Revision: 2.34
Committed: Thu Nov 18 13:28:30 1993 UTC (31 years, 7 months ago) by greg
fixed PC bug in time() call
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14
15
16 typedef struct {
17 char *name; /* variable name */
18 short nick; /* # characters required for nickname */
19 short nass; /* # assignments made */
20 char *value; /* assigned value(s) */
21 int (*fixval)(); /* assignment checking function */
22 } VARIABLE;
23
24 int onevalue(), catvalues(), boolvalue(),
25 qualvalue(), fltvalue(), intvalue();
26
27 /* variables */
28 #define OBJECT 0 /* object files */
29 #define SCENE 1 /* scene files */
30 #define MATERIAL 2 /* material files */
31 #define ILLUM 3 /* mkillum input files */
32 #define MKILLUM 4 /* mkillum options */
33 #define RENDER 5 /* rendering options */
34 #define OCONV 6 /* oconv options */
35 #define PFILT 7 /* pfilt options */
36 #define VIEW 8 /* view(s) for picture(s) */
37 #define ZONE 9 /* simulation zone */
38 #define QUALITY 10 /* desired rendering quality */
39 #define OCTREE 11 /* octree file name */
40 #define PICTURE 12 /* picture file name */
41 #define AMBFILE 13 /* ambient file name */
42 #define OPTFILE 14 /* rendering options file */
43 #define EXPOSURE 15 /* picture exposure setting */
44 #define RESOLUTION 16 /* maximum picture resolution */
45 #define UP 17 /* view up (X, Y or Z) */
46 #define INDIRECT 18 /* indirection in lighting */
47 #define DETAIL 19 /* level of scene detail */
48 #define PENUMBRAS 20 /* shadow penumbras are desired */
49 #define VARIABILITY 21 /* level of light variability */
50 #define REPORT 22 /* report frequency and errfile */
51 /* total number of variables */
52 #define NVARS 23
53
54 VARIABLE vv[NVARS] = { /* variable-value pairs */
55 {"objects", 3, 0, NULL, catvalues},
56 {"scene", 3, 0, NULL, catvalues},
57 {"materials", 3, 0, NULL, catvalues},
58 {"illum", 3, 0, NULL, catvalues},
59 {"mkillum", 3, 0, NULL, catvalues},
60 {"render", 3, 0, NULL, catvalues},
61 {"oconv", 3, 0, NULL, catvalues},
62 {"pfilt", 2, 0, NULL, catvalues},
63 {"view", 2, 0, NULL, NULL},
64 {"ZONE", 2, 0, NULL, onevalue},
65 {"QUALITY", 3, 0, NULL, qualvalue},
66 {"OCTREE", 3, 0, NULL, onevalue},
67 {"PICTURE", 3, 0, NULL, onevalue},
68 {"AMBFILE", 3, 0, NULL, onevalue},
69 {"OPTFILE", 3, 0, NULL, onevalue},
70 {"EXPOSURE", 3, 0, NULL, fltvalue},
71 {"RESOLUTION", 3, 0, NULL, onevalue},
72 {"UP", 2, 0, NULL, onevalue},
73 {"INDIRECT", 3, 0, NULL, intvalue},
74 {"DETAIL", 3, 0, NULL, qualvalue},
75 {"PENUMBRAS", 3, 0, NULL, boolvalue},
76 {"VARIABILITY", 3, 0, NULL, qualvalue},
77 {"REPORT", 3, 0, NULL, onevalue},
78 };
79
80 VARIABLE *matchvar();
81 char *nvalue();
82
83 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
84
85 #define vnam(vc) (vv[vc].name)
86 #define vdef(vc) (vv[vc].nass)
87 #define vval(vc) (vv[vc].value)
88 #define vint(vc) atoi(vval(vc))
89 #define vlet(vc) UPPER(vval(vc)[0])
90 #define vscale vlet
91 #define vbool(vc) (vlet(vc)=='T')
92
93 #define HIGH 'H'
94 #define MEDIUM 'M'
95 #define LOW 'L'
96
97 /* overture calculation file */
98 #ifdef NIX
99 char overfile[] = "overture.raw";
100 #else
101 char overfile[] = "/dev/null";
102 #endif
103
104 extern unsigned long fdate(), time();
105
106 unsigned long scenedate; /* date of latest scene or object file */
107 unsigned long octreedate; /* date of octree */
108 unsigned long matdate; /* date of latest material file */
109 unsigned long illumdate; /* date of last illum file */
110
111 char *oct0name; /* name of pre-mkillum octree */
112 unsigned long oct0date; /* date of pre-mkillum octree */
113 char *oct1name; /* name of post-mkillum octree */
114 unsigned long oct1date; /* date of post-mkillum octree (>= matdate) */
115
116 int explicate = 0; /* explicate variables */
117 int silent = 0; /* do work silently */
118 int noaction = 0; /* don't do anything */
119 int sayview = 0; /* print view out */
120 char *rvdevice = NULL; /* rview output device */
121 char *viewselect = NULL; /* specific view only */
122
123 int overture = 0; /* overture calculation needed */
124
125 char *progname; /* global argv[0] */
126 char *rifname; /* global rad input file name */
127
128 char radname[MAXPATH]; /* root Radiance file name */
129
130
131 main(argc, argv)
132 int argc;
133 char *argv[];
134 {
135 char ropts[512];
136 int i;
137
138 progname = argv[0];
139 /* get options */
140 for (i = 1; i < argc && argv[i][0] == '-'; i++)
141 switch (argv[i][1]) {
142 case 's':
143 silent++;
144 break;
145 case 'n':
146 noaction++;
147 break;
148 case 'e':
149 explicate++;
150 break;
151 case 'o':
152 rvdevice = argv[++i];
153 break;
154 case 'V':
155 sayview++;
156 break;
157 case 'v':
158 viewselect = argv[++i];
159 break;
160 default:
161 goto userr;
162 }
163 if (i >= argc)
164 goto userr;
165 rifname = argv[i];
166 /* assign Radiance root file name */
167 rootname(radname, rifname);
168 /* load variable values */
169 load(rifname);
170 /* get any additional assignments */
171 for (i++; i < argc; i++)
172 setvariable(argv[i]);
173 /* check assignments */
174 checkvalues();
175 /* check files and dates */
176 checkfiles();
177 /* set default values as necessary */
178 setdefaults();
179 /* print all values if requested */
180 if (explicate)
181 printvals();
182 /* build octree (and run mkillum) */
183 oconv();
184 /* check date on ambient file */
185 checkambfile();
186 /* run simulation */
187 renderopts(ropts);
188 xferopts(ropts);
189 if (rvdevice != NULL)
190 rview(ropts);
191 else
192 rpict(ropts);
193 exit(0);
194 userr:
195 fprintf(stderr,
196 "Usage: %s [-s][-n][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
197 progname);
198 exit(1);
199 }
200
201
202 rootname(rn, fn) /* remove tail from end of fn */
203 register char *rn, *fn;
204 {
205 char *tp, *dp;
206
207 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
208 if (ISDIRSEP(*rn))
209 dp = rn;
210 else if (*rn == '.')
211 tp = rn;
212 if (tp != NULL && tp > dp)
213 *tp = '\0';
214 }
215
216
217 #define NOCHAR 127 /* constant for character to delete */
218
219
220 load(rfname) /* load Radiance simulation file */
221 char *rfname;
222 {
223 FILE *fp;
224 char buf[512];
225 register char *cp;
226
227 if (rfname == NULL)
228 fp = stdin;
229 else if ((fp = fopen(rfname, "r")) == NULL)
230 syserr(rfname);
231 while (fgetline(buf, sizeof(buf), fp) != NULL) {
232 for (cp = buf; *cp; cp++) {
233 switch (*cp) {
234 case '\\':
235 *cp++ = NOCHAR;
236 continue;
237 case '#':
238 *cp = '\0';
239 break;
240 default:
241 continue;
242 }
243 break;
244 }
245 setvariable(buf);
246 }
247 fclose(fp);
248 }
249
250
251 setvariable(ass) /* assign variable according to string */
252 register char *ass;
253 {
254 char varname[32];
255 int n;
256 register char *cp;
257 register VARIABLE *vp;
258 register int i;
259
260 while (isspace(*ass)) /* skip leading space */
261 ass++;
262 cp = varname; /* extract name */
263 while (cp < varname+sizeof(varname)-1
264 && *ass && !isspace(*ass) && *ass != '=')
265 *cp++ = *ass++;
266 *cp = '\0';
267 if (!varname[0])
268 return; /* no variable name! */
269 /* trim value */
270 while (isspace(*ass) || *ass == '=')
271 ass++;
272 for (n = strlen(ass); n > 0; n--)
273 if (!isspace(ass[n-1]))
274 break;
275 if (!n) {
276 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
277 progname, varname);
278 return;
279 }
280 /* match variable from list */
281 vp = matchvar(varname);
282 if (vp == NULL) {
283 fprintf(stderr, "%s: unknown variable '%s'\n",
284 progname, varname);
285 exit(1);
286 }
287 /* assign new value */
288 if (i = vp->nass) {
289 cp = vp->value;
290 while (i--)
291 while (*cp++)
292 ;
293 i = cp - vp->value;
294 vp->value = realloc(vp->value, i+n+1);
295 } else
296 vp->value = malloc(n+1);
297 if (vp->value == NULL)
298 syserr(progname);
299 cp = vp->value+i; /* copy value, squeezing spaces */
300 *cp = *ass;
301 for (i = 1; i <= n; i++) {
302 if (ass[i] == NOCHAR)
303 continue;
304 if (isspace(*cp))
305 while (isspace(ass[i]))
306 i++;
307 *++cp = ass[i];
308 }
309 if (isspace(*cp)) /* remove trailing space */
310 *cp = '\0';
311 vp->nass++;
312 }
313
314
315 VARIABLE *
316 matchvar(nam) /* match a variable by its name */
317 char *nam;
318 {
319 int n = strlen(nam);
320 register int i;
321
322 for (i = 0; i < NVARS; i++)
323 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
324 return(vv+i);
325 return(NULL);
326 }
327
328
329 char *
330 nvalue(vp, n) /* return nth variable value */
331 VARIABLE *vp;
332 register int n;
333 {
334 register char *cp;
335
336 if (vp == NULL | n < 0 | n >= vp->nass)
337 return(NULL);
338 cp = vp->value;
339 while (n--)
340 while (*cp++)
341 ;
342 return(cp);
343 }
344
345
346 checkvalues() /* check assignments */
347 {
348 register int i;
349
350 for (i = 0; i < NVARS; i++)
351 if (vv[i].fixval != NULL)
352 (*vv[i].fixval)(vv+i);
353 }
354
355
356 onevalue(vp) /* only one assignment for this variable */
357 register VARIABLE *vp;
358 {
359 if (vp->nass < 2)
360 return;
361 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
362 progname, vp->name);
363 do
364 vp->value += strlen(vp->value)+1;
365 while (--vp->nass > 1);
366 }
367
368
369 catvalues(vp) /* concatenate variable values */
370 register VARIABLE *vp;
371 {
372 register char *cp;
373
374 if (vp->nass < 2)
375 return;
376 for (cp = vp->value; vp->nass > 1; vp->nass--) {
377 while (*cp)
378 cp++;
379 *cp++ = ' ';
380 }
381 }
382
383
384 int
385 badmatch(tv, cv) /* case insensitive truncated comparison */
386 register char *tv, *cv;
387 {
388 if (!*tv) return(1); /* null string cannot match */
389 do
390 if (UPPER(*tv) != *cv++)
391 return(1);
392 while (*++tv);
393 return(0); /* OK */
394 }
395
396
397 boolvalue(vp) /* check boolean for legal values */
398 register VARIABLE *vp;
399 {
400 if (!vp->nass) return;
401 onevalue(vp);
402 switch (UPPER(vp->value[0])) {
403 case 'T':
404 if (badmatch(vp->value, "TRUE")) break;
405 return;
406 case 'F':
407 if (badmatch(vp->value, "FALSE")) break;
408 return;
409 }
410 fprintf(stderr, "%s: illegal value for boolean variable '%s'\n",
411 progname, vp->name);
412 exit(1);
413 }
414
415
416 qualvalue(vp) /* check qualitative var. for legal values */
417 register VARIABLE *vp;
418 {
419 if (!vp->nass) return;
420 onevalue(vp);
421 switch (UPPER(vp->value[0])) {
422 case 'L':
423 if (badmatch(vp->value, "LOW")) break;
424 return;
425 case 'M':
426 if (badmatch(vp->value, "MEDIUM")) break;
427 return;
428 case 'H':
429 if (badmatch(vp->value, "HIGH")) break;
430 return;
431 }
432 fprintf(stderr, "%s: illegal value for qualitative variable '%s'\n",
433 progname, vp->name);
434 exit(1);
435 }
436
437
438 intvalue(vp) /* check integer variable for legal values */
439 register VARIABLE *vp;
440 {
441 if (!vp->nass) return;
442 onevalue(vp);
443 if (isint(vp->value)) return;
444 fprintf(stderr, "%s: illegal value for integer variable '%s'\n",
445 progname, vp->name);
446 exit(1);
447 }
448
449
450 fltvalue(vp) /* check float variable for legal values */
451 register VARIABLE *vp;
452 {
453 if (!vp->nass) return;
454 onevalue(vp);
455 if (isflt(vp->value)) return;
456 fprintf(stderr, "%s: illegal value for real variable '%s'\n",
457 progname, vp->name);
458 exit(1);
459 }
460
461
462 unsigned long
463 checklast(fnames) /* check files and find most recent */
464 register char *fnames;
465 {
466 char thisfile[MAXPATH];
467 unsigned long thisdate, lastdate = 0;
468 register char *cp;
469
470 if (fnames == NULL)
471 return(0);
472 while (*fnames) {
473 while (isspace(*fnames)) fnames++;
474 cp = thisfile;
475 while (*fnames && !isspace(*fnames))
476 *cp++ = *fnames++;
477 *cp = '\0';
478 if (!(thisdate = fdate(thisfile)))
479 syserr(thisfile);
480 if (thisdate > lastdate)
481 lastdate = thisdate;
482 }
483 return(lastdate);
484 }
485
486
487 char *
488 newfname(orig, pred) /* create modified file name */
489 char *orig;
490 int pred;
491 {
492 extern char *rindex();
493 register char *cp;
494 register int n;
495 int suffix;
496
497 n = 0; cp = orig; suffix = -1; /* suffix position, length */
498 while (*cp) {
499 if (*cp == '.') suffix = n;
500 else if (ISDIRSEP(*cp)) suffix = -1;
501 cp++; n++;
502 }
503 if (suffix == -1) suffix = n;
504 if ((cp = bmalloc(n+2)) == NULL)
505 syserr(progname);
506 strncpy(cp, orig, suffix);
507 cp[suffix] = pred; /* root name + pred + suffix */
508 strcpy(cp+suffix+1, orig+suffix);
509 return(cp);
510 }
511
512
513 checkfiles() /* check for existence and modified times */
514 {
515 unsigned long objdate;
516
517 if (!vdef(OCTREE)) {
518 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
519 syserr(progname);
520 sprintf(vval(OCTREE), "%s.oct", radname);
521 vdef(OCTREE)++;
522 }
523 octreedate = fdate(vval(OCTREE));
524 if (vdef(ILLUM)) { /* illum requires secondary octrees */
525 oct0name = newfname(vval(OCTREE), '0');
526 oct1name = newfname(vval(OCTREE), '1');
527 oct0date = fdate(oct0name);
528 oct1date = fdate(oct1name);
529 } else
530 oct0name = oct1name = vval(OCTREE);
531 if ((scenedate = checklast(vval(SCENE))) &&
532 (objdate = checklast(vval(OBJECT))) > scenedate)
533 scenedate = objdate;
534 illumdate = checklast(vval(ILLUM));
535 if (!octreedate & !scenedate & !illumdate) {
536 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
537 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
538 exit(1);
539 }
540 matdate = checklast(vval(MATERIAL));
541 }
542
543
544 getoctcube(org, sizp) /* get octree bounding cube */
545 double org[3], *sizp;
546 {
547 extern FILE *popen();
548 static double oorg[3], osiz = 0.;
549 double min[3], max[3];
550 char buf[512];
551 FILE *fp;
552 register int i;
553
554 if (osiz <= FTINY)
555 if (noaction && fdate(oct1name) <
556 (scenedate>illumdate?scenedate:illumdate)) {
557 /* run getbbox */
558 sprintf(buf, "getbbox -w -h %s",
559 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
560 if ((fp = popen(buf, "r")) == NULL)
561 syserr("getbbox");
562 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
563 &min[0], &max[0], &min[1], &max[1],
564 &min[2], &max[2]) != 6) {
565 fprintf(stderr,
566 "%s: error reading bounding box from getbbox\n",
567 progname);
568 exit(1);
569 }
570 for (i = 0; i < 3; i++)
571 if (max[i] - min[i] > osiz)
572 osiz = max[i] - min[i];
573 for (i = 0; i < 3; i++)
574 oorg[i] = (max[i]+min[i]-osiz)*.5;
575 pclose(fp);
576 } else { /* from octree */
577 oconv(); /* does nothing if done already */
578 sprintf(buf, "getinfo -d < %s", oct1name);
579 if ((fp = popen(buf, "r")) == NULL)
580 syserr("getinfo");
581 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
582 &oorg[2], &osiz) != 4) {
583 fprintf(stderr,
584 "%s: error reading bounding cube from getinfo\n",
585 progname);
586 exit(1);
587 }
588 pclose(fp);
589 }
590 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
591 }
592
593
594 setdefaults() /* set default values for unassigned var's */
595 {
596 double org[3], size;
597 char buf[128];
598
599 if (!vdef(ZONE)) {
600 getoctcube(org, &size);
601 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
602 org[1], org[1]+size, org[2], org[2]+size);
603 vval(ZONE) = savqstr(buf);
604 vdef(ZONE)++;
605 }
606 if (!vdef(INDIRECT)) {
607 vval(INDIRECT) = "0";
608 vdef(INDIRECT)++;
609 }
610 if (!vdef(QUALITY)) {
611 vval(QUALITY) = "L";
612 vdef(QUALITY)++;
613 }
614 if (!vdef(RESOLUTION)) {
615 vval(RESOLUTION) = "512";
616 vdef(RESOLUTION)++;
617 }
618 if (!vdef(PICTURE)) {
619 vval(PICTURE) = radname;
620 vdef(PICTURE)++;
621 }
622 if (!vdef(VIEW)) {
623 vval(VIEW) = "X";
624 vdef(VIEW)++;
625 }
626 if (!vdef(DETAIL)) {
627 vval(DETAIL) = "M";
628 vdef(DETAIL)++;
629 }
630 if (!vdef(PENUMBRAS)) {
631 vval(PENUMBRAS) = "F";
632 vdef(PENUMBRAS)++;
633 }
634 if (!vdef(VARIABILITY)) {
635 vval(VARIABILITY) = "L";
636 vdef(VARIABILITY)++;
637 }
638 }
639
640
641 printvals() /* print variable values */
642 {
643 register int i, j;
644
645 for (i = 0; i < NVARS; i++)
646 for (j = 0; j < vdef(i); j++)
647 printf("%s= %s\n", vnam(i), nvalue(vv+i, j));
648 fflush(stdout);
649 }
650
651
652 oconv() /* run oconv and mkillum if necessary */
653 {
654 static char illumtmp[] = "ilXXXXXX";
655 char combuf[512], ocopts[64], mkopts[64];
656
657 oconvopts(ocopts); /* get options */
658 if (octreedate < scenedate) { /* check date on original octree */
659 /* build command */
660 if (vdef(MATERIAL))
661 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
662 vval(MATERIAL), vval(SCENE), vval(OCTREE));
663 else
664 sprintf(combuf, "oconv%s %s > %s", ocopts,
665 vval(SCENE), vval(OCTREE));
666
667 if (runcom(combuf)) { /* run it */
668 fprintf(stderr,
669 "%s: error generating octree\n\t%s removed\n",
670 progname, vval(OCTREE));
671 unlink(vval(OCTREE));
672 exit(1);
673 }
674 octreedate = time((unsigned long *)NULL);
675 }
676 if (oct1name == vval(OCTREE)) /* no mkillum? */
677 oct1date = octreedate > matdate ? octreedate : matdate;
678 if (oct1date >= octreedate & oct1date >= matdate
679 & oct1date >= illumdate) /* all done */
680 return;
681 /* make octree0 */
682 if (oct0date < scenedate | oct0date < illumdate) {
683 /* build command */
684 if (octreedate)
685 sprintf(combuf, "oconv%s -i %s %s > %s", ocopts,
686 vval(OCTREE), vval(ILLUM), oct0name);
687 else if (vdef(MATERIAL))
688 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
689 vval(MATERIAL), vval(ILLUM), oct0name);
690 else
691 sprintf(combuf, "oconv%s %s > %s", ocopts,
692 vval(ILLUM), oct0name);
693 if (runcom(combuf)) { /* run it */
694 fprintf(stderr,
695 "%s: error generating octree\n\t%s removed\n",
696 progname, oct0name);
697 unlink(oct0name);
698 exit(1);
699 }
700 oct0date = time((unsigned long *)NULL);
701 }
702 mkillumopts(mkopts); /* build mkillum command */
703 mktemp(illumtmp);
704 sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts,
705 oct0name, vval(ILLUM), illumtmp);
706 if (runcom(combuf)) { /* run it */
707 fprintf(stderr, "%s: error running mkillum\n", progname);
708 unlink(illumtmp);
709 exit(1);
710 }
711 /* make octree1 (frozen) */
712 if (octreedate)
713 sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts,
714 vval(OCTREE), illumtmp, oct1name);
715 else if (vdef(MATERIAL))
716 sprintf(combuf, "oconv%s -f %s %s > %s", ocopts,
717 vval(MATERIAL), illumtmp, oct1name);
718 else
719 sprintf(combuf, "oconv%s -f %s > %s", ocopts,
720 illumtmp, oct1name);
721 if (runcom(combuf)) { /* run it */
722 fprintf(stderr,
723 "%s: error generating octree\n\t%s removed\n",
724 progname, oct1name);
725 unlink(oct1name);
726 exit(1);
727 }
728 oct1date = time((unsigned long *)NULL);
729 rmfile(illumtmp);
730 }
731
732
733 char *
734 addarg(op, arg) /* add argument and advance pointer */
735 register char *op, *arg;
736 {
737 *op = ' ';
738 while (*++op = *arg++)
739 ;
740 return(op);
741 }
742
743
744 oconvopts(oo) /* get oconv options */
745 register char *oo;
746 {
747 /* BEWARE: This may be called via setdefaults(), so no assumptions */
748
749 *oo = '\0';
750 if (vdef(OCONV))
751 addarg(oo, vval(OCONV));
752 }
753
754
755 mkillumopts(mo) /* get mkillum options */
756 register char *mo;
757 {
758 /* BEWARE: This may be called via setdefaults(), so no assumptions */
759
760 *mo = '\0';
761 if (vdef(MKILLUM))
762 addarg(mo, vval(MKILLUM));
763 }
764
765
766 checkambfile() /* check date on ambient file */
767 {
768 unsigned long afdate;
769
770 if (!vdef(AMBFILE))
771 return;
772 if (!(afdate = fdate(vval(AMBFILE))))
773 return;
774 if (oct1date > afdate)
775 rmfile(vval(AMBFILE));
776 }
777
778
779 double
780 ambval() /* compute ambient value */
781 {
782 if (vdef(EXPOSURE)) {
783 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
784 return(.5/pow(2.,atof(vval(EXPOSURE))));
785 return(.5/atof(vval(EXPOSURE)));
786 }
787 if (vlet(ZONE) == 'E')
788 return(10.);
789 if (vlet(ZONE) == 'I')
790 return(.01);
791 badvalue(ZONE);
792 }
793
794
795 renderopts(op) /* set rendering options */
796 char *op;
797 {
798 switch(vscale(QUALITY)) {
799 case LOW:
800 lowqopts(op);
801 break;
802 case MEDIUM:
803 medqopts(op);
804 break;
805 case HIGH:
806 hiqopts(op);
807 break;
808 }
809 }
810
811
812 lowqopts(op) /* low quality rendering options */
813 register char *op;
814 {
815 double d, org[3], siz[3];
816
817 *op = '\0';
818 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
819 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
820 badvalue(ZONE);
821 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
822 getoctcube(org, &d);
823 d *= 3./(siz[0]+siz[1]+siz[2]);
824 switch (vscale(DETAIL)) {
825 case LOW:
826 op = addarg(op, "-ps 16 -dp 64");
827 sprintf(op, " -ar %d", (int)(4*d));
828 op += strlen(op);
829 break;
830 case MEDIUM:
831 op = addarg(op, "-ps 8 -dp 128");
832 sprintf(op, " -ar %d", (int)(8*d));
833 op += strlen(op);
834 break;
835 case HIGH:
836 op = addarg(op, "-ps 4 -dp 256");
837 sprintf(op, " -ar %d", (int)(16*d));
838 op += strlen(op);
839 break;
840 }
841 op = addarg(op, "-pt .16");
842 if (vbool(PENUMBRAS))
843 op = addarg(op, "-ds .4");
844 else
845 op = addarg(op, "-ds 0");
846 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
847 if (vdef(AMBFILE)) {
848 sprintf(op, " -af %s", vval(AMBFILE));
849 op += strlen(op);
850 } else
851 overture = 0;
852 switch (vscale(VARIABILITY)) {
853 case LOW:
854 op = addarg(op, "-aa .4 -ad 64");
855 break;
856 case MEDIUM:
857 op = addarg(op, "-aa .3 -ad 128");
858 break;
859 case HIGH:
860 op = addarg(op, "-aa .25 -ad 256");
861 break;
862 }
863 op = addarg(op, "-as 0");
864 d = ambval();
865 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
866 op += strlen(op);
867 op = addarg(op, "-lr 3 -lw .02");
868 if (vdef(RENDER))
869 op = addarg(op, vval(RENDER));
870 }
871
872
873 medqopts(op) /* medium quality rendering options */
874 register char *op;
875 {
876 double d, org[3], siz[3];
877
878 *op = '\0';
879 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
880 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
881 badvalue(ZONE);
882 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
883 getoctcube(org, &d);
884 d *= 3./(siz[0]+siz[1]+siz[2]);
885 switch (vscale(DETAIL)) {
886 case LOW:
887 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
888 op = addarg(op, "-dp 256");
889 sprintf(op, " -ar %d", (int)(8*d));
890 op += strlen(op);
891 break;
892 case MEDIUM:
893 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
894 op = addarg(op, "-dp 512");
895 sprintf(op, " -ar %d", (int)(16*d));
896 op += strlen(op);
897 break;
898 case HIGH:
899 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
900 op = addarg(op, "-dp 1024");
901 sprintf(op, " -ar %d", (int)(32*d));
902 op += strlen(op);
903 break;
904 }
905 op = addarg(op, "-pt .08");
906 if (vbool(PENUMBRAS))
907 op = addarg(op, "-ds .2 -dj .5");
908 else
909 op = addarg(op, "-ds .3");
910 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
911 if (overture = vint(INDIRECT)) {
912 sprintf(op, " -ab %d", overture);
913 op += strlen(op);
914 }
915 if (vdef(AMBFILE)) {
916 sprintf(op, " -af %s", vval(AMBFILE));
917 op += strlen(op);
918 } else
919 overture = 0;
920 switch (vscale(VARIABILITY)) {
921 case LOW:
922 op = addarg(op, "-aa .25 -ad 196 -as 0");
923 break;
924 case MEDIUM:
925 op = addarg(op, "-aa .2 -ad 400 -as 64");
926 break;
927 case HIGH:
928 op = addarg(op, "-aa .15 -ad 768 -as 196");
929 break;
930 }
931 d = ambval();
932 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
933 op += strlen(op);
934 op = addarg(op, "-lr 6 -lw .002");
935 if (vdef(RENDER))
936 op = addarg(op, vval(RENDER));
937 }
938
939
940 hiqopts(op) /* high quality rendering options */
941 register char *op;
942 {
943 double d, org[3], siz[3];
944
945 *op = '\0';
946 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
947 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
948 badvalue(ZONE);
949 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
950 getoctcube(org, &d);
951 d *= 3./(siz[0]+siz[1]+siz[2]);
952 switch (vscale(DETAIL)) {
953 case LOW:
954 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
955 op = addarg(op, "-dp 1024");
956 sprintf(op, " -ar %d", (int)(16*d));
957 op += strlen(op);
958 break;
959 case MEDIUM:
960 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
961 op = addarg(op, "-dp 2048");
962 sprintf(op, " -ar %d", (int)(32*d));
963 op += strlen(op);
964 break;
965 case HIGH:
966 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
967 op = addarg(op, "-dp 4096");
968 sprintf(op, " -ar %d", (int)(64*d));
969 op += strlen(op);
970 break;
971 }
972 op = addarg(op, "-pt .04");
973 if (vbool(PENUMBRAS))
974 op = addarg(op, "-ds .1 -dj .7");
975 else
976 op = addarg(op, "-ds .2");
977 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
978 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
979 op += strlen(op);
980 if (vdef(AMBFILE)) {
981 sprintf(op, " -af %s", vval(AMBFILE));
982 op += strlen(op);
983 } else
984 overture = 0;
985 switch (vscale(VARIABILITY)) {
986 case LOW:
987 op = addarg(op, "-aa .15 -ad 256 -as 0");
988 break;
989 case MEDIUM:
990 op = addarg(op, "-aa .125 -ad 512 -as 256");
991 break;
992 case HIGH:
993 op = addarg(op, "-aa .08 -ad 1024 -as 512");
994 break;
995 }
996 d = ambval();
997 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
998 op += strlen(op);
999 op = addarg(op, "-lr 12 -lw .0005");
1000 if (vdef(RENDER))
1001 op = addarg(op, vval(RENDER));
1002 }
1003
1004
1005 xferopts(ro) /* transfer options if indicated */
1006 char *ro;
1007 {
1008 int fd, n;
1009 register char *cp;
1010
1011 n = strlen(ro);
1012 if (n < 2)
1013 return;
1014 if (vdef(OPTFILE)) {
1015 for (cp = ro; cp[1]; cp++)
1016 if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3]))
1017 *cp = '\n';
1018 else
1019 *cp = cp[1];
1020 *cp = '\n';
1021 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
1022 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
1023 syserr(vval(OPTFILE));
1024 sprintf(ro, " @%s", vval(OPTFILE));
1025 }
1026 #ifdef MSDOS
1027 else if (n > 50) {
1028 setenv("ROPT", ro+1);
1029 strcpy(ro, " $ROPT");
1030 }
1031 #endif
1032 }
1033
1034
1035 pfiltopts(po) /* get pfilt options */
1036 register char *po;
1037 {
1038 *po = '\0';
1039 if (vdef(EXPOSURE)) {
1040 po = addarg(po, "-1 -e");
1041 po = addarg(po, vval(EXPOSURE));
1042 }
1043 switch (vscale(QUALITY)) {
1044 case MEDIUM:
1045 po = addarg(po, "-r 1");
1046 break;
1047 case HIGH:
1048 po = addarg(po, "-m .25");
1049 break;
1050 }
1051 if (vdef(PFILT))
1052 po = addarg(po, vval(PFILT));
1053 }
1054
1055
1056 matchword(s1, s2) /* match white-delimited words */
1057 register char *s1, *s2;
1058 {
1059 while (isspace(*s1)) s1++;
1060 while (isspace(*s2)) s2++;
1061 while (*s1 && !isspace(*s1))
1062 if (*s1++ != *s2++)
1063 return(0);
1064 return(!*s2 || isspace(*s2));
1065 }
1066
1067
1068 char *
1069 specview(vs) /* get proper view spec from vs */
1070 register char *vs;
1071 {
1072 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
1073 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
1074 static char viewopts[128];
1075 register char *cp;
1076 int xpos, ypos, zpos, viewtype, upax;
1077 register int i;
1078 double cent[3], dim[3], mult, d;
1079
1080 if (vs == NULL || *vs == '-')
1081 return(vs);
1082 upax = 0; /* get the up vector */
1083 if (vdef(UP)) {
1084 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
1085 upax = 1-'X'+UPPER(vval(UP)[1]);
1086 else
1087 upax = 1-'X'+vlet(UP);
1088 if (upax < 1 | upax > 3)
1089 badvalue(UP);
1090 if (vval(UP)[0] == '-')
1091 upax = -upax;
1092 }
1093 /* check standard view names */
1094 xpos = ypos = zpos = 0;
1095 if (*vs == 'X') {
1096 xpos = 1; vs++;
1097 } else if (*vs == 'x') {
1098 xpos = -1; vs++;
1099 }
1100 if (*vs == 'Y') {
1101 ypos = 1; vs++;
1102 } else if (*vs == 'y') {
1103 ypos = -1; vs++;
1104 }
1105 if (*vs == 'Z') {
1106 zpos = 1; vs++;
1107 } else if (*vs == 'z') {
1108 zpos = -1; vs++;
1109 }
1110 viewtype = 'v';
1111 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
1112 viewtype = *vs++;
1113 cp = viewopts;
1114 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
1115 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
1116 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
1117 &cent[0], &dim[0], &cent[1], &dim[1],
1118 &cent[2], &dim[2]) != 6)
1119 badvalue(ZONE);
1120 for (i = 0; i < 3; i++) {
1121 dim[i] -= cent[i];
1122 cent[i] += .5*dim[i];
1123 }
1124 mult = vlet(ZONE)=='E' ? 2. : .45 ;
1125 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
1126 cent[0]+xpos*mult*dim[0],
1127 cent[1]+ypos*mult*dim[1],
1128 cent[2]+zpos*mult*dim[2],
1129 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
1130 cp += strlen(cp);
1131 /* redirect up axis if necessary */
1132 switch (upax) {
1133 case 3: /* plus or minus Z axis */
1134 case -3:
1135 case 0:
1136 if (!(xpos|ypos))
1137 upax = 2;
1138 break;
1139 case 2: /* plus or minus Y axis */
1140 case -2:
1141 if (!(xpos|zpos))
1142 upax = 1;
1143 break;
1144 case 1: /* plus or minus X axis */
1145 case -1:
1146 if (!(ypos|zpos))
1147 upax = 3;
1148 break;
1149 }
1150 cp = addarg(cp, vup[upax+3]);
1151 switch (viewtype) {
1152 case 'v':
1153 cp = addarg(cp, "-vh 45 -vv 45");
1154 break;
1155 case 'l':
1156 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
1157 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
1158 cp += strlen(cp);
1159 break;
1160 case 'a':
1161 case 'h':
1162 cp = addarg(cp, "-vh 180 -vv 180");
1163 break;
1164 }
1165 } else {
1166 while (!isspace(*vs)) /* else skip id */
1167 if (!*vs++)
1168 return(NULL);
1169 if (upax) { /* specify up vector */
1170 strcpy(cp, vup[upax+3]);
1171 cp += strlen(cp);
1172 }
1173 }
1174 if (cp == viewopts) /* append any additional options */
1175 vs++; /* skip prefixed space if unneeded */
1176 strcpy(cp, vs);
1177 #ifdef MSDOS
1178 if (strlen(viewopts) > 40) {
1179 setenv("VIEW", viewopts);
1180 return("$VIEW");
1181 }
1182 #endif
1183 return(viewopts);
1184 }
1185
1186
1187 char *
1188 getview(n, vn) /* get view n, or NULL if none */
1189 int n;
1190 char *vn; /* returned view name */
1191 {
1192 register char *mv;
1193
1194 if (viewselect != NULL) { /* command-line selected */
1195 if (n) /* only do one */
1196 return(NULL);
1197 if (viewselect[0] == '-') { /* already specified */
1198 if (vn != NULL) *vn = '\0';
1199 return(viewselect);
1200 }
1201 if (vn != NULL) {
1202 for (mv = viewselect; *mv && !isspace(*mv);
1203 *vn++ = *mv++)
1204 ;
1205 *vn = '\0';
1206 }
1207 /* view number? */
1208 if (isint(viewselect))
1209 return(specview(nvalue(vv+VIEW, atoi(viewselect)-1)));
1210 /* check list */
1211 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
1212 if (matchword(viewselect, mv))
1213 return(specview(mv));
1214 return(specview(viewselect)); /* standard view? */
1215 }
1216 mv = nvalue(vv+VIEW, n); /* use view n */
1217 if (vn != NULL & mv != NULL) {
1218 register char *mv2 = mv;
1219 if (*mv2 != '-')
1220 while (*mv2 && !isspace(*mv2))
1221 *vn++ = *mv2++;
1222 *vn = '\0';
1223 }
1224 return(specview(mv));
1225 }
1226
1227
1228 printview(vopts) /* print out selected view */
1229 register char *vopts;
1230 {
1231 extern char *atos(), *getenv();
1232 char buf[256];
1233 FILE *fp;
1234 register char *cp;
1235
1236 if (vopts == NULL)
1237 return(-1);
1238 fputs("VIEW=", stdout);
1239 do {
1240 if (matchword(vopts, "-vf")) { /* expand view file */
1241 vopts = sskip(vopts);
1242 if (!*atos(buf, sizeof(buf), vopts))
1243 return(-1);
1244 if ((fp = fopen(buf, "r")) == NULL)
1245 return(-1);
1246 for (buf[sizeof(buf)-2] = '\n';
1247 fgets(buf, sizeof(buf), fp) != NULL &&
1248 buf[0] != '\n';
1249 buf[sizeof(buf)-2] = '\n') {
1250 if (buf[sizeof(buf)-2] != '\n') {
1251 ungetc(buf[sizeof(buf)-2], fp);
1252 buf[sizeof(buf)-2] = '\0';
1253 }
1254 if (matchword(buf, "VIEW=") ||
1255 matchword(buf, "rview")) {
1256 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1257 putchar(*cp);
1258 }
1259 }
1260 fclose(fp);
1261 vopts = sskip(vopts);
1262 } else {
1263 while (isspace(*vopts))
1264 vopts++;
1265 putchar(' ');
1266 #ifdef MSDOS
1267 if (*vopts == '$') { /* expand env. var. */
1268 if (!*atos(buf, sizeof(buf), vopts+1))
1269 return(-1);
1270 if ((cp = getenv(buf)) == NULL)
1271 return(-1);
1272 fputs(cp, stdout);
1273 vopts = sskip(vopts);
1274 } else
1275 #endif
1276 while (*vopts && !isspace(*vopts))
1277 putchar(*vopts++);
1278 }
1279 } while (*vopts++);
1280 putchar('\n');
1281 return(0);
1282 }
1283
1284
1285 rview(opts) /* run rview with first view */
1286 char *opts;
1287 {
1288 char *vw;
1289 char combuf[512];
1290 /* build command */
1291 if ((vw = getview(0, NULL)) == NULL)
1292 return;
1293 if (sayview)
1294 printview(vw);
1295 sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname);
1296 if (rvdevice != NULL)
1297 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1298 if (vdef(EXPOSURE))
1299 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1300 strcat(combuf, oct1name);
1301 if (runcom(combuf)) { /* run it */
1302 fprintf(stderr, "%s: error running rview\n", progname);
1303 exit(1);
1304 }
1305 }
1306
1307
1308 rpict(opts) /* run rpict and pfilt for each view */
1309 char *opts;
1310 {
1311 char combuf[1024];
1312 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
1313 char pfopts[128];
1314 char vs[32], *vw;
1315 int vn, mult;
1316 /* get pfilt options */
1317 pfiltopts(pfopts);
1318 /* get resolution, reporting */
1319 switch (vscale(QUALITY)) {
1320 case LOW:
1321 mult = 1;
1322 break;
1323 case MEDIUM:
1324 mult = 2;
1325 break;
1326 case HIGH:
1327 mult = 3;
1328 break;
1329 }
1330 {
1331 int xres, yres;
1332 double aspect;
1333 int n;
1334 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1335 if (n == 3)
1336 sprintf(res, "-x %d -y %d -pa %.3f",
1337 mult*xres, mult*yres, aspect);
1338 else if (n) {
1339 if (n == 1) yres = xres;
1340 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1341 } else
1342 badvalue(RESOLUTION);
1343 }
1344 rep[0] = '\0';
1345 if (vdef(REPORT)) {
1346 double minutes;
1347 int n;
1348 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1349 if (n == 2)
1350 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1351 else if (n == 1)
1352 sprintf(rep, " -t %d", (int)(minutes*60));
1353 else
1354 badvalue(REPORT);
1355 }
1356 /* do each view */
1357 vn = 0;
1358 while ((vw = getview(vn++, vs)) != NULL) {
1359 if (sayview)
1360 printview(vw);
1361 if (!vs[0])
1362 sprintf(vs, "%d", vn);
1363 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1364 /* check date on picture */
1365 if (fdate(picfile) >= oct1date)
1366 continue;
1367 /* build rpict command */
1368 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1369 if (fdate(rawfile) >= oct1date) /* recover */
1370 sprintf(combuf, "rpict%s%s -ro %s %s",
1371 rep, opts, rawfile, oct1name);
1372 else {
1373 if (overture) { /* run overture calculation */
1374 sprintf(combuf,
1375 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1376 rep, vw, opts,
1377 oct1name, overfile);
1378 if (runcom(combuf)) {
1379 fprintf(stderr,
1380 "%s: error in overture for view %s\n",
1381 progname, vs);
1382 exit(1);
1383 }
1384 #ifdef NIX
1385 rmfile(overfile);
1386 #endif
1387 }
1388 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1389 rep, vw, res, opts,
1390 oct1name, rawfile);
1391 }
1392 if (runcom(combuf)) { /* run rpict */
1393 fprintf(stderr, "%s: error rendering view %s\n",
1394 progname, vs);
1395 exit(1);
1396 }
1397 /* build pfilt command */
1398 if (mult > 1)
1399 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1400 pfopts, mult, mult, rawfile, picfile);
1401 else
1402 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1403 rawfile, picfile);
1404 if (runcom(combuf)) { /* run pfilt */
1405 fprintf(stderr,
1406 "%s: error filtering view %s\n\t%s removed\n",
1407 progname, vs, picfile);
1408 unlink(picfile);
1409 exit(1);
1410 }
1411 /* remove raw file */
1412 rmfile(rawfile);
1413 }
1414 }
1415
1416
1417 runcom(cs) /* run command */
1418 char *cs;
1419 {
1420 if (!silent) /* echo it */
1421 printf("\t%s\n", cs);
1422 if (noaction)
1423 return(0);
1424 fflush(stdout); /* flush output and pass to shell */
1425 return(system(cs));
1426 }
1427
1428
1429 rmfile(fn) /* remove a file */
1430 char *fn;
1431 {
1432 if (!silent)
1433 #ifdef MSDOS
1434 printf("\tdel %s\n", fn);
1435 #else
1436 printf("\trm -f %s\n", fn);
1437 #endif
1438 if (noaction)
1439 return(0);
1440 return(unlink(fn));
1441 }
1442
1443
1444 #ifdef MSDOS
1445 setenv(vname, value) /* set an environment variable */
1446 char *vname, *value;
1447 {
1448 register char *evp;
1449
1450 evp = bmalloc(strlen(vname)+strlen(value)+2);
1451 if (evp == NULL)
1452 syserr(progname);
1453 sprintf(evp, "%s=%s", vname, value);
1454 if (putenv(evp) != 0) {
1455 fprintf(stderr, "%s: out of environment space\n", progname);
1456 exit(1);
1457 }
1458 if (!silent)
1459 printf("set %s\n", evp);
1460 }
1461 #endif
1462
1463
1464 badvalue(vc) /* report bad variable value and exit */
1465 int vc;
1466 {
1467 fprintf(stderr, "%s: bad value for variable '%s'\n",
1468 progname, vnam(vc));
1469 exit(1);
1470 }
1471
1472
1473 syserr(s) /* report a system error and exit */
1474 char *s;
1475 {
1476 perror(s);
1477 exit(1);
1478 }
