1 |
/* Copyright (c) 1993 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Executive program for oconv, rpict and pfilt |
9 |
10 |
11 |
#include "standard.h" |
12 |
#include "paths.h" |
13 |
#include <ctype.h> |
14 |
15 |
16 |
typedef struct { |
17 |
char *name; /* variable name */ |
18 |
short nick; /* # characters required for nickname */ |
19 |
short nass; /* # assignments made */ |
20 |
char *value; /* assigned value(s) */ |
21 |
int (*fixval)(); /* assignment checking function */ |
22 |
} VARIABLE; |
23 |
24 |
int onevalue(), catvalues(); |
25 |
26 |
/* variables */ |
27 |
#define OBJECT 0 /* object files */ |
28 |
#define SCENE 1 /* scene files */ |
29 |
#define MATERIAL 2 /* material files */ |
30 |
#define RENDER 3 /* rendering options */ |
31 |
#define OCONV 4 /* oconv options */ |
32 |
#define PFILT 5 /* pfilt options */ |
33 |
#define VIEW 6 /* view(s) for picture(s) */ |
34 |
#define ZONE 7 /* simulation zone */ |
35 |
#define QUALITY 8 /* desired rendering quality */ |
36 |
#define OCTREE 9 /* octree file name */ |
37 |
#define PICTURE 10 /* picture file name */ |
38 |
#define AMBFILE 11 /* ambient file name */ |
39 |
#define OPTFILE 12 /* rendering options file */ |
40 |
#define EXPOSURE 13 /* picture exposure setting */ |
41 |
#define RESOLUTION 14 /* maximum picture resolution */ |
42 |
#define UP 15 /* view up (X, Y or Z) */ |
43 |
#define INDIRECT 16 /* indirection in lighting */ |
44 |
#define DETAIL 17 /* level of scene detail */ |
45 |
#define PENUMBRAS 18 /* shadow penumbras are desired */ |
46 |
#define VARIABILITY 19 /* level of light variability */ |
47 |
#define REPORT 20 /* report frequency and errfile */ |
48 |
/* total number of variables */ |
49 |
#define NVARS 21 |
50 |
51 |
VARIABLE vv[NVARS] = { /* variable-value pairs */ |
52 |
{"objects", 3, 0, NULL, catvalues}, |
53 |
{"scene", 3, 0, NULL, catvalues}, |
54 |
{"materials", 3, 0, NULL, catvalues}, |
55 |
{"render", 3, 0, NULL, catvalues}, |
56 |
{"oconv", 3, 0, NULL, catvalues}, |
57 |
{"pfilt", 2, 0, NULL, catvalues}, |
58 |
{"view", 2, 0, NULL, NULL}, |
59 |
{"ZONE", 2, 0, NULL, onevalue}, |
60 |
{"QUALITY", 3, 0, NULL, onevalue}, |
61 |
{"OCTREE", 3, 0, NULL, onevalue}, |
62 |
{"PICTURE", 3, 0, NULL, onevalue}, |
63 |
{"AMBFILE", 3, 0, NULL, onevalue}, |
64 |
{"OPTFILE", 3, 0, NULL, onevalue}, |
65 |
{"EXPOSURE", 3, 0, NULL, onevalue}, |
66 |
{"RESOLUTION", 3, 0, NULL, onevalue}, |
67 |
{"UP", 2, 0, NULL, onevalue}, |
68 |
{"INDIRECT", 3, 0, NULL, onevalue}, |
69 |
{"DETAIL", 3, 0, NULL, onevalue}, |
70 |
{"PENUMBRAS", 3, 0, NULL, onevalue}, |
71 |
{"VARIABILITY", 3, 0, NULL, onevalue}, |
72 |
{"REPORT", 3, 0, NULL, onevalue}, |
73 |
74 |
75 |
VARIABLE *matchvar(); |
76 |
char *nvalue(); |
77 |
int vscale(); |
78 |
79 |
#define UPPER(c) ((c)&~0x20) /* ASCII trick */ |
80 |
81 |
#define vnam(vc) (vv[vc].name) |
82 |
#define vdef(vc) (vv[vc].nass) |
83 |
#define vval(vc) (vv[vc].value) |
84 |
#define vint(vc) atoi(vval(vc)) |
85 |
#define vlet(vc) UPPER(vval(vc)[0]) |
86 |
#define vbool(vc) (vlet(vc)=='T') |
87 |
88 |
#define HIGH 2 |
89 |
#define MEDIUM 1 |
90 |
#define LOW 0 |
91 |
92 |
int lowqopts(), medqopts(), hiqopts(); |
93 |
int (*setqopts[3])() = {lowqopts, medqopts, hiqopts}; |
94 |
95 |
#define renderopts (*setqopts[vscale(QUALITY)]) |
96 |
97 |
/* overture calculation file */ |
98 |
#ifdef NIX |
99 |
char overfile[] = "overture.raw"; |
100 |
#else |
101 |
char overfile[] = "/dev/null"; |
102 |
#endif |
103 |
104 |
extern long fdate(), time(); |
105 |
106 |
long scenedate; /* date of latest scene or object file */ |
107 |
long octreedate; /* date of octree */ |
108 |
long matdate; /* date of latest material file */ |
109 |
110 |
int explicate = 0; /* explicate variables */ |
111 |
int silent = 0; /* do work silently */ |
112 |
int noaction = 0; /* don't do anything */ |
113 |
char *rvdevice = NULL; /* rview output device */ |
114 |
char *viewselect = NULL; /* specific view only */ |
115 |
116 |
int overture = 0; /* overture calculation needed */ |
117 |
118 |
char *progname; /* global argv[0] */ |
119 |
120 |
char radname[MAXPATH]; /* root Radiance file name */ |
121 |
122 |
123 |
main(argc, argv) |
124 |
int argc; |
125 |
char *argv[]; |
126 |
127 |
char ropts[512]; |
128 |
int i; |
129 |
130 |
progname = argv[0]; |
131 |
/* get options */ |
132 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
133 |
switch (argv[i][1]) { |
134 |
case 's': |
135 |
silent++; |
136 |
break; |
137 |
case 'n': |
138 |
noaction++; |
139 |
break; |
140 |
case 'e': |
141 |
explicate++; |
142 |
break; |
143 |
case 'o': |
144 |
rvdevice = argv[++i]; |
145 |
break; |
146 |
case 'v': |
147 |
viewselect = argv[++i]; |
148 |
break; |
149 |
default: |
150 |
goto userr; |
151 |
152 |
if (i >= argc) |
153 |
goto userr; |
154 |
/* assign Radiance root file name */ |
155 |
rootname(radname, argv[i]); |
156 |
/* load variable values */ |
157 |
load(argv[i]); |
158 |
/* get any additional assignments */ |
159 |
for (i++; i < argc; i++) |
160 |
setvariable(argv[i]); |
161 |
/* check assignments */ |
162 |
checkvalues(); |
163 |
/* check files and dates */ |
164 |
checkfiles(); |
165 |
/* set default values as necessary */ |
166 |
setdefaults(); |
167 |
/* print all values if requested */ |
168 |
if (explicate) |
169 |
printvals(); |
170 |
/* build octree */ |
171 |
oconv(); |
172 |
/* check date on ambient file */ |
173 |
checkambfile(); |
174 |
/* run simulation */ |
175 |
renderopts(ropts); |
176 |
xferopts(ropts); |
177 |
if (rvdevice != NULL) |
178 |
rview(ropts); |
179 |
else |
180 |
rpict(ropts); |
181 |
exit(0); |
182 |
userr: |
183 |
fprintf(stderr, |
184 |
"Usage: %s [-s][-n][-e][-v view][-o dev] rfile [VAR=value ..]\n", |
185 |
progname); |
186 |
exit(1); |
187 |
188 |
189 |
190 |
rootname(rn, fn) /* remove tail from end of fn */ |
191 |
register char *rn, *fn; |
192 |
193 |
char *tp, *dp; |
194 |
195 |
for (tp = NULL, dp = rn; *rn = *fn++; rn++) |
196 |
if (ISDIRSEP(*rn)) |
197 |
dp = rn; |
198 |
else if (*rn == '.') |
199 |
tp = rn; |
200 |
if (tp != NULL && tp > dp) |
201 |
*tp = '\0'; |
202 |
203 |
204 |
205 |
load(rfname) /* load Radiance simulation file */ |
206 |
char *rfname; |
207 |
208 |
FILE *fp; |
209 |
char buf[512]; |
210 |
register char *cp; |
211 |
212 |
if (rfname == NULL) |
213 |
fp = stdin; |
214 |
else if ((fp = fopen(rfname, "r")) == NULL) |
215 |
syserr(rfname); |
216 |
while (fgetline(buf, sizeof(buf), fp) != NULL) { |
217 |
for (cp = buf; *cp; cp++) { |
218 |
switch (*cp) { |
219 |
case '\\': |
220 |
case '\n': |
221 |
*cp = ' '; |
222 |
continue; |
223 |
case '#': |
224 |
*cp = '\0'; |
225 |
break; |
226 |
default: |
227 |
continue; |
228 |
229 |
break; |
230 |
231 |
setvariable(buf); |
232 |
233 |
fclose(fp); |
234 |
235 |
236 |
237 |
setvariable(ass) /* assign variable according to string */ |
238 |
register char *ass; |
239 |
240 |
char varname[32]; |
241 |
242 |
register VARIABLE *vp; |
243 |
register int i; |
244 |
int n; |
245 |
246 |
while (isspace(*ass)) /* skip leading space */ |
247 |
ass++; |
248 |
cp = varname; /* extract name */ |
249 |
while (cp < varname+sizeof(varname)-1 |
250 |
&& *ass && !isspace(*ass) && *ass != '=') |
251 |
*cp++ = *ass++; |
252 |
*cp = '\0'; |
253 |
if (!varname[0]) |
254 |
return; /* no variable name! */ |
255 |
/* trim value */ |
256 |
while (isspace(*ass) || *ass == '=') |
257 |
ass++; |
258 |
cp = ass + strlen(ass); |
259 |
do |
260 |
*cp-- = '\0'; |
261 |
while (cp >= ass && isspace(*cp)); |
262 |
n = cp - ass + 1; |
263 |
if (!n) { |
264 |
fprintf(stderr, "%s: warning - missing value for variable '%s'\n", |
265 |
progname, varname); |
266 |
return; |
267 |
268 |
/* match variable from list */ |
269 |
vp = matchvar(varname); |
270 |
if (vp == NULL) { |
271 |
fprintf(stderr, "%s: unknown variable '%s'\n", |
272 |
273 |
exit(1); |
274 |
275 |
/* assign new value */ |
276 |
if (i = vp->nass) { |
277 |
cp = vp->value; |
278 |
while (i--) |
279 |
while (*cp++) |
280 |
281 |
i = cp - vp->value; |
282 |
vp->value = realloc(vp->value, i+n+1); |
283 |
} else |
284 |
vp->value = malloc(n+1); |
285 |
if (vp->value == NULL) |
286 |
syserr(progname); |
287 |
strcpy(vp->value+i, ass); |
288 |
vp->nass++; |
289 |
290 |
291 |
292 |
VARIABLE * |
293 |
matchvar(nam) /* match a variable by its name */ |
294 |
char *nam; |
295 |
296 |
int n = strlen(nam); |
297 |
register int i; |
298 |
299 |
for (i = 0; i < NVARS; i++) |
300 |
if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n)) |
301 |
return(vv+i); |
302 |
return(NULL); |
303 |
304 |
305 |
306 |
char * |
307 |
nvalue(vp, n) /* return nth variable value */ |
308 |
VARIABLE *vp; |
309 |
register int n; |
310 |
311 |
312 |
313 |
if (vp == NULL || n < 0 || n >= vp->nass) |
314 |
return(NULL); |
315 |
cp = vp->value; |
316 |
while (n--) |
317 |
while (*cp++) |
318 |
319 |
return(cp); |
320 |
321 |
322 |
323 |
int |
324 |
vscale(vc) /* return scale for variable vc */ |
325 |
int vc; |
326 |
327 |
switch(vlet(vc)) { |
328 |
case 'H': |
329 |
return(HIGH); |
330 |
case 'M': |
331 |
return(MEDIUM); |
332 |
case 'L': |
333 |
return(LOW); |
334 |
335 |
badvalue(vc); |
336 |
337 |
338 |
339 |
checkvalues() /* check assignments */ |
340 |
341 |
register int i; |
342 |
343 |
344 |
if (vv[i].fixval != NULL) |
345 |
(*vv[i].fixval)(vv+i); |
346 |
347 |
348 |
349 |
onevalue(vp) /* only one assignment for this variable */ |
350 |
351 |
352 |
if (vp->nass < 2) |
353 |
return; |
354 |
fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n", |
355 |
progname, vp->name); |
356 |
do |
357 |
vp->value += strlen(vp->value)+1; |
358 |
while (--vp->nass > 1); |
359 |
360 |
361 |
362 |
catvalues(vp) /* concatenate variable values */ |
363 |
364 |
365 |
366 |
367 |
if (vp->nass < 2) |
368 |
return; |
369 |
for (cp = vp->value; vp->nass > 1; vp->nass--) { |
370 |
while (*cp) |
371 |
cp++; |
372 |
*cp++ = ' '; |
373 |
374 |
375 |
376 |
377 |
long |
378 |
checklast(fnames) /* check files and find most recent */ |
379 |
register char *fnames; |
380 |
381 |
char thisfile[MAXPATH]; |
382 |
long thisdate, lastdate = -1; |
383 |
384 |
385 |
while (*fnames) { |
386 |
while (isspace(*fnames)) fnames++; |
387 |
cp = thisfile; |
388 |
while (*fnames && !isspace(*fnames)) |
389 |
*cp++ = *fnames++; |
390 |
*cp = '\0'; |
391 |
if ((thisdate = fdate(thisfile)) < 0) |
392 |
syserr(thisfile); |
393 |
if (thisdate > lastdate) |
394 |
lastdate = thisdate; |
395 |
396 |
return(lastdate); |
397 |
398 |
399 |
400 |
checkfiles() /* check for existence and modified times */ |
401 |
402 |
char *cp; |
403 |
long objdate; |
404 |
405 |
if (!vdef(OCTREE)) { |
406 |
if ((cp = bmalloc(strlen(radname)+5)) == NULL) |
407 |
syserr(progname); |
408 |
sprintf(cp, "%s.oct", radname); |
409 |
vval(OCTREE) = cp; |
410 |
vdef(OCTREE)++; |
411 |
412 |
octreedate = fdate(vval(OCTREE)); |
413 |
scenedate = -1; |
414 |
if (vdef(SCENE)) { |
415 |
scenedate = checklast(vval(SCENE)); |
416 |
if (vdef(OBJECT)) { |
417 |
objdate = checklast(vval(OBJECT)); |
418 |
if (objdate > scenedate) |
419 |
scenedate = objdate; |
420 |
421 |
422 |
if (octreedate < 0 & scenedate < 0) { |
423 |
fprintf(stderr, "%s: need '%s' or '%s'\n", progname, |
424 |
vnam(OCTREE), vnam(SCENE)); |
425 |
exit(1); |
426 |
427 |
matdate = -1; |
428 |
if (vdef(MATERIAL)) |
429 |
matdate = checklast(vval(MATERIAL)); |
430 |
431 |
432 |
433 |
getoctcube(org, sizp) /* get octree bounding cube */ |
434 |
double org[3], *sizp; |
435 |
436 |
extern FILE *popen(); |
437 |
static double oorg[3], osiz = 0.; |
438 |
char buf[MAXPATH+16]; |
439 |
FILE *fp; |
440 |
441 |
if (osiz <= FTINY) { |
442 |
oconv(); /* does nothing if done already */ |
443 |
sprintf(buf, "getinfo -d < %s", vval(OCTREE)); |
444 |
if ((fp = popen(buf, "r")) == NULL) |
445 |
syserr("getinfo"); |
446 |
if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1], |
447 |
&oorg[2], &osiz) != 4) { |
448 |
fprintf(stderr, |
449 |
"%s: error reading bounding cube from getinfo\n", |
450 |
progname); |
451 |
exit(1); |
452 |
453 |
pclose(fp); |
454 |
455 |
org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz; |
456 |
457 |
458 |
459 |
setdefaults() /* set default values for unassigned var's */ |
460 |
461 |
double org[3], size; |
462 |
char buf[128]; |
463 |
464 |
if (!vdef(ZONE)) { |
465 |
getoctcube(org, &size); |
466 |
sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size, |
467 |
org[1], org[1]+size, org[2], org[2]+size); |
468 |
vval(ZONE) = savqstr(buf); |
469 |
vdef(ZONE)++; |
470 |
471 |
if (!vdef(INDIRECT)) { |
472 |
vval(INDIRECT) = "0"; |
473 |
vdef(INDIRECT)++; |
474 |
475 |
if (!vdef(QUALITY)) { |
476 |
vval(QUALITY) = "L"; |
477 |
vdef(QUALITY)++; |
478 |
479 |
if (!vdef(RESOLUTION)) { |
480 |
vval(RESOLUTION) = "512"; |
481 |
vdef(RESOLUTION)++; |
482 |
483 |
if (!vdef(PICTURE)) { |
484 |
vval(PICTURE) = radname; |
485 |
vdef(PICTURE)++; |
486 |
487 |
if (!vdef(VIEW)) { |
488 |
vval(VIEW) = "X"; |
489 |
vdef(VIEW)++; |
490 |
491 |
if (!vdef(DETAIL)) { |
492 |
vval(DETAIL) = "M"; |
493 |
vdef(DETAIL)++; |
494 |
495 |
if (!vdef(PENUMBRAS)) { |
496 |
vval(PENUMBRAS) = "F"; |
497 |
vdef(PENUMBRAS)++; |
498 |
499 |
if (!vdef(VARIABILITY)) { |
500 |
vval(VARIABILITY) = "L"; |
501 |
vdef(VARIABILITY)++; |
502 |
503 |
504 |
505 |
506 |
printvals() /* print variable values */ |
507 |
508 |
register int i, j; |
509 |
510 |
511 |
for (j = 0; j < vdef(i); j++) |
512 |
printf("%s= %s\n", vnam(i), nvalue(vv+i, j)); |
513 |
fflush(stdout); |
514 |
515 |
516 |
517 |
oconv() /* run oconv if necessary */ |
518 |
519 |
char combuf[512], ocopts[64]; |
520 |
521 |
if (octreedate >= scenedate) /* check dates */ |
522 |
return; |
523 |
/* build command */ |
524 |
oconvopts(ocopts); |
525 |
526 |
sprintf(combuf, "oconv%s %s %s > %s", ocopts, |
527 |
vval(MATERIAL), vval(SCENE), vval(OCTREE)); |
528 |
else |
529 |
sprintf(combuf, "oconv%s %s > %s", ocopts, |
530 |
531 |
532 |
if (runcom(combuf)) { /* run it */ |
533 |
fprintf(stderr, "%s: error generating octree\n\t%s removed\n", |
534 |
progname, vval(OCTREE)); |
535 |
unlink(vval(OCTREE)); |
536 |
exit(1); |
537 |
538 |
octreedate = time(0); |
539 |
540 |
541 |
542 |
char * |
543 |
addarg(op, arg) /* add argument and advance pointer */ |
544 |
register char *op, *arg; |
545 |
546 |
*op = ' '; |
547 |
while (*++op = *arg++) |
548 |
549 |
return(op); |
550 |
551 |
552 |
553 |
oconvopts(oo) /* get oconv options */ |
554 |
register char *oo; |
555 |
556 |
/* BEWARE: This may be called via setdefaults(), so no assumptions */ |
557 |
558 |
*oo = '\0'; |
559 |
if (vdef(OCONV)) |
560 |
addarg(oo, vval(OCONV)); |
561 |
562 |
563 |
564 |
checkambfile() /* check date on ambient file */ |
565 |
566 |
long afdate; |
567 |
568 |
if (!vdef(AMBFILE)) |
569 |
return; |
570 |
if ((afdate = fdate(vval(AMBFILE))) < 0) |
571 |
return; |
572 |
if (octreedate > afdate | matdate > afdate) |
573 |
rmfile(vval(AMBFILE)); |
574 |
575 |
576 |
577 |
double |
578 |
ambval() /* compute ambient value */ |
579 |
580 |
if (vdef(EXPOSURE)) { |
581 |
if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') |
582 |
return(.5/pow(2.,atof(vval(EXPOSURE)))); |
583 |
if (isdigit(vval(EXPOSURE)[0]) || vval(EXPOSURE)[0] == '.') |
584 |
return(.5/atof(vval(EXPOSURE))); |
585 |
badvalue(EXPOSURE); |
586 |
587 |
if (vlet(ZONE) == 'E') |
588 |
return(10.); |
589 |
if (vlet(ZONE) == 'I') |
590 |
return(.01); |
591 |
badvalue(ZONE); |
592 |
593 |
594 |
595 |
lowqopts(op) /* low quality rendering options */ |
596 |
register char *op; |
597 |
598 |
double d, org[3], siz[3]; |
599 |
600 |
*op = '\0'; |
601 |
if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], |
602 |
&siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) |
603 |
badvalue(ZONE); |
604 |
siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; |
605 |
getoctcube(org, &d); |
606 |
d *= 3./(siz[0]+siz[1]+siz[2]); |
607 |
switch (vscale(DETAIL)) { |
608 |
case LOW: |
609 |
op = addarg(op, "-ps 16 -dp 16"); |
610 |
sprintf(op, " -ar %d", (int)(4*d)); |
611 |
op += strlen(op); |
612 |
break; |
613 |
case MEDIUM: |
614 |
op = addarg(op, "-ps 8 -dp 32"); |
615 |
sprintf(op, " -ar %d", (int)(8*d)); |
616 |
op += strlen(op); |
617 |
break; |
618 |
case HIGH: |
619 |
op = addarg(op, "-ps 4 -dp 64"); |
620 |
sprintf(op, " -ar %d", (int)(16*d)); |
621 |
op += strlen(op); |
622 |
break; |
623 |
624 |
op = addarg(op, "-pt .16"); |
625 |
if (vbool(PENUMBRAS)) |
626 |
op = addarg(op, "-ds .4"); |
627 |
else |
628 |
op = addarg(op, "-ds 0"); |
629 |
op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .7"); |
630 |
if (vdef(AMBFILE)) { |
631 |
sprintf(op, " -af %s", vval(AMBFILE)); |
632 |
op += strlen(op); |
633 |
} else |
634 |
overture = 0; |
635 |
switch (vscale(VARIABILITY)) { |
636 |
case LOW: |
637 |
op = addarg(op, "-aa .4 -ad 32"); |
638 |
break; |
639 |
case MEDIUM: |
640 |
op = addarg(op, "-aa .3 -ad 64"); |
641 |
break; |
642 |
case HIGH: |
643 |
op = addarg(op, "-aa .25 -ad 128"); |
644 |
break; |
645 |
646 |
op = addarg(op, "-as 0"); |
647 |
d = ambval(); |
648 |
sprintf(op, " -av %.2g %.2g %.2g", d, d, d); |
649 |
op += strlen(op); |
650 |
op = addarg(op, "-lr 3 -lw .02"); |
651 |
if (vdef(RENDER)) |
652 |
op = addarg(op, vval(RENDER)); |
653 |
654 |
655 |
656 |
medqopts(op) /* medium quality rendering options */ |
657 |
658 |
659 |
660 |
661 |
*op = '\0'; |
662 |
663 |
664 |
badvalue(ZONE); |
665 |
666 |
667 |
668 |
669 |
case LOW: |
670 |
op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8"); |
671 |
op = addarg(op, "-dp 64"); |
672 |
673 |
op += strlen(op); |
674 |
break; |
675 |
case MEDIUM: |
676 |
op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6"); |
677 |
op = addarg(op, "-dp 128"); |
678 |
679 |
op += strlen(op); |
680 |
break; |
681 |
case HIGH: |
682 |
op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4"); |
683 |
op = addarg(op, "-dp 256"); |
684 |
sprintf(op, " -ar %d", (int)(32*d)); |
685 |
op += strlen(op); |
686 |
break; |
687 |
688 |
op = addarg(op, "-pt .08"); |
689 |
690 |
op = addarg(op, "-ds .2 -dj .35"); |
691 |
else |
692 |
op = addarg(op, "-ds .3"); |
693 |
op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .15"); |
694 |
if (overture = vint(INDIRECT)) { |
695 |
sprintf(op, " -ab %d", overture); |
696 |
op += strlen(op); |
697 |
698 |
699 |
700 |
op += strlen(op); |
701 |
} else |
702 |
overture = 0; |
703 |
704 |
case LOW: |
705 |
op = addarg(op, "-aa .25 -ad 128 -as 0"); |
706 |
break; |
707 |
case MEDIUM: |
708 |
op = addarg(op, "-aa .2 -ad 300 -as 64"); |
709 |
break; |
710 |
case HIGH: |
711 |
op = addarg(op, "-aa .15 -ad 500 -as 128"); |
712 |
break; |
713 |
714 |
d = ambval(); |
715 |
716 |
op += strlen(op); |
717 |
op = addarg(op, "-lr 6 -lw .002"); |
718 |
if (vdef(RENDER)) |
719 |
720 |
721 |
722 |
723 |
hiqopts(op) /* high quality rendering options */ |
724 |
725 |
726 |
727 |
728 |
*op = '\0'; |
729 |
730 |
731 |
badvalue(ZONE); |
732 |
733 |
734 |
735 |
736 |
case LOW: |
737 |
op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8"); |
738 |
739 |
740 |
op += strlen(op); |
741 |
break; |
742 |
case MEDIUM: |
743 |
op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5"); |
744 |
op = addarg(op, "-dp 512"); |
745 |
746 |
op += strlen(op); |
747 |
break; |
748 |
case HIGH: |
749 |
op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3"); |
750 |
op = addarg(op, "-dp 1024"); |
751 |
sprintf(op, " -ar %d", (int)(64*d)); |
752 |
op += strlen(op); |
753 |
break; |
754 |
755 |
op = addarg(op, "-pt .04"); |
756 |
757 |
op = addarg(op, "-ds .1 -dj .7"); |
758 |
else |
759 |
op = addarg(op, "-ds .2"); |
760 |
op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .03"); |
761 |
sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); |
762 |
op += strlen(op); |
763 |
764 |
765 |
op += strlen(op); |
766 |
} else |
767 |
overture = 0; |
768 |
769 |
case LOW: |
770 |
op = addarg(op, "-aa .15 -ad 200 -as 0"); |
771 |
break; |
772 |
case MEDIUM: |
773 |
op = addarg(op, "-aa .125 -ad 512 -as 128"); |
774 |
break; |
775 |
case HIGH: |
776 |
op = addarg(op, "-aa .08 -ad 850 -as 256"); |
777 |
break; |
778 |
779 |
d = ambval(); |
780 |
781 |
op += strlen(op); |
782 |
op = addarg(op, "-lr 12 -lw .0005"); |
783 |
if (vdef(RENDER)) |
784 |
785 |
786 |
787 |
788 |
xferopts(ro) /* transfer options if indicated */ |
789 |
char *ro; |
790 |
791 |
int fd, n; |
792 |
793 |
794 |
n = strlen(ro); |
795 |
if (n < 2) |
796 |
return; |
797 |
if (vdef(OPTFILE)) { |
798 |
for (cp = ro; cp[1]; cp++) |
799 |
if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3])) |
800 |
*cp = '\n'; |
801 |
else |
802 |
*cp = cp[1]; |
803 |
*cp = '\n'; |
804 |
fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666); |
805 |
if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0) |
806 |
syserr(vval(OPTFILE)); |
807 |
sprintf(ro, " \"^%s\"", vval(OPTFILE)); |
808 |
809 |
#ifdef MSDOS |
810 |
else if (n > 50) { |
811 |
setenv("ROPT", ro+1); |
812 |
strcpy(ro, " $ROPT"); |
813 |
814 |
#endif |
815 |
816 |
817 |
818 |
pfiltopts(po) /* get pfilt options */ |
819 |
register char *po; |
820 |
821 |
*po = '\0'; |
822 |
823 |
po = addarg(po, "-1 -e"); |
824 |
po = addarg(po, vval(EXPOSURE)); |
825 |
826 |
switch (vscale(QUALITY)) { |
827 |
case MEDIUM: |
828 |
po = addarg(po, "-r 1"); |
829 |
break; |
830 |
case HIGH: |
831 |
po = addarg(po, "-m .15"); |
832 |
break; |
833 |
834 |
if (vdef(PFILT)) |
835 |
po = addarg(po, vval(PFILT)); |
836 |
837 |
838 |
839 |
matchword(s1, s2) /* match white-delimited words */ |
840 |
register char *s1, *s2; |
841 |
842 |
while (isspace(*s1)) s1++; |
843 |
while (isspace(*s2)) s2++; |
844 |
while (*s1 && !isspace(*s1)) |
845 |
if (*s1++ != *s2++) |
846 |
return(0); |
847 |
return(!*s2 || isspace(*s2)); |
848 |
849 |
850 |
851 |
char * |
852 |
specview(vs) /* get proper view spec from vs */ |
853 |
register char *vs; |
854 |
855 |
static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0", |
856 |
"-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"}; |
857 |
static char viewopts[128]; |
858 |
859 |
int xpos, ypos, zpos, viewtype, upax; |
860 |
register int i; |
861 |
double cent[3], dim[3], mult, d; |
862 |
863 |
if (vs == NULL || *vs == '-') |
864 |
return(vs); |
865 |
upax = 0; /* get the up vector */ |
866 |
if (vdef(UP)) { |
867 |
if (vval(UP)[0] == '-' || vval(UP)[0] == '+') |
868 |
upax = 1-'X'+UPPER(vval(UP)[1]); |
869 |
else |
870 |
upax = 1-'X'+vlet(UP); |
871 |
if (upax < 1 | upax > 3) |
872 |
badvalue(UP); |
873 |
if (vval(UP)[0] == '-') |
874 |
upax = -upax; |
875 |
876 |
/* check standard view names */ |
877 |
xpos = ypos = zpos = 0; |
878 |
if (*vs == 'X') { |
879 |
xpos = 1; vs++; |
880 |
} else if (*vs == 'x') { |
881 |
xpos = -1; vs++; |
882 |
883 |
if (*vs == 'Y') { |
884 |
ypos = 1; vs++; |
885 |
} else if (*vs == 'y') { |
886 |
ypos = -1; vs++; |
887 |
888 |
if (*vs == 'Z') { |
889 |
zpos = 1; vs++; |
890 |
} else if (*vs == 'z') { |
891 |
zpos = -1; vs++; |
892 |
893 |
viewtype = 'v'; |
894 |
if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h') |
895 |
viewtype = *vs++; |
896 |
cp = viewopts; |
897 |
if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */ |
898 |
*cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype; |
899 |
if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", |
900 |
¢[0], &dim[0], ¢[1], &dim[1], |
901 |
¢[2], &dim[2]) != 6) |
902 |
badvalue(ZONE); |
903 |
for (i = 0; i < 3; i++) { |
904 |
dim[i] -= cent[i]; |
905 |
cent[i] += .5*dim[i]; |
906 |
907 |
mult = vlet(ZONE)=='E' ? 2. : .45 ; |
908 |
sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g", |
909 |
cent[0]+xpos*mult*dim[0], |
910 |
cent[1]+ypos*mult*dim[1], |
911 |
cent[2]+zpos*mult*dim[2], |
912 |
-xpos*dim[0], -ypos*dim[1], -zpos*dim[2]); |
913 |
cp += strlen(cp); |
914 |
/* redirect up axis if necessary */ |
915 |
switch (upax) { |
916 |
case 3: /* plus or minus Z axis */ |
917 |
case -3: |
918 |
case 0: |
919 |
if (!(xpos|ypos)) |
920 |
upax = 2; |
921 |
break; |
922 |
case 2: /* plus or minus Y axis */ |
923 |
case -2: |
924 |
if (!(xpos|zpos)) |
925 |
upax = 1; |
926 |
break; |
927 |
case 1: /* plus or minus X axis */ |
928 |
case -1: |
929 |
if (!(ypos|zpos)) |
930 |
upax = 3; |
931 |
break; |
932 |
933 |
cp = addarg(cp, vup[upax+3]); |
934 |
switch (viewtype) { |
935 |
case 'v': |
936 |
cp = addarg(cp, "-vh 45 -vv 45"); |
937 |
break; |
938 |
case 'l': |
939 |
d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]); |
940 |
sprintf(cp, " -vh %.2g -vv %.2g", d, d); |
941 |
cp += strlen(cp); |
942 |
break; |
943 |
case 'a': |
944 |
case 'h': |
945 |
cp = addarg(cp, "-vh 180 -vv 180"); |
946 |
break; |
947 |
948 |
} else { |
949 |
while (!isspace(*vs)) /* else skip id */ |
950 |
if (!*vs++) |
951 |
return(NULL); |
952 |
if (upax) { /* specify up vector */ |
953 |
strcpy(cp, vup[upax+3]); |
954 |
cp += strlen(cp); |
955 |
956 |
957 |
strcpy(cp, vs); /* append any additional options */ |
958 |
#ifdef MSDOS |
959 |
if (strlen(viewopts) > 40) { |
960 |
setenv("VIEW", viewopts); |
961 |
return("$VIEW"); |
962 |
963 |
#endif |
964 |
return(viewopts); |
965 |
966 |
967 |
968 |
char * |
969 |
getview(n, vn) /* get view n, or NULL if none */ |
970 |
int n; |
971 |
char *vn; /* returned view name */ |
972 |
973 |
register char *mv = NULL; |
974 |
975 |
if (viewselect != NULL) { /* command-line selected */ |
976 |
if (n) /* only do one */ |
977 |
return(NULL); |
978 |
if (viewselect[0] == '-') { /* already specified */ |
979 |
if (vn != NULL) *vn = '\0'; |
980 |
return(viewselect); |
981 |
982 |
if (vn != NULL) { |
983 |
for (mv = viewselect; *mv && !isspace(*mv); |
984 |
*vn++ = *mv++) |
985 |
986 |
*vn = '\0'; |
987 |
988 |
/* check list */ |
989 |
while ((mv = nvalue(vv+VIEW, n++)) != NULL) |
990 |
if (matchword(viewselect, mv)) |
991 |
return(specview(mv)); |
992 |
return(specview(viewselect)); /* standard view? */ |
993 |
994 |
mv = nvalue(vv+VIEW, n); /* use view n */ |
995 |
if (vn != NULL & mv != NULL) { |
996 |
if (*mv != '-') |
997 |
while (*mv && !isspace(*mv)) |
998 |
*vn++ = *mv++; |
999 |
*vn = '\0'; |
1000 |
1001 |
1002 |
1003 |
1004 |
1005 |
rview(opts) /* run rview with first view */ |
1006 |
char *opts; |
1007 |
1008 |
char combuf[512]; |
1009 |
1010 |
sprintf(combuf, "rview %s%s ", getview(0, NULL), opts); |
1011 |
1012 |
sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); |
1013 |
strcat(combuf, vval(OCTREE)); |
1014 |
1015 |
fprintf(stderr, "%s: error running rview\n", progname); |
1016 |
exit(1); |
1017 |
1018 |
1019 |
1020 |
1021 |
rpict(opts) /* run rpict and pfilt for each view */ |
1022 |
char *opts; |
1023 |
1024 |
char combuf[1024]; |
1025 |
char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32]; |
1026 |
char pfopts[128]; |
1027 |
char vs[32], *vw; |
1028 |
int vn, mult; |
1029 |
1030 |
pfiltopts(pfopts); |
1031 |
/* get resolution, reporting */ |
1032 |
mult = vscale(QUALITY)+1; |
1033 |
1034 |
int xres, yres; |
1035 |
double aspect; |
1036 |
int n; |
1037 |
n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect); |
1038 |
if (n == 3) |
1039 |
sprintf(res, "-x %d -y %d -pa %.3f", |
1040 |
mult*xres, mult*yres, aspect); |
1041 |
else if (n) { |
1042 |
if (n == 1) yres = xres; |
1043 |
sprintf(res, "-x %d -y %d", mult*xres, mult*yres); |
1044 |
} else |
1045 |
badvalue(RESOLUTION); |
1046 |
1047 |
rep[0] = '\0'; |
1048 |
if (vdef(REPORT)) { |
1049 |
double minutes; |
1050 |
int n; |
1051 |
n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile); |
1052 |
if (n == 2) |
1053 |
sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile); |
1054 |
else if (n == 1) |
1055 |
sprintf(rep, " -t %d", (int)(minutes*60)); |
1056 |
else |
1057 |
badvalue(REPORT); |
1058 |
1059 |
/* do each view */ |
1060 |
vn = 0; |
1061 |
while ((vw = getview(vn++, vs)) != NULL) { |
1062 |
if (!vs[0]) |
1063 |
sprintf(vs, "%d", vn); |
1064 |
sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); |
1065 |
/* check date on picture */ |
1066 |
if (fdate(picfile) >= octreedate) |
1067 |
continue; |
1068 |
/* build rpict command */ |
1069 |
sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs); |
1070 |
if (fdate(rawfile) >= octreedate) /* recover */ |
1071 |
sprintf(combuf, "rpict%s%s -ro %s %s", |
1072 |
rep, opts, rawfile, vval(OCTREE)); |
1073 |
else { |
1074 |
if (overture) { /* run overture calculation */ |
1075 |
sprintf(combuf, |
1076 |
"rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s", |
1077 |
rep, vw, opts, |
1078 |
vval(OCTREE), overfile); |
1079 |
if (runcom(combuf)) { |
1080 |
fprintf(stderr, |
1081 |
"%s: error in overture for view %s\n", |
1082 |
progname, vs); |
1083 |
exit(1); |
1084 |
1085 |
#ifdef NIX |
1086 |
rmfile(overfile); |
1087 |
#endif |
1088 |
1089 |
sprintf(combuf, "rpict%s %s %s%s %s > %s", |
1090 |
rep, vw, res, opts, |
1091 |
vval(OCTREE), rawfile); |
1092 |
1093 |
if (runcom(combuf)) { /* run rpict */ |
1094 |
fprintf(stderr, "%s: error rendering view %s\n", |
1095 |
progname, vs); |
1096 |
exit(1); |
1097 |
1098 |
/* build pfilt command */ |
1099 |
if (mult > 1) |
1100 |
sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s", |
1101 |
pfopts, mult, mult, rawfile, picfile); |
1102 |
else |
1103 |
sprintf(combuf, "pfilt%s %s > %s", pfopts, |
1104 |
1105 |
if (runcom(combuf)) { /* run pfilt */ |
1106 |
fprintf(stderr, |
1107 |
"%s: error filtering view %s\n\t%s removed\n", |
1108 |
progname, vs, picfile); |
1109 |
unlink(picfile); |
1110 |
exit(1); |
1111 |
1112 |
/* remove raw file */ |
1113 |
rmfile(rawfile); |
1114 |
1115 |
1116 |
1117 |
1118 |
runcom(cs) /* run command */ |
1119 |
char *cs; |
1120 |
1121 |
if (!silent) /* echo it */ |
1122 |
printf("\t%s\n", cs); |
1123 |
if (noaction) |
1124 |
return(0); |
1125 |
fflush(stdout); /* flush output and pass to shell */ |
1126 |
return(system(cs)); |
1127 |
1128 |
1129 |
1130 |
rmfile(fn) /* remove a file */ |
1131 |
char *fn; |
1132 |
1133 |
if (!silent) |
1134 |
#ifdef MSDOS |
1135 |
printf("\tdel %s\n", fn); |
1136 |
#else |
1137 |
printf("\trm -f %s\n", fn); |
1138 |
#endif |
1139 |
if (noaction) |
1140 |
return(0); |
1141 |
return(unlink(fn)); |
1142 |
1143 |
1144 |
1145 |
#ifdef MSDOS |
1146 |
setenv(vname, value) /* set an environment variable */ |
1147 |
char *vname, *value; |
1148 |
1149 |
register char *evp; |
1150 |
1151 |
evp = bmalloc(strlen(vname)+strlen(value)+2); |
1152 |
if (evp == NULL) |
1153 |
syserr(progname); |
1154 |
sprintf(evp, "%s=%s", vname, value); |
1155 |
if (putenv(evp) != 0) { |
1156 |
fprintf(stderr, "%s: out of environment space\n", progname); |
1157 |
exit(1); |
1158 |
1159 |
if (!silent) |
1160 |
printf("set %s\n", evp); |
1161 |
1162 |
#endif |
1163 |
1164 |
1165 |
badvalue(vc) /* report bad variable value and exit */ |
1166 |
int vc; |
1167 |
1168 |
fprintf(stderr, "%s: bad value for variable '%s'\n", |
1169 |
progname, vnam(vc)); |
1170 |
exit(1); |
1171 |
1172 |
1173 |
1174 |
syserr(s) /* report a system error and exit */ |
1175 |
char *s; |
1176 |
1177 |
perror(s); |
1178 |
exit(1); |
1179 |
