root/radiance/ray/src/util/pictool.h
Revision: 2.1
Committed: Wed Aug 12 23:07:59 2015 UTC (9 years, 9 months ago) by greg
1 #ifndef __PICTOOL_H
2 #define __PICTOOL_H
3
4 #ifdef __cplusplus
5 extern "C" {
6 #endif
7
8 #include <stdio.h>
9 #include <stdlib.h>
10
11 #include "g3vector.h"
12 #include "g3affine.h"
13 #include "g3flist.h"
14
15 #include "view.h"
16 #include "color.h"
17
18 #define PICT_GLARE
19
20 #define PICT_VIEW 1
21 #define PICT_LUT 2
22
23 #define PICT_CH1 1
24 #define PICT_CH2 2
25 #define PICT_CH3 4
26
27 #define PICT_ALLCH 7
28
29 #ifdef PICT_GLARE
30 typedef struct pixinfo {
31 int gsn;
32 int pgs;
33 double omega;
34 FVECT dir;
35 } pixinfo;
36 #endif
37
38 typedef struct pict {
39 int use_lut;
40 char comment[4096];
41 int valid_view;
42 VIEW view;
43 COLOR* lut;
44 RESOLU resol;
45 COLOR* pic;
46 double pjitter;
47 #ifdef PICT_GLARE
48 pixinfo* pinfo;
49 g3FList* glareinfo;
50 #endif
51 } pict;
52
53 #define pict_get_origin(p) (p->view.vp)
54 #define pict_get_viewdir(p) (p->view.vdir)
55 #define pict_get_viewup(p) (p->view.vup)
56
57 #define pict_lut_used(p) (p->use_lut)
58
59 #define pict_get_comp(p,x,y,i) ((p->pic + x*p->resol.yr)[y][i])
60 #define pict_colbuf(p,buf,x,y) ((buf + y*p->resol.xr)[x])
61 #define pict_get_color(p,x,y) pict_colbuf(p,p->pic,x,y)
62 #define pict_get_xsize(p) (p->resol.xr)
63 #define pict_get_ysize(p) (p->resol.yr)
64
65
66
67 #ifdef PICT_GLARE
68
69 #define pict_get_omega(p,x,y) ((p->pinfo[y + x*p->resol.yr])).omega
70 #define pict_get_cached_dir(p,x,y) (((p->pinfo[y + x*p->resol.yr])).dir)
71 #define pict_get_gsn(p,x,y) ((p->pinfo[y + x*p->resol.yr])).gsn
72 #define pict_get_pgs(p,x,y) ((p->pinfo[y + x*p->resol.yr])).pgs
73
74 enum {
75 PICT_GSN = 0,
76 PICT_NPIX,
77 PICT_AVPOSX,
78 PICT_AVPOSY,
79 PICT_AVLUM,
80 PICT_AVOMEGA,
81 PICT_DXMAX,
82 PICT_DYMAX,
83 PICT_LMIN,
84 PICT_LMAX,
85 PICT_EGLARE,
86 PICT_DGLARE,
87 PICT_GLSIZE
88 };
89
90 #define pict_get_num(p,i) (g3fl_get(p->glareinfo,i)[PICT_GSN])
91 #define pict_get_npix(p,i) (g3fl_get(p->glareinfo,i)[PICT_NPIX])
92 #define pict_get_av_posx(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVPOSX])
93 #define pict_get_av_posy(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVPOSY])
94 #define pict_get_av_lum(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVLUM])
95 #define pict_get_av_omega(p,i) (g3fl_get(p->glareinfo,i)[PICT_AVOMEGA])
96 #define pict_get_dx_max(p,i) (g3fl_get(p->glareinfo,i)[PICT_DXMAX])
97 #define pict_get_dy_max(p,i) (g3fl_get(p->glareinfo,i)[PICT_DYMAX])
98 #define pict_get_lum_min(p,i) (g3fl_get(p->glareinfo,i)[PICT_LMIN])
99 #define pict_get_lum_max(p,i) (g3fl_get(p->glareinfo,i)[PICT_LMAX])
100 #define pict_get_Eglare(p,i) (g3fl_get(p->glareinfo,i)[PICT_EGLARE])
101 #define pict_get_Dglare(p,i) (g3fl_get(p->glareinfo,i)[PICT_DGLARE])
102
103 #define pict_get_gli_size(p) (p->glareinfo->size)
104
105 #ifdef PICT_GLARE
106 #define pict_is_validpixel(p,x,y) (((p->view.type != VT_ANG) || \
107 (DOT(pict_get_cached_dir(p,x,y), p->view.vdir) >= 0.0))\
108 && pict_get_omega(p,x,y) > 0.0)
109 #else
110 #define pict_is_validpixel(p,x,y) (((p->view.type != VT_ANG) || \
111 (DOT(pict_get_cached_dir(p,x,y), p->view.vdir) >= 0.0))\
112 && pict_get_sangle(p,x,y) > 0)
113
114 #endif
115
116 void pict_new_gli(pict* p);
117
118 void pict_update_evalglare_caches(pict* p);
119
120 #endif
121
122 int pict_init(pict* p);
123 pict* pict_create();
124 void pict_free(pict* p);
125
126 pict* pict_get_copy(pict* p);
127
128 void pict_set_comment(pict* p,const char* c);
129
130 int pict_resize(pict* p,int x,int y);
131
132 int pict_zero(pict* p);
133
134 int pict_read(pict* p,char* fn);
135 int pict_read_fp(pict* p,FILE* fp);
136 int pict_read_tt_txt(pict* p,char* fn);
137 int pict_read_from_list(pict* p,FILE* fp);
138 int pict_write(pict* p,char* fn);
139 int pict_write_fp(pict* p,FILE* fp);
140 int pict_write_dir(pict* p,FILE* fp);
141
142 int pict_setup_lut(pict* p,char* theta_fn,char* phi_fn,char* omega_fn);
143 int pict_update_lut(pict* p);
144
145 int pict_update_view(pict* p);
146
147 int pict_get_dir(pict* p,int x,int y,FVECT dir);
148 int pict_get_dir_ic(pict* p,double x,double y,FVECT dir);
149 int pict_get_ray(pict* p,int x,int y,FVECT orig,FVECT dir);
150 int pict_get_ray_ic(pict* p,double x,double y,FVECT orig,FVECT dir);
151 int pict_locate(pict* p,FVECT pt,int* x,int* y);
152 double pict_get_sangle(pict* p,int x,int y);
153
154 int pict_get_vangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a);
155 int pict_get_hangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a);
156 int pict_get_tau(pict* p,double x,double y,FVECT vdir,FVECT vup,double* t);
157 int pict_get_sigma(pict* p,double x,double y,FVECT vdir,FVECT vup,double* s);
158
159 int pict_set_pj(pict* p,double pj);
160 int pict_setorigin(pict* p,FVECT orig);
161 int pict_setdir(pict* p,FVECT dir);
162 int pict_setvtype(pict* p,char vt);
163 int pict_setvup(pict* p,FVECT vup);
164 int pict_sethview(pict* p,double ha);
165 int pict_setvview(pict* p,double va);
166
167 int pict_trans_cam(pict* p,g3ATrans t);
168
169
170
171
172 #ifdef __cplusplus
173 }
174 #endif
175 #endif
