root/Development/ray/src/util/pranim.c
Revision: 1.4
Committed: Fri Nov 5 03:31:39 2004 UTC (21 years, 2 months ago) by greg
State: FILE REMOVED
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: pranim.c,v 1.3 2003/10/27 10:32:06 schorsch Exp $";
5 * Send Sun rasterfiles to PC animation system.
6 *
7 * 6/20/88
8 */
9
10 #include <stdio.h>
11 #include <rasterfile.h>
12
13 #include "rtprocess.h"
14 #include "client/clnt.h"
15
16
17 char *pcom = NULL; /* uncompress command */
18
19
20 main(argc, argv)
21 int argc;
22 char **argv;
23 {
24 int startrec = 0;
25 char *progname;
26 int prognum = PCPROGRAM;
27 /* initialize */
28 for (progname = *argv++; --argc; argv++)
29 if (!strcmp(*argv, "-p") && argv[1]) {
30 prognum = atoi(*++argv); argc--;
31 } else if (!strcmp(*argv, "-u") && argv[1]) {
32 pcom = *++argv; argc--;
33 } else if (!strcmp(*argv, "-r") && argv[1]) {
34 startrec = atoi(*++argv); argc--;
35 } else
36 break;
37 if (!argc) {
38 fputs("Usage: ", stderr);
39 fputs(progname, stderr);
40 fputs(" [-p prognum] [-u uncompress] [-r record] hostname [frame..]\n",
41 stderr);
42 exit(1);
43 }
44 scry_open(*argv++, prognum); argc--;
45 scry_get_info(1) ;
46 scry_set_compress(NONE);
47 if (startrec > 0)
48 scry_init_record(startrec, argc>0?argc:1);
49 else
50 scry_init_record(PREVIEW,0);
51 /* send frames */
52 if (argc <= 0)
53 sendframe(NULL);
54 else
55 for ( ; argc > 0; argc--, argv++)
56 sendframe(*argv);
57 /* clean up */
58 scry_close();
59 exit(0);
60 }
61
62
63 sendframe(file) /* convert and send a frame */
64 char *file;
65 {
66 static struct rasterfile head;
67 char command[128];
68 unsigned char cmap[3][256];
69 unsigned char dmap[256][3] ;
70 static unsigned short targa[256];
71 static int xbeg, ybeg;
72 register FILE *fp;
73 register int i, j;
74 register int c;
75 /* DAVIDR */
76 unsigned char *image_read, *newimage, *compdata ;
77 int new_ht, new_wd, new_depth ;
78 /* end DAVIDR */
79 /* open file */
80 if (file == NULL) {
81 if (pcom != NULL)
82 fp = popen(pcom, "r");
83 else
84 fp = stdin;
85 file = "<stdin>";
86 } else {
87 if (pcom != NULL) {
88 sprintf(command, "( %s ) < %s", pcom, file);
89 fp = popen(command, "r");
90 } else
91 fp = fopen(file, "r");
92 }
93 if (fp == NULL) {
94 perror(file);
95 exit(1);
96 }
97 /* check format */
98 if (fread(&head, sizeof(head), 1, fp) != 1)
99 goto rasfmt;
100 if (head.ras_magic != RAS_MAGIC || head.ras_type != RT_STANDARD)
101 goto rasfmt;
102 if (head.ras_maptype != RMT_EQUAL_RGB || head.ras_maplength != 3*256)
103 goto rasfmt;
104 /* get color table */
105 if (fread(cmap, 256, 3, fp) != 3)
106 goto readerr;
107 /* convert table */
108 #ifdef LATER
109 for (j = 0; j < 253; j++)
110 targa[j+1] = (cmap[0][j] & 0xf8)<<7 |
111 (cmap[1][j] & 0xf8)<<2 | cmap[2][j]>>3;
112 #endif
113 for (j = 0 ; j < 256 ; j++)
114 {
115 dmap[j][0] = cmap[0][j] ;
116 dmap[j][1] = cmap[1][j] ;
117 dmap[j][2] = cmap[2][j] ;
118 }
119 /* send table */
120 scry_set_map(254, dmap);
121 image_read = (unsigned char *) malloc(head.ras_width*head.ras_height) ;
122 for (j = 0 ; j < head.ras_height ; j++)
123 fread (&(image_read[(head.ras_height-j-1)*head.ras_width]),head.ras_width,1,fp) ;
124 fread(image_read,head.ras_width*head.ras_height,1,fp) ;
125 newimage = NULL ;
126 /* send frame */
127 scry_conv_vis (image_read,&newimage,head.ras_height,head.ras_width,&new_ht,&new_wd,1,&new_depth) ;
128 free (image_read) ;
129 compdata = NULL ;
130 scry_compress(newimage,&compdata,new_ht,new_wd,new_depth) ;
131 scry_send_frame(compdata);
132 free(compdata) ;
133 free (newimage) ;
134 /* close file */
135 if (pcom != NULL)
136 pclose(fp);
137 else
138 fclose(fp);
139 return;
140 rasfmt:
141 fputs(file, stderr);
142 fputs(": wrong rasterfile format\n", stderr);
143 exit(1);
144 readerr:
145 fputs(file, stderr);
146 fputs(": read error\n", stderr);
147 exit(1);
148 }
