root/radiance/ray/src/util/pvsum.c
Revision: 2.4
Committed: Fri Apr 18 23:59:03 2025 UTC (6 weeks, 6 days ago) by greg
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.4 static const char RCSid[] = "$Id: pvsum.c,v 2.3 2025/03/28 21:36:31 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * pvsum.c - add together spectral and/or float pictures
6     * based on vector or matrix, similar to dctimestep
7     */
8
9     #include <math.h>
10     #include "rtio.h"
11     #include "resolu.h"
12     #include "platform.h"
13     #include "paths.h"
14 greg 2.2 #include "random.h"
15 greg 2.1 #include "rmatrix.h"
16     #if !defined(_WIN32) && !defined(_WIN64)
17     #include <sys/mman.h>
18     #endif
19
20     int nprocs = 1; /* # of calculation processes (Unix) */
21     int in_type = DTfromHeader; /* input data type */
22     int out_type = DTfromHeader; /* output data type */
23     char *in_spec = NULL; /* input specification */
24     char *out_spec = NULL; /* output file specification */
25
26     int iswapped = 0; /* input data is byte-swapped? */
27     int ncomp = 3; /* # input components */
28     int xres=0, yres=0; /* input image dimensions */
29
30     RMATRIX *cmtx = NULL; /* coefficient matrix */
31
32     /* does the given spec contain integer format? */
33     int
34     hasFormat(const char *s)
35     {
36     restart:
37     if (s) s = strchr(s, '%');
38     if (!s) return(0);
39     if (s[1] == '%') { /* "%%" ? */
40     s += 2;
41     goto restart;
42     }
43     while (*++s) {
44     if (strchr("diouxX", *s))
45     return(1); /* integer format */
46     if (strchr("%fFeEgGaAcsb", *s))
47     break; /* non-integer format */
48     }
49     return(0);
50     }
51
52     /* get first input header data we'll need */
53     int
54     iheadline(char *s, void *p)
55     {
56     char fmt[MAXFMTLEN];
57     int i;
58
59     if (!strncmp(s, "NCOLS=", 6)) {
60     xres = atoi(s+6);
61     return(1);
62     }
63     if (!strncmp(s, "NROWS=", 6)) {
64     yres = atoi(s+6);
65     return(1);
66     }
67     if (isncomp(s)) {
68     ncomp = ncompval(s);
69     return(1);
70     }
71     if (formatval(fmt, s)) {
72     for (in_type = DTend; --in_type > DTfromHeader; )
73     if (!strcmp(fmt, cm_fmt_id[in_type]))
74     return(1);
75     return(-1);
76     }
77     i = isbigendian(s);
78     if (i >= 0) {
79     iswapped = (i != nativebigendian());
80     return(1);
81     }
82     return(0);
83     }
84
85     /* open initial file and get relevant dimensions and type */
86     int
87     get_iotypes(void)
88     {
89     char fbuf[256];
90     FILE *fp;
91
92     sprintf(fbuf, in_spec, 0);
93     fp = fopen(fbuf, "rb");
94     if (!fp) {
95     fprintf(stderr, "%s: cannot open for reading\n", fbuf);
96     return(0);
97     }
98     if (getheader(fp, iheadline, NULL) < 0) {
99     fprintf(stderr, "%s: bad header - wrong format?\n", fbuf);
100     fclose(fp);
101     return(0);
102     }
103     if ((xres <= 0) | (yres <= 0) && !fscnresolu(&xres, &yres, fp)) {
104     fprintf(stderr, "%s: missing input resolution\n", fbuf);
105     fclose(fp);
106     return(0);
107     }
108     if (nprocs > 1 && (in_type==DTrgbe) | (in_type==DTxyze)) {
109     long data_start = ftell(fp); /* make sure input flat */
110     off_t dend = lseek(fileno(fp), 0, SEEK_END);
111     if (dend < data_start + 4L*xres*yres) {
112     fputs("Warning - multi-processing requires flat input files\n",
113     stderr);
114     nprocs = 1;
115     }
116     }
117     fclose(fp);
118     if ((cmtx->ncomp == 1) & (ncomp != 1)) {
119     double xfm[MAXCSAMP];
120     RMATRIX *nmtx;
121     int i;
122     for (i = ncomp; i--; )
123     xfm[i] = 1.;
124     nmtx = rmx_transform(cmtx, ncomp, xfm);
125     if (!nmtx)
126     return(0);
127     rmx_free(cmtx);
128     cmtx = nmtx;
129     } else if (cmtx->ncomp != ncomp) {
130     fprintf(stderr, "operation %s needs %d components, has %d\n",
131     cmtx->ncols == 1 ? "vector" : "matrix",
132     ncomp, cmtx->ncomp);
133     return(0);
134     }
135     if ((in_type != DTrgbe) & (in_type != DTxyze) & (in_type != DTspec) &
136     (in_type != DTfloat)) {
137     fprintf(stderr, "%s unsupported input data type: %s\n",
138     fbuf, cm_fmt_id[in_type]);
139     return(0);
140     }
141     if ((out_type == DTrgbe) & (ncomp > 3))
142     out_type = DTspec;
143     else if (out_type == DTfromHeader ||
144     (out_type == DTrgbe) & (in_type != DTfloat))
145     out_type = in_type;
146     return(1);
147     }
148
149     /* check subsequent headers match initial file */
150     int
151     checkline(char *s, void *p)
152     {
153 greg 2.3 static int exposWarned = 0;
154     int *xyres = (int *)p;
155     char fmt[MAXFMTLEN];
156 greg 2.1
157     if (!strncmp(s, "NCOLS=", 6)) {
158     xyres[0] = atoi(s+6);
159     if (xyres[0] <= 0)
160     return(-1);
161     return(1);
162     }
163     if (!strncmp(s, "NROWS=", 6)) {
164     xyres[1] = atoi(s+6);
165     if (xyres[1] <= 0)
166     return(-1);
167     return(1);
168     }
169     if (isncomp(s)) {
170     if (ncompval(s) != ncomp)
171     return(-1);
172     return(1);
173     }
174     if (isexpos(s)) {
175 greg 2.3 if (!exposWarned && fabs(1. - exposval(s)) > 0.04) {
176     fputs("Warning - ignoring EXPOSURE setting(s)\n",
177     stderr);
178     exposWarned++;
179     }
180 greg 2.1 return(1);
181     }
182     if (formatval(fmt, s)) {
183     if (strcmp(fmt, cm_fmt_id[in_type]))
184     return(-1);
185     return(1);
186     }
187     return(0);
188     }
189
190     /* open and check input file */
191     FILE *
192     open_input(char *fname)
193     {
194     int xyres[2];
195     FILE *fp = fopen(fname, "rb");
196
197     if (!fp) {
198     fprintf(stderr, "%s: cannot open for reading\n", fname);
199     return(NULL);
200     }
201     xyres[0] = xyres[1] = 0;
202     if (getheader(fp, checkline, xyres) < 0) {
203     fprintf(stderr, "%s: bad/inconsistent header\n", fname);
204     fclose(fp);
205     return(NULL);
206     }
207     if ((xyres[0] <= 0) | (xyres[1] <= 0) &&
208     !fscnresolu(&xyres[0], &xyres[1], fp)) {
209     fprintf(stderr, "%s: missing resolution\n", fname);
210     fclose(fp);
211     return(NULL);
212     }
213     if ((xyres[0] != xres) | (xyres[1] != yres)) {
214     fprintf(stderr, "%s: mismatched resolution\n", fname);
215     fclose(fp);
216     return(NULL);
217     }
218     return(fp);
219     }
220
221     /* open output file or command (if !NULL) and write info header */
222     FILE *
223     open_output(char *ospec, int fno)
224     {
225     FILE *fp;
226
227     if (!ospec) {
228     ospec = "<stdout>";
229     fp = stdout;
230     } else if (ospec[0] == '!') {
231     if (!(fp = popen(ospec+1, "w"))) {
232     fprintf(stderr, "Cannot start: %s\n", ospec);
233     return(NULL);
234     }
235 greg 2.3 } else if (!(fp = fopen(ospec, "w"))) {
236 greg 2.1 fprintf(stderr, "%s: cannot open for writing\n", ospec);
237     return(NULL);
238     }
239 greg 2.3 SET_FILE_BINARY(fp);
240 greg 2.1 newheader("RADIANCE", fp);
241 greg 2.2 if (cmtx->info) /* prepend matrix metadata */
242     fputs(cmtx->info, fp);
243     else
244     fputnow(fp);
245 greg 2.1 if (fno >= 0)
246     fprintf(fp, "FRAME=%d\n", fno);
247     switch (out_type) {
248     case DTfloat:
249     case DTdouble:
250     fprintf(fp, "NCOLS=%d\nNROWS=%d\n", xres, yres);
251     fputncomp(ncomp, fp);
252     fputendian(fp);
253     fputformat(cm_fmt_id[out_type], fp);
254     fputc('\n', fp);
255     break;
256     case DTrgbe:
257     fputformat(COLRFMT, fp);
258     fputc('\n', fp);
259     fprtresolu(xres, yres, fp);
260     break;
261     case DTxyze:
262     fputformat(CIEFMT, fp);
263     fputc('\n', fp);
264     fprtresolu(xres, yres, fp);
265     break;
266     case DTspec:
267     fputncomp(ncomp, fp);
268     fputwlsplit(cmtx->wlpart, fp);
269     fputformat(SPECFMT, fp);
270     fputc('\n', fp);
271     fprtresolu(xres, yres, fp);
272     break;
273     default:
274     fputs("Unsupported output type!\n", stderr);
275     return(NULL);
276     }
277     if (fflush(fp) < 0) {
278     fprintf(stderr, "%s: write error\n", ospec);
279     fclose(fp);
280     return(NULL);
281     }
282     return(fp);
283     }
284
285     /* run calculation from a single process */
286     int
287     solo_process(void)
288     {
289     float *osum = (float *)calloc((size_t)xres*yres, sizeof(float)*ncomp);
290     COLORV *iscan = (COLORV *)malloc(sizeof(COLORV)*ncomp*xres);
291     char fbuf[512];
292     int c;
293
294     if (!osum | !iscan) {
295     fprintf(stderr, "Cannot allocate %dx%d %d-component accumulator\n",
296     xres, yres, ncomp);
297     return(0);
298     }
299     if (sizeof(float) != sizeof(COLORV)) {
300     fputs("Code Error 1 in solo_process()\n", stderr);
301     return(0);
302     }
303     for (c = 0; c < cmtx->ncols; c++) { /* run through each column/output */
304     FILE *fout;
305     int y;
306     int rc = cmtx->nrows;
307     if (c > 0) /* clear accumulator? */
308     memset(osum, 0, sizeof(float)*ncomp*xres*yres);
309     while (rc-- > 0) { /* run through each input file */
310     const int r = c&1 ? rc : cmtx->nrows-1 - rc;
311     const rmx_dtype *cval = rmx_val(cmtx, r, c);
312     FILE *finp;
313     int i, x;
314     for (i = ncomp; i--; )
315     if (cval[i] != 0) break;
316     if (i < 0) /* this coefficient is zero, skip */
317     continue;
318     sprintf(fbuf, in_spec, r);
319     finp = open_input(fbuf);
320     if (!finp)
321     return(0);
322     for (y = 0; y < yres; y++) {
323     float *dst = osum + y*xres*ncomp;
324     if (in_type == DTfloat ? getbinary(iscan, sizeof(float)*ncomp,
325     xres, finp) != xres
326     : freadsscan(iscan, ncomp, xres, finp) < 0)
327     goto readerr;
328     if ((in_type == DTfloat) & iswapped)
329     swap32((char *)iscan, ncomp*xres);
330     for (x = 0; x < xres; x++, dst += ncomp)
331     for (i = ncomp; i--; )
332     dst[i] += cval[i]*iscan[x*ncomp + i];
333     }
334     fclose(finp);
335     } /* write out accumulated column result... */
336     if (out_spec) { /* ...to file or command */
337     if (cmtx->ncols > 1 && !hasFormat(out_spec)) {
338     fputs("Sequential result must go to stdout\n", stderr);
339     return(0);
340     }
341     sprintf(fbuf, out_spec, c);
342     fout = open_output(fbuf, c-(cmtx->ncols==1));
343     } else { /* ...to stdout */
344     if ((out_type == DTfloat) & (cmtx->ncols > 1)) {
345     fputs("Float outputs must have separate destinations\n",
346     stderr);
347     return(0);
348     }
349     strcpy(fbuf, "<stdout>");
350     fout = open_output(NULL, c-(cmtx->ncols==1));
351     }
352     if (!fout)
353     return(0); /* assume error was reported */
354     if (out_type != DTfloat) {
355     for (y = 0; y < yres; y++)
356     if (fwritesscan(osum + (size_t)y*xres*ncomp,
357     ncomp, xres, fout) < 0)
358     goto writerr;
359     } else if (fwrite(osum, sizeof(float)*ncomp, (size_t)xres*yres, fout) !=
360     (size_t)xres*yres)
361     goto writerr;
362
363     if (fbuf[0] == '!') {
364     if (pclose(fout) != 0) {
365     fprintf(stderr, "Bad status from: %s\n", fbuf);
366     return(0);
367     }
368     } else if (fout != stdout && fclose(fout) == EOF)
369     goto writerr;
370     }
371     free(osum); /* clean up on success */
372     free(iscan);
373     return(1);
374     readerr:
375     fprintf(stderr, "%s: read error\n", fbuf);
376     return(0);
377     writerr:
378     fprintf(stderr, "%s: write error\n", fbuf);
379     return(0);
380     }
381
382 greg 2.2 /* allocate a scrambled index array of the specified length */
383     int *
384     scramble(int n)
385     {
386     int *scarr = (int *)malloc(sizeof(int)*n);
387     int i;
388
389     if (!scarr) {
390     fprintf(stderr, "Out of memory in scramble(%d)\n", n);
391     exit(1);
392     }
393     for (i = n; i--; )
394     scarr[i] = i;
395     /* perform Fisher-Yates shuffle */
396     for (i = 0; i < n-1; i++) {
397     int ix = irandom(n-i) + i;
398     int ndx = scarr[i];
399     scarr[i] = scarr[ix];
400     scarr[ix] = ndx;
401     }
402     return(scarr);
403     }
404
405 greg 2.1 /* run calculation on multiple processes, using memory maps and fork() */
406     int
407     multi_process(void)
408     {
409     #if defined(_WIN32) || defined(_WIN64)
410     fputs("Bad call to multi_process()\n", stderr);
411     return(0);
412     #else
413     int coff = nprocs;
414     int odd = 0;
415     char fbuf[512];
416     float *osum;
417 greg 2.2 int *syarr;
418 greg 2.1 int c;
419     /* sanity check */
420     if (sizeof(float) != sizeof(COLORV)) {
421     fputs("Code Error 1 in multi_process()\n", stderr);
422     return(0);
423     }
424     while (--coff > 0) { /* parent births children */
425     int pid = fork();
426     if (pid < 0) {
427     fputs("fork() call failed!\n", stderr);
428     return(0);
429     }
430     if (pid == 0) break; /* child gets to work */
431     }
432     osum = (float *)calloc((size_t)xres*yres, sizeof(float)*ncomp);
433     if (!osum) {
434     fprintf(stderr, "Cannot allocate %dx%d %d-component accumulator\n",
435     xres, yres, ncomp);
436     return(0);
437     }
438 greg 2.2 srandom(113*coff + 5669); /* randomize row access for this process */
439     syarr = scramble(yres);
440 greg 2.1 /* run through our unique set of columns */
441     for (c = coff; c < cmtx->ncols; c += nprocs) {
442     FILE *fout;
443     int y;
444     int rc = cmtx->nrows;
445     if (c > coff) /* clear accumulator? */
446     memset(osum, 0, sizeof(float)*ncomp*xres*yres);
447     while (rc-- > 0) { /* map & sum each input file */
448     const int r = odd ? rc : cmtx->nrows-1 - rc;
449     const rmx_dtype *cval = rmx_val(cmtx, r, c);
450 greg 2.2 long dstart;
451 greg 2.1 size_t maplen;
452     void *imap;
453     FILE *finp;
454     float *dst;
455 greg 2.2 int i, x;
456 greg 2.1 for (i = ncomp; i--; )
457     if (cval[i] != 0) break;
458     if (i < 0) /* this coefficient is zero, skip */
459     continue;
460     sprintf(fbuf, in_spec, r);
461     finp = open_input(fbuf);
462     if (!finp)
463     return(0);
464     dstart = ftell(finp);
465     if (dstart < 0) {
466     fprintf(stderr, "%s: ftell() failed!\n", fbuf);
467     return(0);
468     }
469     if (in_type == DTfloat && dstart%sizeof(float)) {
470     fprintf(stderr, "%s: float header misalignment\n", fbuf);
471     return(0);
472     }
473     i = in_type==DTfloat ? ncomp*(int)sizeof(float) : ncomp+1;
474     maplen = dstart + yres*xres*i;
475     imap = mmap(NULL, maplen, PROT_READ,
476     MAP_FILE|MAP_SHARED, fileno(finp), 0);
477 greg 2.3 fclose(finp); /* will read from map (randomly) */
478 greg 2.1 if (imap == MAP_FAILED) {
479     fprintf(stderr, "%s: unable to map input file\n", fbuf);
480     return(0);
481     }
482 greg 2.2 if (in_type == DTfloat)
483     for (y = yres; y-- > 0; ) {
484     const float *fvp = (float *)((char *)imap + dstart) +
485     (size_t)ncomp*xres*syarr[y];
486     dst = osum + (size_t)ncomp*xres*syarr[y];
487     for (x = xres; x-- > 0; dst += ncomp, fvp += ncomp)
488     for (i = ncomp; i--; )
489     dst[i] += cval[i]*fvp[i];
490     }
491     else
492     for (y = yres; y-- > 0; ) {
493     const COLRV *cvp = (COLRV *)((char *)imap + dstart) +
494     (ncomp+1L)*xres*syarr[y];
495     dst = osum + (size_t)ncomp*xres*syarr[y];
496     for (x = xres; x-- > 0; dst += ncomp, cvp += ncomp+1) {
497     const rmx_dtype fe = cxponent[cvp[ncomp]];
498     for (i = ncomp; i--; )
499     dst[i] += cval[i]*(cvp[i]+(rmx_dtype).5)*fe;
500     }
501 greg 2.1 }
502     munmap(imap, maplen);
503 greg 2.3 } /* write accumulated column picture/matrix */
504 greg 2.1 sprintf(fbuf, out_spec, c);
505     fout = open_output(fbuf, c);
506     if (!fout)
507     return(0); /* assume error was reported */
508     if (out_type != DTfloat) {
509     for (y = 0; y < yres; y++)
510     if (fwritesscan(osum + (size_t)y*xres*ncomp,
511     ncomp, xres, fout) < 0)
512     goto writerr;
513     } else if (fwrite(osum, sizeof(float)*ncomp, (size_t)xres*yres, fout) !=
514     (size_t)xres*yres)
515     goto writerr;
516
517     if (fbuf[0] == '!') {
518     if (pclose(fout) != 0) {
519     fprintf(stderr, "Bad status from: %s\n", fbuf);
520     return(0);
521     }
522     } else if (fclose(fout) == EOF)
523     goto writerr;
524     odd = !odd; /* go back & forth to milk page cache */
525     }
526     free(osum);
527 greg 2.2 free(syarr);
528 greg 2.3 if (coff) /* child processes return here... */
529 greg 2.1 return(1);
530     c = 0; /* ...but parent waits for children */
531     while (++coff < nprocs) {
532     int st;
533     if (wait(&st) < 0)
534     break;
535     if (st) c = st;
536     }
537     return(c == 0);
538     writerr:
539     fprintf(stderr, "%s: write error\n", fbuf);
540     return(0);
541     #endif
542     }
543
544     int
545     main(int argc, char *argv[])
546     {
547     int a;
548
549     for (a = 1; a < argc-1 && argv[a][0] == '-'; a++)
550     switch (argv[a][1]) {
551     case 'o': /* output spec/format */
552     switch (argv[a][2]) {
553     case '\0':
554     out_spec = argv[++a];
555     break;
556     case 'f':
557     out_type = DTfloat;
558     break;
559     case 'c':
560     out_type = DTrgbe;
561     break;
562     default:
563     goto badopt;
564     }
565     break;
566     case 'N': /* number of desired processes */
567     case 'n': /* quietly supported alternate */
568     nprocs = atoi(argv[++a]);
569     if (nprocs <= 0)
570     goto userr;
571     break;
572     default:;
573     badopt: fprintf(stderr, "%s: bad option: %s\n", argv[0], argv[a]);
574     goto userr;
575     return(1);
576     }
577     if ((argc-a < 1) | (argc-a > 2) || argv[a][0] == '-')
578     goto userr;
579     in_spec = argv[a];
580 greg 2.4 cmtx = rmx_load(argv[a+1]); /* loads from stdin if a+1==argc */
581 greg 2.1 if (cmtx == NULL)
582     return(1); /* error reported */
583 greg 2.3 if (nprocs > cmtx->ncols)
584     nprocs = cmtx->ncols;
585 greg 2.1 #if defined(_WIN32) || defined(_WIN64)
586     if (nprocs > 1) {
587     fprintf(stderr, "%s: warning - Windows only allows -N 1\n", argv[0]);
588     nprocs = 1;
589     }
590     #else
591     if ((nprocs > 1) & !out_spec) {
592     fprintf(stderr, "%s: multi-processing result cannot go to stdout\n",
593     argv[0]);
594     nprocs = 1;
595     }
596     if ((nprocs > 1) & iswapped && (in_type==DTfloat) | (in_type==DTdouble)) {
597     fprintf(stderr, "%s: multi-processing unsupported on swapped input\n",
598     argv[0]);
599     nprocs = 1;
600     }
601     #endif
602     if (cmtx->nrows > 1 && !hasFormat(in_spec)) {
603     fprintf(stderr, "%s: input specification '%s' needs %%d format\n",
604     argv[0], in_spec);
605     goto userr;
606     }
607     if (!get_iotypes())
608     return(1);
609     if (!(nprocs == 1 ? solo_process() : multi_process()))
610     return(1);
611     return(0);
612     userr:
613     fprintf(stderr, "Usage: %s [-oc | -of][-o ospec][-N nproc] inpspec [mtx]\n",
614     argv[0]);
615     return(1);
616     }
