#ifndef lint static const char RCSid[] = "$Id: pvsum.c,v 2.12 2025/10/30 16:47:13 greg Exp $"; #endif /* * pvsum.c - add together spectral and/or float pictures * based on vector or matrix, similar to dctimestep */ #include #include "rtio.h" #include "resolu.h" #include "platform.h" #include "random.h" #include "rmatrix.h" #if !defined(_WIN32) && !defined(_WIN64) #include #include #endif #define VIEWSTR "VIEW=" /* borrowed from common/view.h */ #define VIEWSTRL 5 int nprocs = 1; /* # of calculation processes (Unix) */ int in_type = DTfromHeader; /* input data type */ int out_type = DTfromHeader; /* output data type */ char *in_spec = NULL; /* input specification */ char *out_spec = NULL; /* output file specification */ int iswapped = 0; /* input data is byte-swapped? */ int ncomp = 3; /* # input components */ int xres=0, yres=0; /* input image dimensions */ char viewspec[128] = ""; /* VIEW= line from first header */ char pixasp[48] = ""; /* PIXASPECT= line from header */ int gargc; /* global argc */ char **gargv; /* global argv */ RMATRIX *cmtx; /* coefficient matrix */ int row0, rowN; /* rows for current pass */ /* does the given spec contain integer format? */ int hasFormat(const char *s) { restart: if (s) s = strchr(s, '%'); if (!s) return(0); if (s[1] == '%') { /* "%%" ? */ s += 2; goto restart; } while (*++s) { if (strchr("diouxX", *s)) return(1); /* integer format */ if (strchr("%fFeEgGaAcsb", *s)) break; /* non-integer format */ } return(0); } /* get first input header data we'll need */ int iheadline(char *s, void *p) { char fmt[MAXFMTLEN]; int i; if (!strncmp(s, "NCOLS=", 6)) { xres = atoi(s+6); return(1); } if (!strncmp(s, "NROWS=", 6)) { yres = atoi(s+6); return(1); } if (isncomp(s)) { ncomp = ncompval(s); return(1); } if (formatval(fmt, s)) { for (in_type = DTend; --in_type > DTfromHeader; ) if (!strcmp(fmt, cm_fmt_id[in_type])) return(1); return(-1); } i = isbigendian(s); if (i >= 0) { iswapped = (i != nativebigendian()); return(1); } if (!strncmp(s, VIEWSTR, VIEWSTRL)) { strcpy(viewspec, s); return(1); } if (isaspect(s)) { strcpy(pixasp, s); return(1); } return(0); } /* open initial file and get relevant dimensions and type */ int get_iotypes(void) { char fbuf[256]; FILE *fp; sprintf(fbuf, in_spec, 0); fp = fopen(fbuf, "rb"); if (!fp) { fprintf(stderr, "%s: cannot open for reading\n", fbuf); return(0); } if (getheader(fp, iheadline, NULL) < 0) { fprintf(stderr, "%s: bad header - wrong format?\n", fbuf); fclose(fp); return(0); } if ((xres <= 0) | (yres <= 0) && !fscnresolu(&xres, &yres, fp)) { fprintf(stderr, "%s: missing input resolution\n", fbuf); fclose(fp); return(0); } if (nprocs > 1 && (in_type==DTrgbe) | (in_type==DTxyze)) { long data_start = ftell(fp); /* make sure input flat */ off_t dend = lseek(fileno(fp), 0, SEEK_END); if (dend < data_start + 4L*xres*yres) { fprintf(stderr, "%s: warning - multi-processing requires flat input files\n", gargv[0]); nprocs = 1; } } fclose(fp); if ((cmtx->ncomp == 1) & (ncomp != 1)) { double xfm[MAXCSAMP]; RMATRIX *nmtx; int i; for (i = ncomp; i--; ) xfm[i] = 1.; nmtx = rmx_transform(cmtx, ncomp, xfm); if (!nmtx) return(0); rmx_free(cmtx); cmtx = nmtx; } else if (cmtx->ncomp != ncomp) { fprintf(stderr, "%s: operation %s needs %d components, has %d\n", gargv[0], cmtx->ncols == 1 ? "vector" : "matrix", ncomp, cmtx->ncomp); return(0); } if ((in_type != DTrgbe) & (in_type != DTxyze) & (in_type != DTspec) & (in_type != DTfloat)) { fprintf(stderr, "%s: unsupported input data type '%s'\n", fbuf, cm_fmt_id[in_type]); return(0); } if ((out_type == DTrgbe) & (ncomp > 3)) out_type = DTspec; else if (out_type == DTfromHeader || (out_type == DTrgbe) & (in_type != DTfloat)) out_type = in_type; return(1); } struct hdata { int xr, yr; /* resolution */ int fno; /* frame # */ char fmt[MAXFMTLEN]; /* format */ }; /* check subsequent headers match initial file */ int checkline(char *s, void *p) { static int exposWarned = 0; struct hdata *hp = (struct hdata *)p; if (!strncmp(s, "NCOLS=", 6)) { hp->xr = atoi(s+6); if (hp->xr <= 0) return(-1); return(1); } if (!strncmp(s, "NROWS=", 6)) { hp->yr = atoi(s+6); if (hp->yr <= 0) return(-1); return(1); } if (!strncmp(s, "FRAME=", 6)) { hp->fno = atoi(s+6); return(1); } if (isncomp(s)) { if (ncompval(s) != ncomp) return(-1); return(1); } if (isexpos(s)) { if (!exposWarned && fabs(1. - exposval(s)) > 0.04) { fprintf(stderr, "%s: warning - ignoring EXPOSURE setting(s)\n", gargv[0]); exposWarned++; } return(1); } if (formatval(hp->fmt, s)) return(1); return(0); } /* open and check input/output file, read/write mode if fno >= 0 */ FILE * open_iofile(char *fname, int fno) { struct hdata hd; FILE *fp = fopen(fname, fno>=0 ? "r+b" : "rb"); if (!fp) { fprintf(stderr, "%s: cannot open for reading%s\n", fname, fno>=0 ? "/writing" : ""); return(NULL); } hd.xr = hd.yr = 0; hd.fno = -1; hd.fmt[0] = '\0'; if (getheader(fp, checkline, &hd) < 0) { fprintf(stderr, "%s: bad/inconsistent header\n", fname); fclose(fp); return(NULL); } if ((hd.fno >= 0) & (fno >= 0) & (hd.fno != fno)) { fprintf(stderr, "%s: unexpected frame number (%d != %d)\n", fname, hd.fno, fno); fclose(fp); return(NULL); } if (strcmp(hd.fmt, cm_fmt_id[fno>=0 ? out_type : in_type])) { fprintf(stderr, "%s: wrong format\n", fname); fclose(fp); return(NULL); } if ((hd.xr <= 0) | (hd.yr <= 0) && !fscnresolu(&hd.xr, &hd.yr, fp)) { fprintf(stderr, "%s: missing resolution\n", fname); fclose(fp); return(NULL); } if ((hd.xr != xres) | (hd.yr != yres)) { fprintf(stderr, "%s: mismatched resolution\n", fname); fclose(fp); return(NULL); } return(fp); } /* read in previous pixel data from output and rewind to data start */ int reload_data(float *osum, FILE *fp) { long dstart; if (!osum | !fp) return(0); if ((dstart = ftell(fp)) < 0) { fprintf(stderr, "%s: ftell() error in reload_data()\n", gargv[0]); return(0); } if (out_type == DTfloat) { if (fread(osum, sizeof(float)*ncomp, (size_t)xres*yres, fp) != (size_t)xres*yres) { fprintf(stderr, "%s: fread() error\n", gargv[0]); return(0); } } else { int y; for (y = 0; y < yres; y++, osum += ncomp*xres) if (freadsscan(osum, ncomp, xres, fp) < 0) { fprintf(stderr, "%s: freadsscan() error\n", gargv[0]); return(0); } } if (fseek(fp, dstart, SEEK_SET) < 0) { fprintf(stderr, "%s: fseek() error in reload_data()\n", gargv[0]); return(0); } return(1); } /* open output file or command (if !NULL) and write info header */ FILE * open_output(char *ospec, int fno) { FILE *fp; if (!ospec) { ospec = ""; fp = stdout; } else if (ospec[0] == '!') { if (!(fp = popen(ospec+1, "w"))) { fprintf(stderr, "%s: cannot start: %s\n", gargv[0], ospec); return(NULL); } } else if (!(fp = fopen(ospec, "w"))) { fprintf(stderr, "%s: cannot open for writing\n", ospec); return(NULL); } SET_FILE_BINARY(fp); newheader("RADIANCE", fp); if (cmtx->info) /* prepend matrix metadata */ fputs(cmtx->info, fp); else fputnow(fp); printargs(gargc, gargv, fp); /* this command */ if (fno >= 0) fprintf(fp, "FRAME=%d\n", fno); if (viewspec[0]) fputs(viewspec, fp); if (pixasp[0]) fputs(pixasp, fp); switch (out_type) { case DTfloat: case DTdouble: fprintf(fp, "NCOLS=%d\nNROWS=%d\n", xres, yres); fputncomp(ncomp, fp); fputendian(fp); fputformat(cm_fmt_id[out_type], fp); fputc('\n', fp); break; case DTrgbe: fputformat(COLRFMT, fp); fputc('\n', fp); fprtresolu(xres, yres, fp); break; case DTxyze: fputformat(CIEFMT, fp); fputc('\n', fp); fprtresolu(xres, yres, fp); break; case DTspec: fputncomp(ncomp, fp); fputwlsplit(cmtx->wlpart, fp); fputformat(SPECFMT, fp); fputc('\n', fp); fprtresolu(xres, yres, fp); break; default: fprintf(stderr, "%s: unsupported output type!\n", gargv[0]); return(NULL); } if (fflush(fp) < 0) { fprintf(stderr, "%s: write error\n", ospec); fclose(fp); return(NULL); } return(fp); } /* run calculation from a single process */ int solo_process(void) { float *osum = (float *)calloc((size_t)xres*yres, sizeof(float)*ncomp); COLORV *iscan = (COLORV *)malloc(sizeof(COLORV)*ncomp*xres); char fbuf[512]; int c; if (!osum | !iscan) { fprintf(stderr, "%s: annot allocate %dx%d %d-component accumulator\n", gargv[0], xres, yres, ncomp); return(0); } if (sizeof(float) != sizeof(COLORV)) { fprintf(stderr, "%s: Code Error 1 in solo_process()\n", gargv[0]); return(0); } /* run through each column/output */ for (c = 0; c < cmtx->ncols; c++) { int rc = rowN - row0; FILE *fout; int y; /* open output (load if multipass) */ if (out_spec) { /* file or command */ if (cmtx->ncols > 1 && !hasFormat(out_spec)) { fprintf(stderr, "%s: sequential result must go to stdout\n", gargv[0]); return(0); } sprintf(fbuf, out_spec, c); if (row0) { /* another pass -- get prev. data */ fout = open_iofile(fbuf, c); if (!reload_data(osum, fout)) return(0); } else /* else new output (clobbers prev. file) */ fout = open_output(fbuf, c-(cmtx->ncols==1)); } else { /* else stdout */ if ((out_type == DTfloat) & (cmtx->ncols > 1)) { fprintf(stderr, "%s: float outputs must have separate destinations\n", gargv[0]); return(0); } strcpy(fbuf, ""); fout = open_output(NULL, c-(cmtx->ncols==1)); } if (!fout) return(0); /* assume error was reported */ if (!row0 & (c > 0)) /* clear accumulator? */ memset(osum, 0, sizeof(float)*ncomp*xres*yres); while (rc-- > 0) { /* run through each input file */ const int r = c&1 ? row0 + rc : rowN-1 - rc; const rmx_dtype *cval = rmx_val(cmtx, r, c); FILE *finp; int i, x; for (i = ncomp; i--; ) if (cval[i] != 0) break; if (i < 0) /* this coefficient is zero, skip */ continue; sprintf(fbuf, in_spec, r); finp = open_iofile(fbuf, -1); if (!finp) return(0); for (y = 0; y < yres; y++) { float *dst = osum + y*xres*ncomp; if (in_type == DTfloat ? getbinary(iscan, sizeof(float)*ncomp, xres, finp) != xres : freadsscan(iscan, ncomp, xres, finp) < 0) goto readerr; if ((in_type == DTfloat) & iswapped) swap32((char *)iscan, ncomp*xres); for (x = 0; x < xres; x++, dst += ncomp) for (i = ncomp; i--; ) dst[i] += cval[i]*iscan[x*ncomp + i]; } fclose(finp); } /* write accumulated picture */ if (out_type != DTfloat) { for (y = 0; y < yres; y++) if (fwritesscan(osum + (size_t)y*xres*ncomp, ncomp, xres, fout) < 0) goto writerr; } else if (fwrite(osum, sizeof(float)*ncomp, (size_t)xres*yres, fout) != (size_t)xres*yres) goto writerr; if (fbuf[0] == '!') { if (pclose(fout) != 0) { fprintf(stderr, "%s: bad status from: %s\n", gargv[0], fbuf); return(0); } } else if (fout != stdout && fclose(fout) == EOF) goto writerr; } free(osum); /* clean up on success */ free(iscan); return(1); readerr: fprintf(stderr, "%s: read error\n", fbuf); return(0); writerr: fprintf(stderr, "%s: write error\n", fbuf); return(0); } #if defined(_WIN32) || defined(_WIN64) #define multi_process solo_process #else /* allocate a scrambled index array of the specified length */ int * scramble(int n) { int *scarr = (int *)malloc(sizeof(int)*n); int i; if (!scarr) { fprintf(stderr, "%s: out of memory in scramble(%d)\n", gargv[0], n); exit(1); } for (i = n; i--; ) scarr[i] = i; /* perform Fisher-Yates shuffle */ for (i = 0; i < n-1; i++) { int ix = irandom(n-i) + i; int ndx = scarr[i]; scarr[i] = scarr[ix]; scarr[ix] = ndx; } return(scarr); } /* run calculation on multiple processes, using memory maps and fork() */ int multi_process(void) { int coff = nprocs; int odd = 0; float *osum = NULL; int *syarr = NULL; char fbuf[512]; int c; /* sanity check */ if (sizeof(float) != sizeof(COLORV)) { fprintf(stderr, "%s: code Error 1 in multi_process()\n", gargv[0]); return(0); } fflush(NULL); /* parent births helper subprocs */ while (--coff > 0) { int pid = fork(); if (pid < 0) { fprintf(stderr, "%s: fork() call failed!\n", gargv[0]); return(0); } if (!pid) break; /* new child gets to work */ } osum = (float *)calloc((size_t)xres*yres, sizeof(float)*ncomp); if (!osum) { fprintf(stderr, "%s: cannot allocate %dx%d %d-component accumulator\n", gargv[0], xres, yres, ncomp); return(0); } srandom(113*coff + 5669); /* randomize row access for this process */ syarr = scramble(yres); /* run through our unique set of columns */ for (c = coff; c < cmtx->ncols; c += nprocs) { int rc = rowN - row0; FILE *fout; int y; /* create/load output */ sprintf(fbuf, out_spec, c); if (row0) { /* making another pass? */ fout = open_iofile(fbuf, c); if (!reload_data(osum, fout)) return(0); } else { /* else new output (clobbers prev. file) */ fout = open_output(fbuf, c); if (!fout) return(0); if (c > coff) /* clear accumulator? */ memset(osum, 0, sizeof(float)*ncomp*xres*yres); } while (rc-- > 0) { /* map & sum each input file */ const int r = odd ? row0 + rc : rowN-1 - rc; const rmx_dtype *cval = rmx_val(cmtx, r, c); long dstart; size_t imaplen; void *imap; FILE *finp; float *dst; int i, x; for (i = ncomp; i--; ) if (cval[i] != 0) break; if (i < 0) /* this coefficient is zero, skip */ continue; sprintf(fbuf, in_spec, r); finp = open_iofile(fbuf, -1); if (!finp) return(0); dstart = ftell(finp); if (dstart < 0) { fprintf(stderr, "%s: ftell() failed!\n", fbuf); return(0); } if (in_type == DTfloat && dstart%sizeof(float)) { fprintf(stderr, "%s: float header misalignment\n", fbuf); return(0); } i = in_type==DTfloat ? ncomp*(int)sizeof(float) : ncomp+1; imaplen = dstart + (size_t)yres*xres*i; imap = mmap(NULL, imaplen, PROT_READ, MAP_FILE|MAP_SHARED, fileno(finp), 0); fclose(finp); /* will read from map (randomly) */ if (imap == MAP_FAILED) { fprintf(stderr, "%s: unable to map input file\n", fbuf); return(0); } if (in_type == DTfloat) for (y = yres; y-- > 0; ) { const float *fvp = (float *)((char *)imap + dstart) + (size_t)ncomp*xres*syarr[y]; dst = osum + (size_t)ncomp*xres*syarr[y]; for (x = xres; x-- > 0; dst += ncomp, fvp += ncomp) for (i = ncomp; i--; ) dst[i] += cval[i]*fvp[i]; } else for (y = yres; y-- > 0; ) { const COLRV *cvp = (COLRV *)((char *)imap + dstart) + (ncomp+1L)*xres*syarr[y]; dst = osum + (size_t)ncomp*xres*syarr[y]; for (x = xres; x-- > 0; dst += ncomp, cvp += ncomp+1) { const rmx_dtype fe = cxponent[cvp[ncomp]]; for (i = ncomp; i--; ) dst[i] += cval[i]*(cvp[i]+(rmx_dtype).5)*fe; } } munmap(imap, imaplen); } /* write accumulated column picture */ if (out_type != DTfloat) { for (y = 0; y < yres; y++) if (fwritesscan(osum + (size_t)y*xres*ncomp, ncomp, xres, fout) < 0) goto writerr; } else if (fwrite(osum, sizeof(float)*ncomp, (size_t)xres*yres, fout) != (size_t)xres*yres) goto writerr; if (fbuf[0] == '!') { if (pclose(fout) != 0) { fprintf(stderr, "%s: bad status from: %s\n", gargv[0], fbuf); return(0); } } else if (fclose(fout) == EOF) goto writerr; odd = !odd; /* go back & forth to milk page cache */ } if (coff) _exit(0); /* child exits here */ /* but parent waits for children */ free(osum); free(syarr); c = 0; while (++coff < nprocs) { int st; if (wait(&st) < 0) { fprintf(stderr, "%s: warning - child disappeared\n", gargv[0]); break; } if (st) { fprintf(stderr, "%s: bad exit status from child\n", gargv[0]); c = st; } } return(c == 0); writerr: fprintf(stderr, "%s: write error\n", fbuf); return(0); } #endif /* ! Windows */ int main(int argc, char *argv[]) { double cacheGB = 0; int rintvl; int a; gargc = argc; /* for header output */ gargv = argv; for (a = 1; a < argc-1 && argv[a][0] == '-'; a++) switch (argv[a][1]) { case 'o': /* output spec/format */ switch (argv[a][2]) { case '\0': out_spec = argv[++a]; break; case 'f': out_type = DTfloat; break; case 'c': out_type = DTrgbe; break; default: goto badopt; } break; case 'm': /* cache size in GigaBytes */ cacheGB = atof(argv[++a]); break; case 'N': /* number of desired processes */ case 'n': /* quietly supported alternate */ nprocs = atoi(argv[++a]); if (nprocs <= 0) goto userr; break; default:; badopt: fprintf(stderr, "%s: bad option: %s\n", argv[0], argv[a]); goto userr; return(1); } if ((argc-a < 1) | (argc-a > 2) || argv[a][0] == '-') goto userr; in_spec = argv[a]; cmtx = rmx_load(argv[a+1]); /* loads from stdin if a+1==argc */ if (cmtx == NULL) return(1); /* error reported */ cacheGB *= (cmtx->ncols > 1); if (cacheGB > 0 && (!out_spec || *out_spec == '!')) { fprintf(stderr, "%s: -m option incompatible with output to %s\n", argv[0], out_spec ? "command" : "stdout"); return(1); } if (nprocs > cmtx->ncols) nprocs = cmtx->ncols; #if defined(_WIN32) || defined(_WIN64) if (nprocs > 1) { fprintf(stderr, "%s: warning - Windows only allows -N 1\n", argv[0]); nprocs = 1; } #else if ((nprocs > 1) & !out_spec) { fprintf(stderr, "%s: multi-processing result cannot go to stdout\n", argv[0]); nprocs = 1; } if ((nprocs > 1) & iswapped && (in_type==DTfloat) | (in_type==DTdouble)) { fprintf(stderr, "%s: multi-processing unsupported on swapped input\n", argv[0]); nprocs = 1; } #endif if (cmtx->nrows > 1 && !hasFormat(in_spec)) { fprintf(stderr, "%s: input specification '%s' needs %%d format\n", argv[0], in_spec); goto userr; } if (!get_iotypes()) return(1); if (cacheGB > 1e-4) { /* figure out # of passes => rintvl */ size_t inp_bytes = (in_type==DTfloat ? sizeof(float)*ncomp : (size_t)(ncomp+1)) * xres*yres; size_t over_bytes = sizeof(float)*ncomp*xres*yres + 2*(out_type==DTfloat ? sizeof(float)*ncomp : (size_t)(ncomp+1)) * xres*yres; int npasses = (double)inp_bytes*cmtx->nrows / (cacheGB*(1L<<30) - (double)over_bytes*nprocs) + 1; if ((npasses <= 0) | (npasses*6 >= cmtx->nrows)) { fprintf(stderr, "%s: warning - insufficient cache space for multi-pass\n", argv[0]); npasses = 1; } rintvl = cmtx->nrows / npasses; rintvl += (rintvl*npasses < cmtx->nrows); } else rintvl = cmtx->nrows; /* make our output accumulation passes */ for (row0 = 0; row0 < cmtx->nrows; row0 += rintvl) { if ((rowN = row0 + rintvl) > cmtx->nrows) rowN = cmtx->nrows; if (nprocs==1 ? !solo_process() : !multi_process()) return(1); } return(0); userr: fprintf(stderr, "Usage: %s [-oc | -of][-o ospec][-N nproc][-m cacheGB] inpspec [mtx]\n", argv[0]); return(1); }
