Revision: 2.3
Committed: Thu Mar 11 17:23:33 1993 UTC (32 years, 4 months ago) by greg
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14
15
16 typedef struct {
17 char *name; /* variable name */
18 short nick; /* # characters required for nickname */
19 short nass; /* # assignments made */
20 char *value; /* assigned value(s) */
21 int (*fixval)(); /* assignment checking function */
22 } VARIABLE;
23
24 int onevalue(), catvalues();
25
26 /* variables */
27 #define OBJECT 0 /* object files */
28 #define SCENE 1 /* scene files */
29 #define MATERIAL 2 /* material files */
30 #define RENDER 3 /* rendering options */
31 #define OCONV 4 /* oconv options */
32 #define PFILT 5 /* pfilt options */
33 #define VIEW 6 /* view(s) for picture(s) */
34 #define ZONE 7 /* simulation zone */
35 #define QUALITY 8 /* desired rendering quality */
36 #define OCTREE 9 /* octree file name */
37 #define PICTURE 10 /* picture file name */
38 #define AMBFILE 11 /* ambient file name */
39 #define OPTFILE 12 /* rendering options file */
40 #define EXPOSURE 13 /* picture exposure setting */
41 #define RESOLUTION 14 /* maximum picture resolution */
42 #define UP 15 /* view up (X, Y or Z) */
43 #define INDIRECT 16 /* indirection in lighting */
44 #define DETAIL 17 /* level of scene detail */
45 #define PENUMBRAS 18 /* shadow penumbras are desired */
46 #define VARIABILITY 19 /* level of light variability */
47 #define REPORT 20 /* report frequency and errfile */
48 /* total number of variables */
49 #define NVARS 21
50
51 VARIABLE vv[NVARS] = { /* variable-value pairs */
52 {"objects", 3, 0, NULL, catvalues},
53 {"scene", 3, 0, NULL, catvalues},
54 {"materials", 3, 0, NULL, catvalues},
55 {"render", 3, 0, NULL, catvalues},
56 {"oconv", 3, 0, NULL, catvalues},
57 {"pfilt", 2, 0, NULL, catvalues},
58 {"view", 2, 0, NULL, NULL},
59 {"ZONE", 2, 0, NULL, onevalue},
60 {"QUALITY", 3, 0, NULL, onevalue},
61 {"OCTREE", 3, 0, NULL, onevalue},
62 {"PICTURE", 3, 0, NULL, onevalue},
63 {"AMBFILE", 3, 0, NULL, onevalue},
64 {"OPTFILE", 3, 0, NULL, onevalue},
65 {"EXPOSURE", 3, 0, NULL, onevalue},
66 {"RESOLUTION", 3, 0, NULL, onevalue},
67 {"UP", 2, 0, NULL, onevalue},
68 {"INDIRECT", 3, 0, NULL, onevalue},
69 {"DETAIL", 3, 0, NULL, onevalue},
70 {"PENUMBRAS", 3, 0, NULL, onevalue},
71 {"VARIABILITY", 3, 0, NULL, onevalue},
72 {"REPORT", 3, 0, NULL, onevalue},
73 };
74
75 VARIABLE *matchvar();
76 char *nvalue();
77 int vscale();
78
79 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
80
81 #define vnam(vc) (vv[vc].name)
82 #define vdef(vc) (vv[vc].nass)
83 #define vval(vc) (vv[vc].value)
84 #define vint(vc) atoi(vval(vc))
85 #define vlet(vc) UPPER(vval(vc)[0])
86 #define vbool(vc) (vlet(vc)=='T')
87
88 #define HIGH 2
89 #define MEDIUM 1
90 #define LOW 0
91
92 int lowqopts(), medqopts(), hiqopts();
93 int (*setqopts[3])() = {lowqopts, medqopts, hiqopts};
94
95 #define renderopts (*setqopts[vscale(QUALITY)])
96
97 extern long fdate(), time();
98
99 long scenedate; /* date of latest scene or object file */
100 long octreedate; /* date of octree */
101
102 int explicate = 0; /* explicate variables */
103 int silent = 0; /* do work silently */
104 int noaction = 0; /* don't do anything */
105 char *rvdevice = NULL; /* rview output device */
106 char *viewselect = NULL; /* specific view only */
107
108 int overture = 0; /* overture calculation needed */
109
110 char *progname; /* global argv[0] */
111
112 char radname[MAXPATH]; /* root Radiance file name */
113
114
115 main(argc, argv)
116 int argc;
117 char *argv[];
118 {
119 char ropts[512];
120 int i;
121
122 progname = argv[0];
123 /* get options */
124 for (i = 1; i < argc && argv[i][0] == '-'; i++)
125 switch (argv[i][1]) {
126 case 's':
127 silent++;
128 break;
129 case 'n':
130 noaction++;
131 break;
132 case 'e':
133 explicate++;
134 break;
135 case 'o':
136 rvdevice = argv[++i];
137 break;
138 case 'v':
139 viewselect = argv[++i];
140 break;
141 default:
142 goto userr;
143 }
144 if (i >= argc)
145 goto userr;
146 /* assign Radiance root file name */
147 rootname(radname, argv[i]);
148 /* load variable values */
149 load(argv[i]);
150 /* get any additional assignments */
151 for (i++; i < argc; i++)
152 setvariable(argv[i]);
153 /* check assignments */
154 checkvalues();
155 /* check files and dates */
156 checkfiles();
157 /* set default values as necessary */
158 setdefaults();
159 /* print all values if requested */
160 if (explicate)
161 printvals();
162 /* run simulation */
163 oconv();
164 renderopts(ropts);
165 xferopts(ropts);
166 if (rvdevice != NULL)
167 rview(ropts);
168 else
169 rpict(ropts);
170 exit(0);
171 userr:
172 fprintf(stderr,
173 "Usage: %s [-s][-n][-e][-v view][-o dev] rfile [VAR=value ..]\n",
174 progname);
175 exit(1);
176 }
177
178
179 rootname(rn, fn) /* remove tail from end of fn */
180 register char *rn, *fn;
181 {
182 char *tp, *dp;
183
184 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
185 if (ISDIRSEP(*rn))
186 dp = rn;
187 else if (*rn == '.')
188 tp = rn;
189 if (tp != NULL && tp > dp)
190 *tp = '\0';
191 }
192
193
194 load(rfname) /* load Radiance simulation file */
195 char *rfname;
196 {
197 FILE *fp;
198 char buf[256];
199 register char *cp;
200
201 if (rfname == NULL)
202 fp = stdin;
203 else if ((fp = fopen(rfname, "r")) == NULL)
204 syserr(rfname);
205 while (fgetline(buf, sizeof(buf), fp) != NULL) {
206 for (cp = buf; *cp; cp++) {
207 switch (*cp) {
208 case '\\':
209 case '\n':
210 *cp = ' ';
211 continue;
212 case '#':
213 *cp = '\0';
214 break;
215 }
216 break;
217 }
218 setvariable(buf);
219 }
220 fclose(fp);
221 }
222
223
224 setvariable(ass) /* assign variable according to string */
225 register char *ass;
226 {
227 char varname[32];
228 register char *cp;
229 register VARIABLE *vp;
230 register int i;
231 int n;
232
233 while (isspace(*ass)) /* skip leading space */
234 ass++;
235 cp = varname; /* extract name */
236 while (cp < varname+sizeof(varname)-1
237 && *ass && !isspace(*ass) && *ass != '=')
238 *cp++ = *ass++;
239 *cp = '\0';
240 if (!varname[0])
241 return; /* no variable name! */
242 /* trim value */
243 while (isspace(*ass) || *ass == '=')
244 ass++;
245 cp = ass + strlen(ass);
246 do
247 *cp-- = '\0';
248 while (cp >= ass && isspace(*cp));
249 n = cp - ass + 1;
250 if (!n) {
251 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
252 progname, varname);
253 return;
254 }
255 /* match variable from list */
256 vp = matchvar(varname);
257 if (vp == NULL) {
258 fprintf(stderr, "%s: unknown variable '%s'\n",
259 progname, varname);
260 exit(1);
261 }
262 /* assign new value */
263 cp = vp->value; i = vp->nass;
264 while (i--)
265 while (*cp++)
266 ;
267 i = cp - vp->value;
268 vp->value = realloc(vp->value, i+n+1);
269 if (vp->value == NULL)
270 syserr(progname);
271 strcpy(vp->value+i, ass);
272 vp->nass++;
273 }
274
275
276 VARIABLE *
277 matchvar(nam) /* match a variable by its name */
278 char *nam;
279 {
280 int n = strlen(nam);
281 register int i;
282
283 for (i = 0; i < NVARS; i++)
284 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
285 return(vv+i);
286 return(NULL);
287 }
288
289
290 char *
291 nvalue(vp, n) /* return nth variable value */
292 VARIABLE *vp;
293 register int n;
294 {
295 register char *cp;
296
297 if (vp == NULL || n < 0 || n >= vp->nass)
298 return(NULL);
299 cp = vp->value;
300 while (n--)
301 while (*cp++)
302 ;
303 return(cp);
304 }
305
306
307 int
308 vscale(vc) /* return scale for variable vc */
309 int vc;
310 {
311 switch(vlet(vc)) {
312 case 'H':
313 return(HIGH);
314 case 'M':
315 return(MEDIUM);
316 case 'L':
317 return(LOW);
318 }
319 badvalue(vc);
320 }
321
322
323 checkvalues() /* check assignments */
324 {
325 register int i;
326
327 for (i = 0; i < NVARS; i++)
328 if (vv[i].fixval != NULL)
329 (*vv[i].fixval)(vv+i);
330 }
331
332
333 onevalue(vp) /* only one assignment for this variable */
334 register VARIABLE *vp;
335 {
336 if (vp->nass < 2)
337 return;
338 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
339 progname, vp->name);
340 do
341 vp->value += strlen(vp->value)+1;
342 while (--vp->nass > 1);
343 }
344
345
346 catvalues(vp) /* concatenate variable values */
347 register VARIABLE *vp;
348 {
349 register char *cp;
350
351 if (vp->nass < 2)
352 return;
353 for (cp = vp->value; vp->nass > 1; vp->nass--) {
354 while (*cp)
355 cp++;
356 *cp++ = ' ';
357 }
358 }
359
360
361 long
362 checklast(fnames) /* check files and find most recent */
363 register char *fnames;
364 {
365 char thisfile[MAXPATH];
366 long thisdate, lastdate = -1;
367 register char *cp;
368
369 while (*fnames) {
370 while (isspace(*fnames)) fnames++;
371 cp = thisfile;
372 while (*fnames && !isspace(*fnames)) *cp++ = *fnames++;
373 *cp = '\0';
374 if ((thisdate = fdate(thisfile)) < 0)
375 syserr(thisfile);
376 if (thisdate > lastdate)
377 lastdate = thisdate;
378 }
379 return(lastdate);
380 }
381
382
383 checkfiles() /* check for existence and modified times */
384 {
385 char *cp;
386 long objdate;
387
388 if (!vdef(OCTREE)) {
389 if ((cp = bmalloc(strlen(radname)+5)) == NULL)
390 syserr(progname);
391 sprintf(cp, "%s.oct", radname);
392 vval(OCTREE) = cp;
393 vdef(OCTREE)++;
394 }
395 octreedate = fdate(vval(OCTREE));
396 scenedate = -1;
397 if (vdef(SCENE)) {
398 scenedate = checklast(vval(SCENE));
399 if (vdef(OBJECT)) {
400 objdate = checklast(vval(OBJECT));
401 if (objdate > scenedate)
402 scenedate = objdate;
403 }
404 }
405 if (octreedate < 0 & scenedate < 0) {
406 fprintf(stderr, "%s: need '%s' or '%s'\n", progname,
407 vnam(OCTREE), vnam(SCENE));
408 exit(1);
409 }
410 }
411
412
413 getoctcube(org, sizp) /* get octree bounding cube */
414 double org[3], *sizp;
415 {
416 extern FILE *popen();
417 static double oorg[3], osiz = 0.;
418 char buf[MAXPATH+16];
419 FILE *fp;
420
421 if (osiz <= FTINY) {
422 oconv(); /* does nothing if done already */
423 sprintf(buf, "getinfo -d < %s", vval(OCTREE));
424 if ((fp = popen(buf, "r")) == NULL)
425 syserr("getinfo");
426 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
427 &oorg[2], &osiz) != 4) {
428 fprintf(stderr,
429 "%s: error reading bounding cube from getinfo\n",
430 progname);
431 exit(1);
432 }
433 pclose(fp);
434 }
435 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
436 }
437
438
439 setdefaults() /* set default values for unassigned var's */
440 {
441 double org[3], size;
442 char buf[128];
443
444 if (!vdef(ZONE)) {
445 getoctcube(org, &size);
446 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
447 org[1], org[1]+size, org[2], org[2]+size);
448 vval(ZONE) = savqstr(buf);
449 vdef(ZONE)++;
450 }
451 if (!vdef(INDIRECT)) {
452 vval(INDIRECT) = "0";
453 vdef(INDIRECT)++;
454 }
455 if (!vdef(QUALITY)) {
456 vval(QUALITY) = "L";
457 vdef(QUALITY)++;
458 }
459 if (!vdef(RESOLUTION)) {
460 vval(RESOLUTION) = "512";
461 vdef(RESOLUTION)++;
462 }
463 if (!vdef(PICTURE)) {
464 vval(PICTURE) = radname;
465 vdef(PICTURE)++;
466 }
467 if (!vdef(VIEW)) {
468 vval(VIEW) = "X";
469 vdef(VIEW)++;
470 }
471 if (!vdef(DETAIL)) {
472 vval(DETAIL) = "M";
473 vdef(DETAIL)++;
474 }
475 if (!vdef(PENUMBRAS)) {
476 vval(PENUMBRAS) = "F";
477 vdef(PENUMBRAS)++;
478 }
479 if (!vdef(VARIABILITY)) {
480 vval(VARIABILITY) = "L";
481 vdef(VARIABILITY)++;
482 }
483 }
484
485
486 printvals() /* print variable values */
487 {
488 register int i, j;
489
490 for (i = 0; i < NVARS; i++)
491 for (j = 0; j < vv[i].nass; j++)
492 printf("%s= %s\n", vv[i].name, nvalue(vv+i, j));
493 fflush(stdout);
494 }
495
496
497 oconv() /* run oconv if necessary */
498 {
499 char combuf[512], ocopts[64];
500
501 if (octreedate >= scenedate) /* check dates */
502 return;
503 /* build command */
504 oconvopts(ocopts);
505 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
506 vdef(MATERIAL) ? vval(MATERIAL) : "",
507 vval(SCENE), vval(OCTREE));
508 if (!silent) { /* echo it */
509 printf("\t%s\n", combuf);
510 fflush(stdout);
511 }
512 if (noaction)
513 return;
514 if (system(combuf)) { /* run it */
515 fprintf(stderr, "%s: error generating octree\n\t%s removed\n",
516 progname, vval(OCTREE));
517 unlink(vval(OCTREE));
518 exit(1);
519 }
520 octreedate = time(0);
521 }
522
523
524 char *
525 addarg(op, arg) /* add argument and advance pointer */
526 register char *op, *arg;
527 {
528 *op = ' ';
529 while (*++op = *arg++)
530 ;
531 return(op);
532 }
533
534
535 oconvopts(oo) /* get oconv options */
536 register char *oo;
537 {
538 /* BEWARE: This may be called via setdefaults(), so no assumptions */
539
540 *oo = '\0';
541 if (vdef(OCONV))
542 addarg(oo, vval(OCONV));
543 }
544
545
546 double
547 ambval() /* compute ambient value */
548 {
549 if (vdef(EXPOSURE)) {
550 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
551 return(.5/pow(2.,atof(vval(EXPOSURE))));
552 if (isdigit(vval(EXPOSURE)[0]) || vval(EXPOSURE)[0] == '.')
553 return(.5/atof(vval(EXPOSURE)));
554 badvalue(EXPOSURE);
555 }
556 if (vlet(ZONE) == 'E')
557 return(10.);
558 if (vlet(ZONE) == 'I')
559 return(.01);
560 badvalue(ZONE);
561 }
562
563
564 lowqopts(op) /* low quality rendering options */
565 register char *op;
566 {
567 double d, org[3], siz[3];
568
569 *op = '\0';
570 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
571 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
572 badvalue(ZONE);
573 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
574 getoctcube(org, &d);
575 d *= 3./(siz[0]+siz[1]+siz[2]);
576 switch (vscale(DETAIL)) {
577 case LOW:
578 op = addarg(op, "-ps 16");
579 op = addarg(op, "-dp 16");
580 sprintf(op, " -ar %d", (int)(4*d));
581 op += strlen(op);
582 break;
583 case MEDIUM:
584 op = addarg(op, "-ps 8");
585 op = addarg(op, "-dp 32");
586 sprintf(op, " -ar %d", (int)(8*d));
587 op += strlen(op);
588 break;
589 case HIGH:
590 op = addarg(op, "-ps 4");
591 op = addarg(op, "-dp 64");
592 sprintf(op, " -ar %d", (int)(16*d));
593 op += strlen(op);
594 break;
595 }
596 op = addarg(op, "-pt .16");
597 if (vbool(PENUMBRAS))
598 op = addarg(op, "-ds .4");
599 op = addarg(op, "-dt .2");
600 op = addarg(op, "-dc .25");
601 op = addarg(op, "-dr 0");
602 op = addarg(op, "-sj 0");
603 op = addarg(op, "-st .7");
604 op = addarg(op, "-ab 0");
605 if (vdef(AMBFILE)) {
606 sprintf(op, " -af %s", vval(AMBFILE));
607 op += strlen(op);
608 } else
609 overture = 0;
610 switch (vscale(VARIABILITY)) {
611 case LOW:
612 op = addarg(op, "-aa .4");
613 op = addarg(op, "-ad 32");
614 break;
615 case MEDIUM:
616 op = addarg(op, "-aa .3");
617 op = addarg(op, "-ad 64");
618 break;
619 case HIGH:
620 op = addarg(op, "-aa .25");
621 op = addarg(op, "-ad 128");
622 break;
623 }
624 op = addarg(op, "-as 0");
625 d = ambval();
626 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
627 op += strlen(op);
628 op = addarg(op, "-lr 3");
629 op = addarg(op, "-lw .02");
630 if (vdef(RENDER))
631 op = addarg(op, vval(RENDER));
632 }
633
634
635 medqopts(op) /* medium quality rendering options */
636 register char *op;
637 {
638 double d, org[3], siz[3];
639
640 *op = '\0';
641 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
642 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
643 badvalue(ZONE);
644 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
645 getoctcube(org, &d);
646 d *= 3./(siz[0]+siz[1]+siz[2]);
647 switch (vscale(DETAIL)) {
648 case LOW:
649 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
650 op = addarg(op, "-dp 64");
651 sprintf(op, " -ar %d", (int)(8*d));
652 op += strlen(op);
653 break;
654 case MEDIUM:
655 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
656 op = addarg(op, "-dp 128");
657 sprintf(op, " -ar %d", (int)(16*d));
658 op += strlen(op);
659 break;
660 case HIGH:
661 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
662 op = addarg(op, "-dp 256");
663 sprintf(op, " -ar %d", (int)(32*d));
664 op += strlen(op);
665 break;
666 }
667 op = addarg(op, "-pt .08");
668 if (vbool(PENUMBRAS)) {
669 op = addarg(op, "-ds .2");
670 op = addarg(op, "-dj .35");
671 } else
672 op = addarg(op, "-ds .3");
673 op = addarg(op, "-dt .1");
674 op = addarg(op, "-dc .5");
675 op = addarg(op, "-dr 1");
676 op = addarg(op, "-sj .7");
677 op = addarg(op, "-st .15");
678 sprintf(op, " -ab %d", overture=vint(INDIRECT));
679 op += strlen(op);
680 if (vdef(AMBFILE)) {
681 sprintf(op, " -af %s", vval(AMBFILE));
682 op += strlen(op);
683 } else
684 overture = 0;
685 switch (vscale(VARIABILITY)) {
686 case LOW:
687 op = addarg(op, "-aa .25");
688 op = addarg(op, "-ad 128");
689 op = addarg(op, "-as 0");
690 break;
691 case MEDIUM:
692 op = addarg(op, "-aa .2");
693 op = addarg(op, "-ad 300");
694 op = addarg(op, "-as 64");
695 break;
696 case HIGH:
697 op = addarg(op, "-aa .15");
698 op = addarg(op, "-ad 500");
699 op = addarg(op, "-as 128");
700 break;
701 }
702 d = ambval();
703 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
704 op += strlen(op);
705 op = addarg(op, "-lr 6");
706 op = addarg(op, "-lw .002");
707 if (vdef(RENDER))
708 op = addarg(op, vval(RENDER));
709 }
710
711
712 hiqopts(op) /* high quality rendering options */
713 register char *op;
714 {
715 double d, org[3], siz[3];
716
717 *op = '\0';
718 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
719 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
720 badvalue(ZONE);
721 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
722 getoctcube(org, &d);
723 d *= 3./(siz[0]+siz[1]+siz[2]);
724 switch (vscale(DETAIL)) {
725 case LOW:
726 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
727 op = addarg(op, "-dp 256");
728 sprintf(op, " -ar %d", (int)(16*d));
729 op += strlen(op);
730 break;
731 case MEDIUM:
732 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
733 op = addarg(op, "-dp 512");
734 sprintf(op, " -ar %d", (int)(32*d));
735 op += strlen(op);
736 break;
737 case HIGH:
738 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
739 op = addarg(op, "-dp 1024");
740 sprintf(op, " -ar %d", (int)(64*d));
741 op += strlen(op);
742 break;
743 }
744 op = addarg(op, "-pt .04");
745 if (vbool(PENUMBRAS)) {
746 op = addarg(op, "-ds .1");
747 op = addarg(op, "-dj .7");
748 } else
749 op = addarg(op, "-ds .2");
750 op = addarg(op, "-dt .05");
751 op = addarg(op, "-dc .75");
752 op = addarg(op, "-dr 3");
753 op = addarg(op, "-sj 1");
754 op = addarg(op, "-st .03");
755 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
756 op += strlen(op);
757 if (vdef(AMBFILE)) {
758 sprintf(op, " -af %s", vval(AMBFILE));
759 op += strlen(op);
760 } else
761 overture = 0;
762 switch (vscale(VARIABILITY)) {
763 case LOW:
764 op = addarg(op, "-aa .15");
765 op = addarg(op, "-ad 200");
766 op = addarg(op, "-as 0");
767 break;
768 case MEDIUM:
769 op = addarg(op, "-aa .125");
770 op = addarg(op, "-ad 512");
771 op = addarg(op, "-as 128");
772 break;
773 case HIGH:
774 op = addarg(op, "-aa .08");
775 op = addarg(op, "-ad 850");
776 op = addarg(op, "-as 256");
777 break;
778 }
779 d = ambval();
780 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
781 op += strlen(op);
782 op = addarg(op, "-lr 12");
783 op = addarg(op, "-lw .0005");
784 if (vdef(RENDER))
785 op = addarg(op, vval(RENDER));
786 }
787
788
789 xferopts(ro) /* transfer options if indicated */
790 char *ro;
791 {
792 int fd, n;
793
794 n = strlen(ro);
795 if (n < 2)
796 return;
797 if (vdef(OPTFILE)) {
798 if ((fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1)
799 syserr(vval(OPTFILE));
800 if (write(fd, ro+1, n-1) != n-1)
801 syserr(vval(OPTFILE));
802 write(fd, "\n", 1);
803 close(fd);
804 ro[0] = ' ';
805 ro[1] = '^';
806 strcpy(ro+2, vval(OPTFILE));
807 }
808 #ifdef MSDOS
809 else if (n > 50) {
810 register char *evp = bmalloc(n+6);
811 if (evp == NULL)
812 syserr(progname);
813 strcpy(evp, "ROPT=");
814 strcat(evp, ro);
815 if (putenv(evp) != 0) {
816 fprintf(stderr, "%s: out of environment space\n",
817 progname);
818 exit(1);
819 }
820 strcpy(ro, " $ROPT");
821 }
822 #endif
823 }
824
825
826 pfiltopts(po) /* get pfilt options */
827 register char *po;
828 {
829 *po = '\0';
830 if (vdef(EXPOSURE)) {
831 po = addarg(po, "-1 -e");
832 po = addarg(po, vval(EXPOSURE));
833 }
834 if (vscale(QUALITY) == HIGH)
835 po = addarg(po, "-r .65");
836 if (vdef(PFILT))
837 po = addarg(po, vval(PFILT));
838 }
839
840
841 matchword(s1, s2) /* match white-delimited words */
842 register char *s1, *s2;
843 {
844 while (isspace(*s1)) s1++;
845 while (isspace(*s2)) s2++;
846 while (*s1 && !isspace(*s1))
847 if (*s1++ != *s2++)
848 return(0);
849 return(!*s2 || isspace(*s2));
850 }
851
852
853 char *
854 specview(vs) /* get proper view spec from vs */
855 register char *vs;
856 {
857 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
858 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
859 static char viewopts[128];
860 register char *cp;
861 int xpos, ypos, zpos, viewtype, upax;
862 register int i;
863 double cent[3], dim[3], mult, d;
864
865 if (vs == NULL || *vs == '-')
866 return(vs);
867 upax = 0; /* get the up vector */
868 if (vdef(UP)) {
869 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
870 upax = 1-'X'+UPPER(vval(UP)[1]);
871 else
872 upax = 1-'X'+vlet(UP);
873 if (upax < 1 | upax > 3)
874 badvalue(UP);
875 if (vval(UP)[0] == '-')
876 upax = -upax;
877 }
878 /* check standard view names */
879 xpos = ypos = zpos = 0;
880 if (*vs == 'X') {
881 xpos = 1; vs++;
882 } else if (*vs == 'x') {
883 xpos = -1; vs++;
884 }
885 if (*vs == 'Y') {
886 ypos = 1; vs++;
887 } else if (*vs == 'y') {
888 ypos = -1; vs++;
889 }
890 if (*vs == 'Z') {
891 zpos = 1; vs++;
892 } else if (*vs == 'z') {
893 zpos = -1; vs++;
894 }
895 viewtype = 'v';
896 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
897 viewtype = *vs++;
898 cp = viewopts;
899 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
900 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
901 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
902 &cent[0], &dim[0], &cent[1], &dim[1],
903 &cent[2], &dim[2]) != 6)
904 badvalue(ZONE);
905 for (i = 0; i < 3; i++) {
906 dim[i] -= cent[i];
907 cent[i] += .5*dim[i];
908 }
909 mult = vlet(ZONE)=='E' ? 2. : .45 ;
910 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
911 cent[0]+xpos*mult*dim[0],
912 cent[1]+ypos*mult*dim[1],
913 cent[2]+zpos*mult*dim[2],
914 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
915 cp += strlen(cp);
916 /* redirect up axis if necessary */
917 switch (upax) {
918 case 3: /* plus or minus Z axis */
919 case -3:
920 case 0:
921 if (!(xpos|ypos))
922 upax = 2;
923 break;
924 case 2: /* plus or minus Y axis */
925 case -2:
926 if (!(xpos|zpos))
927 upax = 1;
928 break;
929 case 1: /* plus or minus X axis */
930 case -1:
931 if (!(ypos|zpos))
932 upax = 3;
933 break;
934 }
935 cp = addarg(cp, vup[upax+3]);
936 switch (viewtype) {
937 case 'v':
938 cp = addarg(cp, "-vh 45 -vv 45");
939 break;
940 case 'l':
941 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
942 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
943 cp += strlen(cp);
944 break;
945 case 'a':
946 case 'h':
947 cp = addarg(cp, "-vh 180 -vv 180");
948 break;
949 }
950 } else {
951 while (*vs && !isspace(*vs)) /* else skip id */
952 vs++;
953 if (upax) { /* specify up vector */
954 strcpy(cp, vup[upax+3]);
955 cp += strlen(cp);
956 }
957 }
958 /* append any additional options */
959 strcpy(cp, vs);
960 return(viewopts);
961 }
962
963
964 char *
965 getview(n, vn) /* get view n, or NULL if none */
966 int n;
967 char *vn;
968 {
969 register char *mv;
970
971 if (viewselect != NULL) {
972 if (n) /* only do one */
973 return(NULL);
974 if (viewselect[0] == '-') { /* already specified */
975 if (vn != NULL) *vn = '\0';
976 return(viewselect);
977 }
978 if (vn != NULL) {
979 for (mv = viewselect; *mv && !isspace(*mv);
980 *vn++ = *mv++)
981 ;
982 *vn = '\0';
983 }
984 /* check list */
985 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
986 if (matchword(viewselect, mv))
987 return(specview(mv));
988 return(specview(viewselect)); /* standard view? */
989 }
990 if (vn != NULL && (mv = nvalue(vv+VIEW, n)) != NULL) {
991 if (*mv != '-')
992 while (*mv && !isspace(*mv))
993 *vn++ = *mv++;
994 *vn = '\0';
995 }
996 return(specview(nvalue(vv+VIEW, n))); /* use view n */
997 }
998
999
1000 rview(opts) /* run rview with first view */
1001 char *opts;
1002 {
1003 char combuf[512];
1004 /* build command */
1005 sprintf(combuf, "rview %s%s ", getview(0, NULL), opts);
1006 if (rvdevice != NULL)
1007 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1008 strcat(combuf, vval(OCTREE));
1009 if (!silent) { /* echo it */
1010 printf("\t%s\n", combuf);
1011 fflush(stdout);
1012 }
1013 if (noaction)
1014 return;
1015 if (system(combuf)) { /* run it */
1016 fprintf(stderr, "%s: error running rview\n", progname);
1017 exit(1);
1018 }
1019 }
1020
1021
1022 rpict(opts) /* run rpict and pfilt for each view */
1023 char *opts;
1024 {
1025 char combuf[1024];
1026 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
1027 char pfopts[128];
1028 char vs[32], *vw;
1029 int vn, mult;
1030 /* get pfilt options */
1031 pfiltopts(pfopts);
1032 /* get resolution, reporting */
1033 mult = vscale(QUALITY)+1;
1034 {
1035 int xres, yres;
1036 double aspect;
1037 int n;
1038 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1039 if (n == 3)
1040 sprintf(res, "-x %d -y %d -pa %.3f",
1041 mult*xres, mult*yres, aspect);
1042 else if (n) {
1043 if (n == 1) yres = xres;
1044 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1045 } else
1046 badvalue(RESOLUTION);
1047 }
1048 rep[0] = '\0';
1049 if (vdef(REPORT)) {
1050 double minutes;
1051 int n;
1052 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1053 if (n == 2)
1054 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1055 else if (n == 1)
1056 sprintf(rep, " -t %d", (int)(minutes*60));
1057 else
1058 badvalue(REPORT);
1059 }
1060 /* check date on ambient file */
1061 if (vdef(AMBFILE)) {
1062 long afdate = fdate(vval(AMBFILE));
1063 if (afdate >= 0 & octreedate > afdate) {
1064 if (!silent)
1065 #ifdef MSDOS
1066 printf("\tdel %s\n", vval(AMBFILE));
1067 #else
1068 printf("\trm %s\n", vval(AMBFILE));
1069 #endif
1070 if (!noaction)
1071 unlink(vval(AMBFILE));
1072 }
1073 }
1074 /* do each view */
1075 vn = 0;
1076 while ((vw = getview(vn++, vs)) != NULL) {
1077 if (!vs[0])
1078 sprintf(vs, "%d", vn);
1079 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1080 /* check date on picture */
1081 if (fdate(picfile) > octreedate)
1082 continue;
1083 /* build rpict command */
1084 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1085 if (fdate(rawfile) > octreedate) /* recover */
1086 sprintf(combuf, "rpict%s%s -ro %s %s",
1087 rep, opts, rawfile, vval(OCTREE));
1088 else {
1089 if (overture) { /* run overture calculation */
1090 sprintf(combuf,
1091 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1092 rep, vw, opts,
1093 vval(OCTREE), rawfile);
1094 if (!silent) {
1095 printf("\t%s\n", combuf);
1096 fflush(stdout);
1097 }
1098 if (!noaction && system(combuf)) {
1099 fprintf(stderr,
1100 "%s: error in overture for view %s\n\t%s removed\n",
1101 progname, vs, rawfile);
1102 unlink(rawfile);
1103 exit(1);
1104 }
1105 }
1106 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1107 rep, vw, res, opts,
1108 vval(OCTREE), rawfile);
1109 }
1110 if (!silent) { /* echo rpict command */
1111 printf("\t%s\n", combuf);
1112 fflush(stdout);
1113 }
1114 if (!noaction && system(combuf)) { /* run rpict */
1115 fprintf(stderr, "%s: error rendering view %s\n",
1116 progname, vs);
1117 exit(1);
1118 }
1119 /* build pfilt command */
1120 if (mult > 1)
1121 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1122 pfopts, mult, mult, rawfile, picfile);
1123 else
1124 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1125 rawfile, picfile);
1126 if (!silent) { /* echo pfilt command */
1127 printf("\t%s\n", combuf);
1128 fflush(stdout);
1129 }
1130 if (!noaction && system(combuf)) { /* run pfilt */
1131 fprintf(stderr,
1132 "%s: error filtering view %s\n\t%s removed\n",
1133 progname, vs, picfile);
1134 unlink(picfile);
1135 exit(1);
1136 }
1137 /* remove raw file */
1138 if (!silent)
1139 #ifdef MSDOS
1140 printf("\tdel %s\n", rawfile);
1141 #else
1142 printf("\trm %s\n", rawfile);
1143 #endif
1144 if (!noaction)
1145 unlink(rawfile);
1146 }
1147 }
1148
1149
1150 badvalue(vc) /* report bad variable value and exit */
1151 int vc;
1152 {
1153 fprintf(stderr, "%s: bad value for variable '%s'\n",
1154 progname, vnam(vc));
1155 exit(1);
1156 }
1157
1158
1159 syserr(s) /* report a system error and exit */
1160 char *s;
1161 {
1162 perror(s);
1163 exit(1);
1164 }
