root/radiance/ray/src/util/pictool.c
Revision: 2.8
Committed: Tue Jun 30 15:57:30 2020 UTC (5 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R3, rad6R0, HEAD
Changes since 2.7: +60 -1 lines
feat(evalglare): new version of evalglare from Jan Wienold
2 static const char RCSid[] = "$Id: pictool.c,v 2.5 2018/01/24 04:39:52 greg Exp $";
4 #include "pictool.h"
5 #include "g3sphere.h"
6 #include <math.h>
7 #include "rtio.h"
8
9 #define index strchr
10
11
12
13 int pict_init(pict* p)
14 {
15 p->pic = NULL;
16 p->use_lut = 0;
17 p->lut = NULL;
18 p->pjitter = 0;
19 p->comment[0] = '\0';
20 #ifdef PICT_GLARE
21 p->pinfo = NULL;
22 p->glareinfo = g3fl_create(PICT_GLSIZE);
23 #endif
24 p->valid_view = 1;
25 p->view = stdview;
26 if (!pict_update_view(p))
27 return 0;
28 p->resol.rt = PIXSTANDARD;
29 return pict_resize(p,512,512);
30 }
31
32 void pict_new_gli(pict* p)
33 {
34 int i;
35
36 g3Float* gli;
37 gli = g3fl_append_new(p->glareinfo);
38 for(i=0;i<PICT_GLSIZE;i++)
39 gli[i] = 0.0;
40 }
41
42 void pict_set_comment(pict* p,const char* c)
43 {
44 strcpy(p->comment,c);
45 }
46
47 pict* pict_get_copy(pict* p)
48 {
49 pict* res;
50
51 if (p->use_lut) {
52 fprintf(stderr,"pict_get_copy: can't copy in lut mode");
53 return NULL;
54 }
55 res = pict_create();
56 pict_resize(res,pict_get_xsize(p),pict_get_ysize(p));
57 res->view = p->view;
58 res->resol = p->resol;
59 res->pjitter = p->pjitter;
60 return res;
61 }
62
63 pict* pict_create()
64 {
65 pict* p = (pict*) malloc(sizeof(pict));
66
67 if (!pict_init(p)) {
68 pict_free(p);
69 return NULL;
70 }
71 return p;
72 }
73
74 void pict_free(pict* p)
75 {
76 if (p->pic)
77 free(p->pic);
78 #ifdef PICT_GLARE
79 if (p->pinfo)
80 free(p->pinfo);
81 g3fl_free(p->glareinfo);
82 p->pinfo = NULL;
83 #endif
84 p->pic = NULL;
85 p->lut = NULL;
86 free(p);
87 }
88 static int exp_headline(char* s,void* exparg) {
89 double* exposure;
90 if(strstr(s, EXPOSSTR) != NULL ) {
91 fprintf(stderr,"EXP AND tab\n");
92 }
93
94 exposure = (double*) exparg;
95 if (isexpos(s)) {
96 (*exposure) *= exposval(s);
97 }
98 return 0;
99 }
100
101 static double read_exposure(FILE* fp)
102 {
103 double exposure = 1;
104
105
106 if ((getheader(fp, exp_headline, &exposure)) < 0) {
107 fprintf(stderr,"error reading header\n");
108 return 0;
109 }
110 return exposure;
111 }
112
113 int pict_update_view(pict* p)
114 {
115 char* ret;
116 if ((ret = setview(&(p->view)))) {
117 fprintf(stderr,"pict_update_view: %s\n",ret);
118 return 0;
119 }
120 return 1;
121 }
122
123 int pict_set_pj(pict* p,double pj)
124 {
125 if ((pj < 0) || (pj > 1))
126 fprintf(stderr,"pict_set_pj: warning jitter factor out of range\n");
127 p->pjitter = pj;
128 return 1;
129 }
130
131 int pict_setvup(pict* p,FVECT vup)
132 {
133 VCOPY(p->view.vup,vup);
134 return pict_update_view(p);
135 }
136
137 int pict_trans_cam(pict* p,g3ATrans t)
138 {
139 g3Vec o = g3v_create();
140 g3Vec d = g3v_create();
141 g3Vec u = g3v_create();
142
143 fprintf(stderr,"vdpre %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]);
144 fprintf(stderr,"vupre %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]);
145 g3v_fromrad(o,p->view.vp);
146 g3v_fromrad(d,p->view.vdir);
147 g3v_fromrad(u,p->view.vup);
148
149 g3v_add(d,d,o);
150 g3v_add(u,u,o);
151 g3at_apply(t,o);
152 g3at_apply(t,u);
153 g3at_apply(t,d);
154 g3v_sub(d,d,o);
155 g3v_sub(u,u,o);
156 g3v_torad(p->view.vp,o);
157 g3v_torad(p->view.vdir,d);
158 g3v_torad(p->view.vup,u);
159 fprintf(stderr,"vd %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]);
160 fprintf(stderr,"vu %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]);
161
162 g3v_free(o);
163 g3v_free(d);
164 g3v_free(u);
165 return pict_update_view(p);
166 }
167
168 int pict_resize(pict* p,int x,int y)
169 {
170 p->resol.xr = x;
171 p->resol.yr = y;
172
173 if (!(p->pic = (COLOR*) realloc(p->pic,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) {
174 fprintf(stderr,"Can't alloc picture\n");
175 return 0;
176 }
177 if (pict_lut_used(p)) {
178 if (!(p->lut = (COLOR*) realloc(p->lut,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) {
179 fprintf(stderr,"Can't alloc LUT\n");
180 return 0;
181 }
182 }
183 #ifdef PICT_GLARE
184 if (!(p->pinfo = (pixinfo*)
185 realloc(p->pinfo,(p->resol.xr)*p->resol.yr*sizeof(pixinfo)))) {
186 fprintf(stderr,"Can't alloc picture info\n");
187 return 0;
188 }
189 /* fprintf(stderr,"resize %d %d %d\n",p->resol.xr,p->resol.yr,sizeof(pixinfo));*/
190 #endif
191 return 1;
192 }
193
194
195 int pict_zero(pict* p)
196 {
197 int x,y,i;
198
199 for(x=0;x<pict_get_xsize(p);x++)
200 for(y=0;y<pict_get_ysize(p);y++)
201 for(i=0;i<3;i++)
202 pict_get_color(p,x,y)[i] = 0;
203 return 1;
204 }
205
206 struct hinfo {
207 VIEW *hv;
208 int ok;
209 double exposure;
210 };
211
212
213 static int
214 gethinfo( /* get view from header */
215 char *s,
216 void *v
217 )
218 {
219 if(strstr(s, EXPOSSTR) != NULL && strstr(s, "\t") != NULL) {
220
221 fprintf(stderr,"error: header contains invalid exposure entry!!!!\n");
222 fprintf(stderr,"check exposure and correct header setting !\n");
223
224
225 fprintf(stderr,"stopping !!!!\n");
226 exit(1);
227 }
228 if (isview(s) && sscanview(((struct hinfo*)v)->hv, s) > 0) {
229 ((struct hinfo*)v)->ok++;
230 } else if (isexpos(s)) {
231 /*fprintf(stderr,"readexp %f %f\n",((struct hinfo*)v)->exposure,exposval(s));*/
232 ((struct hinfo*)v)->exposure *= exposval(s);
233 }
234 return(0);
235 }
236
237 int pict_read_fp(pict* p,FILE* fp)
238 {
239 struct hinfo hi;
240 int x,y,yy;
241
242
243 hi.hv = &(p->view);
244 hi.ok = 0;
245 hi.exposure = 1;
246 getheader(fp, gethinfo, &hi);
247 /*fprintf(stderr,"expscale %f\n",hi.exposure);*/
248
249 if (!(pict_update_view(p)) || !(hi.ok))
250 p->valid_view = 0;
251 /* printf("dir %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); */
252 if (fgetsresolu(&(p->resol),fp) < 0) {
253 fprintf(stderr,"No resolution given\n");
254 return 0;
255 }
256 if (!(p->resol.rt & YMAJOR)) {
257 x = p->resol.xr;
258 p->resol.xr = p->resol.yr;
259 p->resol.yr = x;
260 p->resol.rt |= YMAJOR;
261 }
262 if (!pict_resize(p,p->resol.xr,p->resol.yr))
263 return 0;
264 for(yy=0;yy<p->resol.yr;yy++) {
265 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
266 if (freadscan((p->pic + y*p->resol.xr),p->resol.xr,fp) < 0) {
267 fprintf(stderr,"error reading line %d\n",y);
268 return 0;
269 }
270 for(x=0;x<p->resol.xr;x++) {
271 scalecolor(pict_get_color(p,x,y),1.0/hi.exposure);
272 }
273 }
274 #ifdef PICT_GLARE
275 pict_update_evalglare_caches(p);
276 #endif
277 return 1;
278 }
279
280 int pict_read_fp_noupdate(pict* p,FILE* fp)
281 {
282 struct hinfo hi;
283 int x,y,yy;
284
285
286 hi.hv = &(p->view);
287 hi.ok = 0;
288 hi.exposure = 1;
289 getheader(fp, gethinfo, &hi);
290 /*fprintf(stderr,"expscale %f\n",hi.exposure); */
291
292 if (!(pict_update_view(p)) || !(hi.ok))
293 p->valid_view = 0;
294 /* printf("dir %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); */
295 if (fgetsresolu(&(p->resol),fp) < 0) {
296 fprintf(stderr,"No resolution given\n");
297 return 0;
298 }
299 if (!(p->resol.rt & YMAJOR)) {
300 x = p->resol.xr;
301 p->resol.xr = p->resol.yr;
302 p->resol.yr = x;
303 p->resol.rt |= YMAJOR;
304 }
305 if (!pict_resize(p,p->resol.xr,p->resol.yr))
306 return 0;
307 for(yy=0;yy<p->resol.yr;yy++) {
308 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
309 if (freadscan((p->pic + y*p->resol.xr),p->resol.xr,fp) < 0) {
310 fprintf(stderr,"error reading line %d\n",y);
311 return 0;
312 }
313 for(x=0;x<p->resol.xr;x++) {
314 scalecolor(pict_get_color(p,x,y),1.0/hi.exposure);
315 }
316 }
317 return 1;
318 }
319
320
321
322
323 #ifdef PICT_GLARE
324 void pict_update_evalglare_caches(pict* p)
325 {
326 int x,y,yy;
327 float lum;
328 for(yy=0;yy<p->resol.yr;yy++) {
329 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
330 for(x=0;x<p->resol.xr;x++) {
331 pict_get_omega(p,x,y) = pict_get_sangle(p,x,y);
332 pict_get_dir(p,x,y,pict_get_cached_dir(p,x,y));
333 pict_get_gsn(p,x,y) = 0;
334 pict_get_pgs(p,x,y) = 0;
335 /* make picture grey */
336 lum=luminance(pict_get_color(p,x,y))/179.0;
337 pict_get_color(p,x,y)[RED]=lum;
338 pict_get_color(p,x,y)[GRN]=lum;
339 pict_get_color(p,x,y)[BLU]=lum;
340 }
341 }
342 }
343
344 #endif
345
346 int pict_read(pict* p,char* fn)
347 {
348 FILE* fp;
349
350 if (!(fp = fopen(fn,"rb"))) {
351 fprintf(stderr,"Can't open %s\n",fn);
352 return 0;
353 }
354 if (!(pict_read_fp(p,fp)))
355 return 0;
356 fclose(fp);
357 return 1;
358 }
359
360 int pict_read_noupdate(pict* p,char* fn)
361 {
362 FILE* fp;
363
364 if (!(fp = fopen(fn,"rb"))) {
365 fprintf(stderr,"Can't open %s\n",fn);
366 return 0;
367 }
368 if (!(pict_read_fp_noupdate(p,fp)))
369 return 0;
370 fclose(fp);
371 return 1;
372 }
373
374
375
376 static void ch_pct(char* line)
377 {
378 char* pct;
379
380 while ((pct = index(line,',')))
381 *pct = '.';
382 }
383
384 char* nextline(FILE* fp)
385 {
386 static char* line = NULL;
387 static int lsize = 500;
388 int done;
389 long fpos;
390
391 if (!line) {
392 if (!(line = (char*) malloc((lsize + 1)*sizeof(char)))) {
393 fprintf(stderr,"allocation problem in nextline\n");
394 return NULL;
395 }
396 }
397 done = 0;
398 fpos = ftell(fp);
399 while(!done) {
400 if (!fgets(line,lsize,fp))
401 return NULL;
402 if (!index(line,'\n')) {
403 lsize *= 2;
404 if (!(line = (char*) realloc(line,(lsize + 1)*sizeof(char)))) {
405 fprintf(stderr,"allocation problem in nextline\n");
406 return NULL;
407 }
408 fseek(fp,fpos,SEEK_SET);
409 } else {
410 done = 1;
411 }
412 }
413 return line;
414 }
415
416 static int read_tt_txt(pict* p,int bufsel,int channel,char* fn)
417 {
418 FILE* fp;
419 char* line = NULL;
420 int x,y,vsize,hsize;
421 float* col;
422 float c;
423 char* curr;
424 char** endp;
425 COLOR* picbuf;
426
427 if (!(fp = fopen(fn,"r"))) {
428 fprintf(stderr,"pict_read_tt_txt: Can't open file %s\n",fn);
429 return 0;
430 }
431 if (!(line = nextline(fp))) {
432 fprintf(stderr,"pict_read_tt_txt: reading from file failed\n");
433 return 0;
434 }
435 if (strncmp(line,"float",strlen("float"))) {
436 fprintf(stderr,"pict_read_tt_txt: Unexpected format\n");
437 return 0;
438 }
439 if (!(line = nextline(fp))) {
440 fprintf(stderr,"pict_read_tt_txt: reading from file failed\n");
441 return 0;
442 }
443 sscanf(line,"%d %d %d %d",&x,&vsize,&y,&hsize);
444 vsize = vsize - x;
445 hsize = hsize - y;
446 if (!pict_resize(p,vsize,hsize))
447 return 0;
448 endp = malloc(sizeof(char*));
449 picbuf = (bufsel == PICT_LUT) ? p->lut : p->pic;
450 for(x=0;x<vsize;x++) {
451 if (!(line = nextline(fp))) {
452 fprintf(stderr,"pict_read_tt_txt: too few lines %d of %d\n",x,vsize);
453 free(endp);
454 return 0;
455 }
456 ch_pct(line);
457 curr = line;
458 for(y=0;y<hsize;y++) {
459 col = pict_colbuf(p,picbuf,x,y);
460 c = strtod(curr,endp);
461 if (channel & PICT_CH1)
462 col[0] = c;
463 if (channel & PICT_CH2)
464 col[1] = c;
465 if (channel & PICT_CH3)
466 col[2] = c;
467 if (curr == (*endp)) {
468 fprintf(stderr,"pict_read_tt_txt: too few values in line %d\n",x);
469 free(endp);
470 return 0;
471 }
472 curr = (*endp);
473 }
474 }
475 free(endp);
476 return 1;
477 }
478
479 int pict_read_tt_txt(pict* p,char* fn)
480 {
481 return read_tt_txt(p,PICT_VIEW,PICT_ALLCH,fn);
482 }
483
484 int pict_setup_lut(pict* p,char* theta_fn,char* phi_fn,char* omega_fn)
485 {
486 int xs,ys;
487
488 p->use_lut = 1;
489 if (!read_tt_txt(p,PICT_LUT,PICT_CH1,theta_fn)) {
490 fprintf(stderr,"pict_setup_lut: error reading theta file\n");
491 p->use_lut = 0;
492 return 0;
493 }
494 xs = pict_get_xsize(p);
495 ys = pict_get_ysize(p);
496 if (!read_tt_txt(p,PICT_LUT,PICT_CH2,phi_fn)) {
497 fprintf(stderr,"pict_setup_lut: error reading phi file\n");
498 p->use_lut = 0;
499 return 0;
500 }
501 if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) {
502 fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n");
503 p->use_lut = 0;
504 return 0;
505 }
506 if (!read_tt_txt(p,PICT_LUT,PICT_CH3,omega_fn)) {
507 fprintf(stderr,"pict_setup_lut: error reading omega file\n");
508 p->use_lut = 0;
509 return 0;
510 }
511 if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) {
512 fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n");
513 p->use_lut = 0;
514 return 0;
515 }
516 return 1;
517 }
518
519 int pict_update_lut(pict* p)
520 {
521 g3ATrans transf;
522 g3Vec d;
523 g3Vec u;
524 int x,y;
525
526 d = g3v_fromrad(g3v_create(),p->view.vdir);
527 u = g3v_fromrad(g3v_create(),p->view.vup);
528 g3at_ctrans(transf,d,u);
529 for(x=0;x<p->resol.xr;x++) {
530 for(y=0;y<p->resol.yr;y++) {
531 d[G3S_RAD] = 1.0;
532 d[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]);
533 d[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]);
534 g3s_sphtocc(d,d);
535 g3at_apply(transf,d);
536 g3s_cctosph(d,d);
537 pict_colbuf(p,p->lut,x,y)[0] = RAD2DEG(d[G3S_THETA]);
538 pict_colbuf(p,p->lut,x,y)[1] = RAD2DEG(d[G3S_PHI]);
539 }
540 }
541 g3v_free(d);
542 g3v_free(u);
543 return 1;
544 }
545
546
547 int pict_write_dir(pict* p,FILE* fp)
548 {
549 int x,y;
550 FVECT dir,orig;
551
552 for(y=0;y<p->resol.yr;y++) {
553 for(x=0;x<p->resol.xr;x++) {
554 if (!(pict_get_ray(p,x,y,orig,dir))) {
555 fprintf(fp,"%f %f %f 0.0 0.0 0.0\n",orig[0],orig[1],orig[2]);
556 } else {
557 fprintf(fp,"%f %f %f %f %f %f\n",orig[0],orig[1],orig[2],dir[0],dir[1],dir[2]);
558 }
559 }
560 }
561 return 1;
562 }
563
564 int pict_read_from_list(pict* p,FILE* fp)
565 {
566 int x,y,sz;
567 char ln[1024];
568 double val;
569
570 sz = 0;
571 for(y=0;y<p->resol.yr;y++) {
572 for(x=0;x<p->resol.xr;x++) {
573 if (!(fgets(ln,1023,fp))) {
574 fprintf(stderr,"pict_read_from_list: Read only %d values\n",sz);
575 return 0;
576 }
577 if (sscanf(ln,"%lg",&val) != 1) {
578 fprintf(stderr,"pict_read_from_list: errline %d\n",sz);
579 } else {
580 sz++;
581 setcolor(pict_get_color(p,x,y),val,val,val);
582 }
583 }
584 }
585 return 1;
586 }
587
588 int pict_write(pict* p,char* fn)
589 {
590 FILE* fp;
591
592 if (!(fp = fopen(fn,"wb"))) {
593 fprintf(stderr,"Can't open %s for writing\n",fn);
594 return 0;
595 }
596 if (!(pict_write_fp(p,fp))) {
597 fclose(fp);
598 return 0;
599 }
600 fclose(fp);
601 return 1;
602 }
603
604 int pict_write_fp(pict* p,FILE* fp)
605 {
606 char res[100];
607 int y,yy;
608 newheader("RADIANCE",fp);
609 fputnow(fp);
610 if (strlen(p->comment) > 0)
611 fputs(p->comment,fp);
612 fputs(VIEWSTR, fp);
613 fprintview(&(p->view), fp);
614 fprintf(fp,"\n");
615 fputformat(COLRFMT,fp);
616 fprintf(fp,"\n");
617
618 resolu2str(res,&(p->resol));
619 fprintf(fp,"%s",res);
620 for(y=0;y<p->resol.yr;y++) {
621 yy = (p->resol.rt & YDECR) ? p->resol.yr - 1 - y : y;
622 if (fwritescan((p->pic + yy*p->resol.xr),p->resol.xr,fp) < 0) {
623 fprintf(stderr,"writing pic-file failed\n");
624 return 0;
625 }
626 }
627 return 1;
628 }
629
630 int pict_get_dir(pict* p,int x,int y,FVECT dir)
631 {
632 FVECT orig;
633 if (pict_lut_used(p)) {
634 if (!(p->lut)) {
635 fprintf(stderr,"pict_get_dir: no lut defined\n");
636 return 0;
637 }
638 dir[G3S_RAD] = 1.0;
639 dir[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]);
640 dir[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]);
641 g3s_sphtocc(dir,dir);
642 return 1;
643 }
644 return pict_get_ray(p,x,y,orig,dir);
645 }
646
647 int pict_get_dir_ic(pict* p,double x,double y,FVECT dir)
648 {
649 FVECT orig;
650 if (pict_lut_used(p)) {
651 int res[2];
652 loc2pix(res,&(p->resol),x,y);
653 return pict_get_dir(p,res[0],res[1],dir);
654 }
655 return pict_get_ray_ic(p,x,y,orig,dir);
656 }
657
658 int pict_get_ray(pict* p,int x,int y,FVECT orig,FVECT dir)
659 {
660 RREAL pc[2];
661
662 pix2loc(pc,&(p->resol),x,p->resol.yr - 1 - y);
663 if (pict_lut_used(p)) {
664 if (viewray(orig,dir,&(p->view),pc[0],pc[1]) <= 0)
665 return 0;
666 return pict_get_dir(p,x,y,dir);
667 }
668 return pict_get_ray_ic(p,pc[0],pc[1],orig,dir);
669 }
670
671 int pict_get_ray_ic(pict* p,double x,double y,FVECT orig,FVECT dir)
672 {
673 if (pict_lut_used(p)) {
674 int res[2];
675 loc2pix(res,&(p->resol),x,y);
676 return pict_get_ray(p,res[0],res[1],orig,dir);
677 }
678 x = (x + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.xr);
679 y = (y + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.yr);
680 if (viewray(orig,dir,&(p->view),x,y) < 0)
681 return 0;
682 return 1;
683 }
684
685
686 static int splane_normal(pict* p,double e1x,double e1y,
687 double e2x,double e2y,FVECT n)
688 {
689 FVECT e1 = {0,0,0};
690 FVECT e2 = {0,0,0};
691
692 pict_get_dir_ic(p,e1x,e1y,e1);
693 pict_get_dir_ic(p,e2x,e2y,n);
694 VSUB(e2,n,e1);
695 VCROSS(n,e1,e2);
696 if (normalize(n) == 0.0) {
697 return 0;
698 }
699 return 1;
700 }
701
702 double pict_get_sangle(pict* p,int x,int y)
703 {
704 int i;
705 double ang,a,hpx,hpy;
706 RREAL pc[2];
707 FVECT n[4] = {{0,0,0},{0,0,0},{0,0,0},{0,0,0}};
708
709 if (pict_lut_used(p)) {
710 return pict_colbuf(p,p->lut,x,y)[2];
711 }
712 pix2loc(pc,&(p->resol),x,y);
713 hpx = (0.5/p->resol.xr);
714 hpy = (0.5/p->resol.yr);
715 pc[0] -= hpx;
716 pc[1] -= hpy;
717
718 i = splane_normal(p,pc[0],pc[1],pc[0],(pc[1]+2.0*hpy),n[0]);
719 i &= splane_normal(p,pc[0],(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),n[1]);
720 i &= splane_normal(p,(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),pc[1],n[2]);
721 i &= splane_normal(p,(pc[0]+2.0*hpx),pc[1],pc[0],pc[1],n[3]);
722
723 if (!i) {
724 return 0;
725 }
726 ang = 0;
727 for(i=0;i<4;i++) {
728 a = DOT(n[i],n[(i+1)%4]);
729 a = acos(a);
730 a = fabs(a);
731 ang += M_PI - a;
732 }
733 ang = ang - 2.0*M_PI;
734 if ((ang > (2.0*M_PI)) || ang < 0) {
735 fprintf(stderr,"Normal error in pict_get_sangle %f %d %d\n",ang,x,y);
736 return -1.0;
737 }
738 return ang;
739 }
740
741 int pict_locate(pict* p,FVECT pt,int* x,int* y)
742 {
743 FVECT pp;
744 int res[2];
745
746 if (pict_lut_used(p)) {
747 fprintf(stderr,"pict_locate: Not implemented for lut mode\n");
748 return 0;
749 }
750
751 if (viewloc(pp,&(p->view),pt) != VL_GOOD)
752 return 0;
753 loc2pix(res,&(p->resol),pp[0],pp[1]);
754 *x = res[0];
755 *y = res[1];
756 return 1;
757 }
758
759 int pict_get_sigma(pict* p,double x,double y,FVECT vdir,FVECT vup,double* s)
760 {
761 FVECT pvdir;
762
763 if (!pict_get_dir(p,x,y,pvdir))
764 return 0;
765 if (normalize(vdir) == 0.0) {
766 fprintf(stderr,"get_sigma: view dir is zero\n");
767 return 0;
768 }
769 if (normalize(vup) == 0.0) {
770 fprintf(stderr,"get_sigma: view up is zero\n");
771 return 0;
772 }
773 *s = acos(DOT(vdir,pvdir));
774 return 1;
775 }
776
777 int pict_get_tau(pict* p,double x,double y,FVECT vdir,FVECT vup,double* t)
778 {
779 FVECT hv,pvdir;
780 double s;
781 int i;
782 if (!pict_get_sigma(p,x,y,vdir,vup,&s))
783 return 0;
784 if (!pict_get_dir(p,x,y,pvdir))
785 return 0;
786 VCOPY(hv,pvdir);
787 normalize(hv);
788 for(i=0;i<3;i++){
789 hv[i] /= cos(s);
790 }
791 VSUB(hv,hv,vdir);
792 normalize(hv);
793 *t = acos(fdot(vup,hv));
794 return 1;
795 }
796
797 static int ortho_coord(FVECT vdir,FVECT vup,FVECT vv,FVECT hv)
798 {
799 if (normalize(vdir) == 0.0) {
800 fprintf(stderr,"ortho_coord: view direction is zero\n");
801 return 0;
802 }
803 if (normalize(vup) == 0.0) {
804 fprintf(stderr,"ortho_coord: view direction is zero\n");
805 return 0;
806 }
807 fcross(hv,vdir,vup);
808 fcross(vv,vdir,hv);
809 return 1;
810 }
811
812 int pict_get_vangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a)
813 {
814 FVECT hv,vv,pvdir;
815 if (!ortho_coord(vdir,vup,vv,hv)) {
816 return 0;
817 }
818 if (!pict_get_dir(p,x,y,pvdir))
819 return 0;
820 *a = acos(fdot(vv,pvdir)) - (M_PI/2.0) ;
821 return 1;
822 }
823
824 int pict_get_hangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a)
825 {
826 FVECT hv,vv,pvdir;
827 if (!ortho_coord(vdir,vup,vv,hv)) {
828 return 0;
829 }
830 if (!pict_get_dir(p,x,y,pvdir)) {
831 return 0;
832 }
833 *a = ((M_PI/2.0) - acos(fdot(hv,pvdir)));
834 return 1;
835 }
836
837 int pict_setorigin(pict* p,FVECT orig)
838 {
839 VCOPY(p->view.vp,orig);
840 return pict_update_view(p);
841 }
842
843 int pict_setdir(pict* p,FVECT dir)
844 {
845 VCOPY(p->view.vdir,dir);
846 return pict_update_view(p);
847 }
848
849 int pict_sethview(pict* p,double ha)
850 {
851 p->view.horiz = ha;
852 return pict_update_view(p);
853 }
854
855 int pict_setvview(pict* p,double va)
856 {
857 p->view.vert = va;
858 return pict_update_view(p);
859 }
860
861 int pict_setvtype(pict* p,char vt)
862 {
863 p->view.type = vt;
864 return pict_update_view(p);
865 }
866
867 #ifdef TEST_PICTTOOL
868
869 char* progname = "pictool";
870
871 int main(int argc,char** argv)
872 {
873 pict* p = pict_create();
874 FVECT dir = {0,-1,0};
875 FVECT vdir,edir;
876 FVECT up = {0,0,1};
877 int x,y,i;
878 double sang,h,v;
879
880 if (argc < 2) {
881 fprintf(stderr,"usage: %s <pic-file>\n",argv[0]);
882 return EXIT_FAILURE;
883 }
884 fprintf(stderr,"readdd\n");
885 pict_read(p,argv[1]);
886 pict_set_comment(p,"pictool test output\n");
887 /*
888 pict_get_dir(p,100,100,edir); // YDECR
889 for(y=0;y<p->resol.yr;y++) {
890 for(x=0;x<p->resol.xr;x++) {
891 pict_get_hangle(p,x,y,dir,up,&h);
892 pict_get_vangle(p,x,y,dir,up,&v);
893 pict_get_dir(p,x,y,vdir);
894 if (acos(DOT(vdir,edir)) < DEG2RAD(3))
895 setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,1);
896 else
897 setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,0);
898 }
899 }
900 */
901 printf("resolution: %dx%d\n",pict_get_xsize(p),pict_get_ysize(p));
902 sang = 0.0;
903
904 pict_new_gli(p);
905 for(x=0;x<pict_get_xsize(p);x++)
906 for(y=0;y<pict_get_ysize(p);y++) {
907 pict_get_dir(p,x,y,dir);
908 if (DOT(dir,p->view.vdir) >= 0.0) {
909 pict_get_av_omega(p,0) += pict_get_omega(p,x,y);
910 }
911 sang = pict_get_sangle(p,x,y);
912 for(i=0;i<3;i++)
913 if (sang <= 0 && pict_is_validpixel(p,x,y)) {
914 pict_get_color(p,x,y)[i] = 1;
915 } else {
916 pict_get_color(p,x,y)[i] =0;
917 }
918 }
919 printf("s %f\n",pict_get_av_omega(p,0));
920 pict_write(p,"test.pic");
921 while(1) {
922 printf("pos\n");
923 if (scanf("%d %d",&x,&y) != 2)
924 continue;
925 pict_get_dir(p,x,y,dir);
926 printf("dir: \t\t %f %f %f\n",dir[0],dir[1],dir[2]);
927 printf("solid angle: \t %f \n",pict_get_sangle(p,x,y));
928 }
929 return EXIT_SUCCESS;
930 }
931
932 #endif
