root/radiance/ray/src/util/pranim.c
Revision: 1.1
Committed: Tue Mar 12 13:05:11 1991 UTC (33 years, 2 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Send Sun rasterfiles to PC animation system.
9 *
10 * 6/20/88
11 */
12
13 #include <stdio.h>
14 #include <rasterfile.h>
15
16 #include "client/clnt.h"
17
18 FILE *popen();
19
20 char *pcom = NULL; /* uncompress command */
21
22
23 main(argc, argv)
24 int argc;
25 char **argv;
26 {
27 int startrec = 0;
28 char *progname;
29 int prognum = PCPROGRAM;
30 /* initialize */
31 for (progname = *argv++; --argc; argv++)
32 if (!strcmp(*argv, "-p") && argv[1]) {
33 prognum = atoi(*++argv); argc--;
34 } else if (!strcmp(*argv, "-u") && argv[1]) {
35 pcom = *++argv; argc--;
36 } else if (!strcmp(*argv, "-r") && argv[1]) {
37 startrec = atoi(*++argv); argc--;
38 } else
39 break;
40 if (!argc) {
41 fputs("Usage: ", stderr);
42 fputs(progname, stderr);
43 fputs(" [-p prognum] [-u uncompress] [-r record] hostname [frame..]\n",
44 stderr);
45 exit(1);
46 }
47 scry_open(*argv++, prognum); argc--;
48 scry_get_info(1) ;
49 scry_set_compress(NONE);
50 if (startrec > 0)
51 scry_init_record(startrec, argc>0?argc:1);
52 else
53 scry_init_record(PREVIEW,0);
54 /* send frames */
55 if (argc <= 0)
56 sendframe(NULL);
57 else
58 for ( ; argc > 0; argc--, argv++)
59 sendframe(*argv);
60 /* clean up */
61 scry_close();
62 exit(0);
63 }
64
65
66 sendframe(file) /* convert and send a frame */
67 char *file;
68 {
69 static struct rasterfile head;
70 char command[128];
71 unsigned char cmap[3][256];
72 unsigned char dmap[256][3] ;
73 static unsigned short targa[256];
74 static int xbeg, ybeg;
75 register FILE *fp;
76 register int i, j;
77 register int c;
78 /* DAVIDR */
79 unsigned char *image_read, *newimage, *compdata ;
80 int new_ht, new_wd, new_depth ;
81 /* end DAVIDR */
82 /* open file */
83 if (file == NULL) {
84 if (pcom != NULL)
85 fp = popen(pcom, "r");
86 else
87 fp = stdin;
88 file = "<stdin>";
89 } else {
90 if (pcom != NULL) {
91 sprintf(command, "( %s ) < %s", pcom, file);
92 fp = popen(command, "r");
93 } else
94 fp = fopen(file, "r");
95 }
96 if (fp == NULL) {
97 perror(file);
98 exit(1);
99 }
100 /* check format */
101 if (fread(&head, sizeof(head), 1, fp) != 1)
102 goto rasfmt;
103 if (head.ras_magic != RAS_MAGIC || head.ras_type != RT_STANDARD)
104 goto rasfmt;
105 if (head.ras_maptype != RMT_EQUAL_RGB || head.ras_maplength != 3*256)
106 goto rasfmt;
107 /* get color table */
108 if (fread(cmap, 256, 3, fp) != 3)
109 goto readerr;
110 /* convert table */
111 #ifdef LATER
112 for (j = 0; j < 253; j++)
113 targa[j+1] = (cmap[0][j] & 0xf8)<<7 |
114 (cmap[1][j] & 0xf8)<<2 | cmap[2][j]>>3;
115 #endif
116 for (j = 0 ; j < 256 ; j++)
117 {
118 dmap[j][0] = cmap[0][j] ;
119 dmap[j][1] = cmap[1][j] ;
120 dmap[j][2] = cmap[2][j] ;
121 }
122 /* send table */
123 scry_set_map(254, dmap);
124 image_read = (unsigned char *) malloc(head.ras_width*head.ras_height) ;
125 for (j = 0 ; j < head.ras_height ; j++)
126 fread (&(image_read[(head.ras_height-j-1)*head.ras_width]),head.ras_width,1,fp) ;
127 fread(image_read,head.ras_width*head.ras_height,1,fp) ;
128 newimage = NULL ;
129 /* send frame */
130 scry_conv_vis (image_read,&newimage,head.ras_height,head.ras_width,&new_ht,&new_wd,1,&new_depth) ;
131 free (image_read) ;
132 compdata = NULL ;
133 scry_compress(newimage,&compdata,new_ht,new_wd,new_depth) ;
134 scry_send_frame(compdata);
135 free(compdata) ;
136 free (newimage) ;
137 /* close file */
138 if (pcom != NULL)
139 pclose(fp);
140 else
141 fclose(fp);
142 return;
143 rasfmt:
144 fputs(file, stderr);
145 fputs(": wrong rasterfile format\n", stderr);
146 exit(1);
147 readerr:
148 fputs(file, stderr);
149 fputs(": read error\n", stderr);
150 exit(1);
151 }
