Revision: 2.48
Committed: Tue Dec 12 13:30:14 1995 UTC (29 years, 5 months ago) by greg
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include "vars.h"
14 #include <ctype.h>
15 #include <sys/types.h>
16
17 /* variables */
18 #define OBJECT 0 /* object files */
19 #define SCENE 1 /* scene files */
20 #define MATERIAL 2 /* material files */
21 #define ILLUM 3 /* mkillum input files */
22 #define MKILLUM 4 /* mkillum options */
23 #define RENDER 5 /* rendering options */
24 #define OCONV 6 /* oconv options */
25 #define PFILT 7 /* pfilt options */
26 #define VIEW 8 /* view(s) for picture(s) */
27 #define ZONE 9 /* simulation zone */
28 #define QUALITY 10 /* desired rendering quality */
29 #define OCTREE 11 /* octree file name */
30 #define PICTURE 12 /* picture file root name */
31 #define AMBFILE 13 /* ambient file name */
32 #define OPTFILE 14 /* rendering options file */
33 #define EXPOSURE 15 /* picture exposure setting */
34 #define RESOLUTION 16 /* maximum picture resolution */
35 #define UP 17 /* view up (X, Y or Z) */
36 #define INDIRECT 18 /* indirection in lighting */
37 #define DETAIL 19 /* level of scene detail */
38 #define PENUMBRAS 20 /* shadow penumbras are desired */
39 #define VARIABILITY 21 /* level of light variability */
40 #define REPORT 22 /* report frequency and errfile */
41 #define RAWFILE 23 /* raw picture file root name */
42 #define ZFILE 24 /* distance file root name */
43 /* total number of variables */
44 int NVARS = 25;
45
46 VARIABLE vv[] = { /* variable-value pairs */
47 {"objects", 3, 0, NULL, catvalues},
48 {"scene", 3, 0, NULL, catvalues},
49 {"materials", 3, 0, NULL, catvalues},
50 {"illum", 3, 0, NULL, catvalues},
51 {"mkillum", 3, 0, NULL, catvalues},
52 {"render", 3, 0, NULL, catvalues},
53 {"oconv", 3, 0, NULL, catvalues},
54 {"pfilt", 2, 0, NULL, catvalues},
55 {"view", 2, 0, NULL, NULL},
56 {"ZONE", 2, 0, NULL, onevalue},
57 {"QUALITY", 3, 0, NULL, qualvalue},
58 {"OCTREE", 3, 0, NULL, onevalue},
59 {"PICTURE", 3, 0, NULL, onevalue},
60 {"AMBFILE", 3, 0, NULL, onevalue},
61 {"OPTFILE", 3, 0, NULL, onevalue},
62 {"EXPOSURE", 3, 0, NULL, fltvalue},
63 {"RESOLUTION", 3, 0, NULL, onevalue},
64 {"UP", 2, 0, NULL, onevalue},
65 {"INDIRECT", 3, 0, NULL, intvalue},
66 {"DETAIL", 3, 0, NULL, qualvalue},
67 {"PENUMBRAS", 3, 0, NULL, boolvalue},
68 {"VARIABILITY", 3, 0, NULL, qualvalue},
69 {"REPORT", 3, 0, NULL, onevalue},
70 {"RAWFILE", 3, 0, NULL, onevalue},
71 {"ZFILE", 2, 0, NULL, onevalue},
72 };
73
74 /* overture calculation file */
75 #ifdef NIX
76 char overfile[] = "overture.unf";
77 #else
78 char overfile[] = "/dev/null";
79 #endif
80
81 extern time_t fdate(), time();
82
83 time_t scenedate; /* date of latest scene or object file */
84 time_t octreedate; /* date of octree */
85 time_t matdate; /* date of latest material file */
86 time_t illumdate; /* date of last illum file */
87
88 char *oct0name; /* name of pre-mkillum octree */
89 time_t oct0date; /* date of pre-mkillum octree */
90 char *oct1name; /* name of post-mkillum octree */
91 time_t oct1date; /* date of post-mkillum octree (>= matdate) */
92
93 int nowarn = 0; /* no warnings */
94 int explicate = 0; /* explicate variables */
95 int silent = 0; /* do work silently */
96 int touchonly = 0; /* touch files only */
97 int noaction = 0; /* don't do anything */
98 int sayview = 0; /* print view out */
99 char *rvdevice = NULL; /* rview output device */
100 char *viewselect = NULL; /* specific view only */
101
102 int overture = 0; /* overture calculation needed */
103
104 char *progname; /* global argv[0] */
105 char *rifname; /* global rad input file name */
106
107 char radname[MAXPATH]; /* root Radiance file name */
108
109
110 main(argc, argv)
111 int argc;
112 char *argv[];
113 {
114 char ropts[512];
115 char popts[64];
116 int i;
117
118 progname = argv[0];
119 /* get options */
120 for (i = 1; i < argc && argv[i][0] == '-'; i++)
121 switch (argv[i][1]) {
122 case 's':
123 silent++;
124 break;
125 case 'n':
126 noaction++;
127 break;
128 case 't':
129 touchonly++;
130 break;
131 case 'e':
132 explicate++;
133 break;
134 case 'o':
135 rvdevice = argv[++i];
136 break;
137 case 'V':
138 sayview++;
139 break;
140 case 'v':
141 viewselect = argv[++i];
142 break;
143 case 'w':
144 nowarn++;
145 break;
146 default:
147 goto userr;
148 }
149 if (i >= argc)
150 goto userr;
151 rifname = argv[i];
152 /* assign Radiance root file name */
153 rootname(radname, rifname);
154 /* load variable values */
155 loadvars(rifname);
156 /* get any additional assignments */
157 for (i++; i < argc; i++)
158 setvariable(argv[i]);
159 /* check assignments */
160 checkvalues();
161 /* check files and dates */
162 checkfiles();
163 /* set default values as necessary */
164 setdefaults();
165 /* print all values if requested */
166 if (explicate)
167 printvars(stdout);
168 /* build octree (and run mkillum) */
169 oconv();
170 /* check date on ambient file */
171 checkambfile();
172 /* run simulation */
173 renderopts(ropts, popts);
174 xferopts(ropts);
175 if (rvdevice != NULL)
176 rview(ropts, popts);
177 else
178 rpict(ropts, popts);
179 exit(0);
180 userr:
181 fprintf(stderr,
182 "Usage: %s [-s][-n][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
183 progname);
184 exit(1);
185 }
186
187
188 rootname(rn, fn) /* remove tail from end of fn */
189 register char *rn, *fn;
190 {
191 char *tp, *dp;
192
193 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
194 if (ISDIRSEP(*rn))
195 dp = rn;
196 else if (*rn == '.')
197 tp = rn;
198 if (tp != NULL && tp > dp)
199 *tp = '\0';
200 }
201
202
203 time_t
204 checklast(fnames) /* check files and find most recent */
205 register char *fnames;
206 {
207 char thisfile[MAXPATH];
208 time_t thisdate, lastdate = 0;
209 register char *cp;
210
211 if (fnames == NULL)
212 return(0);
213 while (*fnames) {
214 while (isspace(*fnames)) fnames++;
215 cp = thisfile;
216 while (*fnames && !isspace(*fnames))
217 *cp++ = *fnames++;
218 *cp = '\0';
219 if (!(thisdate = fdate(thisfile)))
220 syserr(thisfile);
221 if (thisdate > lastdate)
222 lastdate = thisdate;
223 }
224 return(lastdate);
225 }
226
227
228 char *
229 newfname(orig, pred) /* create modified file name */
230 char *orig;
231 int pred;
232 {
233 extern char *rindex();
234 register char *cp;
235 register int n;
236 int suffix;
237
238 n = 0; cp = orig; suffix = -1; /* suffix position, length */
239 while (*cp) {
240 if (*cp == '.') suffix = n;
241 else if (ISDIRSEP(*cp)) suffix = -1;
242 cp++; n++;
243 }
244 if (suffix == -1) suffix = n;
245 if ((cp = bmalloc(n+2)) == NULL)
246 syserr(progname);
247 strncpy(cp, orig, suffix);
248 cp[suffix] = pred; /* root name + pred + suffix */
249 strcpy(cp+suffix+1, orig+suffix);
250 return(cp);
251 }
252
253
254 checkfiles() /* check for existence and modified times */
255 {
256 time_t objdate;
257
258 if (!vdef(OCTREE)) {
259 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
260 syserr(progname);
261 sprintf(vval(OCTREE), "%s.oct", radname);
262 vdef(OCTREE)++;
263 }
264 octreedate = fdate(vval(OCTREE));
265 if (vdef(ILLUM)) { /* illum requires secondary octrees */
266 oct0name = newfname(vval(OCTREE), '0');
267 oct1name = newfname(vval(OCTREE), '1');
268 oct0date = fdate(oct0name);
269 oct1date = fdate(oct1name);
270 } else
271 oct0name = oct1name = vval(OCTREE);
272 if ((scenedate = checklast(vval(SCENE))) &&
273 (objdate = checklast(vval(OBJECT))) > scenedate)
274 scenedate = objdate;
275 illumdate = checklast(vval(ILLUM));
276 if (!octreedate & !scenedate & !illumdate) {
277 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
278 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
279 exit(1);
280 }
281 matdate = checklast(vval(MATERIAL));
282 }
283
284
285 getoctcube(org, sizp) /* get octree bounding cube */
286 double org[3], *sizp;
287 {
288 extern FILE *popen();
289 static double oorg[3], osiz = 0.;
290 double min[3], max[3];
291 char buf[1024];
292 FILE *fp;
293 register int i;
294
295 if (osiz <= FTINY)
296 if (noaction && fdate(oct1name) <
297 (scenedate>illumdate?scenedate:illumdate)) {
298 /* run getbbox */
299 sprintf(buf, "getbbox -w -h %s",
300 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
301 if ((fp = popen(buf, "r")) == NULL)
302 syserr("getbbox");
303 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
304 &min[0], &max[0], &min[1], &max[1],
305 &min[2], &max[2]) != 6) {
306 fprintf(stderr,
307 "%s: error reading bounding box from getbbox\n",
308 progname);
309 exit(1);
310 }
311 for (i = 0; i < 3; i++)
312 if (max[i] - min[i] > osiz)
313 osiz = max[i] - min[i];
314 for (i = 0; i < 3; i++)
315 oorg[i] = (max[i]+min[i]-osiz)*.5;
316 pclose(fp);
317 } else { /* from octree */
318 oconv(); /* does nothing if done already */
319 sprintf(buf, "getinfo -d < %s", oct1name);
320 if ((fp = popen(buf, "r")) == NULL)
321 syserr("getinfo");
322 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
323 &oorg[2], &osiz) != 4) {
324 fprintf(stderr,
325 "%s: error reading bounding cube from getinfo\n",
326 progname);
327 exit(1);
328 }
329 pclose(fp);
330 }
331 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
332 }
333
334
335 setdefaults() /* set default values for unassigned var's */
336 {
337 double org[3], size;
338 char buf[128];
339
340 if (!vdef(ZONE)) {
341 getoctcube(org, &size);
342 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
343 org[1], org[1]+size, org[2], org[2]+size);
344 vval(ZONE) = savqstr(buf);
345 vdef(ZONE)++;
346 }
347 if (!vdef(INDIRECT)) {
348 vval(INDIRECT) = "0";
349 vdef(INDIRECT)++;
350 }
351 if (!vdef(QUALITY)) {
352 vval(QUALITY) = "L";
353 vdef(QUALITY)++;
354 }
355 if (!vdef(RESOLUTION)) {
356 vval(RESOLUTION) = "512";
357 vdef(RESOLUTION)++;
358 }
359 if (!vdef(PICTURE)) {
360 vval(PICTURE) = radname;
361 vdef(PICTURE)++;
362 }
363 if (!vdef(VIEW)) {
364 vval(VIEW) = "X";
365 vdef(VIEW)++;
366 }
367 if (!vdef(DETAIL)) {
368 vval(DETAIL) = "M";
369 vdef(DETAIL)++;
370 }
371 if (!vdef(PENUMBRAS)) {
372 vval(PENUMBRAS) = "F";
373 vdef(PENUMBRAS)++;
374 }
375 if (!vdef(VARIABILITY)) {
376 vval(VARIABILITY) = "L";
377 vdef(VARIABILITY)++;
378 }
379 }
380
381
382 oconv() /* run oconv and mkillum if necessary */
383 {
384 static char illumtmp[] = "ilXXXXXX";
385 char combuf[1024], ocopts[64], mkopts[64];
386
387 oconvopts(ocopts); /* get options */
388 if (octreedate < scenedate) { /* check date on original octree */
389 if (touchonly && octreedate)
390 touch(vval(OCTREE));
391 else { /* build command */
392 if (vdef(MATERIAL))
393 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
394 vval(MATERIAL), vval(SCENE),
395 vval(OCTREE));
396 else
397 sprintf(combuf, "oconv%s %s > %s", ocopts,
398 vval(SCENE), vval(OCTREE));
399
400 if (runcom(combuf)) { /* run it */
401 fprintf(stderr,
402 "%s: error generating octree\n\t%s removed\n",
403 progname, vval(OCTREE));
404 unlink(vval(OCTREE));
405 exit(1);
406 }
407 }
408 octreedate = time((time_t *)NULL);
409 if (octreedate < scenedate) /* in case clock is off */
410 octreedate = scenedate;
411 }
412 if (oct1name == vval(OCTREE)) /* no mkillum? */
413 oct1date = octreedate > matdate ? octreedate : matdate;
414 if (oct1date >= octreedate & oct1date >= matdate
415 & oct1date >= illumdate) /* all done */
416 return;
417 /* make octree0 */
418 if (oct0date < scenedate | oct0date < illumdate) {
419 if (touchonly && oct0date)
420 touch(oct0name);
421 else { /* build command */
422 if (octreedate)
423 sprintf(combuf, "oconv%s -i %s %s > %s", ocopts,
424 vval(OCTREE), vval(ILLUM), oct0name);
425 else if (vdef(MATERIAL))
426 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
427 vval(MATERIAL), vval(ILLUM), oct0name);
428 else
429 sprintf(combuf, "oconv%s %s > %s", ocopts,
430 vval(ILLUM), oct0name);
431 if (runcom(combuf)) { /* run it */
432 fprintf(stderr,
433 "%s: error generating octree\n\t%s removed\n",
434 progname, oct0name);
435 unlink(oct0name);
436 exit(1);
437 }
438 }
439 oct0date = time((time_t *)NULL);
440 if (oct0date < octreedate) /* in case clock is off */
441 oct0date = octreedate;
442 if (oct0date < illumdate) /* ditto */
443 oct0date = illumdate;
444 }
445 if (touchonly && oct1date)
446 touch(oct1name);
447 else {
448 mkillumopts(mkopts); /* build mkillum command */
449 mktemp(illumtmp);
450 sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts,
451 oct0name, vval(ILLUM), illumtmp);
452 if (runcom(combuf)) { /* run it */
453 fprintf(stderr, "%s: error running mkillum\n",
454 progname);
455 unlink(illumtmp);
456 exit(1);
457 }
458 /* make octree1 (frozen) */
459 if (octreedate)
460 sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts,
461 vval(OCTREE), illumtmp, oct1name);
462 else if (vdef(MATERIAL))
463 sprintf(combuf, "oconv%s -f %s %s > %s", ocopts,
464 vval(MATERIAL), illumtmp, oct1name);
465 else
466 sprintf(combuf, "oconv%s -f %s > %s", ocopts,
467 illumtmp, oct1name);
468 if (runcom(combuf)) { /* run it */
469 fprintf(stderr,
470 "%s: error generating octree\n\t%s removed\n",
471 progname, oct1name);
472 unlink(oct1name);
473 unlink(illumtmp);
474 exit(1);
475 }
476 rmfile(illumtmp);
477 }
478 oct1date = time((time_t *)NULL);
479 if (oct1date < oct0date) /* in case clock is off */
480 oct1date = oct0date;
481 }
482
483
484 char *
485 addarg(op, arg) /* add argument and advance pointer */
486 register char *op, *arg;
487 {
488 *op = ' ';
489 while (*++op = *arg++)
490 ;
491 return(op);
492 }
493
494
495 oconvopts(oo) /* get oconv options */
496 register char *oo;
497 {
498 /* BEWARE: This may be called via setdefaults(), so no assumptions */
499
500 *oo = '\0';
501 if (vdef(OCONV))
502 addarg(oo, vval(OCONV));
503 }
504
505
506 mkillumopts(mo) /* get mkillum options */
507 register char *mo;
508 {
509 /* BEWARE: This may be called via setdefaults(), so no assumptions */
510
511 *mo = '\0';
512 if (vdef(MKILLUM))
513 addarg(mo, vval(MKILLUM));
514 }
515
516
517 checkambfile() /* check date on ambient file */
518 {
519 time_t afdate;
520
521 if (!vdef(AMBFILE))
522 return;
523 if (!(afdate = fdate(vval(AMBFILE))))
524 return;
525 if (oct1date > afdate)
526 if (touchonly)
527 touch(vval(AMBFILE));
528 else
529 rmfile(vval(AMBFILE));
530 }
531
532
533 double
534 ambval() /* compute ambient value */
535 {
536 if (vdef(EXPOSURE)) {
537 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
538 return(.5/pow(2.,atof(vval(EXPOSURE))));
539 return(.5/atof(vval(EXPOSURE)));
540 }
541 if (vlet(ZONE) == 'E')
542 return(10.);
543 if (vlet(ZONE) == 'I')
544 return(.01);
545 badvalue(ZONE);
546 }
547
548
549 renderopts(op, po) /* set rendering options */
550 char *op, *po;
551 {
552 switch(vscale(QUALITY)) {
553 case LOW:
554 lowqopts(op, po);
555 break;
556 case MEDIUM:
557 medqopts(op, po);
558 break;
559 case HIGH:
560 hiqopts(op, po);
561 break;
562 }
563 }
564
565
566 lowqopts(op, po) /* low quality rendering options */
567 register char *op;
568 char *po;
569 {
570 double d, org[3], siz[3];
571
572 *op = '\0';
573 *po = '\0';
574 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
575 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
576 badvalue(ZONE);
577 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
578 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
579 badvalue(ZONE);
580 getoctcube(org, &d);
581 d *= 3./(siz[0]+siz[1]+siz[2]);
582 switch (vscale(DETAIL)) {
583 case LOW:
584 po = addarg(po, "-ps 16");
585 op = addarg(op, "-dp 64");
586 sprintf(op, " -ar %d", (int)(4*d));
587 op += strlen(op);
588 break;
589 case MEDIUM:
590 po = addarg(po, "-ps 8");
591 op = addarg(op, "-dp 128");
592 sprintf(op, " -ar %d", (int)(8*d));
593 op += strlen(op);
594 break;
595 case HIGH:
596 po = addarg(po, "-ps 4");
597 op = addarg(op, "-dp 256");
598 sprintf(op, " -ar %d", (int)(16*d));
599 op += strlen(op);
600 break;
601 }
602 po = addarg(po, "-pt .16");
603 if (vbool(PENUMBRAS))
604 op = addarg(op, "-ds .4");
605 else
606 op = addarg(op, "-ds 0");
607 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
608 if (vdef(AMBFILE)) {
609 sprintf(op, " -af %s", vval(AMBFILE));
610 op += strlen(op);
611 } else
612 overture = 0;
613 switch (vscale(VARIABILITY)) {
614 case LOW:
615 op = addarg(op, "-aa .4 -ad 64");
616 break;
617 case MEDIUM:
618 op = addarg(op, "-aa .3 -ad 128");
619 break;
620 case HIGH:
621 op = addarg(op, "-aa .25 -ad 256");
622 break;
623 }
624 op = addarg(op, "-as 0");
625 d = ambval();
626 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
627 op += strlen(op);
628 op = addarg(op, "-lr 3 -lw .02");
629 if (vdef(RENDER))
630 op = addarg(op, vval(RENDER));
631 }
632
633
634 medqopts(op, po) /* medium quality rendering options */
635 register char *op;
636 char *po;
637 {
638 double d, org[3], siz[3], asz;
639
640 *op = '\0';
641 *po = '\0';
642 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
643 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
644 badvalue(ZONE);
645 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
646 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
647 badvalue(ZONE);
648 getoctcube(org, &d);
649 asz = (siz[0]+siz[1]+siz[2])/3.;
650 d /= asz;
651 switch (vscale(DETAIL)) {
652 case LOW:
653 po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
654 op = addarg(op, "-dp 256");
655 sprintf(op, " -ar %d", (int)(8*d));
656 op += strlen(op);
657 sprintf(op, " -ms %.2g", asz/20.);
658 op += strlen(op);
659 break;
660 case MEDIUM:
661 po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
662 op = addarg(op, "-dp 512");
663 sprintf(op, " -ar %d", (int)(16*d));
664 op += strlen(op);
665 sprintf(op, " -ms %.2g", asz/40.);
666 op += strlen(op);
667 break;
668 case HIGH:
669 po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
670 op = addarg(op, "-dp 1024");
671 sprintf(op, " -ar %d", (int)(32*d));
672 op += strlen(op);
673 sprintf(op, " -ms %.2g", asz/80.);
674 op += strlen(op);
675 break;
676 }
677 po = addarg(po, "-pt .08");
678 if (vbool(PENUMBRAS))
679 op = addarg(op, "-ds .2 -dj .5");
680 else
681 op = addarg(op, "-ds .3");
682 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
683 if (overture = vint(INDIRECT)) {
684 sprintf(op, " -ab %d", overture);
685 op += strlen(op);
686 }
687 if (vdef(AMBFILE)) {
688 sprintf(op, " -af %s", vval(AMBFILE));
689 op += strlen(op);
690 } else
691 overture = 0;
692 switch (vscale(VARIABILITY)) {
693 case LOW:
694 op = addarg(op, "-aa .25 -ad 196 -as 0");
695 break;
696 case MEDIUM:
697 op = addarg(op, "-aa .2 -ad 400 -as 64");
698 break;
699 case HIGH:
700 op = addarg(op, "-aa .15 -ad 768 -as 196");
701 break;
702 }
703 d = ambval();
704 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
705 op += strlen(op);
706 op = addarg(op, "-lr 6 -lw .002");
707 if (vdef(RENDER))
708 op = addarg(op, vval(RENDER));
709 }
710
711
712 hiqopts(op, po) /* high quality rendering options */
713 register char *op;
714 char *po;
715 {
716 double d, org[3], siz[3], asz;
717
718 *op = '\0';
719 *po = '\0';
720 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
721 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
722 badvalue(ZONE);
723 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
724 if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY)
725 badvalue(ZONE);
726 getoctcube(org, &d);
727 asz = (siz[0]+siz[1]+siz[2])/3.;
728 d /= asz;
729 switch (vscale(DETAIL)) {
730 case LOW:
731 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
732 op = addarg(op, "-dp 1024");
733 sprintf(op, " -ar %d", (int)(16*d));
734 op += strlen(op);
735 sprintf(op, " -ms %.2g", asz/40.);
736 op += strlen(op);
737 break;
738 case MEDIUM:
739 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
740 op = addarg(op, "-dp 2048");
741 sprintf(op, " -ar %d", (int)(32*d));
742 op += strlen(op);
743 sprintf(op, " -ms %.2g", asz/80.);
744 op += strlen(op);
745 break;
746 case HIGH:
747 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
748 op = addarg(op, "-dp 4096");
749 sprintf(op, " -ar %d", (int)(64*d));
750 op += strlen(op);
751 sprintf(op, " -ms %.2g", asz/160.);
752 op += strlen(op);
753 break;
754 }
755 po = addarg(po, "-pt .04");
756 if (vbool(PENUMBRAS))
757 op = addarg(op, "-ds .1 -dj .65");
758 else
759 op = addarg(op, "-ds .2");
760 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
761 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
762 op += strlen(op);
763 if (vdef(AMBFILE)) {
764 sprintf(op, " -af %s", vval(AMBFILE));
765 op += strlen(op);
766 } else
767 overture = 0;
768 switch (vscale(VARIABILITY)) {
769 case LOW:
770 op = addarg(op, "-aa .15 -ad 256 -as 0");
771 break;
772 case MEDIUM:
773 op = addarg(op, "-aa .125 -ad 512 -as 256");
774 break;
775 case HIGH:
776 op = addarg(op, "-aa .08 -ad 1024 -as 512");
777 break;
778 }
779 d = ambval();
780 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
781 op += strlen(op);
782 op = addarg(op, "-lr 12 -lw .0005");
783 if (vdef(RENDER))
784 op = addarg(op, vval(RENDER));
785 }
786
787
788 xferopts(ro) /* transfer options if indicated */
789 char *ro;
790 {
791 int fd, n;
792 register char *cp;
793
794 n = strlen(ro);
795 if (n < 2)
796 return;
797 if (vdef(OPTFILE)) {
798 for (cp = ro; cp[1]; cp++)
799 if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3]))
800 *cp = '\n';
801 else
802 *cp = cp[1];
803 *cp = '\n';
804 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
805 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
806 syserr(vval(OPTFILE));
807 sprintf(ro, " @%s", vval(OPTFILE));
808 }
809 #ifdef MSDOS
810 else if (n > 50) {
811 setenv("ROPT", ro+1);
812 strcpy(ro, " $ROPT");
813 }
814 #endif
815 }
816
817
818 pfiltopts(po) /* get pfilt options */
819 register char *po;
820 {
821 *po = '\0';
822 if (vdef(EXPOSURE)) {
823 po = addarg(po, "-1 -e");
824 po = addarg(po, vval(EXPOSURE));
825 }
826 switch (vscale(QUALITY)) {
827 case MEDIUM:
828 po = addarg(po, "-r 1");
829 break;
830 case HIGH:
831 po = addarg(po, "-m .25");
832 break;
833 }
834 if (vdef(PFILT))
835 po = addarg(po, vval(PFILT));
836 }
837
838
839 matchword(s1, s2) /* match white-delimited words */
840 register char *s1, *s2;
841 {
842 while (isspace(*s1)) s1++;
843 while (isspace(*s2)) s2++;
844 while (*s1 && !isspace(*s1))
845 if (*s1++ != *s2++)
846 return(0);
847 return(!*s2 || isspace(*s2));
848 }
849
850
851 char *
852 specview(vs) /* get proper view spec from vs */
853 register char *vs;
854 {
855 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
856 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
857 static char viewopts[128];
858 register char *cp;
859 int xpos, ypos, zpos, viewtype, upax;
860 register int i;
861 double cent[3], dim[3], mult, d;
862
863 if (vs == NULL || *vs == '-')
864 return(vs);
865 upax = 0; /* get the up vector */
866 if (vdef(UP)) {
867 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
868 upax = 1-'X'+UPPER(vval(UP)[1]);
869 else
870 upax = 1-'X'+vlet(UP);
871 if (upax < 1 | upax > 3)
872 badvalue(UP);
873 if (vval(UP)[0] == '-')
874 upax = -upax;
875 }
876 /* check standard view names */
877 xpos = ypos = zpos = 0;
878 if (*vs == 'X') {
879 xpos = 1; vs++;
880 } else if (*vs == 'x') {
881 xpos = -1; vs++;
882 }
883 if (*vs == 'Y') {
884 ypos = 1; vs++;
885 } else if (*vs == 'y') {
886 ypos = -1; vs++;
887 }
888 if (*vs == 'Z') {
889 zpos = 1; vs++;
890 } else if (*vs == 'z') {
891 zpos = -1; vs++;
892 }
893 viewtype = 'v';
894 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h' | *vs == 'c')
895 viewtype = *vs++;
896 cp = viewopts;
897 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
898 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
899 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
900 &cent[0], &dim[0], &cent[1], &dim[1],
901 &cent[2], &dim[2]) != 6)
902 badvalue(ZONE);
903 for (i = 0; i < 3; i++) {
904 dim[i] -= cent[i];
905 if (dim[i] <= FTINY)
906 badvalue(ZONE);
907 cent[i] += .5*dim[i];
908 }
909 mult = vlet(ZONE)=='E' ? 2. : .45 ;
910 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
911 cent[0]+xpos*mult*dim[0],
912 cent[1]+ypos*mult*dim[1],
913 cent[2]+zpos*mult*dim[2],
914 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
915 cp += strlen(cp);
916 /* redirect up axis if necessary */
917 switch (upax) {
918 case 3: /* plus or minus Z axis */
919 case -3:
920 case 0:
921 if (!(xpos|ypos))
922 upax = 2;
923 break;
924 case 2: /* plus or minus Y axis */
925 case -2:
926 if (!(xpos|zpos))
927 upax = 1;
928 break;
929 case 1: /* plus or minus X axis */
930 case -1:
931 if (!(ypos|zpos))
932 upax = 3;
933 break;
934 }
935 cp = addarg(cp, vup[upax+3]);
936 switch (viewtype) {
937 case 'v':
938 cp = addarg(cp, "-vh 45 -vv 45");
939 break;
940 case 'l':
941 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
942 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
943 cp += strlen(cp);
944 break;
945 case 'a':
946 case 'h':
947 cp = addarg(cp, "-vh 180 -vv 180");
948 break;
949 case 'c':
950 cp = addarg(cp, "-vh 180 -vv 90");
951 break;
952 }
953 } else {
954 while (!isspace(*vs)) /* else skip id */
955 if (!*vs++)
956 return(NULL);
957 if (upax) { /* specify up vector */
958 strcpy(cp, vup[upax+3]);
959 cp += strlen(cp);
960 }
961 }
962 if (cp == viewopts) /* append any additional options */
963 vs++; /* skip prefixed space if unneeded */
964 strcpy(cp, vs);
965 #ifdef MSDOS
966 if (strlen(viewopts) > 40) {
967 setenv("VIEW", viewopts);
968 return("$VIEW");
969 }
970 #endif
971 return(viewopts);
972 }
973
974
975 char *
976 getview(n, vn) /* get view n, or NULL if none */
977 int n;
978 char *vn; /* returned view name */
979 {
980 register char *mv;
981
982 if (viewselect != NULL) { /* command-line selected */
983 if (n) /* only do one */
984 return(NULL);
985 if (viewselect[0] == '-') { /* already specified */
986 if (vn != NULL) *vn = '\0';
987 return(viewselect);
988 }
989 if (vn != NULL) {
990 for (mv = viewselect; *mv && !isspace(*mv);
991 *vn++ = *mv++)
992 ;
993 *vn = '\0';
994 }
995 /* view number? */
996 if (isint(viewselect))
997 return(specview(nvalue(vv+VIEW, atoi(viewselect)-1)));
998 /* check list */
999 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
1000 if (matchword(viewselect, mv))
1001 return(specview(mv));
1002 return(specview(viewselect)); /* standard view? */
1003 }
1004 mv = nvalue(vv+VIEW, n); /* use view n */
1005 if (vn != NULL & mv != NULL) {
1006 register char *mv2 = mv;
1007 if (*mv2 != '-')
1008 while (*mv2 && !isspace(*mv2))
1009 *vn++ = *mv2++;
1010 *vn = '\0';
1011 }
1012 return(specview(mv));
1013 }
1014
1015
1016 printview(vopts) /* print out selected view */
1017 register char *vopts;
1018 {
1019 extern char *atos(), *getenv();
1020 char buf[256];
1021 FILE *fp;
1022 register char *cp;
1023
1024 if (vopts == NULL)
1025 return(-1);
1026 fputs("VIEW=", stdout);
1027 do {
1028 if (matchword(vopts, "-vf")) { /* expand view file */
1029 vopts = sskip(vopts);
1030 if (!*atos(buf, sizeof(buf), vopts))
1031 return(-1);
1032 if ((fp = fopen(buf, "r")) == NULL)
1033 return(-1);
1034 for (buf[sizeof(buf)-2] = '\n';
1035 fgets(buf, sizeof(buf), fp) != NULL &&
1036 buf[0] != '\n';
1037 buf[sizeof(buf)-2] = '\n') {
1038 if (buf[sizeof(buf)-2] != '\n') {
1039 ungetc(buf[sizeof(buf)-2], fp);
1040 buf[sizeof(buf)-2] = '\0';
1041 }
1042 if (matchword(buf, "VIEW=") ||
1043 matchword(buf, "rview")) {
1044 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1045 putchar(*cp);
1046 }
1047 }
1048 fclose(fp);
1049 vopts = sskip(vopts);
1050 } else {
1051 while (isspace(*vopts))
1052 vopts++;
1053 putchar(' ');
1054 #ifdef MSDOS
1055 if (*vopts == '$') { /* expand env. var. */
1056 if (!*atos(buf, sizeof(buf), vopts+1))
1057 return(-1);
1058 if ((cp = getenv(buf)) == NULL)
1059 return(-1);
1060 fputs(cp, stdout);
1061 vopts = sskip(vopts);
1062 } else
1063 #endif
1064 while (*vopts && !isspace(*vopts))
1065 putchar(*vopts++);
1066 }
1067 } while (*vopts++);
1068 putchar('\n');
1069 return(0);
1070 }
1071
1072
1073 rview(opts, po) /* run rview with first view */
1074 char *opts, *po;
1075 {
1076 char *vw;
1077 char combuf[512];
1078 /* build command */
1079 if (touchonly || (vw = getview(0, NULL)) == NULL)
1080 return;
1081 if (sayview)
1082 printview(vw);
1083 sprintf(combuf, "rview %s%s%s -R %s ", vw, po, opts, rifname);
1084 if (rvdevice != NULL)
1085 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1086 if (vdef(EXPOSURE))
1087 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1088 strcat(combuf, oct1name);
1089 if (runcom(combuf)) { /* run it */
1090 fprintf(stderr, "%s: error running rview\n", progname);
1091 exit(1);
1092 }
1093 }
1094
1095
1096 rpict(opts, po) /* run rpict and pfilt for each view */
1097 char *opts, *po;
1098 {
1099 char combuf[1024];
1100 char rawfile[MAXPATH], picfile[MAXPATH];
1101 char zopt[MAXPATH+4], rep[MAXPATH+16], res[32];
1102 char pfopts[128];
1103 char vs[32], *vw;
1104 int vn, mult;
1105 time_t rfdt, pfdt;
1106 /* get pfilt options */
1107 pfiltopts(pfopts);
1108 /* get resolution, reporting */
1109 switch (vscale(QUALITY)) {
1110 case LOW:
1111 mult = 1;
1112 break;
1113 case MEDIUM:
1114 mult = 2;
1115 break;
1116 case HIGH:
1117 mult = 3;
1118 break;
1119 }
1120 {
1121 int xres, yres;
1122 double aspect;
1123 int n;
1124 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1125 if (n == 3)
1126 sprintf(res, "-x %d -y %d -pa %.3f",
1127 mult*xres, mult*yres, aspect);
1128 else if (n) {
1129 if (n == 1) yres = xres;
1130 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1131 } else
1132 badvalue(RESOLUTION);
1133 }
1134 rep[0] = '\0';
1135 if (vdef(REPORT)) {
1136 double minutes;
1137 int n;
1138 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1139 if (n == 2)
1140 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1141 else if (n == 1)
1142 sprintf(rep, " -t %d", (int)(minutes*60));
1143 else
1144 badvalue(REPORT);
1145 }
1146 /* do each view */
1147 vn = 0;
1148 while ((vw = getview(vn++, vs)) != NULL) {
1149 if (sayview)
1150 printview(vw);
1151 if (!vs[0])
1152 sprintf(vs, "%d", vn);
1153 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1154 if (vdef(ZFILE))
1155 sprintf(zopt, " -z %s_%s.zbf", vval(ZFILE), vs);
1156 else
1157 zopt[0] = '\0';
1158 /* check date on picture */
1159 pfdt = fdate(picfile);
1160 if (pfdt >= oct1date)
1161 continue;
1162 /* get raw file name */
1163 sprintf(rawfile, "%s_%s.unf",
1164 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE), vs);
1165 rfdt = fdate(rawfile);
1166 if (touchonly) { /* update times only */
1167 if (rfdt) {
1168 if (rfdt < oct1date)
1169 touch(rawfile);
1170 } else if (pfdt && pfdt < oct1date)
1171 touch(picfile);
1172 continue;
1173 }
1174 /* build rpict command */
1175 if (rfdt >= oct1date) /* recover */
1176 sprintf(combuf, "rpict%s%s%s%s -ro %s %s",
1177 rep, po, opts, zopt, rawfile, oct1name);
1178 else {
1179 if (overture) { /* run overture calculation */
1180 sprintf(combuf,
1181 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1182 rep, vw, opts,
1183 oct1name, overfile);
1184 if (runcom(combuf)) {
1185 fprintf(stderr,
1186 "%s: error in overture for view %s\n",
1187 progname, vs);
1188 exit(1);
1189 }
1190 #ifdef NIX
1191 rmfile(overfile);
1192 #endif
1193 }
1194 sprintf(combuf, "rpict%s %s %s%s%s%s %s > %s",
1195 rep, vw, res, po, opts, zopt,
1196 oct1name, rawfile);
1197 }
1198 if (runcom(combuf)) { /* run rpict */
1199 fprintf(stderr, "%s: error rendering view %s\n",
1200 progname, vs);
1201 exit(1);
1202 }
1203 if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) {
1204 /* build pfilt command */
1205 if (mult > 1)
1206 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1207 pfopts, mult, mult, rawfile, picfile);
1208 else
1209 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1210 rawfile, picfile);
1211 if (runcom(combuf)) { /* run pfilt */
1212 fprintf(stderr,
1213 "%s: error filtering view %s\n\t%s removed\n",
1214 progname, vs, picfile);
1215 unlink(picfile);
1216 exit(1);
1217 }
1218 }
1219 /* remove/rename raw file */
1220 if (vdef(RAWFILE)) {
1221 sprintf(combuf, "%s_%s.pic", vval(RAWFILE), vs);
1222 mvfile(rawfile, combuf);
1223 } else
1224 rmfile(rawfile);
1225 }
1226 }
1227
1228
1229 touch(fn) /* update a file */
1230 char *fn;
1231 {
1232 if (!silent)
1233 printf("\ttouch %s\n", fn);
1234 if (noaction)
1235 return(0);
1236 #ifdef notused
1237 if (access(fn, F_OK) == -1) /* create it */
1238 if (close(open(fn, O_WRONLY|O_CREAT, 0666)) == -1)
1239 return(-1);
1240 #endif
1241 return(setfdate(fn, time((time_t *)NULL)));
1242 }
1243
1244
1245 runcom(cs) /* run command */
1246 char *cs;
1247 {
1248 if (!silent) /* echo it */
1249 printf("\t%s\n", cs);
1250 if (noaction)
1251 return(0);
1252 fflush(stdout); /* flush output and pass to shell */
1253 return(system(cs));
1254 }
1255
1256
1257 rmfile(fn) /* remove a file */
1258 char *fn;
1259 {
1260 if (!silent)
1261 #ifdef MSDOS
1262 printf("\tdel %s\n", fn);
1263 #else
1264 printf("\trm -f %s\n", fn);
1265 #endif
1266 if (noaction)
1267 return(0);
1268 return(unlink(fn));
1269 }
1270
1271
1272 mvfile(fold, fnew) /* move a file */
1273 char *fold, *fnew;
1274 {
1275 if (!silent)
1276 #ifdef MSDOS
1277 printf("\trename %s %s\n", fold, fnew);
1278 #else
1279 printf("\tmv %s %s\n", fold, fnew);
1280 #endif
1281 if (noaction)
1282 return(0);
1283 return(rename(fold, fnew));
1284 }
1285
1286
1287 #ifdef MSDOS
1288 setenv(vname, value) /* set an environment variable */
1289 char *vname, *value;
1290 {
1291 register char *evp;
1292
1293 evp = bmalloc(strlen(vname)+strlen(value)+2);
1294 if (evp == NULL)
1295 syserr(progname);
1296 sprintf(evp, "%s=%s", vname, value);
1297 if (putenv(evp) != 0) {
1298 fprintf(stderr, "%s: out of environment space\n", progname);
1299 exit(1);
1300 }
1301 if (!silent)
1302 printf("set %s\n", evp);
1303 }
1304 #endif
1305
1306
1307 badvalue(vc) /* report bad variable value and exit */
1308 int vc;
1309 {
1310 fprintf(stderr, "%s: bad value for variable '%s'\n",
1311 progname, vnam(vc));
1312 exit(1);
1313 }
1314
1315
1316 syserr(s) /* report a system error and exit */
1317 char *s;
1318 {
1319 perror(s);
1320 exit(1);
1321 }
