ -704,7 +793,7 @@ register char *mo; checkambfile() /* check date on ambient file */ { - unsigned long afdate; + time_t afdate; if (!vdef(AMBFILE)) return; @@ -719,8 +808,6 @@ double ambval() /* compute ambient value */ { if (vdef(EXPOSURE)) { - if (!isflt(vval(EXPOSURE))) - badvalue(EXPOSURE); if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') return(.5/pow(2.,atof(vval(EXPOSURE)))); return(.5/atof(vval(EXPOSURE))); @@ -733,6 +820,23 @@ ambval() /* compute ambient value */ } +renderopts(op) /* set rendering options */ +char *op; +{ + switch(vscale(QUALITY)) { + case LOW: + lowqopts(op); + break; + case MEDIUM: + medqopts(op); + break; + case HIGH: + hiqopts(op); + break; + } +} + + lowqopts(op) /* low quality rendering options */ register char *op; { @@ -828,7 +932,7 @@ register char *op; } op = addarg(op, "-pt .08"); if (vbool(PENUMBRAS)) - op = addarg(op, "-ds .2 -dj .35"); + op = addarg(op, "-ds .2 -dj .5"); else op = addarg(op, "-ds .3"); op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1"); @@ -1219,6 +1323,8 @@ char *opts; sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname); if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); + if (vdef(EXPOSURE)) + sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE)); strcat(combuf, oct1name); if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error running rview\n", progname); @@ -1238,7 +1344,17 @@ char *opts; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ - mult = vscale(QUALITY)+1; + switch (vscale(QUALITY)) { + case LOW: + mult = 1; + break; + case MEDIUM: + mult = 2; + break; + case HIGH: + mult = 3; + break; + } { int xres, yres; double aspect; @@ -1299,7 +1415,7 @@ char *opts; } sprintf(combuf, "rpict%s %s %s%s %s > %s", rep, vw, res, opts, - oct1name, rawfile); + oct1name, rawfile); } if (runcom(combuf)) { /* run rpict */ fprintf(stderr, "%s: error rendering view %s\n",
