Revision: 2.14
Committed: Thu Jul 15 18:32:57 1993 UTC (31 years, 11 months ago) by greg
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14
15
16 typedef struct {
17 char *name; /* variable name */
18 short nick; /* # characters required for nickname */
19 short nass; /* # assignments made */
20 char *value; /* assigned value(s) */
21 int (*fixval)(); /* assignment checking function */
22 } VARIABLE;
23
24 int onevalue(), catvalues();
25
26 /* variables */
27 #define OBJECT 0 /* object files */
28 #define SCENE 1 /* scene files */
29 #define MATERIAL 2 /* material files */
30 #define RENDER 3 /* rendering options */
31 #define OCONV 4 /* oconv options */
32 #define PFILT 5 /* pfilt options */
33 #define VIEW 6 /* view(s) for picture(s) */
34 #define ZONE 7 /* simulation zone */
35 #define QUALITY 8 /* desired rendering quality */
36 #define OCTREE 9 /* octree file name */
37 #define PICTURE 10 /* picture file name */
38 #define AMBFILE 11 /* ambient file name */
39 #define OPTFILE 12 /* rendering options file */
40 #define EXPOSURE 13 /* picture exposure setting */
41 #define RESOLUTION 14 /* maximum picture resolution */
42 #define UP 15 /* view up (X, Y or Z) */
43 #define INDIRECT 16 /* indirection in lighting */
44 #define DETAIL 17 /* level of scene detail */
45 #define PENUMBRAS 18 /* shadow penumbras are desired */
46 #define VARIABILITY 19 /* level of light variability */
47 #define REPORT 20 /* report frequency and errfile */
48 /* total number of variables */
49 #define NVARS 21
50
51 VARIABLE vv[NVARS] = { /* variable-value pairs */
52 {"objects", 3, 0, NULL, catvalues},
53 {"scene", 3, 0, NULL, catvalues},
54 {"materials", 3, 0, NULL, catvalues},
55 {"render", 3, 0, NULL, catvalues},
56 {"oconv", 3, 0, NULL, catvalues},
57 {"pfilt", 2, 0, NULL, catvalues},
58 {"view", 2, 0, NULL, NULL},
59 {"ZONE", 2, 0, NULL, onevalue},
60 {"QUALITY", 3, 0, NULL, onevalue},
61 {"OCTREE", 3, 0, NULL, onevalue},
62 {"PICTURE", 3, 0, NULL, onevalue},
63 {"AMBFILE", 3, 0, NULL, onevalue},
64 {"OPTFILE", 3, 0, NULL, onevalue},
65 {"EXPOSURE", 3, 0, NULL, onevalue},
66 {"RESOLUTION", 3, 0, NULL, onevalue},
67 {"UP", 2, 0, NULL, onevalue},
68 {"INDIRECT", 3, 0, NULL, onevalue},
69 {"DETAIL", 3, 0, NULL, onevalue},
70 {"PENUMBRAS", 3, 0, NULL, onevalue},
71 {"VARIABILITY", 3, 0, NULL, onevalue},
72 {"REPORT", 3, 0, NULL, onevalue},
73 };
74
75 VARIABLE *matchvar();
76 char *nvalue();
77 int vscale();
78
79 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
80
81 #define vnam(vc) (vv[vc].name)
82 #define vdef(vc) (vv[vc].nass)
83 #define vval(vc) (vv[vc].value)
84 #define vint(vc) atoi(vval(vc))
85 #define vlet(vc) UPPER(vval(vc)[0])
86 #define vbool(vc) (vlet(vc)=='T')
87
88 #define HIGH 2
89 #define MEDIUM 1
90 #define LOW 0
91
92 int lowqopts(), medqopts(), hiqopts();
93 int (*setqopts[3])() = {lowqopts, medqopts, hiqopts};
94
95 #define renderopts (*setqopts[vscale(QUALITY)])
96
97 /* overture calculation file */
98 #ifdef NIX
99 char overfile[] = "overture.raw";
100 #else
101 char overfile[] = "/dev/null";
102 #endif
103
104 extern long fdate(), time();
105
106 long scenedate; /* date of latest scene or object file */
107 long octreedate; /* date of octree */
108 long matdate; /* date of latest material file */
109
110 int explicate = 0; /* explicate variables */
111 int silent = 0; /* do work silently */
112 int noaction = 0; /* don't do anything */
113 char *rvdevice = NULL; /* rview output device */
114 char *viewselect = NULL; /* specific view only */
115
116 int overture = 0; /* overture calculation needed */
117
118 char *progname; /* global argv[0] */
119
120 char radname[MAXPATH]; /* root Radiance file name */
121
122
123 main(argc, argv)
124 int argc;
125 char *argv[];
126 {
127 char ropts[512];
128 int i;
129
130 progname = argv[0];
131 /* get options */
132 for (i = 1; i < argc && argv[i][0] == '-'; i++)
133 switch (argv[i][1]) {
134 case 's':
135 silent++;
136 break;
137 case 'n':
138 noaction++;
139 break;
140 case 'e':
141 explicate++;
142 break;
143 case 'o':
144 rvdevice = argv[++i];
145 break;
146 case 'v':
147 viewselect = argv[++i];
148 break;
149 default:
150 goto userr;
151 }
152 if (i >= argc)
153 goto userr;
154 /* assign Radiance root file name */
155 rootname(radname, argv[i]);
156 /* load variable values */
157 load(argv[i]);
158 /* get any additional assignments */
159 for (i++; i < argc; i++)
160 setvariable(argv[i]);
161 /* check assignments */
162 checkvalues();
163 /* check files and dates */
164 checkfiles();
165 /* set default values as necessary */
166 setdefaults();
167 /* print all values if requested */
168 if (explicate)
169 printvals();
170 /* build octree */
171 oconv();
172 /* check date on ambient file */
173 checkambfile();
174 /* run simulation */
175 renderopts(ropts);
176 xferopts(ropts);
177 if (rvdevice != NULL)
178 rview(ropts);
179 else
180 rpict(ropts);
181 exit(0);
182 userr:
183 fprintf(stderr,
184 "Usage: %s [-s][-n][-e][-v view][-o dev] rfile [VAR=value ..]\n",
185 progname);
186 exit(1);
187 }
188
189
190 rootname(rn, fn) /* remove tail from end of fn */
191 register char *rn, *fn;
192 {
193 char *tp, *dp;
194
195 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
196 if (ISDIRSEP(*rn))
197 dp = rn;
198 else if (*rn == '.')
199 tp = rn;
200 if (tp != NULL && tp > dp)
201 *tp = '\0';
202 }
203
204
205 load(rfname) /* load Radiance simulation file */
206 char *rfname;
207 {
208 FILE *fp;
209 char buf[512];
210 register char *cp;
211
212 if (rfname == NULL)
213 fp = stdin;
214 else if ((fp = fopen(rfname, "r")) == NULL)
215 syserr(rfname);
216 while (fgetline(buf, sizeof(buf), fp) != NULL) {
217 for (cp = buf; *cp; cp++) {
218 switch (*cp) {
219 case '\\':
220 case '\n':
221 *cp = ' ';
222 continue;
223 case '#':
224 *cp = '\0';
225 break;
226 default:
227 continue;
228 }
229 break;
230 }
231 setvariable(buf);
232 }
233 fclose(fp);
234 }
235
236
237 setvariable(ass) /* assign variable according to string */
238 register char *ass;
239 {
240 char varname[32];
241 register char *cp;
242 register VARIABLE *vp;
243 register int i;
244 int n;
245
246 while (isspace(*ass)) /* skip leading space */
247 ass++;
248 cp = varname; /* extract name */
249 while (cp < varname+sizeof(varname)-1
250 && *ass && !isspace(*ass) && *ass != '=')
251 *cp++ = *ass++;
252 *cp = '\0';
253 if (!varname[0])
254 return; /* no variable name! */
255 /* trim value */
256 while (isspace(*ass) || *ass == '=')
257 ass++;
258 cp = ass + strlen(ass);
259 do
260 *cp-- = '\0';
261 while (cp >= ass && isspace(*cp));
262 n = cp - ass + 1;
263 if (!n) {
264 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
265 progname, varname);
266 return;
267 }
268 /* match variable from list */
269 vp = matchvar(varname);
270 if (vp == NULL) {
271 fprintf(stderr, "%s: unknown variable '%s'\n",
272 progname, varname);
273 exit(1);
274 }
275 /* assign new value */
276 if (i = vp->nass) {
277 cp = vp->value;
278 while (i--)
279 while (*cp++)
280 ;
281 i = cp - vp->value;
282 vp->value = realloc(vp->value, i+n+1);
283 } else
284 vp->value = malloc(n+1);
285 if (vp->value == NULL)
286 syserr(progname);
287 strcpy(vp->value+i, ass);
288 vp->nass++;
289 }
290
291
292 VARIABLE *
293 matchvar(nam) /* match a variable by its name */
294 char *nam;
295 {
296 int n = strlen(nam);
297 register int i;
298
299 for (i = 0; i < NVARS; i++)
300 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
301 return(vv+i);
302 return(NULL);
303 }
304
305
306 char *
307 nvalue(vp, n) /* return nth variable value */
308 VARIABLE *vp;
309 register int n;
310 {
311 register char *cp;
312
313 if (vp == NULL || n < 0 || n >= vp->nass)
314 return(NULL);
315 cp = vp->value;
316 while (n--)
317 while (*cp++)
318 ;
319 return(cp);
320 }
321
322
323 int
324 vscale(vc) /* return scale for variable vc */
325 int vc;
326 {
327 switch(vlet(vc)) {
328 case 'H':
329 return(HIGH);
330 case 'M':
331 return(MEDIUM);
332 case 'L':
333 return(LOW);
334 }
335 badvalue(vc);
336 }
337
338
339 checkvalues() /* check assignments */
340 {
341 register int i;
342
343 for (i = 0; i < NVARS; i++)
344 if (vv[i].fixval != NULL)
345 (*vv[i].fixval)(vv+i);
346 }
347
348
349 onevalue(vp) /* only one assignment for this variable */
350 register VARIABLE *vp;
351 {
352 if (vp->nass < 2)
353 return;
354 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
355 progname, vp->name);
356 do
357 vp->value += strlen(vp->value)+1;
358 while (--vp->nass > 1);
359 }
360
361
362 catvalues(vp) /* concatenate variable values */
363 register VARIABLE *vp;
364 {
365 register char *cp;
366
367 if (vp->nass < 2)
368 return;
369 for (cp = vp->value; vp->nass > 1; vp->nass--) {
370 while (*cp)
371 cp++;
372 *cp++ = ' ';
373 }
374 }
375
376
377 long
378 checklast(fnames) /* check files and find most recent */
379 register char *fnames;
380 {
381 char thisfile[MAXPATH];
382 long thisdate, lastdate = -1;
383 register char *cp;
384
385 while (*fnames) {
386 while (isspace(*fnames)) fnames++;
387 cp = thisfile;
388 while (*fnames && !isspace(*fnames))
389 *cp++ = *fnames++;
390 *cp = '\0';
391 if ((thisdate = fdate(thisfile)) < 0)
392 syserr(thisfile);
393 if (thisdate > lastdate)
394 lastdate = thisdate;
395 }
396 return(lastdate);
397 }
398
399
400 checkfiles() /* check for existence and modified times */
401 {
402 char *cp;
403 long objdate;
404
405 if (!vdef(OCTREE)) {
406 if ((cp = bmalloc(strlen(radname)+5)) == NULL)
407 syserr(progname);
408 sprintf(cp, "%s.oct", radname);
409 vval(OCTREE) = cp;
410 vdef(OCTREE)++;
411 }
412 octreedate = fdate(vval(OCTREE));
413 scenedate = -1;
414 if (vdef(SCENE)) {
415 scenedate = checklast(vval(SCENE));
416 if (vdef(OBJECT)) {
417 objdate = checklast(vval(OBJECT));
418 if (objdate > scenedate)
419 scenedate = objdate;
420 }
421 }
422 if (octreedate < 0 & scenedate < 0) {
423 fprintf(stderr, "%s: need '%s' or '%s'\n", progname,
424 vnam(OCTREE), vnam(SCENE));
425 exit(1);
426 }
427 matdate = -1;
428 if (vdef(MATERIAL))
429 matdate = checklast(vval(MATERIAL));
430 }
431
432
433 getoctcube(org, sizp) /* get octree bounding cube */
434 double org[3], *sizp;
435 {
436 extern FILE *popen();
437 static double oorg[3], osiz = 0.;
438 char buf[MAXPATH+16];
439 FILE *fp;
440
441 if (osiz <= FTINY) {
442 oconv(); /* does nothing if done already */
443 sprintf(buf, "getinfo -d < %s", vval(OCTREE));
444 if ((fp = popen(buf, "r")) == NULL)
445 syserr("getinfo");
446 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
447 &oorg[2], &osiz) != 4) {
448 fprintf(stderr,
449 "%s: error reading bounding cube from getinfo\n",
450 progname);
451 exit(1);
452 }
453 pclose(fp);
454 }
455 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
456 }
457
458
459 setdefaults() /* set default values for unassigned var's */
460 {
461 double org[3], size;
462 char buf[128];
463
464 if (!vdef(ZONE)) {
465 getoctcube(org, &size);
466 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
467 org[1], org[1]+size, org[2], org[2]+size);
468 vval(ZONE) = savqstr(buf);
469 vdef(ZONE)++;
470 }
471 if (!vdef(INDIRECT)) {
472 vval(INDIRECT) = "0";
473 vdef(INDIRECT)++;
474 }
475 if (!vdef(QUALITY)) {
476 vval(QUALITY) = "L";
477 vdef(QUALITY)++;
478 }
479 if (!vdef(RESOLUTION)) {
480 vval(RESOLUTION) = "512";
481 vdef(RESOLUTION)++;
482 }
483 if (!vdef(PICTURE)) {
484 vval(PICTURE) = radname;
485 vdef(PICTURE)++;
486 }
487 if (!vdef(VIEW)) {
488 vval(VIEW) = "X";
489 vdef(VIEW)++;
490 }
491 if (!vdef(DETAIL)) {
492 vval(DETAIL) = "M";
493 vdef(DETAIL)++;
494 }
495 if (!vdef(PENUMBRAS)) {
496 vval(PENUMBRAS) = "F";
497 vdef(PENUMBRAS)++;
498 }
499 if (!vdef(VARIABILITY)) {
500 vval(VARIABILITY) = "L";
501 vdef(VARIABILITY)++;
502 }
503 }
504
505
506 printvals() /* print variable values */
507 {
508 register int i, j;
509
510 for (i = 0; i < NVARS; i++)
511 for (j = 0; j < vdef(i); j++)
512 printf("%s= %s\n", vnam(i), nvalue(vv+i, j));
513 fflush(stdout);
514 }
515
516
517 oconv() /* run oconv if necessary */
518 {
519 char combuf[512], ocopts[64];
520
521 if (octreedate >= scenedate) /* check dates */
522 return;
523 /* build command */
524 oconvopts(ocopts);
525 if (vdef(MATERIAL))
526 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
527 vval(MATERIAL), vval(SCENE), vval(OCTREE));
528 else
529 sprintf(combuf, "oconv%s %s > %s", ocopts,
530 vval(SCENE), vval(OCTREE));
531
532 if (runcom(combuf)) { /* run it */
533 fprintf(stderr, "%s: error generating octree\n\t%s removed\n",
534 progname, vval(OCTREE));
535 unlink(vval(OCTREE));
536 exit(1);
537 }
538 octreedate = time(0);
539 }
540
541
542 char *
543 addarg(op, arg) /* add argument and advance pointer */
544 register char *op, *arg;
545 {
546 *op = ' ';
547 while (*++op = *arg++)
548 ;
549 return(op);
550 }
551
552
553 oconvopts(oo) /* get oconv options */
554 register char *oo;
555 {
556 /* BEWARE: This may be called via setdefaults(), so no assumptions */
557
558 *oo = '\0';
559 if (vdef(OCONV))
560 addarg(oo, vval(OCONV));
561 }
562
563
564 checkambfile() /* check date on ambient file */
565 {
566 long afdate;
567
568 if (!vdef(AMBFILE))
569 return;
570 if ((afdate = fdate(vval(AMBFILE))) < 0)
571 return;
572 if (octreedate > afdate | matdate > afdate)
573 rmfile(vval(AMBFILE));
574 }
575
576
577 double
578 ambval() /* compute ambient value */
579 {
580 if (vdef(EXPOSURE)) {
581 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
582 return(.5/pow(2.,atof(vval(EXPOSURE))));
583 if (isdigit(vval(EXPOSURE)[0]) || vval(EXPOSURE)[0] == '.')
584 return(.5/atof(vval(EXPOSURE)));
585 badvalue(EXPOSURE);
586 }
587 if (vlet(ZONE) == 'E')
588 return(10.);
589 if (vlet(ZONE) == 'I')
590 return(.01);
591 badvalue(ZONE);
592 }
593
594
595 lowqopts(op) /* low quality rendering options */
596 register char *op;
597 {
598 double d, org[3], siz[3];
599
600 *op = '\0';
601 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
602 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
603 badvalue(ZONE);
604 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
605 getoctcube(org, &d);
606 d *= 3./(siz[0]+siz[1]+siz[2]);
607 switch (vscale(DETAIL)) {
608 case LOW:
609 op = addarg(op, "-ps 16 -dp 16");
610 sprintf(op, " -ar %d", (int)(4*d));
611 op += strlen(op);
612 break;
613 case MEDIUM:
614 op = addarg(op, "-ps 8 -dp 32");
615 sprintf(op, " -ar %d", (int)(8*d));
616 op += strlen(op);
617 break;
618 case HIGH:
619 op = addarg(op, "-ps 4 -dp 64");
620 sprintf(op, " -ar %d", (int)(16*d));
621 op += strlen(op);
622 break;
623 }
624 op = addarg(op, "-pt .16");
625 if (vbool(PENUMBRAS))
626 op = addarg(op, "-ds .4");
627 else
628 op = addarg(op, "-ds 0");
629 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .7");
630 if (vdef(AMBFILE)) {
631 sprintf(op, " -af %s", vval(AMBFILE));
632 op += strlen(op);
633 } else
634 overture = 0;
635 switch (vscale(VARIABILITY)) {
636 case LOW:
637 op = addarg(op, "-aa .4 -ad 32");
638 break;
639 case MEDIUM:
640 op = addarg(op, "-aa .3 -ad 64");
641 break;
642 case HIGH:
643 op = addarg(op, "-aa .25 -ad 128");
644 break;
645 }
646 op = addarg(op, "-as 0");
647 d = ambval();
648 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
649 op += strlen(op);
650 op = addarg(op, "-lr 3 -lw .02");
651 if (vdef(RENDER))
652 op = addarg(op, vval(RENDER));
653 }
654
655
656 medqopts(op) /* medium quality rendering options */
657 register char *op;
658 {
659 double d, org[3], siz[3];
660
661 *op = '\0';
662 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
663 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
664 badvalue(ZONE);
665 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
666 getoctcube(org, &d);
667 d *= 3./(siz[0]+siz[1]+siz[2]);
668 switch (vscale(DETAIL)) {
669 case LOW:
670 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
671 op = addarg(op, "-dp 64");
672 sprintf(op, " -ar %d", (int)(8*d));
673 op += strlen(op);
674 break;
675 case MEDIUM:
676 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
677 op = addarg(op, "-dp 128");
678 sprintf(op, " -ar %d", (int)(16*d));
679 op += strlen(op);
680 break;
681 case HIGH:
682 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
683 op = addarg(op, "-dp 256");
684 sprintf(op, " -ar %d", (int)(32*d));
685 op += strlen(op);
686 break;
687 }
688 op = addarg(op, "-pt .08");
689 if (vbool(PENUMBRAS))
690 op = addarg(op, "-ds .2 -dj .35");
691 else
692 op = addarg(op, "-ds .3");
693 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .15");
694 if (overture = vint(INDIRECT)) {
695 sprintf(op, " -ab %d", overture);
696 op += strlen(op);
697 }
698 if (vdef(AMBFILE)) {
699 sprintf(op, " -af %s", vval(AMBFILE));
700 op += strlen(op);
701 } else
702 overture = 0;
703 switch (vscale(VARIABILITY)) {
704 case LOW:
705 op = addarg(op, "-aa .25 -ad 128 -as 0");
706 break;
707 case MEDIUM:
708 op = addarg(op, "-aa .2 -ad 300 -as 64");
709 break;
710 case HIGH:
711 op = addarg(op, "-aa .15 -ad 500 -as 128");
712 break;
713 }
714 d = ambval();
715 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
716 op += strlen(op);
717 op = addarg(op, "-lr 6 -lw .002");
718 if (vdef(RENDER))
719 op = addarg(op, vval(RENDER));
720 }
721
722
723 hiqopts(op) /* high quality rendering options */
724 register char *op;
725 {
726 double d, org[3], siz[3];
727
728 *op = '\0';
729 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
730 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
731 badvalue(ZONE);
732 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
733 getoctcube(org, &d);
734 d *= 3./(siz[0]+siz[1]+siz[2]);
735 switch (vscale(DETAIL)) {
736 case LOW:
737 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
738 op = addarg(op, "-dp 256");
739 sprintf(op, " -ar %d", (int)(16*d));
740 op += strlen(op);
741 break;
742 case MEDIUM:
743 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
744 op = addarg(op, "-dp 512");
745 sprintf(op, " -ar %d", (int)(32*d));
746 op += strlen(op);
747 break;
748 case HIGH:
749 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
750 op = addarg(op, "-dp 1024");
751 sprintf(op, " -ar %d", (int)(64*d));
752 op += strlen(op);
753 break;
754 }
755 op = addarg(op, "-pt .04");
756 if (vbool(PENUMBRAS))
757 op = addarg(op, "-ds .1 -dj .7");
758 else
759 op = addarg(op, "-ds .2");
760 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .03");
761 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
762 op += strlen(op);
763 if (vdef(AMBFILE)) {
764 sprintf(op, " -af %s", vval(AMBFILE));
765 op += strlen(op);
766 } else
767 overture = 0;
768 switch (vscale(VARIABILITY)) {
769 case LOW:
770 op = addarg(op, "-aa .15 -ad 200 -as 0");
771 break;
772 case MEDIUM:
773 op = addarg(op, "-aa .125 -ad 512 -as 128");
774 break;
775 case HIGH:
776 op = addarg(op, "-aa .08 -ad 850 -as 256");
777 break;
778 }
779 d = ambval();
780 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
781 op += strlen(op);
782 op = addarg(op, "-lr 12 -lw .0005");
783 if (vdef(RENDER))
784 op = addarg(op, vval(RENDER));
785 }
786
787
788 xferopts(ro) /* transfer options if indicated */
789 char *ro;
790 {
791 int fd, n;
792 register char *cp;
793
794 n = strlen(ro);
795 if (n < 2)
796 return;
797 if (vdef(OPTFILE)) {
798 for (cp = ro; cp[1]; cp++)
799 if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3]))
800 *cp = '\n';
801 else
802 *cp = cp[1];
803 *cp = '\n';
804 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
805 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
806 syserr(vval(OPTFILE));
807 sprintf(ro, " \"^%s\"", vval(OPTFILE));
808 }
809 #ifdef MSDOS
810 else if (n > 50) {
811 setenv("ROPT", ro+1);
812 strcpy(ro, " $ROPT");
813 }
814 #endif
815 }
816
817
818 pfiltopts(po) /* get pfilt options */
819 register char *po;
820 {
821 *po = '\0';
822 if (vdef(EXPOSURE)) {
823 po = addarg(po, "-1 -e");
824 po = addarg(po, vval(EXPOSURE));
825 }
826 switch (vscale(QUALITY)) {
827 case MEDIUM:
828 po = addarg(po, "-r 1");
829 break;
830 case HIGH:
831 po = addarg(po, "-m .25");
832 break;
833 }
834 if (vdef(PFILT))
835 po = addarg(po, vval(PFILT));
836 }
837
838
839 matchword(s1, s2) /* match white-delimited words */
840 register char *s1, *s2;
841 {
842 while (isspace(*s1)) s1++;
843 while (isspace(*s2)) s2++;
844 while (*s1 && !isspace(*s1))
845 if (*s1++ != *s2++)
846 return(0);
847 return(!*s2 || isspace(*s2));
848 }
849
850
851 char *
852 specview(vs) /* get proper view spec from vs */
853 register char *vs;
854 {
855 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
856 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
857 static char viewopts[128];
858 register char *cp;
859 int xpos, ypos, zpos, viewtype, upax;
860 register int i;
861 double cent[3], dim[3], mult, d;
862
863 if (vs == NULL || *vs == '-')
864 return(vs);
865 upax = 0; /* get the up vector */
866 if (vdef(UP)) {
867 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
868 upax = 1-'X'+UPPER(vval(UP)[1]);
869 else
870 upax = 1-'X'+vlet(UP);
871 if (upax < 1 | upax > 3)
872 badvalue(UP);
873 if (vval(UP)[0] == '-')
874 upax = -upax;
875 }
876 /* check standard view names */
877 xpos = ypos = zpos = 0;
878 if (*vs == 'X') {
879 xpos = 1; vs++;
880 } else if (*vs == 'x') {
881 xpos = -1; vs++;
882 }
883 if (*vs == 'Y') {
884 ypos = 1; vs++;
885 } else if (*vs == 'y') {
886 ypos = -1; vs++;
887 }
888 if (*vs == 'Z') {
889 zpos = 1; vs++;
890 } else if (*vs == 'z') {
891 zpos = -1; vs++;
892 }
893 viewtype = 'v';
894 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
895 viewtype = *vs++;
896 cp = viewopts;
897 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
898 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
899 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
900 &cent[0], &dim[0], &cent[1], &dim[1],
901 &cent[2], &dim[2]) != 6)
902 badvalue(ZONE);
903 for (i = 0; i < 3; i++) {
904 dim[i] -= cent[i];
905 cent[i] += .5*dim[i];
906 }
907 mult = vlet(ZONE)=='E' ? 2. : .45 ;
908 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
909 cent[0]+xpos*mult*dim[0],
910 cent[1]+ypos*mult*dim[1],
911 cent[2]+zpos*mult*dim[2],
912 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
913 cp += strlen(cp);
914 /* redirect up axis if necessary */
915 switch (upax) {
916 case 3: /* plus or minus Z axis */
917 case -3:
918 case 0:
919 if (!(xpos|ypos))
920 upax = 2;
921 break;
922 case 2: /* plus or minus Y axis */
923 case -2:
924 if (!(xpos|zpos))
925 upax = 1;
926 break;
927 case 1: /* plus or minus X axis */
928 case -1:
929 if (!(ypos|zpos))
930 upax = 3;
931 break;
932 }
933 cp = addarg(cp, vup[upax+3]);
934 switch (viewtype) {
935 case 'v':
936 cp = addarg(cp, "-vh 45 -vv 45");
937 break;
938 case 'l':
939 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
940 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
941 cp += strlen(cp);
942 break;
943 case 'a':
944 case 'h':
945 cp = addarg(cp, "-vh 180 -vv 180");
946 break;
947 }
948 } else {
949 while (!isspace(*vs)) /* else skip id */
950 if (!*vs++)
951 return(NULL);
952 if (upax) { /* specify up vector */
953 strcpy(cp, vup[upax+3]);
954 cp += strlen(cp);
955 }
956 }
957 strcpy(cp, vs); /* append any additional options */
958 #ifdef MSDOS
959 if (strlen(viewopts) > 40) {
960 setenv("VIEW", viewopts);
961 return("$VIEW");
962 }
963 #endif
964 return(viewopts);
965 }
966
967
968 char *
969 getview(n, vn) /* get view n, or NULL if none */
970 int n;
971 char *vn; /* returned view name */
972 {
973 register char *mv = NULL;
974
975 if (viewselect != NULL) { /* command-line selected */
976 if (n) /* only do one */
977 return(NULL);
978 if (viewselect[0] == '-') { /* already specified */
979 if (vn != NULL) *vn = '\0';
980 return(viewselect);
981 }
982 if (vn != NULL) {
983 for (mv = viewselect; *mv && !isspace(*mv);
984 *vn++ = *mv++)
985 ;
986 *vn = '\0';
987 }
988 /* check list */
989 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
990 if (matchword(viewselect, mv))
991 return(specview(mv));
992 return(specview(viewselect)); /* standard view? */
993 }
994 mv = nvalue(vv+VIEW, n); /* use view n */
995 if (vn != NULL & mv != NULL) {
996 if (*mv != '-')
997 while (*mv && !isspace(*mv))
998 *vn++ = *mv++;
999 *vn = '\0';
1000 }
1001 return(specview(mv));
1002 }
1003
1004
1005 rview(opts) /* run rview with first view */
1006 char *opts;
1007 {
1008 char combuf[512];
1009 /* build command */
1010 sprintf(combuf, "rview %s%s ", getview(0, NULL), opts);
1011 if (rvdevice != NULL)
1012 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1013 strcat(combuf, vval(OCTREE));
1014 if (runcom(combuf)) { /* run it */
1015 fprintf(stderr, "%s: error running rview\n", progname);
1016 exit(1);
1017 }
1018 }
1019
1020
1021 rpict(opts) /* run rpict and pfilt for each view */
1022 char *opts;
1023 {
1024 char combuf[1024];
1025 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
1026 char pfopts[128];
1027 char vs[32], *vw;
1028 int vn, mult;
1029 long lastdate;
1030 /* get pfilt options */
1031 pfiltopts(pfopts);
1032 /* get resolution, reporting */
1033 mult = vscale(QUALITY)+1;
1034 {
1035 int xres, yres;
1036 double aspect;
1037 int n;
1038 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1039 if (n == 3)
1040 sprintf(res, "-x %d -y %d -pa %.3f",
1041 mult*xres, mult*yres, aspect);
1042 else if (n) {
1043 if (n == 1) yres = xres;
1044 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1045 } else
1046 badvalue(RESOLUTION);
1047 }
1048 rep[0] = '\0';
1049 if (vdef(REPORT)) {
1050 double minutes;
1051 int n;
1052 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1053 if (n == 2)
1054 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1055 else if (n == 1)
1056 sprintf(rep, " -t %d", (int)(minutes*60));
1057 else
1058 badvalue(REPORT);
1059 }
1060 /* get update time */
1061 lastdate = octreedate > matdate ? octreedate : matdate;
1062 /* do each view */
1063 vn = 0;
1064 while ((vw = getview(vn++, vs)) != NULL) {
1065 if (!vs[0])
1066 sprintf(vs, "%d", vn);
1067 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1068 /* check date on picture */
1069 if (fdate(picfile) >= lastdate)
1070 continue;
1071 /* build rpict command */
1072 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1073 if (fdate(rawfile) >= octreedate) /* recover */
1074 sprintf(combuf, "rpict%s%s -ro %s %s",
1075 rep, opts, rawfile, vval(OCTREE));
1076 else {
1077 if (overture) { /* run overture calculation */
1078 sprintf(combuf,
1079 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1080 rep, vw, opts,
1081 vval(OCTREE), overfile);
1082 if (runcom(combuf)) {
1083 fprintf(stderr,
1084 "%s: error in overture for view %s\n",
1085 progname, vs);
1086 exit(1);
1087 }
1088 #ifdef NIX
1089 rmfile(overfile);
1090 #endif
1091 }
1092 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1093 rep, vw, res, opts,
1094 vval(OCTREE), rawfile);
1095 }
1096 if (runcom(combuf)) { /* run rpict */
1097 fprintf(stderr, "%s: error rendering view %s\n",
1098 progname, vs);
1099 exit(1);
1100 }
1101 /* build pfilt command */
1102 if (mult > 1)
1103 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1104 pfopts, mult, mult, rawfile, picfile);
1105 else
1106 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1107 rawfile, picfile);
1108 if (runcom(combuf)) { /* run pfilt */
1109 fprintf(stderr,
1110 "%s: error filtering view %s\n\t%s removed\n",
1111 progname, vs, picfile);
1112 unlink(picfile);
1113 exit(1);
1114 }
1115 /* remove raw file */
1116 rmfile(rawfile);
1117 }
1118 }
1119
1120
1121 runcom(cs) /* run command */
1122 char *cs;
1123 {
1124 if (!silent) /* echo it */
1125 printf("\t%s\n", cs);
1126 if (noaction)
1127 return(0);
1128 fflush(stdout); /* flush output and pass to shell */
1129 return(system(cs));
1130 }
1131
1132
1133 rmfile(fn) /* remove a file */
1134 char *fn;
1135 {
1136 if (!silent)
1137 #ifdef MSDOS
1138 printf("\tdel %s\n", fn);
1139 #else
1140 printf("\trm -f %s\n", fn);
1141 #endif
1142 if (noaction)
1143 return(0);
1144 return(unlink(fn));
1145 }
1146
1147
1148 #ifdef MSDOS
1149 setenv(vname, value) /* set an environment variable */
1150 char *vname, *value;
1151 {
1152 register char *evp;
1153
1154 evp = bmalloc(strlen(vname)+strlen(value)+2);
1155 if (evp == NULL)
1156 syserr(progname);
1157 sprintf(evp, "%s=%s", vname, value);
1158 if (putenv(evp) != 0) {
1159 fprintf(stderr, "%s: out of environment space\n", progname);
1160 exit(1);
1161 }
1162 if (!silent)
1163 printf("set %s\n", evp);
1164 }
1165 #endif
1166
1167
1168 badvalue(vc) /* report bad variable value and exit */
1169 int vc;
1170 {
1171 fprintf(stderr, "%s: bad value for variable '%s'\n",
1172 progname, vnam(vc));
1173 exit(1);
1174 }
1175
1176
1177 syserr(s) /* report a system error and exit */
1178 char *s;
1179 {
1180 perror(s);
1181 exit(1);
1182 }
