1 |
greg |
2.2 |
/* RCSid $Id$ */ |
2 |
greg |
2.1 |
#ifndef __PICTOOL_H |
3 |
#define __PICTOOL_H |
4 |
5 |
#ifdef __cplusplus |
6 |
extern "C" { |
7 |
#endif |
8 |
9 |
#include <stdio.h> |
10 |
#include <stdlib.h> |
11 |
12 |
#include "g3vector.h" |
13 |
#include "g3affine.h" |
14 |
#include "g3flist.h" |
15 |
16 |
#include "view.h" |
17 |
#include "color.h" |
18 |
19 |
#define PICT_GLARE |
20 |
21 |
#define PICT_VIEW 1 |
22 |
#define PICT_LUT 2 |
23 |
24 |
#define PICT_CH1 1 |
25 |
#define PICT_CH2 2 |
26 |
#define PICT_CH3 4 |
27 |
28 |
#define PICT_ALLCH 7 |
29 |
30 |
#ifdef PICT_GLARE |
31 |
typedef struct pixinfo { |
32 |
int gsn; |
33 |
int pgs; |
34 |
double omega; |
35 |
FVECT dir; |
36 |
} pixinfo; |
37 |
#endif |
38 |
39 |
typedef struct pict { |
40 |
int use_lut; |
41 |
char comment[4096]; |
42 |
int valid_view; |
43 |
VIEW view; |
44 |
COLOR* lut; |
45 |
RESOLU resol; |
46 |
COLOR* pic; |
47 |
double pjitter; |
48 |
#ifdef PICT_GLARE |
49 |
pixinfo* pinfo; |
50 |
g3FList* glareinfo; |
51 |
#endif |
52 |
} pict; |
53 |
54 |
#define pict_get_origin(p) (p->view.vp) |
55 |
#define pict_get_viewdir(p) (p->view.vdir) |
56 |
#define pict_get_viewup(p) (p->view.vup) |
57 |
58 |
#define pict_lut_used(p) (p->use_lut) |
59 |
60 |
#define pict_get_comp(p,x,y,i) ((p->pic + x*p->resol.yr)[y][i]) |
61 |
#define pict_colbuf(p,buf,x,y) ((buf + y*p->resol.xr)[x]) |
62 |
#define pict_get_color(p,x,y) pict_colbuf(p,p->pic,x,y) |
63 |
#define pict_get_xsize(p) (p->resol.xr) |
64 |
#define pict_get_ysize(p) (p->resol.yr) |
65 |
66 |
67 |
68 |
#ifdef PICT_GLARE |
69 |
70 |
#define pict_get_omega(p,x,y) ((p->pinfo[y + x*p->resol.yr])).omega |
71 |
#define pict_get_cached_dir(p,x,y) (((p->pinfo[y + x*p->resol.yr])).dir) |
72 |
#define pict_get_gsn(p,x,y) ((p->pinfo[y + x*p->resol.yr])).gsn |
73 |
#define pict_get_pgs(p,x,y) ((p->pinfo[y + x*p->resol.yr])).pgs |
74 |
75 |
enum { |
76 |
PICT_GSN = 0, |
77 |
PICT_NPIX, |
78 |
PICT_AVPOSX, |
79 |
PICT_AVPOSY, |
80 |
PICT_AVLUM, |
81 |
PICT_AVOMEGA, |
82 |
PICT_DXMAX, |
83 |
PICT_DYMAX, |
84 |
PICT_LMIN, |
85 |
PICT_LMAX, |
86 |
PICT_EGLARE, |
87 |
PICT_DGLARE, |
88 |
PICT_GLSIZE |
89 |
90 |
91 |
#define pict_get_num(p,i) (g3fl_get(p->glareinfo,i)[PICT_GSN]) |
92 |
#define pict_get_npix(p,i) (g3fl_get(p->glareinfo,i)[PICT_NPIX]) |
93 |
#define pict_get_av_posx(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVPOSX]) |
94 |
#define pict_get_av_posy(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVPOSY]) |
95 |
#define pict_get_av_lum(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVLUM]) |
96 |
#define pict_get_av_omega(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVOMEGA]) |
97 |
#define pict_get_dx_max(p,i) (g3fl_get(p->glareinfo,i)[PICT_DXMAX]) |
98 |
#define pict_get_dy_max(p,i) (g3fl_get(p->glareinfo,i)[PICT_DYMAX]) |
99 |
#define pict_get_lum_min(p,i) (g3fl_get(p->glareinfo,i)[PICT_LMIN]) |
100 |
#define pict_get_lum_max(p,i) (g3fl_get(p->glareinfo,i)[PICT_LMAX]) |
101 |
#define pict_get_Eglare(p,i) (g3fl_get(p->glareinfo,i)[PICT_EGLARE]) |
102 |
#define pict_get_Dglare(p,i) (g3fl_get(p->glareinfo,i)[PICT_DGLARE]) |
103 |
104 |
#define pict_get_gli_size(p) (p->glareinfo->size) |
105 |
106 |
#ifdef PICT_GLARE |
107 |
#define pict_is_validpixel(p,x,y) (((p->view.type != VT_ANG) || \ |
108 |
(DOT(pict_get_cached_dir(p,x,y), p->view.vdir) >= 0.0))\ |
109 |
&& pict_get_omega(p,x,y) > 0.0) |
110 |
#else |
111 |
112 |
113 |
&& pict_get_sangle(p,x,y) > 0) |
114 |
115 |
#endif |
116 |
117 |
void pict_new_gli(pict* p); |
118 |
119 |
void pict_update_evalglare_caches(pict* p); |
120 |
121 |
#endif |
122 |
123 |
int pict_init(pict* p); |
124 |
pict* pict_create(); |
125 |
void pict_free(pict* p); |
126 |
127 |
pict* pict_get_copy(pict* p); |
128 |
129 |
void pict_set_comment(pict* p,const char* c); |
130 |
131 |
int pict_resize(pict* p,int x,int y); |
132 |
133 |
int pict_zero(pict* p); |
134 |
135 |
int pict_read(pict* p,char* fn); |
136 |
int pict_read_fp(pict* p,FILE* fp); |
137 |
int pict_read_tt_txt(pict* p,char* fn); |
138 |
int pict_read_from_list(pict* p,FILE* fp); |
139 |
int pict_write(pict* p,char* fn); |
140 |
int pict_write_fp(pict* p,FILE* fp); |
141 |
int pict_write_dir(pict* p,FILE* fp); |
142 |
143 |
int pict_setup_lut(pict* p,char* theta_fn,char* phi_fn,char* omega_fn); |
144 |
int pict_update_lut(pict* p); |
145 |
146 |
int pict_update_view(pict* p); |
147 |
148 |
int pict_get_dir(pict* p,int x,int y,FVECT dir); |
149 |
int pict_get_dir_ic(pict* p,double x,double y,FVECT dir); |
150 |
int pict_get_ray(pict* p,int x,int y,FVECT orig,FVECT dir); |
151 |
int pict_get_ray_ic(pict* p,double x,double y,FVECT orig,FVECT dir); |
152 |
int pict_locate(pict* p,FVECT pt,int* x,int* y); |
153 |
double pict_get_sangle(pict* p,int x,int y); |
154 |
155 |
int pict_get_vangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a); |
156 |
int pict_get_hangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a); |
157 |
int pict_get_tau(pict* p,double x,double y,FVECT vdir,FVECT vup,double* t); |
158 |
int pict_get_sigma(pict* p,double x,double y,FVECT vdir,FVECT vup,double* s); |
159 |
160 |
int pict_set_pj(pict* p,double pj); |
161 |
int pict_setorigin(pict* p,FVECT orig); |
162 |
int pict_setdir(pict* p,FVECT dir); |
163 |
int pict_setvtype(pict* p,char vt); |
164 |
int pict_setvup(pict* p,FVECT vup); |
165 |
int pict_sethview(pict* p,double ha); |
166 |
int pict_setvview(pict* p,double va); |
167 |
168 |
int pict_trans_cam(pict* p,g3ATrans t); |
169 |
170 |
171 |
172 |
173 |
174 |
175 |
#endif |
176 |
#endif |
