root/radiance/ray/src/util/pvsum.c
Revision: 2.6
Committed: Sat Jun 28 17:30:50 2025 UTC (5 weeks, 1 day ago) by greg
CVS Tags: rad6R0, HEAD
fix(pvsum): Missed cast to protect from integer overflow
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.6 static const char RCSid[] = "$Id: pvsum.c,v 2.5 2025/06/06 18:26:22 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * pvsum.c - add together spectral and/or float pictures
6     * based on vector or matrix, similar to dctimestep
7     */
8
9     #include <math.h>
10     #include "rtio.h"
11     #include "resolu.h"
12     #include "platform.h"
13     #include "paths.h"
14 greg 2.2 #include "random.h"
15 greg 2.1 #include "rmatrix.h"
16     #if !defined(_WIN32) && !defined(_WIN64)
17     #include <sys/mman.h>
18 greg 2.5 #include <sys/wait.h>
19 greg 2.1 #endif
20
21     int nprocs = 1; /* # of calculation processes (Unix) */
22     int in_type = DTfromHeader; /* input data type */
23     int out_type = DTfromHeader; /* output data type */
24     char *in_spec = NULL; /* input specification */
25     char *out_spec = NULL; /* output file specification */
26
27     int iswapped = 0; /* input data is byte-swapped? */
28     int ncomp = 3; /* # input components */
29     int xres=0, yres=0; /* input image dimensions */
30
31     RMATRIX *cmtx = NULL; /* coefficient matrix */
32
33     /* does the given spec contain integer format? */
34     int
35     hasFormat(const char *s)
36     {
37     restart:
38     if (s) s = strchr(s, '%');
39     if (!s) return(0);
40     if (s[1] == '%') { /* "%%" ? */
41     s += 2;
42     goto restart;
43     }
44     while (*++s) {
45     if (strchr("diouxX", *s))
46     return(1); /* integer format */
47     if (strchr("%fFeEgGaAcsb", *s))
48     break; /* non-integer format */
49     }
50     return(0);
51     }
52
53     /* get first input header data we'll need */
54     int
55     iheadline(char *s, void *p)
56     {
57     char fmt[MAXFMTLEN];
58     int i;
59
60     if (!strncmp(s, "NCOLS=", 6)) {
61     xres = atoi(s+6);
62     return(1);
63     }
64     if (!strncmp(s, "NROWS=", 6)) {
65     yres = atoi(s+6);
66     return(1);
67     }
68     if (isncomp(s)) {
69     ncomp = ncompval(s);
70     return(1);
71     }
72     if (formatval(fmt, s)) {
73     for (in_type = DTend; --in_type > DTfromHeader; )
74     if (!strcmp(fmt, cm_fmt_id[in_type]))
75     return(1);
76     return(-1);
77     }
78     i = isbigendian(s);
79     if (i >= 0) {
80     iswapped = (i != nativebigendian());
81     return(1);
82     }
83     return(0);
84     }
85
86     /* open initial file and get relevant dimensions and type */
87     int
88     get_iotypes(void)
89     {
90     char fbuf[256];
91     FILE *fp;
92
93     sprintf(fbuf, in_spec, 0);
94     fp = fopen(fbuf, "rb");
95     if (!fp) {
96     fprintf(stderr, "%s: cannot open for reading\n", fbuf);
97     return(0);
98     }
99     if (getheader(fp, iheadline, NULL) < 0) {
100     fprintf(stderr, "%s: bad header - wrong format?\n", fbuf);
101     fclose(fp);
102     return(0);
103     }
104     if ((xres <= 0) | (yres <= 0) && !fscnresolu(&xres, &yres, fp)) {
105     fprintf(stderr, "%s: missing input resolution\n", fbuf);
106     fclose(fp);
107     return(0);
108     }
109     if (nprocs > 1 && (in_type==DTrgbe) | (in_type==DTxyze)) {
110     long data_start = ftell(fp); /* make sure input flat */
111     off_t dend = lseek(fileno(fp), 0, SEEK_END);
112     if (dend < data_start + 4L*xres*yres) {
113     fputs("Warning - multi-processing requires flat input files\n",
114     stderr);
115     nprocs = 1;
116     }
117     }
118     fclose(fp);
119     if ((cmtx->ncomp == 1) & (ncomp != 1)) {
120     double xfm[MAXCSAMP];
121     RMATRIX *nmtx;
122     int i;
123     for (i = ncomp; i--; )
124     xfm[i] = 1.;
125     nmtx = rmx_transform(cmtx, ncomp, xfm);
126     if (!nmtx)
127     return(0);
128     rmx_free(cmtx);
129     cmtx = nmtx;
130     } else if (cmtx->ncomp != ncomp) {
131     fprintf(stderr, "operation %s needs %d components, has %d\n",
132     cmtx->ncols == 1 ? "vector" : "matrix",
133     ncomp, cmtx->ncomp);
134     return(0);
135     }
136     if ((in_type != DTrgbe) & (in_type != DTxyze) & (in_type != DTspec) &
137     (in_type != DTfloat)) {
138     fprintf(stderr, "%s unsupported input data type: %s\n",
139     fbuf, cm_fmt_id[in_type]);
140     return(0);
141     }
142     if ((out_type == DTrgbe) & (ncomp > 3))
143     out_type = DTspec;
144     else if (out_type == DTfromHeader ||
145     (out_type == DTrgbe) & (in_type != DTfloat))
146     out_type = in_type;
147     return(1);
148     }
149
150     /* check subsequent headers match initial file */
151     int
152     checkline(char *s, void *p)
153     {
154 greg 2.3 static int exposWarned = 0;
155     int *xyres = (int *)p;
156     char fmt[MAXFMTLEN];
157 greg 2.1
158     if (!strncmp(s, "NCOLS=", 6)) {
159     xyres[0] = atoi(s+6);
160     if (xyres[0] <= 0)
161     return(-1);
162     return(1);
163     }
164     if (!strncmp(s, "NROWS=", 6)) {
165     xyres[1] = atoi(s+6);
166     if (xyres[1] <= 0)
167     return(-1);
168     return(1);
169     }
170     if (isncomp(s)) {
171     if (ncompval(s) != ncomp)
172     return(-1);
173     return(1);
174     }
175     if (isexpos(s)) {
176 greg 2.3 if (!exposWarned && fabs(1. - exposval(s)) > 0.04) {
177     fputs("Warning - ignoring EXPOSURE setting(s)\n",
178     stderr);
179     exposWarned++;
180     }
181 greg 2.1 return(1);
182     }
183     if (formatval(fmt, s)) {
184     if (strcmp(fmt, cm_fmt_id[in_type]))
185     return(-1);
186     return(1);
187     }
188     return(0);
189     }
190
191     /* open and check input file */
192     FILE *
193     open_input(char *fname)
194     {
195     int xyres[2];
196     FILE *fp = fopen(fname, "rb");
197
198     if (!fp) {
199     fprintf(stderr, "%s: cannot open for reading\n", fname);
200     return(NULL);
201     }
202     xyres[0] = xyres[1] = 0;
203     if (getheader(fp, checkline, xyres) < 0) {
204     fprintf(stderr, "%s: bad/inconsistent header\n", fname);
205     fclose(fp);
206     return(NULL);
207     }
208     if ((xyres[0] <= 0) | (xyres[1] <= 0) &&
209     !fscnresolu(&xyres[0], &xyres[1], fp)) {
210     fprintf(stderr, "%s: missing resolution\n", fname);
211     fclose(fp);
212     return(NULL);
213     }
214     if ((xyres[0] != xres) | (xyres[1] != yres)) {
215     fprintf(stderr, "%s: mismatched resolution\n", fname);
216     fclose(fp);
217     return(NULL);
218     }
219     return(fp);
220     }
221
222     /* open output file or command (if !NULL) and write info header */
223     FILE *
224     open_output(char *ospec, int fno)
225     {
226     FILE *fp;
227
228     if (!ospec) {
229     ospec = "<stdout>";
230     fp = stdout;
231     } else if (ospec[0] == '!') {
232     if (!(fp = popen(ospec+1, "w"))) {
233     fprintf(stderr, "Cannot start: %s\n", ospec);
234     return(NULL);
235     }
236 greg 2.3 } else if (!(fp = fopen(ospec, "w"))) {
237 greg 2.1 fprintf(stderr, "%s: cannot open for writing\n", ospec);
238     return(NULL);
239     }
240 greg 2.3 SET_FILE_BINARY(fp);
241 greg 2.1 newheader("RADIANCE", fp);
242 greg 2.2 if (cmtx->info) /* prepend matrix metadata */
243     fputs(cmtx->info, fp);
244     else
245     fputnow(fp);
246 greg 2.1 if (fno >= 0)
247     fprintf(fp, "FRAME=%d\n", fno);
248     switch (out_type) {
249     case DTfloat:
250     case DTdouble:
251     fprintf(fp, "NCOLS=%d\nNROWS=%d\n", xres, yres);
252     fputncomp(ncomp, fp);
253     fputendian(fp);
254     fputformat(cm_fmt_id[out_type], fp);
255     fputc('\n', fp);
256     break;
257     case DTrgbe:
258     fputformat(COLRFMT, fp);
259     fputc('\n', fp);
260     fprtresolu(xres, yres, fp);
261     break;
262     case DTxyze:
263     fputformat(CIEFMT, fp);
264     fputc('\n', fp);
265     fprtresolu(xres, yres, fp);
266     break;
267     case DTspec:
268     fputncomp(ncomp, fp);
269     fputwlsplit(cmtx->wlpart, fp);
270     fputformat(SPECFMT, fp);
271     fputc('\n', fp);
272     fprtresolu(xres, yres, fp);
273     break;
274     default:
275     fputs("Unsupported output type!\n", stderr);
276     return(NULL);
277     }
278     if (fflush(fp) < 0) {
279     fprintf(stderr, "%s: write error\n", ospec);
280     fclose(fp);
281     return(NULL);
282     }
283     return(fp);
284     }
285
286     /* run calculation from a single process */
287     int
288     solo_process(void)
289     {
290     float *osum = (float *)calloc((size_t)xres*yres, sizeof(float)*ncomp);
291     COLORV *iscan = (COLORV *)malloc(sizeof(COLORV)*ncomp*xres);
292     char fbuf[512];
293     int c;
294
295     if (!osum | !iscan) {
296     fprintf(stderr, "Cannot allocate %dx%d %d-component accumulator\n",
297     xres, yres, ncomp);
298     return(0);
299     }
300     if (sizeof(float) != sizeof(COLORV)) {
301     fputs("Code Error 1 in solo_process()\n", stderr);
302     return(0);
303     }
304     for (c = 0; c < cmtx->ncols; c++) { /* run through each column/output */
305     FILE *fout;
306     int y;
307     int rc = cmtx->nrows;
308     if (c > 0) /* clear accumulator? */
309     memset(osum, 0, sizeof(float)*ncomp*xres*yres);
310     while (rc-- > 0) { /* run through each input file */
311     const int r = c&1 ? rc : cmtx->nrows-1 - rc;
312     const rmx_dtype *cval = rmx_val(cmtx, r, c);
313     FILE *finp;
314     int i, x;
315     for (i = ncomp; i--; )
316     if (cval[i] != 0) break;
317     if (i < 0) /* this coefficient is zero, skip */
318     continue;
319     sprintf(fbuf, in_spec, r);
320     finp = open_input(fbuf);
321     if (!finp)
322     return(0);
323     for (y = 0; y < yres; y++) {
324     float *dst = osum + y*xres*ncomp;
325     if (in_type == DTfloat ? getbinary(iscan, sizeof(float)*ncomp,
326     xres, finp) != xres
327     : freadsscan(iscan, ncomp, xres, finp) < 0)
328     goto readerr;
329     if ((in_type == DTfloat) & iswapped)
330     swap32((char *)iscan, ncomp*xres);
331     for (x = 0; x < xres; x++, dst += ncomp)
332     for (i = ncomp; i--; )
333     dst[i] += cval[i]*iscan[x*ncomp + i];
334     }
335     fclose(finp);
336     } /* write out accumulated column result... */
337     if (out_spec) { /* ...to file or command */
338     if (cmtx->ncols > 1 && !hasFormat(out_spec)) {
339     fputs("Sequential result must go to stdout\n", stderr);
340     return(0);
341     }
342     sprintf(fbuf, out_spec, c);
343     fout = open_output(fbuf, c-(cmtx->ncols==1));
344     } else { /* ...to stdout */
345     if ((out_type == DTfloat) & (cmtx->ncols > 1)) {
346     fputs("Float outputs must have separate destinations\n",
347     stderr);
348     return(0);
349     }
350     strcpy(fbuf, "<stdout>");
351     fout = open_output(NULL, c-(cmtx->ncols==1));
352     }
353     if (!fout)
354     return(0); /* assume error was reported */
355     if (out_type != DTfloat) {
356     for (y = 0; y < yres; y++)
357     if (fwritesscan(osum + (size_t)y*xres*ncomp,
358     ncomp, xres, fout) < 0)
359     goto writerr;
360     } else if (fwrite(osum, sizeof(float)*ncomp, (size_t)xres*yres, fout) !=
361     (size_t)xres*yres)
362     goto writerr;
363
364     if (fbuf[0] == '!') {
365     if (pclose(fout) != 0) {
366     fprintf(stderr, "Bad status from: %s\n", fbuf);
367     return(0);
368     }
369     } else if (fout != stdout && fclose(fout) == EOF)
370     goto writerr;
371     }
372     free(osum); /* clean up on success */
373     free(iscan);
374     return(1);
375     readerr:
376     fprintf(stderr, "%s: read error\n", fbuf);
377     return(0);
378     writerr:
379     fprintf(stderr, "%s: write error\n", fbuf);
380     return(0);
381     }
382
383 greg 2.2 /* allocate a scrambled index array of the specified length */
384     int *
385     scramble(int n)
386     {
387     int *scarr = (int *)malloc(sizeof(int)*n);
388     int i;
389
390     if (!scarr) {
391     fprintf(stderr, "Out of memory in scramble(%d)\n", n);
392     exit(1);
393     }
394     for (i = n; i--; )
395     scarr[i] = i;
396     /* perform Fisher-Yates shuffle */
397     for (i = 0; i < n-1; i++) {
398     int ix = irandom(n-i) + i;
399     int ndx = scarr[i];
400     scarr[i] = scarr[ix];
401     scarr[ix] = ndx;
402     }
403     return(scarr);
404     }
405
406 greg 2.1 /* run calculation on multiple processes, using memory maps and fork() */
407     int
408     multi_process(void)
409     {
410     #if defined(_WIN32) || defined(_WIN64)
411     fputs("Bad call to multi_process()\n", stderr);
412     return(0);
413     #else
414     int coff = nprocs;
415     int odd = 0;
416     char fbuf[512];
417     float *osum;
418 greg 2.2 int *syarr;
419 greg 2.1 int c;
420     /* sanity check */
421     if (sizeof(float) != sizeof(COLORV)) {
422     fputs("Code Error 1 in multi_process()\n", stderr);
423     return(0);
424     }
425     while (--coff > 0) { /* parent births children */
426     int pid = fork();
427     if (pid < 0) {
428     fputs("fork() call failed!\n", stderr);
429     return(0);
430     }
431     if (pid == 0) break; /* child gets to work */
432     }
433     osum = (float *)calloc((size_t)xres*yres, sizeof(float)*ncomp);
434     if (!osum) {
435     fprintf(stderr, "Cannot allocate %dx%d %d-component accumulator\n",
436     xres, yres, ncomp);
437     return(0);
438     }
439 greg 2.2 srandom(113*coff + 5669); /* randomize row access for this process */
440     syarr = scramble(yres);
441 greg 2.1 /* run through our unique set of columns */
442     for (c = coff; c < cmtx->ncols; c += nprocs) {
443     FILE *fout;
444     int y;
445     int rc = cmtx->nrows;
446     if (c > coff) /* clear accumulator? */
447     memset(osum, 0, sizeof(float)*ncomp*xres*yres);
448     while (rc-- > 0) { /* map & sum each input file */
449     const int r = odd ? rc : cmtx->nrows-1 - rc;
450     const rmx_dtype *cval = rmx_val(cmtx, r, c);
451 greg 2.2 long dstart;
452 greg 2.1 size_t maplen;
453     void *imap;
454     FILE *finp;
455     float *dst;
456 greg 2.2 int i, x;
457 greg 2.1 for (i = ncomp; i--; )
458     if (cval[i] != 0) break;
459     if (i < 0) /* this coefficient is zero, skip */
460     continue;
461     sprintf(fbuf, in_spec, r);
462     finp = open_input(fbuf);
463     if (!finp)
464     return(0);
465     dstart = ftell(finp);
466     if (dstart < 0) {
467     fprintf(stderr, "%s: ftell() failed!\n", fbuf);
468     return(0);
469     }
470     if (in_type == DTfloat && dstart%sizeof(float)) {
471     fprintf(stderr, "%s: float header misalignment\n", fbuf);
472     return(0);
473     }
474     i = in_type==DTfloat ? ncomp*(int)sizeof(float) : ncomp+1;
475 greg 2.6 maplen = dstart + (size_t)yres*xres*i;
476 greg 2.1 imap = mmap(NULL, maplen, PROT_READ,
477     MAP_FILE|MAP_SHARED, fileno(finp), 0);
478 greg 2.3 fclose(finp); /* will read from map (randomly) */
479 greg 2.1 if (imap == MAP_FAILED) {
480     fprintf(stderr, "%s: unable to map input file\n", fbuf);
481     return(0);
482     }
483 greg 2.2 if (in_type == DTfloat)
484     for (y = yres; y-- > 0; ) {
485     const float *fvp = (float *)((char *)imap + dstart) +
486     (size_t)ncomp*xres*syarr[y];
487     dst = osum + (size_t)ncomp*xres*syarr[y];
488     for (x = xres; x-- > 0; dst += ncomp, fvp += ncomp)
489     for (i = ncomp; i--; )
490     dst[i] += cval[i]*fvp[i];
491     }
492     else
493     for (y = yres; y-- > 0; ) {
494     const COLRV *cvp = (COLRV *)((char *)imap + dstart) +
495     (ncomp+1L)*xres*syarr[y];
496     dst = osum + (size_t)ncomp*xres*syarr[y];
497     for (x = xres; x-- > 0; dst += ncomp, cvp += ncomp+1) {
498     const rmx_dtype fe = cxponent[cvp[ncomp]];
499     for (i = ncomp; i--; )
500     dst[i] += cval[i]*(cvp[i]+(rmx_dtype).5)*fe;
501     }
502 greg 2.1 }
503     munmap(imap, maplen);
504 greg 2.3 } /* write accumulated column picture/matrix */
505 greg 2.1 sprintf(fbuf, out_spec, c);
506     fout = open_output(fbuf, c);
507     if (!fout)
508     return(0); /* assume error was reported */
509     if (out_type != DTfloat) {
510     for (y = 0; y < yres; y++)
511     if (fwritesscan(osum + (size_t)y*xres*ncomp,
512     ncomp, xres, fout) < 0)
513     goto writerr;
514     } else if (fwrite(osum, sizeof(float)*ncomp, (size_t)xres*yres, fout) !=
515     (size_t)xres*yres)
516     goto writerr;
517
518     if (fbuf[0] == '!') {
519     if (pclose(fout) != 0) {
520     fprintf(stderr, "Bad status from: %s\n", fbuf);
521     return(0);
522     }
523     } else if (fclose(fout) == EOF)
524     goto writerr;
525     odd = !odd; /* go back & forth to milk page cache */
526     }
527     free(osum);
528 greg 2.2 free(syarr);
529 greg 2.3 if (coff) /* child processes return here... */
530 greg 2.1 return(1);
531     c = 0; /* ...but parent waits for children */
532     while (++coff < nprocs) {
533     int st;
534     if (wait(&st) < 0)
535     break;
536     if (st) c = st;
537     }
538     return(c == 0);
539     writerr:
540     fprintf(stderr, "%s: write error\n", fbuf);
541     return(0);
542     #endif
543     }
544
545     int
546     main(int argc, char *argv[])
547     {
548     int a;
549
550     for (a = 1; a < argc-1 && argv[a][0] == '-'; a++)
551     switch (argv[a][1]) {
552     case 'o': /* output spec/format */
553     switch (argv[a][2]) {
554     case '\0':
555     out_spec = argv[++a];
556     break;
557     case 'f':
558     out_type = DTfloat;
559     break;
560     case 'c':
561     out_type = DTrgbe;
562     break;
563     default:
564     goto badopt;
565     }
566     break;
567     case 'N': /* number of desired processes */
568     case 'n': /* quietly supported alternate */
569     nprocs = atoi(argv[++a]);
570     if (nprocs <= 0)
571     goto userr;
572     break;
573     default:;
574     badopt: fprintf(stderr, "%s: bad option: %s\n", argv[0], argv[a]);
575     goto userr;
576     return(1);
577     }
578     if ((argc-a < 1) | (argc-a > 2) || argv[a][0] == '-')
579     goto userr;
580     in_spec = argv[a];
581 greg 2.4 cmtx = rmx_load(argv[a+1]); /* loads from stdin if a+1==argc */
582 greg 2.1 if (cmtx == NULL)
583     return(1); /* error reported */
584 greg 2.3 if (nprocs > cmtx->ncols)
585     nprocs = cmtx->ncols;
586 greg 2.1 #if defined(_WIN32) || defined(_WIN64)
587     if (nprocs > 1) {
588     fprintf(stderr, "%s: warning - Windows only allows -N 1\n", argv[0]);
589     nprocs = 1;
590     }
591     #else
592     if ((nprocs > 1) & !out_spec) {
593     fprintf(stderr, "%s: multi-processing result cannot go to stdout\n",
594     argv[0]);
595     nprocs = 1;
596     }
597     if ((nprocs > 1) & iswapped && (in_type==DTfloat) | (in_type==DTdouble)) {
598     fprintf(stderr, "%s: multi-processing unsupported on swapped input\n",
599     argv[0]);
600     nprocs = 1;
601     }
602     #endif
603     if (cmtx->nrows > 1 && !hasFormat(in_spec)) {
604     fprintf(stderr, "%s: input specification '%s' needs %%d format\n",
605     argv[0], in_spec);
606     goto userr;
607     }
608     if (!get_iotypes())
609     return(1);
610     if (!(nprocs == 1 ? solo_process() : multi_process()))
611     return(1);
612     return(0);
613     userr:
614     fprintf(stderr, "Usage: %s [-oc | -of][-o ospec][-N nproc] inpspec [mtx]\n",
615     argv[0]);
616     return(1);
617     }
