root/radiance/ray/src/util/pranim.c
Revision: 1.4
Committed: Fri Nov 5 03:31:39 2004 UTC (19 years, 6 months ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.4 static const char RCSid[] = "$Id: pranim.c,v 1.3 2003/10/27 10:32:06 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * Send Sun rasterfiles to PC animation system.
6     *
7     * 6/20/88
8     */
9
10     #include <stdio.h>
11     #include <rasterfile.h>
12
13 schorsch 1.3 #include "rtprocess.h"
14 greg 1.1 #include "client/clnt.h"
15
16
17     char *pcom = NULL; /* uncompress command */
18
19
20     main(argc, argv)
21     int argc;
22     char **argv;
23     {
24     int startrec = 0;
25     char *progname;
26     int prognum = PCPROGRAM;
27     /* initialize */
28     for (progname = *argv++; --argc; argv++)
29     if (!strcmp(*argv, "-p") && argv[1]) {
30     prognum = atoi(*++argv); argc--;
31     } else if (!strcmp(*argv, "-u") && argv[1]) {
32     pcom = *++argv; argc--;
33     } else if (!strcmp(*argv, "-r") && argv[1]) {
34     startrec = atoi(*++argv); argc--;
35     } else
36     break;
37     if (!argc) {
38     fputs("Usage: ", stderr);
39     fputs(progname, stderr);
40     fputs(" [-p prognum] [-u uncompress] [-r record] hostname [frame..]\n",
41     stderr);
42     exit(1);
43     }
44     scry_open(*argv++, prognum); argc--;
45     scry_get_info(1) ;
46     scry_set_compress(NONE);
47     if (startrec > 0)
48     scry_init_record(startrec, argc>0?argc:1);
49     else
50     scry_init_record(PREVIEW,0);
51     /* send frames */
52     if (argc <= 0)
53     sendframe(NULL);
54     else
55     for ( ; argc > 0; argc--, argv++)
56     sendframe(*argv);
57     /* clean up */
58     scry_close();
59     exit(0);
60     }
61
62
63     sendframe(file) /* convert and send a frame */
64     char *file;
65     {
66     static struct rasterfile head;
67     char command[128];
68     unsigned char cmap[3][256];
69     unsigned char dmap[256][3] ;
70     static unsigned short targa[256];
71     static int xbeg, ybeg;
72     register FILE *fp;
73     register int i, j;
74     register int c;
75     /* DAVIDR */
76     unsigned char *image_read, *newimage, *compdata ;
77     int new_ht, new_wd, new_depth ;
78     /* end DAVIDR */
79     /* open file */
80     if (file == NULL) {
81     if (pcom != NULL)
82     fp = popen(pcom, "r");
83     else
84     fp = stdin;
85     file = "<stdin>";
86     } else {
87     if (pcom != NULL) {
88     sprintf(command, "( %s ) < %s", pcom, file);
89     fp = popen(command, "r");
90     } else
91     fp = fopen(file, "r");
92     }
93     if (fp == NULL) {
94     perror(file);
95     exit(1);
96     }
97     /* check format */
98     if (fread(&head, sizeof(head), 1, fp) != 1)
99     goto rasfmt;
100     if (head.ras_magic != RAS_MAGIC || head.ras_type != RT_STANDARD)
101     goto rasfmt;
102     if (head.ras_maptype != RMT_EQUAL_RGB || head.ras_maplength != 3*256)
103     goto rasfmt;
104     /* get color table */
105     if (fread(cmap, 256, 3, fp) != 3)
106     goto readerr;
107     /* convert table */
108     #ifdef LATER
109     for (j = 0; j < 253; j++)
110     targa[j+1] = (cmap[0][j] & 0xf8)<<7 |
111     (cmap[1][j] & 0xf8)<<2 | cmap[2][j]>>3;
112     #endif
113     for (j = 0 ; j < 256 ; j++)
114     {
115     dmap[j][0] = cmap[0][j] ;
116     dmap[j][1] = cmap[1][j] ;
117     dmap[j][2] = cmap[2][j] ;
118     }
119     /* send table */
120     scry_set_map(254, dmap);
121     image_read = (unsigned char *) malloc(head.ras_width*head.ras_height) ;
122     for (j = 0 ; j < head.ras_height ; j++)
123     fread (&(image_read[(head.ras_height-j-1)*head.ras_width]),head.ras_width,1,fp) ;
124     fread(image_read,head.ras_width*head.ras_height,1,fp) ;
125     newimage = NULL ;
126     /* send frame */
127     scry_conv_vis (image_read,&newimage,head.ras_height,head.ras_width,&new_ht,&new_wd,1,&new_depth) ;
128     free (image_read) ;
129     compdata = NULL ;
130     scry_compress(newimage,&compdata,new_ht,new_wd,new_depth) ;
131     scry_send_frame(compdata);
132     free(compdata) ;
133     free (newimage) ;
134     /* close file */
135     if (pcom != NULL)
136     pclose(fp);
137     else
138     fclose(fp);
139     return;
140     rasfmt:
141     fputs(file, stderr);
142     fputs(": wrong rasterfile format\n", stderr);
143     exit(1);
144     readerr:
145     fputs(file, stderr);
146     fputs(": read error\n", stderr);
147     exit(1);
148     }
