Revision: 2.36
Committed: Thu Dec 30 08:20:45 1993 UTC (31 years, 4 months ago) by greg
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14 #include <sys/types.h>
15
16
17 typedef struct {
18 char *name; /* variable name */
19 short nick; /* # characters required for nickname */
20 short nass; /* # assignments made */
21 char *value; /* assigned value(s) */
22 int (*fixval)(); /* assignment checking function */
23 } VARIABLE;
24
25 int onevalue(), catvalues(), boolvalue(),
26 qualvalue(), fltvalue(), intvalue();
27
28 /* variables */
29 #define OBJECT 0 /* object files */
30 #define SCENE 1 /* scene files */
31 #define MATERIAL 2 /* material files */
32 #define ILLUM 3 /* mkillum input files */
33 #define MKILLUM 4 /* mkillum options */
34 #define RENDER 5 /* rendering options */
35 #define OCONV 6 /* oconv options */
36 #define PFILT 7 /* pfilt options */
37 #define VIEW 8 /* view(s) for picture(s) */
38 #define ZONE 9 /* simulation zone */
39 #define QUALITY 10 /* desired rendering quality */
40 #define OCTREE 11 /* octree file name */
41 #define PICTURE 12 /* picture file name */
42 #define AMBFILE 13 /* ambient file name */
43 #define OPTFILE 14 /* rendering options file */
44 #define EXPOSURE 15 /* picture exposure setting */
45 #define RESOLUTION 16 /* maximum picture resolution */
46 #define UP 17 /* view up (X, Y or Z) */
47 #define INDIRECT 18 /* indirection in lighting */
48 #define DETAIL 19 /* level of scene detail */
49 #define PENUMBRAS 20 /* shadow penumbras are desired */
50 #define VARIABILITY 21 /* level of light variability */
51 #define REPORT 22 /* report frequency and errfile */
52 /* total number of variables */
53 #define NVARS 23
54
55 VARIABLE vv[NVARS] = { /* variable-value pairs */
56 {"objects", 3, 0, NULL, catvalues},
57 {"scene", 3, 0, NULL, catvalues},
58 {"materials", 3, 0, NULL, catvalues},
59 {"illum", 3, 0, NULL, catvalues},
60 {"mkillum", 3, 0, NULL, catvalues},
61 {"render", 3, 0, NULL, catvalues},
62 {"oconv", 3, 0, NULL, catvalues},
63 {"pfilt", 2, 0, NULL, catvalues},
64 {"view", 2, 0, NULL, NULL},
65 {"ZONE", 2, 0, NULL, onevalue},
66 {"QUALITY", 3, 0, NULL, qualvalue},
67 {"OCTREE", 3, 0, NULL, onevalue},
68 {"PICTURE", 3, 0, NULL, onevalue},
69 {"AMBFILE", 3, 0, NULL, onevalue},
70 {"OPTFILE", 3, 0, NULL, onevalue},
71 {"EXPOSURE", 3, 0, NULL, fltvalue},
72 {"RESOLUTION", 3, 0, NULL, onevalue},
73 {"UP", 2, 0, NULL, onevalue},
74 {"INDIRECT", 3, 0, NULL, intvalue},
75 {"DETAIL", 3, 0, NULL, qualvalue},
76 {"PENUMBRAS", 3, 0, NULL, boolvalue},
77 {"VARIABILITY", 3, 0, NULL, qualvalue},
78 {"REPORT", 3, 0, NULL, onevalue},
79 };
80
81 VARIABLE *matchvar();
82 char *nvalue();
83
84 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
85
86 #define vnam(vc) (vv[vc].name)
87 #define vdef(vc) (vv[vc].nass)
88 #define vval(vc) (vv[vc].value)
89 #define vint(vc) atoi(vval(vc))
90 #define vlet(vc) UPPER(vval(vc)[0])
91 #define vscale vlet
92 #define vbool(vc) (vlet(vc)=='T')
93
94 #define HIGH 'H'
95 #define MEDIUM 'M'
96 #define LOW 'L'
97
98 /* overture calculation file */
99 #ifdef NIX
100 char overfile[] = "overture.raw";
101 #else
102 char overfile[] = "/dev/null";
103 #endif
104
105 extern time_t fdate(), time();
106
107 time_t scenedate; /* date of latest scene or object file */
108 time_t octreedate; /* date of octree */
109 time_t matdate; /* date of latest material file */
110 time_t illumdate; /* date of last illum file */
111
112 char *oct0name; /* name of pre-mkillum octree */
113 time_t oct0date; /* date of pre-mkillum octree */
114 char *oct1name; /* name of post-mkillum octree */
115 time_t oct1date; /* date of post-mkillum octree (>= matdate) */
116
117 int explicate = 0; /* explicate variables */
118 int silent = 0; /* do work silently */
119 int noaction = 0; /* don't do anything */
120 int sayview = 0; /* print view out */
121 char *rvdevice = NULL; /* rview output device */
122 char *viewselect = NULL; /* specific view only */
123
124 int overture = 0; /* overture calculation needed */
125
126 char *progname; /* global argv[0] */
127 char *rifname; /* global rad input file name */
128
129 char radname[MAXPATH]; /* root Radiance file name */
130
131
132 main(argc, argv)
133 int argc;
134 char *argv[];
135 {
136 char ropts[512];
137 int i;
138
139 progname = argv[0];
140 /* get options */
141 for (i = 1; i < argc && argv[i][0] == '-'; i++)
142 switch (argv[i][1]) {
143 case 's':
144 silent++;
145 break;
146 case 'n':
147 noaction++;
148 break;
149 case 'e':
150 explicate++;
151 break;
152 case 'o':
153 rvdevice = argv[++i];
154 break;
155 case 'V':
156 sayview++;
157 break;
158 case 'v':
159 viewselect = argv[++i];
160 break;
161 default:
162 goto userr;
163 }
164 if (i >= argc)
165 goto userr;
166 rifname = argv[i];
167 /* assign Radiance root file name */
168 rootname(radname, rifname);
169 /* load variable values */
170 load(rifname);
171 /* get any additional assignments */
172 for (i++; i < argc; i++)
173 setvariable(argv[i]);
174 /* check assignments */
175 checkvalues();
176 /* check files and dates */
177 checkfiles();
178 /* set default values as necessary */
179 setdefaults();
180 /* print all values if requested */
181 if (explicate)
182 printvals();
183 /* build octree (and run mkillum) */
184 oconv();
185 /* check date on ambient file */
186 checkambfile();
187 /* run simulation */
188 renderopts(ropts);
189 xferopts(ropts);
190 if (rvdevice != NULL)
191 rview(ropts);
192 else
193 rpict(ropts);
194 exit(0);
195 userr:
196 fprintf(stderr,
197 "Usage: %s [-s][-n][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
198 progname);
199 exit(1);
200 }
201
202
203 rootname(rn, fn) /* remove tail from end of fn */
204 register char *rn, *fn;
205 {
206 char *tp, *dp;
207
208 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
209 if (ISDIRSEP(*rn))
210 dp = rn;
211 else if (*rn == '.')
212 tp = rn;
213 if (tp != NULL && tp > dp)
214 *tp = '\0';
215 }
216
217
218 #define NOCHAR 127 /* constant for character to delete */
219
220
221 load(rfname) /* load Radiance simulation file */
222 char *rfname;
223 {
224 FILE *fp;
225 char buf[512];
226 register char *cp;
227
228 if (rfname == NULL)
229 fp = stdin;
230 else if ((fp = fopen(rfname, "r")) == NULL)
231 syserr(rfname);
232 while (fgetline(buf, sizeof(buf), fp) != NULL) {
233 for (cp = buf; *cp; cp++) {
234 switch (*cp) {
235 case '\\':
236 *cp++ = NOCHAR;
237 continue;
238 case '#':
239 *cp = '\0';
240 break;
241 default:
242 continue;
243 }
244 break;
245 }
246 setvariable(buf);
247 }
248 fclose(fp);
249 }
250
251
252 setvariable(ass) /* assign variable according to string */
253 register char *ass;
254 {
255 char varname[32];
256 int n;
257 register char *cp;
258 register VARIABLE *vp;
259 register int i;
260
261 while (isspace(*ass)) /* skip leading space */
262 ass++;
263 cp = varname; /* extract name */
264 while (cp < varname+sizeof(varname)-1
265 && *ass && !isspace(*ass) && *ass != '=')
266 *cp++ = *ass++;
267 *cp = '\0';
268 if (!varname[0])
269 return; /* no variable name! */
270 /* trim value */
271 while (isspace(*ass) || *ass == '=')
272 ass++;
273 for (n = strlen(ass); n > 0; n--)
274 if (!isspace(ass[n-1]))
275 break;
276 if (!n) {
277 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
278 progname, varname);
279 return;
280 }
281 /* match variable from list */
282 vp = matchvar(varname);
283 if (vp == NULL) {
284 fprintf(stderr, "%s: unknown variable '%s'\n",
285 progname, varname);
286 exit(1);
287 }
288 /* assign new value */
289 if (i = vp->nass) {
290 cp = vp->value;
291 while (i--)
292 while (*cp++)
293 ;
294 i = cp - vp->value;
295 vp->value = realloc(vp->value, i+n+1);
296 } else
297 vp->value = malloc(n+1);
298 if (vp->value == NULL)
299 syserr(progname);
300 cp = vp->value+i; /* copy value, squeezing spaces */
301 *cp = *ass;
302 for (i = 1; i <= n; i++) {
303 if (ass[i] == NOCHAR)
304 continue;
305 if (isspace(*cp))
306 while (isspace(ass[i]))
307 i++;
308 *++cp = ass[i];
309 }
310 if (isspace(*cp)) /* remove trailing space */
311 *cp = '\0';
312 vp->nass++;
313 }
314
315
316 VARIABLE *
317 matchvar(nam) /* match a variable by its name */
318 char *nam;
319 {
320 int n = strlen(nam);
321 register int i;
322
323 for (i = 0; i < NVARS; i++)
324 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
325 return(vv+i);
326 return(NULL);
327 }
328
329
330 char *
331 nvalue(vp, n) /* return nth variable value */
332 VARIABLE *vp;
333 register int n;
334 {
335 register char *cp;
336
337 if (vp == NULL | n < 0 | n >= vp->nass)
338 return(NULL);
339 cp = vp->value;
340 while (n--)
341 while (*cp++)
342 ;
343 return(cp);
344 }
345
346
347 checkvalues() /* check assignments */
348 {
349 register int i;
350
351 for (i = 0; i < NVARS; i++)
352 if (vv[i].fixval != NULL)
353 (*vv[i].fixval)(vv+i);
354 }
355
356
357 onevalue(vp) /* only one assignment for this variable */
358 register VARIABLE *vp;
359 {
360 if (vp->nass < 2)
361 return;
362 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
363 progname, vp->name);
364 do
365 vp->value += strlen(vp->value)+1;
366 while (--vp->nass > 1);
367 }
368
369
370 catvalues(vp) /* concatenate variable values */
371 register VARIABLE *vp;
372 {
373 register char *cp;
374
375 if (vp->nass < 2)
376 return;
377 for (cp = vp->value; vp->nass > 1; vp->nass--) {
378 while (*cp)
379 cp++;
380 *cp++ = ' ';
381 }
382 }
383
384
385 int
386 badmatch(tv, cv) /* case insensitive truncated comparison */
387 register char *tv, *cv;
388 {
389 if (!*tv) return(1); /* null string cannot match */
390 do
391 if (UPPER(*tv) != *cv++)
392 return(1);
393 while (*++tv);
394 return(0); /* OK */
395 }
396
397
398 boolvalue(vp) /* check boolean for legal values */
399 register VARIABLE *vp;
400 {
401 if (!vp->nass) return;
402 onevalue(vp);
403 switch (UPPER(vp->value[0])) {
404 case 'T':
405 if (badmatch(vp->value, "TRUE")) break;
406 return;
407 case 'F':
408 if (badmatch(vp->value, "FALSE")) break;
409 return;
410 }
411 fprintf(stderr, "%s: illegal value for boolean variable '%s'\n",
412 progname, vp->name);
413 exit(1);
414 }
415
416
417 qualvalue(vp) /* check qualitative var. for legal values */
418 register VARIABLE *vp;
419 {
420 if (!vp->nass) return;
421 onevalue(vp);
422 switch (UPPER(vp->value[0])) {
423 case 'L':
424 if (badmatch(vp->value, "LOW")) break;
425 return;
426 case 'M':
427 if (badmatch(vp->value, "MEDIUM")) break;
428 return;
429 case 'H':
430 if (badmatch(vp->value, "HIGH")) break;
431 return;
432 }
433 fprintf(stderr, "%s: illegal value for qualitative variable '%s'\n",
434 progname, vp->name);
435 exit(1);
436 }
437
438
439 intvalue(vp) /* check integer variable for legal values */
440 register VARIABLE *vp;
441 {
442 if (!vp->nass) return;
443 onevalue(vp);
444 if (isint(vp->value)) return;
445 fprintf(stderr, "%s: illegal value for integer variable '%s'\n",
446 progname, vp->name);
447 exit(1);
448 }
449
450
451 fltvalue(vp) /* check float variable for legal values */
452 register VARIABLE *vp;
453 {
454 if (!vp->nass) return;
455 onevalue(vp);
456 if (isflt(vp->value)) return;
457 fprintf(stderr, "%s: illegal value for real variable '%s'\n",
458 progname, vp->name);
459 exit(1);
460 }
461
462
463 time_t
464 checklast(fnames) /* check files and find most recent */
465 register char *fnames;
466 {
467 char thisfile[MAXPATH];
468 time_t thisdate, lastdate = 0;
469 register char *cp;
470
471 if (fnames == NULL)
472 return(0);
473 while (*fnames) {
474 while (isspace(*fnames)) fnames++;
475 cp = thisfile;
476 while (*fnames && !isspace(*fnames))
477 *cp++ = *fnames++;
478 *cp = '\0';
479 if (!(thisdate = fdate(thisfile)))
480 syserr(thisfile);
481 if (thisdate > lastdate)
482 lastdate = thisdate;
483 }
484 return(lastdate);
485 }
486
487
488 char *
489 newfname(orig, pred) /* create modified file name */
490 char *orig;
491 int pred;
492 {
493 extern char *rindex();
494 register char *cp;
495 register int n;
496 int suffix;
497
498 n = 0; cp = orig; suffix = -1; /* suffix position, length */
499 while (*cp) {
500 if (*cp == '.') suffix = n;
501 else if (ISDIRSEP(*cp)) suffix = -1;
502 cp++; n++;
503 }
504 if (suffix == -1) suffix = n;
505 if ((cp = bmalloc(n+2)) == NULL)
506 syserr(progname);
507 strncpy(cp, orig, suffix);
508 cp[suffix] = pred; /* root name + pred + suffix */
509 strcpy(cp+suffix+1, orig+suffix);
510 return(cp);
511 }
512
513
514 checkfiles() /* check for existence and modified times */
515 {
516 time_t objdate;
517
518 if (!vdef(OCTREE)) {
519 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
520 syserr(progname);
521 sprintf(vval(OCTREE), "%s.oct", radname);
522 vdef(OCTREE)++;
523 }
524 octreedate = fdate(vval(OCTREE));
525 if (vdef(ILLUM)) { /* illum requires secondary octrees */
526 oct0name = newfname(vval(OCTREE), '0');
527 oct1name = newfname(vval(OCTREE), '1');
528 oct0date = fdate(oct0name);
529 oct1date = fdate(oct1name);
530 } else
531 oct0name = oct1name = vval(OCTREE);
532 if ((scenedate = checklast(vval(SCENE))) &&
533 (objdate = checklast(vval(OBJECT))) > scenedate)
534 scenedate = objdate;
535 illumdate = checklast(vval(ILLUM));
536 if (!octreedate & !scenedate & !illumdate) {
537 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
538 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
539 exit(1);
540 }
541 matdate = checklast(vval(MATERIAL));
542 }
543
544
545 getoctcube(org, sizp) /* get octree bounding cube */
546 double org[3], *sizp;
547 {
548 extern FILE *popen();
549 static double oorg[3], osiz = 0.;
550 double min[3], max[3];
551 char buf[512];
552 FILE *fp;
553 register int i;
554
555 if (osiz <= FTINY)
556 if (noaction && fdate(oct1name) <
557 (scenedate>illumdate?scenedate:illumdate)) {
558 /* run getbbox */
559 sprintf(buf, "getbbox -w -h %s",
560 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
561 if ((fp = popen(buf, "r")) == NULL)
562 syserr("getbbox");
563 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
564 &min[0], &max[0], &min[1], &max[1],
565 &min[2], &max[2]) != 6) {
566 fprintf(stderr,
567 "%s: error reading bounding box from getbbox\n",
568 progname);
569 exit(1);
570 }
571 for (i = 0; i < 3; i++)
572 if (max[i] - min[i] > osiz)
573 osiz = max[i] - min[i];
574 for (i = 0; i < 3; i++)
575 oorg[i] = (max[i]+min[i]-osiz)*.5;
576 pclose(fp);
577 } else { /* from octree */
578 oconv(); /* does nothing if done already */
579 sprintf(buf, "getinfo -d < %s", oct1name);
580 if ((fp = popen(buf, "r")) == NULL)
581 syserr("getinfo");
582 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
583 &oorg[2], &osiz) != 4) {
584 fprintf(stderr,
585 "%s: error reading bounding cube from getinfo\n",
586 progname);
587 exit(1);
588 }
589 pclose(fp);
590 }
591 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
592 }
593
594
595 setdefaults() /* set default values for unassigned var's */
596 {
597 double org[3], size;
598 char buf[128];
599
600 if (!vdef(ZONE)) {
601 getoctcube(org, &size);
602 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
603 org[1], org[1]+size, org[2], org[2]+size);
604 vval(ZONE) = savqstr(buf);
605 vdef(ZONE)++;
606 }
607 if (!vdef(INDIRECT)) {
608 vval(INDIRECT) = "0";
609 vdef(INDIRECT)++;
610 }
611 if (!vdef(QUALITY)) {
612 vval(QUALITY) = "L";
613 vdef(QUALITY)++;
614 }
615 if (!vdef(RESOLUTION)) {
616 vval(RESOLUTION) = "512";
617 vdef(RESOLUTION)++;
618 }
619 if (!vdef(PICTURE)) {
620 vval(PICTURE) = radname;
621 vdef(PICTURE)++;
622 }
623 if (!vdef(VIEW)) {
624 vval(VIEW) = "X";
625 vdef(VIEW)++;
626 }
627 if (!vdef(DETAIL)) {
628 vval(DETAIL) = "M";
629 vdef(DETAIL)++;
630 }
631 if (!vdef(PENUMBRAS)) {
632 vval(PENUMBRAS) = "F";
633 vdef(PENUMBRAS)++;
634 }
635 if (!vdef(VARIABILITY)) {
636 vval(VARIABILITY) = "L";
637 vdef(VARIABILITY)++;
638 }
639 }
640
641
642 printvals() /* print variable values */
643 {
644 int i, j, clipline;
645 register char *cp;
646 register int k;
647
648 for (i = 0; i < NVARS; i++) /* print each variable */
649 for (j = 0; j < vdef(i); j++) { /* print each assignment */
650 fputs(vnam(i), stdout);
651 fputs("= ", stdout);
652 k = clipline = ( vv[i].fixval == catvalues ? 64 : 320 )
653 - strlen(vnam(i)) ;
654 cp = nvalue(vv+i, j);
655 while (*cp) {
656 putchar(*cp++);
657 if (--k <= 0) { /* line too long */
658 while (*cp && !isspace(*cp))
659 putchar(*cp++); /* finish this word */
660 if (*cp) { /* start new line */
661 putchar('\n');
662 fputs(vnam(i), stdout);
663 putchar('=');
664 k = clipline;
665 }
666 }
667 }
668 putchar('\n');
669 }
670 fflush(stdout);
671 }
672
673
674 oconv() /* run oconv and mkillum if necessary */
675 {
676 static char illumtmp[] = "ilXXXXXX";
677 char combuf[512], ocopts[64], mkopts[64];
678
679 oconvopts(ocopts); /* get options */
680 if (octreedate < scenedate) { /* check date on original octree */
681 /* build command */
682 if (vdef(MATERIAL))
683 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
684 vval(MATERIAL), vval(SCENE), vval(OCTREE));
685 else
686 sprintf(combuf, "oconv%s %s > %s", ocopts,
687 vval(SCENE), vval(OCTREE));
688
689 if (runcom(combuf)) { /* run it */
690 fprintf(stderr,
691 "%s: error generating octree\n\t%s removed\n",
692 progname, vval(OCTREE));
693 unlink(vval(OCTREE));
694 exit(1);
695 }
696 octreedate = time((time_t *)NULL);
697 }
698 if (oct1name == vval(OCTREE)) /* no mkillum? */
699 oct1date = octreedate > matdate ? octreedate : matdate;
700 if (oct1date >= octreedate & oct1date >= matdate
701 & oct1date >= illumdate) /* all done */
702 return;
703 /* make octree0 */
704 if (oct0date < scenedate | oct0date < illumdate) {
705 /* build command */
706 if (octreedate)
707 sprintf(combuf, "oconv%s -i %s %s > %s", ocopts,
708 vval(OCTREE), vval(ILLUM), oct0name);
709 else if (vdef(MATERIAL))
710 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
711 vval(MATERIAL), vval(ILLUM), oct0name);
712 else
713 sprintf(combuf, "oconv%s %s > %s", ocopts,
714 vval(ILLUM), oct0name);
715 if (runcom(combuf)) { /* run it */
716 fprintf(stderr,
717 "%s: error generating octree\n\t%s removed\n",
718 progname, oct0name);
719 unlink(oct0name);
720 exit(1);
721 }
722 oct0date = time((time_t *)NULL);
723 }
724 mkillumopts(mkopts); /* build mkillum command */
725 mktemp(illumtmp);
726 sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts,
727 oct0name, vval(ILLUM), illumtmp);
728 if (runcom(combuf)) { /* run it */
729 fprintf(stderr, "%s: error running mkillum\n", progname);
730 unlink(illumtmp);
731 exit(1);
732 }
733 /* make octree1 (frozen) */
734 if (octreedate)
735 sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts,
736 vval(OCTREE), illumtmp, oct1name);
737 else if (vdef(MATERIAL))
738 sprintf(combuf, "oconv%s -f %s %s > %s", ocopts,
739 vval(MATERIAL), illumtmp, oct1name);
740 else
741 sprintf(combuf, "oconv%s -f %s > %s", ocopts,
742 illumtmp, oct1name);
743 if (runcom(combuf)) { /* run it */
744 fprintf(stderr,
745 "%s: error generating octree\n\t%s removed\n",
746 progname, oct1name);
747 unlink(oct1name);
748 exit(1);
749 }
750 oct1date = time((time_t *)NULL);
751 rmfile(illumtmp);
752 }
753
754
755 char *
756 addarg(op, arg) /* add argument and advance pointer */
757 register char *op, *arg;
758 {
759 *op = ' ';
760 while (*++op = *arg++)
761 ;
762 return(op);
763 }
764
765
766 oconvopts(oo) /* get oconv options */
767 register char *oo;
768 {
769 /* BEWARE: This may be called via setdefaults(), so no assumptions */
770
771 *oo = '\0';
772 if (vdef(OCONV))
773 addarg(oo, vval(OCONV));
774 }
775
776
777 mkillumopts(mo) /* get mkillum options */
778 register char *mo;
779 {
780 /* BEWARE: This may be called via setdefaults(), so no assumptions */
781
782 *mo = '\0';
783 if (vdef(MKILLUM))
784 addarg(mo, vval(MKILLUM));
785 }
786
787
788 checkambfile() /* check date on ambient file */
789 {
790 time_t afdate;
791
792 if (!vdef(AMBFILE))
793 return;
794 if (!(afdate = fdate(vval(AMBFILE))))
795 return;
796 if (oct1date > afdate)
797 rmfile(vval(AMBFILE));
798 }
799
800
801 double
802 ambval() /* compute ambient value */
803 {
804 if (vdef(EXPOSURE)) {
805 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
806 return(.5/pow(2.,atof(vval(EXPOSURE))));
807 return(.5/atof(vval(EXPOSURE)));
808 }
809 if (vlet(ZONE) == 'E')
810 return(10.);
811 if (vlet(ZONE) == 'I')
812 return(.01);
813 badvalue(ZONE);
814 }
815
816
817 renderopts(op) /* set rendering options */
818 char *op;
819 {
820 switch(vscale(QUALITY)) {
821 case LOW:
822 lowqopts(op);
823 break;
824 case MEDIUM:
825 medqopts(op);
826 break;
827 case HIGH:
828 hiqopts(op);
829 break;
830 }
831 }
832
833
834 lowqopts(op) /* low quality rendering options */
835 register char *op;
836 {
837 double d, org[3], siz[3];
838
839 *op = '\0';
840 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
841 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
842 badvalue(ZONE);
843 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
844 getoctcube(org, &d);
845 d *= 3./(siz[0]+siz[1]+siz[2]);
846 switch (vscale(DETAIL)) {
847 case LOW:
848 op = addarg(op, "-ps 16 -dp 64");
849 sprintf(op, " -ar %d", (int)(4*d));
850 op += strlen(op);
851 break;
852 case MEDIUM:
853 op = addarg(op, "-ps 8 -dp 128");
854 sprintf(op, " -ar %d", (int)(8*d));
855 op += strlen(op);
856 break;
857 case HIGH:
858 op = addarg(op, "-ps 4 -dp 256");
859 sprintf(op, " -ar %d", (int)(16*d));
860 op += strlen(op);
861 break;
862 }
863 op = addarg(op, "-pt .16");
864 if (vbool(PENUMBRAS))
865 op = addarg(op, "-ds .4");
866 else
867 op = addarg(op, "-ds 0");
868 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
869 if (vdef(AMBFILE)) {
870 sprintf(op, " -af %s", vval(AMBFILE));
871 op += strlen(op);
872 } else
873 overture = 0;
874 switch (vscale(VARIABILITY)) {
875 case LOW:
876 op = addarg(op, "-aa .4 -ad 64");
877 break;
878 case MEDIUM:
879 op = addarg(op, "-aa .3 -ad 128");
880 break;
881 case HIGH:
882 op = addarg(op, "-aa .25 -ad 256");
883 break;
884 }
885 op = addarg(op, "-as 0");
886 d = ambval();
887 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
888 op += strlen(op);
889 op = addarg(op, "-lr 3 -lw .02");
890 if (vdef(RENDER))
891 op = addarg(op, vval(RENDER));
892 }
893
894
895 medqopts(op) /* medium quality rendering options */
896 register char *op;
897 {
898 double d, org[3], siz[3];
899
900 *op = '\0';
901 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
902 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
903 badvalue(ZONE);
904 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
905 getoctcube(org, &d);
906 d *= 3./(siz[0]+siz[1]+siz[2]);
907 switch (vscale(DETAIL)) {
908 case LOW:
909 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
910 op = addarg(op, "-dp 256");
911 sprintf(op, " -ar %d", (int)(8*d));
912 op += strlen(op);
913 break;
914 case MEDIUM:
915 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
916 op = addarg(op, "-dp 512");
917 sprintf(op, " -ar %d", (int)(16*d));
918 op += strlen(op);
919 break;
920 case HIGH:
921 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
922 op = addarg(op, "-dp 1024");
923 sprintf(op, " -ar %d", (int)(32*d));
924 op += strlen(op);
925 break;
926 }
927 op = addarg(op, "-pt .08");
928 if (vbool(PENUMBRAS))
929 op = addarg(op, "-ds .2 -dj .5");
930 else
931 op = addarg(op, "-ds .3");
932 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
933 if (overture = vint(INDIRECT)) {
934 sprintf(op, " -ab %d", overture);
935 op += strlen(op);
936 }
937 if (vdef(AMBFILE)) {
938 sprintf(op, " -af %s", vval(AMBFILE));
939 op += strlen(op);
940 } else
941 overture = 0;
942 switch (vscale(VARIABILITY)) {
943 case LOW:
944 op = addarg(op, "-aa .25 -ad 196 -as 0");
945 break;
946 case MEDIUM:
947 op = addarg(op, "-aa .2 -ad 400 -as 64");
948 break;
949 case HIGH:
950 op = addarg(op, "-aa .15 -ad 768 -as 196");
951 break;
952 }
953 d = ambval();
954 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
955 op += strlen(op);
956 op = addarg(op, "-lr 6 -lw .002");
957 if (vdef(RENDER))
958 op = addarg(op, vval(RENDER));
959 }
960
961
962 hiqopts(op) /* high quality rendering options */
963 register char *op;
964 {
965 double d, org[3], siz[3];
966
967 *op = '\0';
968 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
969 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
970 badvalue(ZONE);
971 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
972 getoctcube(org, &d);
973 d *= 3./(siz[0]+siz[1]+siz[2]);
974 switch (vscale(DETAIL)) {
975 case LOW:
976 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
977 op = addarg(op, "-dp 1024");
978 sprintf(op, " -ar %d", (int)(16*d));
979 op += strlen(op);
980 break;
981 case MEDIUM:
982 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
983 op = addarg(op, "-dp 2048");
984 sprintf(op, " -ar %d", (int)(32*d));
985 op += strlen(op);
986 break;
987 case HIGH:
988 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
989 op = addarg(op, "-dp 4096");
990 sprintf(op, " -ar %d", (int)(64*d));
991 op += strlen(op);
992 break;
993 }
994 op = addarg(op, "-pt .04");
995 if (vbool(PENUMBRAS))
996 op = addarg(op, "-ds .1 -dj .7");
997 else
998 op = addarg(op, "-ds .2");
999 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
1000 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
1001 op += strlen(op);
1002 if (vdef(AMBFILE)) {
1003 sprintf(op, " -af %s", vval(AMBFILE));
1004 op += strlen(op);
1005 } else
1006 overture = 0;
1007 switch (vscale(VARIABILITY)) {
1008 case LOW:
1009 op = addarg(op, "-aa .15 -ad 256 -as 0");
1010 break;
1011 case MEDIUM:
1012 op = addarg(op, "-aa .125 -ad 512 -as 256");
1013 break;
1014 case HIGH:
1015 op = addarg(op, "-aa .08 -ad 1024 -as 512");
1016 break;
1017 }
1018 d = ambval();
1019 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
1020 op += strlen(op);
1021 op = addarg(op, "-lr 12 -lw .0005");
1022 if (vdef(RENDER))
1023 op = addarg(op, vval(RENDER));
1024 }
1025
1026
1027 xferopts(ro) /* transfer options if indicated */
1028 char *ro;
1029 {
1030 int fd, n;
1031 register char *cp;
1032
1033 n = strlen(ro);
1034 if (n < 2)
1035 return;
1036 if (vdef(OPTFILE)) {
1037 for (cp = ro; cp[1]; cp++)
1038 if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3]))
1039 *cp = '\n';
1040 else
1041 *cp = cp[1];
1042 *cp = '\n';
1043 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
1044 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
1045 syserr(vval(OPTFILE));
1046 sprintf(ro, " @%s", vval(OPTFILE));
1047 }
1048 #ifdef MSDOS
1049 else if (n > 50) {
1050 setenv("ROPT", ro+1);
1051 strcpy(ro, " $ROPT");
1052 }
1053 #endif
1054 }
1055
1056
1057 pfiltopts(po) /* get pfilt options */
1058 register char *po;
1059 {
1060 *po = '\0';
1061 if (vdef(EXPOSURE)) {
1062 po = addarg(po, "-1 -e");
1063 po = addarg(po, vval(EXPOSURE));
1064 }
1065 switch (vscale(QUALITY)) {
1066 case MEDIUM:
1067 po = addarg(po, "-r 1");
1068 break;
1069 case HIGH:
1070 po = addarg(po, "-m .25");
1071 break;
1072 }
1073 if (vdef(PFILT))
1074 po = addarg(po, vval(PFILT));
1075 }
1076
1077
1078 matchword(s1, s2) /* match white-delimited words */
1079 register char *s1, *s2;
1080 {
1081 while (isspace(*s1)) s1++;
1082 while (isspace(*s2)) s2++;
1083 while (*s1 && !isspace(*s1))
1084 if (*s1++ != *s2++)
1085 return(0);
1086 return(!*s2 || isspace(*s2));
1087 }
1088
1089
1090 char *
1091 specview(vs) /* get proper view spec from vs */
1092 register char *vs;
1093 {
1094 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
1095 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
1096 static char viewopts[128];
1097 register char *cp;
1098 int xpos, ypos, zpos, viewtype, upax;
1099 register int i;
1100 double cent[3], dim[3], mult, d;
1101
1102 if (vs == NULL || *vs == '-')
1103 return(vs);
1104 upax = 0; /* get the up vector */
1105 if (vdef(UP)) {
1106 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
1107 upax = 1-'X'+UPPER(vval(UP)[1]);
1108 else
1109 upax = 1-'X'+vlet(UP);
1110 if (upax < 1 | upax > 3)
1111 badvalue(UP);
1112 if (vval(UP)[0] == '-')
1113 upax = -upax;
1114 }
1115 /* check standard view names */
1116 xpos = ypos = zpos = 0;
1117 if (*vs == 'X') {
1118 xpos = 1; vs++;
1119 } else if (*vs == 'x') {
1120 xpos = -1; vs++;
1121 }
1122 if (*vs == 'Y') {
1123 ypos = 1; vs++;
1124 } else if (*vs == 'y') {
1125 ypos = -1; vs++;
1126 }
1127 if (*vs == 'Z') {
1128 zpos = 1; vs++;
1129 } else if (*vs == 'z') {
1130 zpos = -1; vs++;
1131 }
1132 viewtype = 'v';
1133 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
1134 viewtype = *vs++;
1135 cp = viewopts;
1136 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
1137 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
1138 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
1139 &cent[0], &dim[0], &cent[1], &dim[1],
1140 &cent[2], &dim[2]) != 6)
1141 badvalue(ZONE);
1142 for (i = 0; i < 3; i++) {
1143 dim[i] -= cent[i];
1144 cent[i] += .5*dim[i];
1145 }
1146 mult = vlet(ZONE)=='E' ? 2. : .45 ;
1147 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
1148 cent[0]+xpos*mult*dim[0],
1149 cent[1]+ypos*mult*dim[1],
1150 cent[2]+zpos*mult*dim[2],
1151 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
1152 cp += strlen(cp);
1153 /* redirect up axis if necessary */
1154 switch (upax) {
1155 case 3: /* plus or minus Z axis */
1156 case -3:
1157 case 0:
1158 if (!(xpos|ypos))
1159 upax = 2;
1160 break;
1161 case 2: /* plus or minus Y axis */
1162 case -2:
1163 if (!(xpos|zpos))
1164 upax = 1;
1165 break;
1166 case 1: /* plus or minus X axis */
1167 case -1:
1168 if (!(ypos|zpos))
1169 upax = 3;
1170 break;
1171 }
1172 cp = addarg(cp, vup[upax+3]);
1173 switch (viewtype) {
1174 case 'v':
1175 cp = addarg(cp, "-vh 45 -vv 45");
1176 break;
1177 case 'l':
1178 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
1179 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
1180 cp += strlen(cp);
1181 break;
1182 case 'a':
1183 case 'h':
1184 cp = addarg(cp, "-vh 180 -vv 180");
1185 break;
1186 }
1187 } else {
1188 while (!isspace(*vs)) /* else skip id */
1189 if (!*vs++)
1190 return(NULL);
1191 if (upax) { /* specify up vector */
1192 strcpy(cp, vup[upax+3]);
1193 cp += strlen(cp);
1194 }
1195 }
1196 if (cp == viewopts) /* append any additional options */
1197 vs++; /* skip prefixed space if unneeded */
1198 strcpy(cp, vs);
1199 #ifdef MSDOS
1200 if (strlen(viewopts) > 40) {
1201 setenv("VIEW", viewopts);
1202 return("$VIEW");
1203 }
1204 #endif
1205 return(viewopts);
1206 }
1207
1208
1209 char *
1210 getview(n, vn) /* get view n, or NULL if none */
1211 int n;
1212 char *vn; /* returned view name */
1213 {
1214 register char *mv;
1215
1216 if (viewselect != NULL) { /* command-line selected */
1217 if (n) /* only do one */
1218 return(NULL);
1219 if (viewselect[0] == '-') { /* already specified */
1220 if (vn != NULL) *vn = '\0';
1221 return(viewselect);
1222 }
1223 if (vn != NULL) {
1224 for (mv = viewselect; *mv && !isspace(*mv);
1225 *vn++ = *mv++)
1226 ;
1227 *vn = '\0';
1228 }
1229 /* view number? */
1230 if (isint(viewselect))
1231 return(specview(nvalue(vv+VIEW, atoi(viewselect)-1)));
1232 /* check list */
1233 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
1234 if (matchword(viewselect, mv))
1235 return(specview(mv));
1236 return(specview(viewselect)); /* standard view? */
1237 }
1238 mv = nvalue(vv+VIEW, n); /* use view n */
1239 if (vn != NULL & mv != NULL) {
1240 register char *mv2 = mv;
1241 if (*mv2 != '-')
1242 while (*mv2 && !isspace(*mv2))
1243 *vn++ = *mv2++;
1244 *vn = '\0';
1245 }
1246 return(specview(mv));
1247 }
1248
1249
1250 printview(vopts) /* print out selected view */
1251 register char *vopts;
1252 {
1253 extern char *atos(), *getenv();
1254 char buf[256];
1255 FILE *fp;
1256 register char *cp;
1257
1258 if (vopts == NULL)
1259 return(-1);
1260 fputs("VIEW=", stdout);
1261 do {
1262 if (matchword(vopts, "-vf")) { /* expand view file */
1263 vopts = sskip(vopts);
1264 if (!*atos(buf, sizeof(buf), vopts))
1265 return(-1);
1266 if ((fp = fopen(buf, "r")) == NULL)
1267 return(-1);
1268 for (buf[sizeof(buf)-2] = '\n';
1269 fgets(buf, sizeof(buf), fp) != NULL &&
1270 buf[0] != '\n';
1271 buf[sizeof(buf)-2] = '\n') {
1272 if (buf[sizeof(buf)-2] != '\n') {
1273 ungetc(buf[sizeof(buf)-2], fp);
1274 buf[sizeof(buf)-2] = '\0';
1275 }
1276 if (matchword(buf, "VIEW=") ||
1277 matchword(buf, "rview")) {
1278 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1279 putchar(*cp);
1280 }
1281 }
1282 fclose(fp);
1283 vopts = sskip(vopts);
1284 } else {
1285 while (isspace(*vopts))
1286 vopts++;
1287 putchar(' ');
1288 #ifdef MSDOS
1289 if (*vopts == '$') { /* expand env. var. */
1290 if (!*atos(buf, sizeof(buf), vopts+1))
1291 return(-1);
1292 if ((cp = getenv(buf)) == NULL)
1293 return(-1);
1294 fputs(cp, stdout);
1295 vopts = sskip(vopts);
1296 } else
1297 #endif
1298 while (*vopts && !isspace(*vopts))
1299 putchar(*vopts++);
1300 }
1301 } while (*vopts++);
1302 putchar('\n');
1303 return(0);
1304 }
1305
1306
1307 rview(opts) /* run rview with first view */
1308 char *opts;
1309 {
1310 char *vw;
1311 char combuf[512];
1312 /* build command */
1313 if ((vw = getview(0, NULL)) == NULL)
1314 return;
1315 if (sayview)
1316 printview(vw);
1317 sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname);
1318 if (rvdevice != NULL)
1319 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1320 if (vdef(EXPOSURE))
1321 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1322 strcat(combuf, oct1name);
1323 if (runcom(combuf)) { /* run it */
1324 fprintf(stderr, "%s: error running rview\n", progname);
1325 exit(1);
1326 }
1327 }
1328
1329
1330 rpict(opts) /* run rpict and pfilt for each view */
1331 char *opts;
1332 {
1333 char combuf[1024];
1334 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
1335 char pfopts[128];
1336 char vs[32], *vw;
1337 int vn, mult;
1338 /* get pfilt options */
1339 pfiltopts(pfopts);
1340 /* get resolution, reporting */
1341 switch (vscale(QUALITY)) {
1342 case LOW:
1343 mult = 1;
1344 break;
1345 case MEDIUM:
1346 mult = 2;
1347 break;
1348 case HIGH:
1349 mult = 3;
1350 break;
1351 }
1352 {
1353 int xres, yres;
1354 double aspect;
1355 int n;
1356 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1357 if (n == 3)
1358 sprintf(res, "-x %d -y %d -pa %.3f",
1359 mult*xres, mult*yres, aspect);
1360 else if (n) {
1361 if (n == 1) yres = xres;
1362 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1363 } else
1364 badvalue(RESOLUTION);
1365 }
1366 rep[0] = '\0';
1367 if (vdef(REPORT)) {
1368 double minutes;
1369 int n;
1370 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1371 if (n == 2)
1372 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1373 else if (n == 1)
1374 sprintf(rep, " -t %d", (int)(minutes*60));
1375 else
1376 badvalue(REPORT);
1377 }
1378 /* do each view */
1379 vn = 0;
1380 while ((vw = getview(vn++, vs)) != NULL) {
1381 if (sayview)
1382 printview(vw);
1383 if (!vs[0])
1384 sprintf(vs, "%d", vn);
1385 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1386 /* check date on picture */
1387 if (fdate(picfile) >= oct1date)
1388 continue;
1389 /* build rpict command */
1390 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1391 if (fdate(rawfile) >= oct1date) /* recover */
1392 sprintf(combuf, "rpict%s%s -ro %s %s",
1393 rep, opts, rawfile, oct1name);
1394 else {
1395 if (overture) { /* run overture calculation */
1396 sprintf(combuf,
1397 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1398 rep, vw, opts,
1399 oct1name, overfile);
1400 if (runcom(combuf)) {
1401 fprintf(stderr,
1402 "%s: error in overture for view %s\n",
1403 progname, vs);
1404 exit(1);
1405 }
1406 #ifdef NIX
1407 rmfile(overfile);
1408 #endif
1409 }
1410 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1411 rep, vw, res, opts,
1412 oct1name, rawfile);
1413 }
1414 if (runcom(combuf)) { /* run rpict */
1415 fprintf(stderr, "%s: error rendering view %s\n",
1416 progname, vs);
1417 exit(1);
1418 }
1419 /* build pfilt command */
1420 if (mult > 1)
1421 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1422 pfopts, mult, mult, rawfile, picfile);
1423 else
1424 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1425 rawfile, picfile);
1426 if (runcom(combuf)) { /* run pfilt */
1427 fprintf(stderr,
1428 "%s: error filtering view %s\n\t%s removed\n",
1429 progname, vs, picfile);
1430 unlink(picfile);
1431 exit(1);
1432 }
1433 /* remove raw file */
1434 rmfile(rawfile);
1435 }
1436 }
1437
1438
1439 runcom(cs) /* run command */
1440 char *cs;
1441 {
1442 if (!silent) /* echo it */
1443 printf("\t%s\n", cs);
1444 if (noaction)
1445 return(0);
1446 fflush(stdout); /* flush output and pass to shell */
1447 return(system(cs));
1448 }
1449
1450
1451 rmfile(fn) /* remove a file */
1452 char *fn;
1453 {
1454 if (!silent)
1455 #ifdef MSDOS
1456 printf("\tdel %s\n", fn);
1457 #else
1458 printf("\trm -f %s\n", fn);
1459 #endif
1460 if (noaction)
1461 return(0);
1462 return(unlink(fn));
1463 }
1464
1465
1466 #ifdef MSDOS
1467 setenv(vname, value) /* set an environment variable */
1468 char *vname, *value;
1469 {
1470 register char *evp;
1471
1472 evp = bmalloc(strlen(vname)+strlen(value)+2);
1473 if (evp == NULL)
1474 syserr(progname);
1475 sprintf(evp, "%s=%s", vname, value);
1476 if (putenv(evp) != 0) {
1477 fprintf(stderr, "%s: out of environment space\n", progname);
1478 exit(1);
1479 }
1480 if (!silent)
1481 printf("set %s\n", evp);
1482 }
1483 #endif
1484
1485
1486 badvalue(vc) /* report bad variable value and exit */
1487 int vc;
1488 {
1489 fprintf(stderr, "%s: bad value for variable '%s'\n",
1490 progname, vnam(vc));
1491 exit(1);
1492 }
1493
1494
1495 syserr(s) /* report a system error and exit */
1496 char *s;
1497 {
1498 perror(s);
1499 exit(1);
1500 }
