--- ray/src/util/rad.c 2003/09/24 14:55:54 2.72 +++ ray/src/util/rad.c 2016/06/07 16:53:19 2.125 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rad.c,v 2.72 2003/09/24 14:55:54 greg Exp $"; +static const char RCSid[] = "$Id: rad.c,v 2.125 2016/06/07 16:53:19 greg Exp $"; #endif /* * Executive program for oconv, rpict and pfilt @@ -9,18 +9,23 @@ static const char RCSid[] = "$Id: rad.c,v 2.72 2003/09 #include #include +#include #include "platform.h" +#include "rtprocess.h" #include "view.h" #include "paths.h" #include "vars.h" -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) #define DELCMD "del" #define RENAMECMD "rename" #else #define DELCMD "rm -f" #define RENAMECMD "mv" + #include + #include + #include #endif /* variables (alphabetical by name) */ @@ -32,26 +37,31 @@ static const char RCSid[] = "$Id: rad.c,v 2.72 2003/09 #define INDIRECT 5 /* indirection in lighting */ #define MATERIAL 6 /* material files */ #define MKILLUM 7 /* mkillum options */ -#define OBJECT 8 /* object files */ -#define OCONV 9 /* oconv options */ -#define OCTREE 10 /* octree file name */ -#define OPTFILE 11 /* rendering options file */ -#define PENUMBRAS 12 /* shadow penumbras are desired */ -#define PFILT 13 /* pfilt options */ -#define PICTURE 14 /* picture file root name */ -#define QUALITY 15 /* desired rendering quality */ -#define RAWFILE 16 /* raw picture file root name */ -#define RENDER 17 /* rendering options */ -#define REPORT 18 /* report frequency and errfile */ -#define RESOLUTION 19 /* maximum picture resolution */ -#define SCENE 20 /* scene files */ -#define UP 21 /* view up (X, Y or Z) */ -#define VARIABILITY 22 /* level of light variability */ -#define VIEWS 23 /* view(s) for picture(s) */ -#define ZFILE 24 /* distance file root name */ -#define ZONE 25 /* simulation zone */ +#define MKPMAP 8 /* mkpmap options */ +#define OBJECT 9 /* object files */ +#define OCONV 10 /* oconv options */ +#define OCTREE 11 /* octree file name */ +#define OPTFILE 12 /* rendering options file */ +#define PCMAP 13 /* caustic photon map */ +#define PENUMBRAS 14 /* shadow penumbras are desired */ +#define PFILT 15 /* pfilt options */ +#define PGMAP 16 /* global photon map */ +#define PICTURE 17 /* picture file root name */ +#define QUALITY 18 /* desired rendering quality */ +#define RAWFILE 19 /* raw picture file root name */ +#define RENDER 20 /* rendering options */ +#define REPORT 21 /* report frequency and errfile */ +#define RESOLUTION 22 /* maximum picture resolution */ +#define RPICT 23 /* rpict parameters */ +#define RVU 24 /* rvu parameters */ +#define SCENE 25 /* scene files */ +#define UP 26 /* view up (X, Y or Z) */ +#define VARIABILITY 27 /* level of light variability */ +#define VIEWS 28 /* view(s) for picture(s) */ +#define ZFILE 29 /* distance file root name */ +#define ZONE 30 /* simulation zone */ /* total number of variables */ -int NVARS = 26; +int NVARS = 31; VARIABLE vv[] = { /* variable-value pairs */ {"AMBFILE", 3, 0, NULL, onevalue}, @@ -62,18 +72,23 @@ VARIABLE vv[] = { /* variable-value pairs */ {"INDIRECT", 3, 0, NULL, intvalue}, {"materials", 3, 0, NULL, catvalues}, {"mkillum", 3, 0, NULL, catvalues}, + {"mkpmap", 3, 0, NULL, catvalues}, {"objects", 3, 0, NULL, catvalues}, {"oconv", 3, 0, NULL, catvalues}, {"OCTREE", 3, 0, NULL, onevalue}, {"OPTFILE", 3, 0, NULL, onevalue}, + {"PCMAP", 2, 0, NULL, onevalue}, {"PENUMBRAS", 3, 0, NULL, boolvalue}, {"pfilt", 2, 0, NULL, catvalues}, + {"PGMAP", 2, 0, NULL, onevalue}, {"PICTURE", 3, 0, NULL, onevalue}, {"QUALITY", 3, 0, NULL, qualvalue}, {"RAWFILE", 3, 0, NULL, onevalue}, {"render", 3, 0, NULL, catvalues}, {"REPORT", 3, 0, NULL, onevalue}, {"RESOLUTION", 3, 0, NULL, onevalue}, + {"rpict", 3, 0, NULL, catvalues}, + {"rvu", 3, 0, NULL, catvalues}, {"scene", 3, 0, NULL, catvalues}, {"UP", 2, 0, NULL, onevalue}, {"VARIABILITY", 3, 0, NULL, qualvalue}, @@ -100,15 +115,31 @@ time_t oct0date; /* date of pre-mkillum octree */ char *oct1name; /* name of post-mkillum octree */ time_t oct1date; /* date of post-mkillum octree (>= matdate) */ +char *pgmapname; /* name of global photon map */ +time_t pgmapdate; /* date of global photon map (>= oct1date) */ +char *pcmapname; /* name of caustic photon map */ +time_t pcmapdate; /* date of caustic photon map (>= oct1date) */ + int nowarn = 0; /* no warnings */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ int touchonly = 0; /* touch files only */ int nprocs = 1; /* maximum executing processes */ int sayview = 0; /* print view out */ -char *rvdevice = NULL; /* rview output device */ +char *rvdevice = NULL; /* rvu output device */ char *viewselect = NULL; /* specific view only */ +#define DEF_RPICT_PATH "rpict" /* default rpict path */ + + /* command paths */ +char c_oconv[256] = "oconv"; +char c_mkillum[256] = "mkillum"; +char c_mkpmap[256] = "mkpmap"; +char c_rvu[256] = "rvu"; +char c_rpict[256] = DEF_RPICT_PATH; +char c_rpiece[] = "rpiece"; +char c_pfilt[256] = "pfilt"; + int overture = 0; /* overture calculation needed */ int children_running = 0; /* set negative in children */ @@ -120,10 +151,48 @@ char radname[PATH_MAX]; /* root Radiance file name */ #define inchild() (children_running < 0) +static void rootname(char *rn, char *fn); +static time_t checklast(char *fnames); +static char * newfname(char *orig, int pred); +static void checkfiles(void); +static void getoctcube(double org[3], double *sizp); +static void setdefaults(void); +static void oconv(void); +static void mkpmap(void); +static char * addarg(char *op, char *arg); +static void oconvopts(char *oo); +static void mkillumopts(char *mo); +static void mkpmapopts(char *mo); +static void checkambfile(void); +static double ambval(void); +static void renderopts(char *op, char *po); +static void lowqopts(char *op, char *po); +static void medqopts(char *op, char *po); +static void hiqopts(char *op, char *po); +static void xferopts(char *ro); +static void pfiltopts(char *po); +static int matchword(char *s1, char *s2); +static char * specview(char *vs); +static char * getview(int n, char *vn); +static int myprintview(char *vopts, FILE *fp); +static void rvu(char *opts, char *po); +static void rpict(char *opts, char *po); +static int touch(char *fn); +static int runcom(char *cs); +static int rmfile(char *fn); +static int mvfile(char *fold, char *fnew); +static int next_process(int reserve); +static void wait_process(int all); +static void finish_process(void); +static void badvalue(int vc); +static void syserr(char *s); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { char ropts[512]; char popts[64]; @@ -168,9 +237,6 @@ char *argv[]; if (i >= argc) goto userr; rifname = argv[i]; - /* check command-line options */ - if ((nprocs > 1) & (viewselect != NULL)) - nprocs = 1; /* assign Radiance root file name */ rootname(radname, rifname); /* load variable values */ @@ -193,13 +259,15 @@ char *argv[]; printvars(stdout); /* build octree (and run mkillum) */ oconv(); + /* run mkpmap if indicated */ + mkpmap(); /* check date on ambient file */ checkambfile(); /* run simulation */ renderopts(ropts, popts); xferopts(ropts); if (rvdevice != NULL) - rview(ropts, popts); + rvu(ropts, popts); else rpict(ropts, popts); quit(0); @@ -208,11 +276,15 @@ userr: "Usage: %s [-w][-s][-n|-N npr][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); quit(1); + return 1; /* pro forma return */ } -rootname(rn, fn) /* remove tail from end of fn */ -register char *rn, *fn; +static void +rootname( /* remove tail from end of fn */ + char *rn, + char *fn +) { char *tp, *dp; @@ -226,9 +298,10 @@ register char *rn, *fn; } -time_t -checklast(fnames) /* check files and find most recent */ -register char *fnames; +static time_t +checklast( /* check files and find most recent */ + char *fnames +) { char thisfile[PATH_MAX]; time_t thisdate, lastdate = 0; @@ -237,8 +310,11 @@ register char *fnames; return(0); while ((fnames = nextword(thisfile, PATH_MAX, fnames)) != NULL) { if (thisfile[0] == '!' || - (thisfile[0] == '\\' && thisfile[1] == '!')) + (thisfile[0] == '\\' && thisfile[1] == '!')) { + if (!lastdate) + lastdate = 1; continue; + } if (!(thisdate = fdate(thisfile))) syserr(thisfile); if (thisdate > lastdate) @@ -248,13 +324,14 @@ register char *fnames; } -char * -newfname(orig, pred) /* create modified file name */ -char *orig; -int pred; +static char * +newfname( /* create modified file name */ + char *orig, + int pred +) { - register char *cp; - register int n; + char *cp; + int n; int suffix; n = 0; cp = orig; suffix = -1; /* suffix position, length */ @@ -273,8 +350,10 @@ int pred; } -checkfiles() /* check for existence and modified times */ +static void +checkfiles(void) /* check for existence and modified times */ { + char fntemp[256]; time_t objdate; if (!vdef(OCTREE)) { @@ -304,19 +383,41 @@ checkfiles() /* check for existence and modified tim vnam(OCTREE), vnam(SCENE), vnam(ILLUM)); quit(1); } + if (vdef(PGMAP)) { + if (!*sskip2(vval(PGMAP),1)) { + fprintf(stderr, "%s: '%s' missing # photons argument\n", + progname, vnam(PGMAP)); + quit(1); + } + atos(fntemp, sizeof(fntemp), vval(PGMAP)); + pgmapname = savqstr(fntemp); + pgmapdate = fdate(pgmapname); + } + if (vdef(PCMAP)) { + if (!*sskip2(vval(PCMAP),1)) { + fprintf(stderr, "%s: '%s' missing # photons argument\n", + progname, vnam(PCMAP)); + quit(1); + } + atos(fntemp, sizeof(fntemp), vval(PCMAP)); + pcmapname = savqstr(fntemp); + pcmapdate = fdate(pcmapname); + } matdate = checklast(vval(MATERIAL)); } -getoctcube(org, sizp) /* get octree bounding cube */ -double org[3], *sizp; +static void +getoctcube( /* get octree bounding cube */ + double org[3], + double *sizp +) { - extern FILE *popen(); static double oorg[3], osiz = 0.; double min[3], max[3]; char buf[1024]; FILE *fp; - register int i; + int i; if (osiz <= FTINY) { if (!nprocs && fdate(oct1name) < @@ -359,7 +460,8 @@ double org[3], *sizp; } -setdefaults() /* set default values for unassigned var's */ +static void +setdefaults(void) /* set default values for unassigned var's */ { double org[3], lim[3], size; char buf[128]; @@ -416,10 +518,11 @@ setdefaults() /* set default values for unassigned v } -oconv() /* run oconv and mkillum if necessary */ +static void +oconv(void) /* run oconv and mkillum if necessary */ { static char illumtmp[] = "ilXXXXXX"; - char combuf[PATH_MAX], ocopts[64], mkopts[64]; + char combuf[PATH_MAX], ocopts[64], mkopts[1024]; oconvopts(ocopts); /* get options */ if (octreedate < scenedate) { /* check date on original octree */ @@ -427,11 +530,11 @@ oconv() /* run oconv and mkillum if necessary */ touch(vval(OCTREE)); else { /* build command */ if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vval(MATERIAL), vval(SCENE), - vval(OCTREE)); + sprintf(combuf, "%s%s %s %s > %s", c_oconv, + ocopts, vval(MATERIAL), + vval(SCENE), vval(OCTREE)); else - sprintf(combuf, "oconv%s %s > %s", ocopts, + sprintf(combuf, "%s%s %s > %s", c_oconv, ocopts, vval(SCENE), vval(OCTREE)); if (runcom(combuf)) { /* run it */ @@ -457,14 +560,16 @@ oconv() /* run oconv and mkillum if necessary */ touch(oct0name); else { /* build command */ if (octreedate) - sprintf(combuf, "oconv%s -i %s %s > %s", ocopts, - vval(OCTREE), vval(ILLUM), oct0name); + sprintf(combuf, "%s%s -i %s %s > %s", c_oconv, + ocopts, vval(OCTREE), + vval(ILLUM), oct0name); else if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vval(MATERIAL), vval(ILLUM), oct0name); - else - sprintf(combuf, "oconv%s %s > %s", ocopts, + sprintf(combuf, "%s%s %s %s > %s", c_oconv, + ocopts, vval(MATERIAL), vval(ILLUM), oct0name); + else + sprintf(combuf, "%s%s %s > %s", c_oconv, + ocopts, vval(ILLUM), oct0name); if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error generating octree\n\t%s removed\n", @@ -484,23 +589,24 @@ oconv() /* run oconv and mkillum if necessary */ else { mkillumopts(mkopts); /* build mkillum command */ mktemp(illumtmp); - sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts, + sprintf(combuf, "%s%s %s \"<\" %s > %s", c_mkillum, mkopts, oct0name, vval(ILLUM), illumtmp); if (runcom(combuf)) { /* run it */ - fprintf(stderr, "%s: error running mkillum\n", - progname); + fprintf(stderr, "%s: error running %s\n", + progname, c_mkillum); unlink(illumtmp); quit(1); } + rmfile(oct0name); /* make octree1 (frozen) */ if (octreedate) - sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts, - vval(OCTREE), illumtmp, oct1name); + sprintf(combuf, "%s%s -f -i %s %s > %s", c_oconv, + ocopts, vval(OCTREE), illumtmp, oct1name); else if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s -f %s %s > %s", ocopts, - vval(MATERIAL), illumtmp, oct1name); + sprintf(combuf, "%s%s -f %s %s > %s", c_oconv, + ocopts, vval(MATERIAL), illumtmp, oct1name); else - sprintf(combuf, "oconv%s -f %s > %s", ocopts, + sprintf(combuf, "%s%s -f %s > %s", c_oconv, ocopts, illumtmp, oct1name); if (runcom(combuf)) { /* run it */ fprintf(stderr, @@ -518,10 +624,81 @@ oconv() /* run oconv and mkillum if necessary */ } -char * -addarg(op, arg) /* add argument and advance pointer */ -register char *op, *arg; +static void +mkpmap(void) /* run mkpmap if indicated */ { + char combuf[2048], *cp; + time_t tnow; + /* nothing to do? */ + if ((pgmapname == NULL) | (pgmapdate >= oct1date) && + (pcmapname == NULL) | (pcmapdate >= oct1date)) + return; + /* just update existing file dates? */ + if (touchonly && (pgmapname == NULL) | (pgmapdate > 0) && + (pcmapname == NULL) | (pcmapdate > 0)) { + if (pgmapname != NULL) + touch(pgmapname); + if (pcmapname != NULL) + touch(pcmapname); + } else { /* else need to (re)run pkpmap */ + strcpy(combuf, c_mkpmap); + for (cp = combuf; *cp; cp++) + ; + mkpmapopts(cp); + /* force file overwrite */ + cp = addarg(cp, "-fo+"); + if (vdef(REPORT)) { + char errfile[256]; + int n; + double minutes; + n = sscanf(vval(REPORT), "%lf %s", &minutes, errfile); + if (n == 2) + sprintf(cp, " -t %d -e %s", (int)(minutes*60), errfile); + else if (n == 1) + sprintf(cp, " -t %d", (int)(minutes*60)); + else + badvalue(REPORT); + } + if (pgmapname != NULL && pgmapdate < oct1date) { + cp = addarg(cp, "-apg"); + addarg(cp, vval(PGMAP)); + cp = sskip(sskip(cp)); /* remove any bandwidth */ + *cp = '\0'; + } + if (pcmapname != NULL && pcmapdate < oct1date) { + cp = addarg(cp, "-apc"); + addarg(cp, vval(PCMAP)); + cp = sskip(sskip(cp)); /* remove any bandwidth */ + *cp = '\0'; + } + cp = addarg(cp, oct1name); + if (runcom(combuf)) { + fprintf(stderr, "%s: error running %s\n", + progname, c_mkpmap); + if (pgmapname != NULL && pgmapdate < oct1date) + unlink(pgmapname); + if (pcmapname != NULL && pcmapdate < oct1date) + unlink(pcmapname); + quit(1); + } + } + tnow = time((time_t *)NULL); + if (pgmapname != NULL) + pgmapdate = tnow; + if (pcmapname != NULL) + pcmapdate = tnow; + oct1date = tnow; /* trigger ambient file removal if needed */ +} + + +static char * +addarg( /* append argument and advance pointer */ +char *op, +char *arg +) +{ + while (*op) + op++; *op = ' '; while ( (*++op = *arg++) ) ; @@ -529,30 +706,69 @@ register char *op, *arg; } -oconvopts(oo) /* get oconv options */ -register char *oo; +static void +oconvopts( /* get oconv options */ + char *oo +) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ *oo = '\0'; - if (vdef(OCONV)) - addarg(oo, vval(OCONV)); + if (!vdef(OCONV)) + return; + if (vval(OCONV)[0] != '-') { + atos(c_oconv, sizeof(c_oconv), vval(OCONV)); + oo = addarg(oo, sskip2(vval(OCONV), 1)); + } else + oo = addarg(oo, vval(OCONV)); } -mkillumopts(mo) /* get mkillum options */ -register char *mo; +static void +mkillumopts( /* get mkillum options */ + char *mo +) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ - *mo = '\0'; - if (vdef(MKILLUM)) - addarg(mo, vval(MKILLUM)); + if (nprocs > 1) + sprintf(mo, " -n %d", nprocs); + else + *mo = '\0'; + if (!vdef(MKILLUM)) + return; + if (vval(MKILLUM)[0] != '-') { + atos(c_mkillum, sizeof(c_mkillum), vval(MKILLUM)); + mo = addarg(mo, sskip2(vval(MKILLUM), 1)); + } else + mo = addarg(mo, vval(MKILLUM)); } -checkambfile() /* check date on ambient file */ +static void +mkpmapopts( /* get mkpmap options */ + char *mo +) { + /* BEWARE: This may be called via setdefaults(), so no assumptions */ + + if (nprocs > 1) + sprintf(mo, " -n %d", nprocs); + else + *mo = '\0'; + if (!vdef(MKPMAP)) + return; + if (vval(MKPMAP)[0] != '-') { + atos(c_mkpmap, sizeof(c_mkpmap), vval(MKPMAP)); + mo = addarg(mo, sskip2(vval(MKPMAP), 1)); + } else + mo = addarg(mo, vval(MKPMAP)); +} + + +static void +checkambfile(void) /* check date on ambient file */ +{ time_t afdate; if (!vdef(AMBFILE)) @@ -568,8 +784,8 @@ checkambfile() /* check date on ambient file */ } -double -ambval() /* compute ambient value */ +static double +ambval(void) /* compute ambient value */ { if (vdef(EXPOSURE)) { if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') @@ -581,12 +797,25 @@ ambval() /* compute ambient value */ if (vlet(ZONE) == 'I') return(.01); badvalue(ZONE); + return 0; /* pro forma return */ } -renderopts(op, po) /* set rendering options */ -char *op, *po; +static void +renderopts( /* set rendering options */ + char *op, + char *po +) { + char pmapf[256], *bw; + + if (vdef(PGMAP)) { + *op = '\0'; + bw = sskip2(vval(PGMAP), 2); + atos(pmapf, sizeof(pmapf), vval(PGMAP)); + op = addarg(addarg(op, "-ap"), pmapf); + if (atoi(bw) > 0) op = addarg(op, bw); + } switch(vscale(QUALITY)) { case LOW: lowqopts(op, po); @@ -598,12 +827,39 @@ char *op, *po; hiqopts(op, po); break; } + if (vdef(PCMAP)) { + bw = sskip2(vval(PCMAP), 2); + atos(pmapf, sizeof(pmapf), vval(PCMAP)); + op = addarg(addarg(op, "-ap"), pmapf); + if (atoi(bw) > 0) op = addarg(op, bw); + } + if (vdef(RENDER)) + op = addarg(op, vval(RENDER)); + if (rvdevice != NULL) { + if (vdef(RVU)) { + if (vval(RVU)[0] != '-') { + atos(c_rvu, sizeof(c_rvu), vval(RVU)); + po = addarg(po, sskip2(vval(RVU), 1)); + } else + po = addarg(po, vval(RVU)); + } + } else { + if (vdef(RPICT)) { + if (vval(RPICT)[0] != '-') { + atos(c_rpict, sizeof(c_rpict), vval(RPICT)); + po = addarg(po, sskip2(vval(RPICT), 1)); + } else + po = addarg(po, vval(RPICT)); + } + } } -lowqopts(op, po) /* low quality rendering options */ -register char *op; -char *po; +static void +lowqopts( /* low quality rendering options */ + char *op, + char *po +) { double d, org[3], siz[3]; @@ -642,7 +898,7 @@ char *po; op = addarg(op, "-ds .4"); else op = addarg(op, "-ds 0"); - op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5"); + op = addarg(op, "-dt .2 -dc .25 -dr 0 -ss 0 -st .5"); if (vdef(AMBFILE)) { sprintf(op, " -af %s", vval(AMBFILE)); op += strlen(op); @@ -663,15 +919,15 @@ char *po; d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 6 -lw .01"); - if (vdef(RENDER)) - op = addarg(op, vval(RENDER)); + op = addarg(op, "-lr 6 -lw .003"); } -medqopts(op, po) /* medium quality rendering options */ -register char *op; -char *po; +static void +medqopts( /* medium quality rendering options */ + char *op, + char *po +) { double d, org[3], siz[3], asz; @@ -714,10 +970,10 @@ char *po; } po = addarg(po, "-pt .08"); if (vbool(PENUMBRAS)) - op = addarg(op, "-ds .2 -dj .5"); + op = addarg(op, "-ds .2 -dj .9"); else op = addarg(op, "-ds .3"); - op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1"); + op = addarg(op, "-dt .1 -dc .5 -dr 1 -ss 1 -st .1"); if ( (overture = vint(INDIRECT)) ) { sprintf(op, " -ab %d", overture); op += strlen(op); @@ -741,15 +997,15 @@ char *po; d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 8 -lw .002"); - if (vdef(RENDER)) - op = addarg(op, vval(RENDER)); + op = addarg(op, "-lr 8 -lw 1e-4"); } -hiqopts(op, po) /* high quality rendering options */ -register char *op; -char *po; +static void +hiqopts( /* high quality rendering options */ + char *op, + char *po +) { double d, org[3], siz[3], asz; @@ -792,10 +1048,10 @@ char *po; } po = addarg(po, "-pt .04"); if (vbool(PENUMBRAS)) - op = addarg(op, "-ds .1 -dj .65"); + op = addarg(op, "-ds .1 -dj .9"); else op = addarg(op, "-ds .2"); - op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01"); + op = addarg(op, "-dt .05 -dc .75 -dr 3 -ss 16 -st .01"); sprintf(op, " -ab %d", overture=vint(INDIRECT)+1); op += strlen(op); if (vdef(AMBFILE)) { @@ -817,17 +1073,40 @@ char *po; d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 12 -lw .0005"); - if (vdef(RENDER)) - op = addarg(op, vval(RENDER)); + op = addarg(op, "-lr 12 -lw 1e-5"); } -xferopts(ro) /* transfer options if indicated */ -char *ro; +#if defined(_WIN32) || defined(_WIN64) +static void +setenv( /* set an environment variable */ + char *vname, + char *value +) { + char *evp; + + evp = bmalloc(strlen(vname)+strlen(value)+2); + if (evp == NULL) + syserr(progname); + sprintf(evp, "%s=%s", vname, value); + if (putenv(evp) != 0) { + fprintf(stderr, "%s: out of environment space\n", progname); + quit(1); + } + if (!silent) + printf("set %s\n", evp); +} +#endif + + +static void +xferopts( /* transfer options if indicated */ + char *ro +) +{ int fd, n; - register char *cp; + char *cp; n = strlen(ro); if (n < 2) @@ -845,7 +1124,7 @@ char *ro; syserr(vval(OPTFILE)); sprintf(ro, " @%s", vval(OPTFILE)); } -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) else if (n > 50) { setenv("ROPT", ro+1); strcpy(ro, " $ROPT"); @@ -854,8 +1133,10 @@ char *ro; } -pfiltopts(po) /* get pfilt options */ -register char *po; +static void +pfiltopts( /* get pfilt options */ + char *po +) { *po = '\0'; if (vdef(EXPOSURE)) { @@ -870,13 +1151,21 @@ register char *po; po = addarg(po, "-m .25"); break; } - if (vdef(PFILT)) - po = addarg(po, vval(PFILT)); + if (vdef(PFILT)) { + if (vval(PFILT)[0] != '-') { + atos(c_pfilt, sizeof(c_pfilt), vval(PFILT)); + po = addarg(po, sskip2(vval(PFILT), 1)); + } else + po = addarg(po, vval(PFILT)); + } } -matchword(s1, s2) /* match white-delimited words */ -register char *s1, *s2; +static int +matchword( /* match white-delimited words */ + char *s1, + char *s2 +) { while (isspace(*s1)) s1++; while (isspace(*s2)) s2++; @@ -887,16 +1176,17 @@ register char *s1, *s2; } -char * -specview(vs) /* get proper view spec from vs */ -register char *vs; +static char * +specview( /* get proper view spec from vs */ + char *vs +) { static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0", "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"}; static char viewopts[128]; - register char *cp; + char *cp; int xpos, ypos, zpos, viewtype, upax; - register int i; + int i; double cent[3], dim[3], mult, d; if (vs == NULL || *vs == '-') @@ -929,9 +1219,19 @@ register char *vs; } else if (*vs == 'z') { zpos = -1; vs++; } - viewtype = 'v'; - if((*vs == 'v') | (*vs == 'l') | (*vs == 'a') | (*vs == 'h') | (*vs == 'c')) + switch (*vs) { + case VT_PER: + case VT_PAR: + case VT_ANG: + case VT_HEM: + case VT_PLS: + case VT_CYL: viewtype = *vs++; + break; + default: + viewtype = VT_PER; + break; + } cp = viewopts; if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */ *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype; @@ -946,7 +1246,7 @@ register char *vs; cent[i] += .5*dim[i]; } mult = vlet(ZONE)=='E' ? 2. : .45 ; - sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g", + sprintf(cp, " -vp %.3g %.3g %.3g -vd %.3g %.3g %.3g", cent[0]+xpos*mult*dim[0], cent[1]+ypos*mult*dim[1], cent[2]+zpos*mult*dim[2], @@ -973,19 +1273,20 @@ register char *vs; } cp = addarg(cp, vup[upax+3]); switch (viewtype) { - case 'v': + case VT_PER: cp = addarg(cp, "-vh 45 -vv 45"); break; - case 'l': + case VT_PAR: d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]); - sprintf(cp, " -vh %.2g -vv %.2g", d, d); + sprintf(cp, " -vh %.3g -vv %.3g", d, d); cp += strlen(cp); break; - case 'a': - case 'h': + case VT_ANG: + case VT_HEM: + case VT_PLS: cp = addarg(cp, "-vh 180 -vv 180"); break; - case 'c': + case VT_CYL: cp = addarg(cp, "-vh 180 -vv 90"); break; } @@ -993,7 +1294,7 @@ register char *vs; while (!isspace(*vs)) /* else skip id */ if (!*vs++) return(NULL); - if (upax) { /* specify up vector */ + if (upax) { /* prepend up vector */ strcpy(cp, vup[upax+3]); cp += strlen(cp); } @@ -1001,7 +1302,7 @@ register char *vs; if (cp == viewopts) /* append any additional options */ vs++; /* skip prefixed space if unneeded */ strcpy(cp, vs); -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) if (strlen(viewopts) > 40) { setenv("VIEW", viewopts); return("$VIEW"); @@ -1011,18 +1312,25 @@ register char *vs; } -char * -getview(n, vn) /* get view n, or NULL if none */ -int n; -char *vn; /* returned view name */ +static char * +getview( /* get view n, or NULL if none */ + int n, + char *vn /* returned view name */ +) { - register char *mv; + char *mv; if (viewselect != NULL) { /* command-line selected */ if (n) /* only do one */ return(NULL); + + if (isint(viewselect)) { /* view number? */ + n = atoi(viewselect)-1; + goto numview; + } if (viewselect[0] == '-') { /* already specified */ - if (vn != NULL) *vn = '\0'; + if (vn != NULL) + strcpy(vn, "0"); return(viewselect); } if (vn != NULL) { @@ -1031,39 +1339,45 @@ char *vn; /* returned view name */ ; *vn = '\0'; } - /* view number? */ - if (isint(viewselect)) - return(specview(nvalue(VIEWS, atoi(viewselect)-1))); /* check list */ while ((mv = nvalue(VIEWS, n++)) != NULL) if (matchword(viewselect, mv)) return(specview(mv)); + return(specview(viewselect)); /* standard view? */ } +numview: mv = nvalue(VIEWS, n); /* use view n */ if ((vn != NULL) & (mv != NULL)) { - register char *mv2 = mv; - if (*mv2 != '-') + if (*mv != '-') { + char *mv2 = mv; while (*mv2 && !isspace(*mv2)) *vn++ = *mv2++; - *vn = '\0'; + *vn = '\0'; + } else + sprintf(vn, "%d", n+1); } return(specview(mv)); } -int -myprintview(vopts, fp) /* print out selected view */ -register char *vopts; -FILE *fp; +static int +myprintview( /* print out selected view */ + char *vopts, + FILE *fp +) { VIEW vwr; char buf[128]; - register char *cp; + char *cp; +#if defined(_WIN32) || defined(_WIN64) +/* XXX Should we allow something like this for all platforms? */ +/* XXX Or is it still required at all? */ again: +#endif if (vopts == NULL) return(-1); -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) if (vopts[0] == '$') { vopts = getenv(vopts+1); goto again; @@ -1083,8 +1397,11 @@ again: } -rview(opts, po) /* run rview with first view */ -char *opts, *po; +static void +rvu( /* run rvu with first view */ + char *opts, + char *po +) { char *vw; char combuf[PATH_MAX]; @@ -1093,31 +1410,66 @@ char *opts, *po; return; if (sayview) myprintview(vw, stdout); - sprintf(combuf, "rview %s%s%s -R %s ", vw, po, opts, rifname); + sprintf(combuf, "%s %s%s%s -R %s ", c_rvu, vw, opts, po, rifname); + if (nprocs > 1) + sprintf(combuf+strlen(combuf), "-n %d ", nprocs); if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); if (vdef(EXPOSURE)) sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE)); strcat(combuf, oct1name); if (runcom(combuf)) { /* run it */ - fprintf(stderr, "%s: error running rview\n", progname); + fprintf(stderr, "%s: error running %s\n", progname, c_rvu); quit(1); } } -rpict(opts, po) /* run rpict and pfilt for each view */ -char *opts, *po; +static int +syncf_done( /* check if an rpiece sync file is complete */ + char *sfname +) { - char combuf[PATH_MAX]; + FILE *fp = fopen(sfname, "r"); + int todo = 1; + int x, y; + + if (fp == NULL) + return(0); + if (fscanf(fp, "%d %d", &x, &y) != 2) + goto checked; + todo = x*y; /* total number of tiles */ + if (fscanf(fp, "%d %d", &x, &y) != 2 || (x != 0) | (y != 0)) + goto checked; + /* XXX assume no redundant tiles */ + while (fscanf(fp, "%d %d", &x, &y) == 2) + if (!--todo) + break; +checked: + fclose(fp); + return(!todo); +} + + +static void +rpict( /* run rpict and pfilt for each view */ + char *opts, + char *po +) +{ +#define do_rpiece (sfile[0]!='\0') + char combuf[5*PATH_MAX+512]; char rawfile[PATH_MAX], picfile[PATH_MAX]; char zopt[PATH_MAX+4], rep[PATH_MAX+16], res[32]; - char rppopt[128], *pfile = NULL; + char rppopt[32], sfile[PATH_MAX], *pfile = NULL; char pfopts[128]; char vs[32], *vw; int vn, mult; FILE *fp; time_t rfdt, pfdt; + int xres, yres; + double aspect; + int n; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ @@ -1132,24 +1484,19 @@ char *opts, *po; mult = 3; break; } - { - int xres, yres; - double aspect; - int n; - n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect); - if (n == 3) - sprintf(res, "-x %d -y %d -pa %.3f", - mult*xres, mult*yres, aspect); - else if (n) { - if (n == 1) yres = xres; - sprintf(res, "-x %d -y %d", mult*xres, mult*yres); - } else - badvalue(RESOLUTION); - } + n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect); + if (n == 3) + sprintf(res, "-x %d -y %d -pa %.3f", + mult*xres, mult*yres, aspect); + else if (n) { + aspect = 1.; + if (n == 1) yres = xres; + sprintf(res, "-x %d -y %d", mult*xres, mult*yres); + } else + badvalue(RESOLUTION); rep[0] = '\0'; if (vdef(REPORT)) { double minutes; - int n; n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile); if (n == 2) sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile); @@ -1159,19 +1506,33 @@ char *opts, *po; badvalue(REPORT); } /* set up parallel rendering */ - if ((nprocs > 1) & (!vdef(ZFILE))) { - strcpy(rppopt, "-S 1 -PP pfXXXXXX"); - pfile = rppopt+9; - if (mktemp(pfile) == NULL) + sfile[0] = '\0'; + if ((nprocs > 1) & !touchonly & !vdef(ZFILE) && + getview(0, vs) != NULL) { + if (!strcmp(c_rpict, DEF_RPICT_PATH) && + getview(1, NULL) == NULL) { + sprintf(sfile, "%s_%s_rpsync.txt", + vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE), + vs); + strcpy(rppopt, "-PP pfXXXXXX"); + } else { + strcpy(rppopt, "-S 1 -PP pfXXXXXX"); + } + pfile = rppopt + strlen(rppopt) - 8; + if (mktemp(pfile) == NULL) { + if (do_rpiece) { + fprintf(stderr, "%s: cannot create\n", pfile); + quit(1); + } + pfile[-5] = '\0'; pfile = NULL; + } } vn = 0; /* do each view */ while ((vw = getview(vn++, vs)) != NULL) { if (sayview) myprintview(vw, stdout); - if (!vs[0]) - sprintf(vs, "%d", vn); - sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); + sprintf(picfile, "%s_%s.hdr", vval(PICTURE), vs); if (vdef(ZFILE)) sprintf(zopt, " -z %s_%s.zbf", vval(ZFILE), vs); else @@ -1192,64 +1553,122 @@ char *opts, *po; touch(picfile); continue; } - if (next_process()) { /* parallel running? */ + /* parallel running? */ + if (do_rpiece) { + if (rfdt < oct1date || !fdate(sfile)) { + int xdiv = 8+nprocs/3, ydiv = 8+nprocs/3; + if (rfdt >= oct1date) { + fprintf(stderr, + "%s: partial output not created with %s\n", rawfile, c_rpiece); + quit(1); + } + if (rfdt) { /* start fresh */ + rmfile(rawfile); + rfdt = 0; + } + if (!silent) + printf("\techo %d %d > %s\n", + xdiv, ydiv, sfile); + if ((fp = fopen(sfile, "w")) == NULL) { + fprintf(stderr, "%s: cannot create\n", + sfile); + quit(1); + } + fprintf(fp, "%d %d\n", xdiv, ydiv); + fclose(fp); + } + } else if (next_process(0)) { if (pfile != NULL) - sleep(20); + sleep(10); continue; - } + } else if (!inchild()) + pfile = NULL; /* XXX Remember to call finish_process() */ /* build rpict command */ - if (rfdt >= oct1date) { /* recover */ - sprintf(combuf, "rpict%s%s%s%s -ro %s %s", - rep, po, opts, zopt, rawfile, oct1name); - if (runcom(combuf)) /* run rpict */ + if (rfdt >= oct1date) { /* already in progress */ + if (do_rpiece) { + sprintf(combuf, "%s -R %s %s%s %s %s%s%s -o %s %s", + c_rpiece, sfile, rppopt, rep, vw, + res, opts, po, rawfile, oct1name); + while (next_process(1)) { + sleep(10); + combuf[strlen(c_rpiece)+2] = 'F'; + } + } else + sprintf(combuf, "%s%s%s%s%s -ro %s %s", c_rpict, + rep, opts, po, zopt, rawfile, oct1name); + if (runcom(combuf)) /* run rpict/rpiece */ goto rperror; } else { if (overture) { /* run overture calculation */ sprintf(combuf, - "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s", - rep, vw, opts, + "%s%s %s%s -x 64 -y 64 -ps 1 %s > %s", + c_rpict, rep, vw, opts, oct1name, overfile); - if (runcom(combuf)) { - fprintf(stderr, + if (!do_rpiece || !next_process(0)) { + if (runcom(combuf)) { + fprintf(stderr, "%s: error in overture for view %s\n", - progname, vs); - quit(1); - } + progname, vs); + quit(1); + } #ifndef NULL_DEVICE - rmfile(overfile); + rmfile(overfile); #endif + } else if (do_rpiece) + sleep(20); } - sprintf(combuf, "rpict%s %s %s%s%s%s %s > %s", - rep, vw, res, po, opts, - zopt, oct1name, rawfile); - if (pfile != NULL && inchild()) { - /* rpict persistent mode */ + if (do_rpiece) { + sprintf(combuf, "%s -F %s %s%s %s %s%s%s -o %s %s", + c_rpiece, sfile, rppopt, rep, vw, + res, opts, po, rawfile, oct1name); + while (next_process(1)) + sleep(10); + } else { + sprintf(combuf, "%s%s %s %s%s%s%s %s > %s", + c_rpict, rep, vw, res, opts, po, + zopt, oct1name, rawfile); + } + if ((pfile != NULL) & !do_rpiece) { if (!silent) printf("\t%s\n", combuf); - sprintf(combuf, "rpict%s %s %s%s%s %s > %s", - rep, rppopt, res, po, opts, - oct1name, rawfile); fflush(stdout); + sprintf(combuf, "%s%s %s %s%s%s %s > %s", + c_rpict, rep, rppopt, res, + opts, po, oct1name, rawfile); fp = popen(combuf, "w"); if (fp == NULL) goto rperror; myprintview(vw, fp); if (pclose(fp)) goto rperror; - } else { /* rpict normal mode */ - if (runcom(combuf)) - goto rperror; + } else if (runcom(combuf)) + goto rperror; + } + if (do_rpiece) { /* need to finish raw, first */ + finish_process(); + wait_process(1); + if (!syncf_done(sfile)) { + fprintf(stderr, + "%s: %s did not complete rendering of view %s\n", + progname, c_rpiece, vs); + quit(1); } } if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) { /* build pfilt command */ - if (mult > 1) - sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s", - pfopts, mult, mult, rawfile, picfile); + if (do_rpiece) + sprintf(combuf, + "%s%s -x %d -y %d -p %.3f %s > %s", + c_pfilt, pfopts, xres, yres, aspect, + rawfile, picfile); + else if (mult > 1) + sprintf(combuf, "%s%s -x /%d -y /%d %s > %s", + c_pfilt, pfopts, mult, mult, + rawfile, picfile); else - sprintf(combuf, "pfilt%s %s > %s", pfopts, - rawfile, picfile); + sprintf(combuf, "%s%s %s > %s", c_pfilt, + pfopts, rawfile, picfile); if (runcom(combuf)) { /* run pfilt */ fprintf(stderr, "%s: error filtering view %s\n\t%s removed\n", @@ -1260,19 +1679,22 @@ char *opts, *po; } /* remove/rename raw file */ if (vdef(RAWFILE)) { - sprintf(combuf, "%s_%s.pic", vval(RAWFILE), vs); + sprintf(combuf, "%s_%s.hdr", vval(RAWFILE), vs); mvfile(rawfile, combuf); } else rmfile(rawfile); - finish_process(); /* leave if child */ + if (do_rpiece) /* done with sync file */ + rmfile(sfile); + else + finish_process(); /* exit if child */ } wait_process(1); /* wait for children to finish */ - if (pfile != NULL) { /* clean up rpict persistent mode */ - int pid; + if (pfile != NULL) { /* clean up persistent rpict */ + RT_PID pid; fp = fopen(pfile, "r"); if (fp != NULL) { if (fscanf(fp, "%*s %d", &pid) != 1 || - kill(pid, 1) == -1) + kill(pid, 1) < 0) unlink(pfile); fclose(fp); } @@ -1281,39 +1703,41 @@ char *opts, *po; rperror: fprintf(stderr, "%s: error rendering view %s\n", progname, vs); quit(1); +#undef do_rpiece } -touch(fn) /* update a file */ -char *fn; +static int +touch( /* update a file */ + char *fn +) { if (!silent) printf("\ttouch %s\n", fn); if (!nprocs) return(0); -#ifdef notused - if (access(fn, F_OK) == -1) /* create it */ - if (close(open(fn, O_WRONLY|O_CREAT, 0666)) == -1) - return(-1); -#endif return(setfdate(fn, time((time_t *)NULL))); } -runcom(cs) /* run command */ -char *cs; +static int +runcom( /* run command */ + char *cs +) { if (!silent) /* echo it */ printf("\t%s\n", cs); if (!nprocs) return(0); - fflush(stdout); /* flush output and pass to shell */ + fflush(NULL); /* flush output and pass to shell */ return(system(cs)); } -rmfile(fn) /* remove a file */ -char *fn; +static int +rmfile( /* remove a file */ + char *fn +) { if (!silent) printf("\t%s %s\n", DELCMD, fn); @@ -1323,8 +1747,11 @@ char *fn; } -mvfile(fold, fnew) /* move a file */ -char *fold, *fnew; +static int +mvfile( /* move a file */ + char *fold, + char *fnew +) { if (!silent) printf("\t%s %s %s\n", RENAMECMD, fold, fnew); @@ -1335,24 +1762,27 @@ char *fold, *fnew; #ifdef RHAS_FORK_EXEC -int -next_process() /* fork the next process (max. nprocs) */ +static int +next_process(int reserve) /* fork the next process */ { - int child_pid; + RT_PID child_pid; if (nprocs <= 1) return(0); /* it's us or no one */ if (inchild()) { - fprintf(stderr, "%s: internal error 1 in spawn_process()\n", + fprintf(stderr, "%s: internal error 1 in next_process()\n", progname); quit(1); } + if (reserve > 0 && children_running >= nprocs-reserve) + return(0); /* caller holding back process(es) */ if (children_running >= nprocs) wait_process(0); /* wait for someone to finish */ - fflush(stdout); + fflush(NULL); /* flush output */ child_pid = fork(); /* split process */ if (child_pid == 0) { /* we're the child */ children_running = -1; + nprocs = 1; return(0); } if (child_pid > 0) { /* we're the parent */ @@ -1363,11 +1793,13 @@ next_process() /* fork the next process (max. nprocs return(0); } -wait_process(all) /* wait for process(es) to finish */ -int all; +static void +wait_process( /* wait for process(es) to finish */ + int all +) { - int ourstatus = 0; - int pid, status; + int ourstatus = 0, status; + RT_PID pid; if (all) all = children_running; @@ -1391,11 +1823,12 @@ int all; quit(ourstatus); /* bad status from child */ } #else /* ! RHAS_FORK_EXEC */ -int -next_process() +static int +next_process(int reserve) { return(0); /* cannot start new process */ } +static void wait_process(all) int all; { @@ -1403,41 +1836,26 @@ int all; } int kill(pid, sig) /* win|unix_process.c should also wait and kill */ -int pid, sig; +RT_PID pid; +int sig; { return 0; } #endif /* ! RHAS_FORK_EXEC */ -finish_process() /* exit a child process */ +static void +finish_process(void) /* exit a child process */ { if (!inchild()) return; /* in parent -- noop */ exit(0); } -#ifdef _WIN32 -setenv(vname, value) /* set an environment variable */ -char *vname, *value; -{ - register char *evp; - evp = bmalloc(strlen(vname)+strlen(value)+2); - if (evp == NULL) - syserr(progname); - sprintf(evp, "%s=%s", vname, value); - if (putenv(evp) != 0) { - fprintf(stderr, "%s: out of environment space\n", progname); - quit(1); - } - if (!silent) - printf("set %s\n", evp); -} -#endif - - -badvalue(vc) /* report bad variable value and exit */ -int vc; +static void +badvalue( /* report bad variable value and exit */ + int vc +) { fprintf(stderr, "%s: bad value for variable '%s'\n", progname, vnam(vc)); @@ -1445,8 +1863,10 @@ int vc; } -syserr(s) /* report a system error and exit */ -char *s; +static void +syserr( /* report a system error and exit */ + char *s +) { perror(s); quit(1);
