Added some additional (and probably unnecessary) fflush() calls
Using RT_PID instead of int.
Continued ANSIfication.
Minor comment changes
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Moved some more platform dependencies to common header files. Included a few necessary system headers.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed parameter to nvalue()
added vflt() macro
forgot to remove illumtmp file upon oconv failure increased command line length for oconv and getbbox in the case of many files
Changed RAWSAVE to RAWFILE (and changed meaning) added ZFILE variable to rad
added cylindrical view type
added -t (touch) option
compatibility fixes
fixed PC bug in time() call
fixed minor compiler warning
added -pe option to rview
changed fdate() return to unsigned long added illum and mkillum variables for calling mkillum program changed getoctcube() to call getbbox program with -n and no previous octree
fixed view echoing for MS-DOS
added -R option to rview
