root/radiance/ray/src/util/pictool.c
Revision: 2.3
Committed: Thu Jul 14 17:32:12 2016 UTC (9 years ago) by greg
Changes since 2.2: +9 -0 lines
Changes to evalglare by Jan Wienold
4 #include "pictool.h"
5 #include "g3sphere.h"
6 #include <math.h>
7 #include <string.h>
8
9 #define index strchr
10
11
12
13 int pict_init(pict* p)
14 {
15 p->pic = NULL;
16 p->use_lut = 0;
17 p->lut = NULL;
18 p->pjitter = 0;
19 p->comment[0] = '\0';
20 #ifdef PICT_GLARE
21 p->pinfo = NULL;
22 p->glareinfo = g3fl_create(PICT_GLSIZE);
23 #endif
24 p->valid_view = 1;
25 p->view = stdview;
26 if (!pict_update_view(p))
27 return 0;
28 p->resol.rt = PIXSTANDARD;
29 return pict_resize(p,512,512);
30 }
31
32 void pict_new_gli(pict* p)
33 {
34 int i;
35
36 g3Float* gli;
37 gli = g3fl_append_new(p->glareinfo);
38 for(i=0;i<PICT_GLSIZE;i++)
39 gli[i] = 0.0;
40 }
41
42 void pict_set_comment(pict* p,const char* c)
43 {
44 strcpy(p->comment,c);
45 }
46
47 pict* pict_get_copy(pict* p)
48 {
49 pict* res;
50
51 if (p->use_lut) {
52 fprintf(stderr,"pict_get_copy: can't copy in lut mode");
53 return NULL;
54 }
55 res = pict_create();
56 pict_resize(res,pict_get_xsize(p),pict_get_ysize(p));
57 res->view = p->view;
58 res->resol = p->resol;
59 res->pjitter = p->pjitter;
60 return res;
61 }
62
63 pict* pict_create()
64 {
65 pict* p = (pict*) malloc(sizeof(pict));
66
67 if (!pict_init(p)) {
68 pict_free(p);
69 return NULL;
70 }
71 return p;
72 }
73
74 void pict_free(pict* p)
75 {
76 if (p->pic)
77 free(p->pic);
78 #ifdef PICT_GLARE
79 if (p->pinfo)
80 free(p->pinfo);
81 g3fl_free(p->glareinfo);
82 p->pinfo = NULL;
83 #endif
84 p->pic = NULL;
85 p->lut = NULL;
86 free(p);
87 }
88 static int exp_headline(char* s,void* exparg) {
89 double* exposure;
90 if(strstr(s, EXPOSSTR) != NULL ) {
91 fprintf(stderr,"EXP AND tab\n");
92 }
93
94 exposure = (double*) exparg;
95 if (isexpos(s)) {
96 (*exposure) *= exposval(s);
97 }
98 return 0;
99 }
100
101 static double read_exposure(FILE* fp)
102 {
103 double exposure = 1;
104
105
106 if ((getheader(fp, exp_headline, &exposure)) < 0) {
107 fprintf(stderr,"error reading header\n");
108 return 0;
109 }
110 return exposure;
111 }
112
113 int pict_update_view(pict* p)
114 {
115 char* ret;
116 if ((ret = setview(&(p->view)))) {
117 fprintf(stderr,"pict_update_view: %s\n",ret);
118 return 0;
119 }
120 return 1;
121 }
122
123 int pict_set_pj(pict* p,double pj)
124 {
125 if ((pj < 0) || (pj > 1))
126 fprintf(stderr,"pict_set_pj: warning jitter factor out of range\n");
127 p->pjitter = pj;
128 return 1;
129 }
130
131 int pict_setvup(pict* p,FVECT vup)
132 {
133 VCOPY(p->view.vup,vup);
134 return pict_update_view(p);
135 }
136
137 int pict_trans_cam(pict* p,g3ATrans t)
138 {
139 g3Vec o = g3v_create();
140 g3Vec d = g3v_create();
141 g3Vec u = g3v_create();
142
143 fprintf(stderr,"vdpre %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]);
144 fprintf(stderr,"vupre %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]);
145 g3v_fromrad(o,p->view.vp);
146 g3v_fromrad(d,p->view.vdir);
147 g3v_fromrad(u,p->view.vup);
148
149 g3v_add(d,d,o);
150 g3v_add(u,u,o);
151 g3at_apply(t,o);
152 g3at_apply(t,u);
153 g3at_apply(t,d);
154 g3v_sub(d,d,o);
155 g3v_sub(u,u,o);
156 g3v_torad(p->view.vp,o);
157 g3v_torad(p->view.vdir,d);
158 g3v_torad(p->view.vup,u);
159 fprintf(stderr,"vd %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]);
160 fprintf(stderr,"vu %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]);
161
162 g3v_free(o);
163 g3v_free(d);
164 g3v_free(u);
165 return pict_update_view(p);
166 }
167
168 int pict_resize(pict* p,int x,int y)
169 {
170 p->resol.xr = x;
171 p->resol.yr = y;
172
173 if (!(p->pic = (COLOR*) realloc(p->pic,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) {
174 fprintf(stderr,"Can't alloc picture\n");
175 return 0;
176 }
177 if (pict_lut_used(p)) {
178 if (!(p->lut = (COLOR*) realloc(p->lut,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) {
179 fprintf(stderr,"Can't alloc LUT\n");
180 return 0;
181 }
182 }
183 #ifdef PICT_GLARE
184 if (!(p->pinfo = (pixinfo*)
185 realloc(p->pinfo,(p->resol.xr)*p->resol.yr*sizeof(pixinfo)))) {
186 fprintf(stderr,"Can't alloc picture info\n");
187 return 0;
188 }
189 /* fprintf(stderr,"resize %d %d %d\n",p->resol.xr,p->resol.yr,sizeof(pixinfo));*/
190 #endif
191 return 1;
192 }
193
194
195 int pict_zero(pict* p)
196 {
197 int x,y,i;
198
199 for(x=0;x<pict_get_xsize(p);x++)
200 for(y=0;y<pict_get_ysize(p);y++)
201 for(i=0;i<3;i++)
202 pict_get_color(p,x,y)[i] = 0;
203 return 1;
204 }
205
206 struct hinfo {
207 VIEW *hv;
208 int ok;
209 double exposure;
210 };
211
212
213 static int
214 gethinfo( /* get view from header */
215 char *s,
216 void *v
217 )
218 {
219 if(strstr(s, EXPOSSTR) != NULL && strstr(s, "\t") != NULL) {
220 fprintf(stderr,"error: header contains invalid exposure !!!!\n");
221 fprintf(stderr,"check exposure and remove tab !\n");
222 fprintf(stderr,"stopping !!!!\n");
223 exit(1);
224 }
225 if (isview(s) && sscanview(((struct hinfo*)v)->hv, s) > 0) {
226 ((struct hinfo*)v)->ok++;
227 } else if (isexpos(s)) {
228 /*fprintf(stderr,"readexp %f %f\n",((struct hinfo*)v)->exposure,exposval(s));*/
229 ((struct hinfo*)v)->exposure *= exposval(s);
230 }
231 return(0);
232 }
233
234 int pict_read_fp(pict* p,FILE* fp)
235 {
236 struct hinfo hi;
237 int x,y,yy;
238
239
240 hi.hv = &(p->view);
241 hi.ok = 0;
242 hi.exposure = 1;
243 getheader(fp, gethinfo, &hi);
244 /*fprintf(stderr,"expscale %f\n",hi.exposure);*/
245
246 if (!(pict_update_view(p)) || !(hi.ok))
247 p->valid_view = 0;
248 /* printf("dir %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); */
249 if (fgetsresolu(&(p->resol),fp) < 0) {
250 fprintf(stderr,"No resolution given\n");
251 return 0;
252 }
253 if (!(p->resol.rt & YMAJOR)) {
254 x = p->resol.xr;
255 p->resol.xr = p->resol.yr;
256 p->resol.yr = x;
257 p->resol.rt |= YMAJOR;
258 }
259 if (!pict_resize(p,p->resol.xr,p->resol.yr))
260 return 0;
261 for(yy=0;yy<p->resol.yr;yy++) {
262 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
263 if (freadscan((p->pic + y*p->resol.xr),p->resol.xr,fp) < 0) {
264 fprintf(stderr,"error reading line %d\n",y);
265 return 0;
266 }
267 for(x=0;x<p->resol.xr;x++) {
268 scalecolor(pict_get_color(p,x,y),1.0/hi.exposure);
269 }
270 }
271 #ifdef PICT_GLARE
272 pict_update_evalglare_caches(p);
273 #endif
274 return 1;
275 }
276
277 #ifdef PICT_GLARE
278 void pict_update_evalglare_caches(pict* p)
279 {
280 int x,y,yy;
281 float lum;
282 for(yy=0;yy<p->resol.yr;yy++) {
283 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
284 for(x=0;x<p->resol.xr;x++) {
285 pict_get_omega(p,x,y) = pict_get_sangle(p,x,y);
286 pict_get_dir(p,x,y,pict_get_cached_dir(p,x,y));
287 pict_get_gsn(p,x,y) = 0;
288 pict_get_pgs(p,x,y) = 0;
289 /* make picture grey */
290 lum=luminance(pict_get_color(p,x,y))/179.0;
291 pict_get_color(p,x,y)[RED]=lum;
292 pict_get_color(p,x,y)[GRN]=lum;
293 pict_get_color(p,x,y)[BLU]=lum;
294 }
295 }
296 }
297
298 #endif
299
300 int pict_read(pict* p,char* fn)
301 {
302 FILE* fp;
303
304 if (!(fp = fopen(fn,"rb"))) {
305 fprintf(stderr,"Can't open %s\n",fn);
306 return 0;
307 }
308 if (!(pict_read_fp(p,fp)))
309 return 0;
310 fclose(fp);
311 return 1;
312 }
313
314 static void ch_pct(char* line)
315 {
316 char* pct;
317
318 while ((pct = index(line,',')))
319 *pct = '.';
320 }
321
322 char* nextline(FILE* fp)
323 {
324 static char* line = NULL;
325 static int lsize = 500;
326 int done;
327 long fpos;
328
329 if (!line) {
330 if (!(line = (char*) malloc((lsize + 1)*sizeof(char)))) {
331 fprintf(stderr,"allocation problem in nextline\n");
332 return NULL;
333 }
334 }
335 done = 0;
336 fpos = ftell(fp);
337 while(!done) {
338 if (!fgets(line,lsize,fp))
339 return NULL;
340 if (!index(line,'\n')) {
341 lsize *= 2;
342 if (!(line = (char*) realloc(line,(lsize + 1)*sizeof(char)))) {
343 fprintf(stderr,"allocation problem in nextline\n");
344 return NULL;
345 }
346 fseek(fp,fpos,SEEK_SET);
347 } else {
348 done = 1;
349 }
350 }
351 return line;
352 }
353
354 static int read_tt_txt(pict* p,int bufsel,int channel,char* fn)
355 {
356 FILE* fp;
357 char* line = NULL;
358 int x,y,vsize,hsize;
359 float* col;
360 float c;
361 char* curr;
362 char** endp;
363 COLOR* picbuf;
364
365 if (!(fp = fopen(fn,"r"))) {
366 fprintf(stderr,"pict_read_tt_txt: Can't open file %s\n",fn);
367 return 0;
368 }
369 if (!(line = nextline(fp))) {
370 fprintf(stderr,"pict_read_tt_txt: reading from file failed\n");
371 return 0;
372 }
373 if (strncmp(line,"float",strlen("float"))) {
374 fprintf(stderr,"pict_read_tt_txt: Unexpected format\n");
375 return 0;
376 }
377 if (!(line = nextline(fp))) {
378 fprintf(stderr,"pict_read_tt_txt: reading from file failed\n");
379 return 0;
380 }
381 sscanf(line,"%d %d %d %d",&x,&vsize,&y,&hsize);
382 vsize = vsize - x;
383 hsize = hsize - y;
384 if (!pict_resize(p,vsize,hsize))
385 return 0;
386 endp = malloc(sizeof(char*));
387 picbuf = (bufsel == PICT_LUT) ? p->lut : p->pic;
388 for(x=0;x<vsize;x++) {
389 if (!(line = nextline(fp))) {
390 fprintf(stderr,"pict_read_tt_txt: too few lines %d of %d\n",x,vsize);
391 free(endp);
392 return 0;
393 }
394 ch_pct(line);
395 curr = line;
396 for(y=0;y<hsize;y++) {
397 col = pict_colbuf(p,picbuf,x,y);
398 c = strtod(curr,endp);
399 if (channel & PICT_CH1)
400 col[0] = c;
401 if (channel & PICT_CH2)
402 col[1] = c;
403 if (channel & PICT_CH3)
404 col[2] = c;
405 if (curr == (*endp)) {
406 fprintf(stderr,"pict_read_tt_txt: too few values in line %d\n",x);
407 free(endp);
408 return 0;
409 }
410 curr = (*endp);
411 }
412 }
413 free(endp);
414 return 1;
415 }
416
417 int pict_read_tt_txt(pict* p,char* fn)
418 {
419 return read_tt_txt(p,PICT_VIEW,PICT_ALLCH,fn);
420 }
421
422 int pict_setup_lut(pict* p,char* theta_fn,char* phi_fn,char* omega_fn)
423 {
424 int xs,ys;
425
426 p->use_lut = 1;
427 if (!read_tt_txt(p,PICT_LUT,PICT_CH1,theta_fn)) {
428 fprintf(stderr,"pict_setup_lut: error reading theta file\n");
429 p->use_lut = 0;
430 return 0;
431 }
432 xs = pict_get_xsize(p);
433 ys = pict_get_ysize(p);
434 if (!read_tt_txt(p,PICT_LUT,PICT_CH2,phi_fn)) {
435 fprintf(stderr,"pict_setup_lut: error reading phi file\n");
436 p->use_lut = 0;
437 return 0;
438 }
439 if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) {
440 fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n");
441 p->use_lut = 0;
442 return 0;
443 }
444 if (!read_tt_txt(p,PICT_LUT,PICT_CH3,omega_fn)) {
445 fprintf(stderr,"pict_setup_lut: error reading omega file\n");
446 p->use_lut = 0;
447 return 0;
448 }
449 if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) {
450 fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n");
451 p->use_lut = 0;
452 return 0;
453 }
454 return 1;
455 }
456
457 int pict_update_lut(pict* p)
458 {
459 g3ATrans transf;
460 g3Vec d;
461 g3Vec u;
462 int x,y;
463
464 d = g3v_fromrad(g3v_create(),p->view.vdir);
465 u = g3v_fromrad(g3v_create(),p->view.vup);
466 g3at_ctrans(transf,d,u);
467 for(x=0;x<p->resol.xr;x++) {
468 for(y=0;y<p->resol.yr;y++) {
469 d[G3S_RAD] = 1.0;
470 d[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]);
471 d[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]);
472 g3s_sphtocc(d,d);
473 g3at_apply(transf,d);
474 g3s_cctosph(d,d);
475 pict_colbuf(p,p->lut,x,y)[0] = RAD2DEG(d[G3S_THETA]);
476 pict_colbuf(p,p->lut,x,y)[1] = RAD2DEG(d[G3S_PHI]);
477 }
478 }
479 g3v_free(d);
480 g3v_free(u);
481 return 1;
482 }
483
484
485 int pict_write_dir(pict* p,FILE* fp)
486 {
487 int x,y;
488 FVECT dir,orig;
489
490 for(y=0;y<p->resol.yr;y++) {
491 for(x=0;x<p->resol.xr;x++) {
492 if (!(pict_get_ray(p,x,y,orig,dir))) {
493 fprintf(fp,"%f %f %f 0.0 0.0 0.0\n",orig[0],orig[1],orig[2]);
494 } else {
495 fprintf(fp,"%f %f %f %f %f %f\n",orig[0],orig[1],orig[2],dir[0],dir[1],dir[2]);
496 }
497 }
498 }
499 return 1;
500 }
501
502 int pict_read_from_list(pict* p,FILE* fp)
503 {
504 int x,y,sz;
505 char ln[1024];
506 double val;
507
508 sz = 0;
509 for(y=0;y<p->resol.yr;y++) {
510 for(x=0;x<p->resol.xr;x++) {
511 if (!(fgets(ln,1023,fp))) {
512 fprintf(stderr,"pict_read_from_list: Read only %d values\n",sz);
513 return 0;
514 }
515 if (sscanf(ln,"%lg",&val) != 1) {
516 fprintf(stderr,"pict_read_from_list: errline %d\n",sz);
517 } else {
518 sz++;
519 setcolor(pict_get_color(p,x,y),val,val,val);
520 }
521 }
522 }
523 return 1;
524 }
525
526 int pict_write(pict* p,char* fn)
527 {
528 FILE* fp;
529
530 if (!(fp = fopen(fn,"wb"))) {
531 fprintf(stderr,"Can't open %s for writing\n",fn);
532 return 0;
533 }
534 if (!(pict_write_fp(p,fp))) {
535 fclose(fp);
536 return 0;
537 }
538 fclose(fp);
539 return 1;
540 }
541
542 int pict_write_fp(pict* p,FILE* fp)
543 {
544 char res[100];
545 int y,yy;
546 newheader("RADIANCE",fp);
547 fputnow(fp);
548 if (strlen(p->comment) > 0)
549 fputs(p->comment,fp);
550 fputs(VIEWSTR, fp);
551 fprintview(&(p->view), fp);
552 fprintf(fp,"\n");
553 fputformat(COLRFMT,fp);
554 fprintf(fp,"\n");
555
556 resolu2str(res,&(p->resol));
557 fprintf(fp,"%s",res);
558 for(y=0;y<p->resol.yr;y++) {
559 yy = (p->resol.rt & YDECR) ? p->resol.yr - 1 - y : y;
560 if (fwritescan((p->pic + yy*p->resol.xr),p->resol.xr,fp) < 0) {
561 fprintf(stderr,"writing pic-file failed\n");
562 return 0;
563 }
564 }
565 return 1;
566 }
567
568 int pict_get_dir(pict* p,int x,int y,FVECT dir)
569 {
570 FVECT orig;
571 if (pict_lut_used(p)) {
572 if (!(p->lut)) {
573 fprintf(stderr,"pict_get_dir: no lut defined\n");
574 return 0;
575 }
576 dir[G3S_RAD] = 1.0;
577 dir[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]);
578 dir[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]);
579 g3s_sphtocc(dir,dir);
580 return 1;
581 }
582 return pict_get_ray(p,x,y,orig,dir);
583 }
584
585 int pict_get_dir_ic(pict* p,double x,double y,FVECT dir)
586 {
587 FVECT orig;
588 if (pict_lut_used(p)) {
589 int res[2];
590 loc2pix(res,&(p->resol),x,y);
591 return pict_get_dir(p,res[0],res[1],dir);
592 }
593 return pict_get_ray_ic(p,x,y,orig,dir);
594 }
595
596 int pict_get_ray(pict* p,int x,int y,FVECT orig,FVECT dir)
597 {
598 RREAL pc[2];
599
600 pix2loc(pc,&(p->resol),x,p->resol.yr - 1 - y);
601 if (pict_lut_used(p)) {
602 if (viewray(orig,dir,&(p->view),pc[0],pc[1]) <= 0)
603 return 0;
604 return pict_get_dir(p,x,y,dir);
605 }
606 return pict_get_ray_ic(p,pc[0],pc[1],orig,dir);
607 }
608
609 int pict_get_ray_ic(pict* p,double x,double y,FVECT orig,FVECT dir)
610 {
611 if (pict_lut_used(p)) {
612 int res[2];
613 loc2pix(res,&(p->resol),x,y);
614 return pict_get_ray(p,res[0],res[1],orig,dir);
615 }
616 x = (x + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.xr);
617 y = (y + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.yr);
618 if (viewray(orig,dir,&(p->view),x,y) < 0)
619 return 0;
620 return 1;
621 }
622
623
624 static int splane_normal(pict* p,double e1x,double e1y,
625 double e2x,double e2y,FVECT n)
626 {
627 FVECT e1 = {0,0,0};
628 FVECT e2 = {0,0,0};
629
630 pict_get_dir_ic(p,e1x,e1y,e1);
631 pict_get_dir_ic(p,e2x,e2y,n);
632 VSUB(e2,n,e1);
633 VCROSS(n,e1,e2);
634 if (normalize(n) == 0.0) {
635 return 0;
636 }
637 return 1;
638 }
639
640 double pict_get_sangle(pict* p,int x,int y)
641 {
642 int i;
643 double ang,a,hpx,hpy;
644 RREAL pc[2];
645 FVECT n[4] = {{0,0,0},{0,0,0},{0,0,0},{0,0,0}};
646
647 if (pict_lut_used(p)) {
648 return pict_colbuf(p,p->lut,x,y)[2];
649 }
650 pix2loc(pc,&(p->resol),x,y);
651 hpx = (0.5/p->resol.xr);
652 hpy = (0.5/p->resol.yr);
653 pc[0] -= hpx;
654 pc[1] -= hpy;
655
656 i = splane_normal(p,pc[0],pc[1],pc[0],(pc[1]+2.0*hpy),n[0]);
657 i &= splane_normal(p,pc[0],(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),n[1]);
658 i &= splane_normal(p,(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),pc[1],n[2]);
659 i &= splane_normal(p,(pc[0]+2.0*hpx),pc[1],pc[0],pc[1],n[3]);
660
661 if (!i) {
662 return 0;
663 }
664 ang = 0;
665 for(i=0;i<4;i++) {
666 a = DOT(n[i],n[(i+1)%4]);
667 a = acos(a);
668 a = fabs(a);
669 ang += M_PI - a;
670 }
671 ang = ang - 2.0*M_PI;
672 if ((ang > (2.0*M_PI)) || ang < 0) {
673 fprintf(stderr,"Normal error in pict_get_sangle %f %d %d\n",ang,x,y);
674 return -1.0;
675 }
676 return ang;
677 }
678
679 int pict_locate(pict* p,FVECT pt,int* x,int* y)
680 {
681 FVECT pp;
682 int res[2];
683
684 if (pict_lut_used(p)) {
685 fprintf(stderr,"pict_locate: Not implemented for lut mode\n");
686 return 0;
687 }
688
689 viewloc(pp,&(p->view),pt);
690 if (pp[2] < 0)
691 return 0;
692 loc2pix(res,&(p->resol),pp[0],pp[1]);
693 *x = res[0];
694 *y = res[1];
695 return 1;
696 }
697
698 int pict_get_sigma(pict* p,double x,double y,FVECT vdir,FVECT vup,double* s)
699 {
700 FVECT pvdir;
701
702 if (!pict_get_dir(p,x,y,pvdir))
703 return 0;
704 if (normalize(vdir) == 0.0) {
705 fprintf(stderr,"get_sigma: view dir is zero\n");
706 return 0;
707 }
708 if (normalize(vup) == 0.0) {
709 fprintf(stderr,"get_sigma: view up is zero\n");
710 return 0;
711 }
712 *s = acos(DOT(vdir,pvdir));
713 return 1;
714 }
715
716 int pict_get_tau(pict* p,double x,double y,FVECT vdir,FVECT vup,double* t)
717 {
718 FVECT hv,pvdir;
719 double s;
720 int i;
721 if (!pict_get_sigma(p,x,y,vdir,vup,&s))
722 return 0;
723 if (!pict_get_dir(p,x,y,pvdir))
724 return 0;
725 VCOPY(hv,pvdir);
726 normalize(hv);
727 for(i=0;i<3;i++){
728 hv[i] /= cos(s);
729 }
730 VSUB(hv,hv,vdir);
731 normalize(hv);
732 *t = acos(fdot(vup,hv));
733 return 1;
734 }
735
736 static int ortho_coord(FVECT vdir,FVECT vup,FVECT vv,FVECT hv)
737 {
738 if (normalize(vdir) == 0.0) {
739 fprintf(stderr,"ortho_coord: view direction is zero\n");
740 return 0;
741 }
742 if (normalize(vup) == 0.0) {
743 fprintf(stderr,"ortho_coord: view direction is zero\n");
744 return 0;
745 }
746 fcross(hv,vdir,vup);
747 fcross(vv,vdir,hv);
748 return 1;
749 }
750
751 int pict_get_vangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a)
752 {
753 FVECT hv,vv,pvdir;
754 if (!ortho_coord(vdir,vup,vv,hv)) {
755 return 0;
756 }
757 if (!pict_get_dir(p,x,y,pvdir))
758 return 0;
759 *a = acos(fdot(vv,pvdir)) - (M_PI/2.0) ;
760 return 1;
761 }
762
763 int pict_get_hangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a)
764 {
765 FVECT hv,vv,pvdir;
766 if (!ortho_coord(vdir,vup,vv,hv)) {
767 return 0;
768 }
769 if (!pict_get_dir(p,x,y,pvdir)) {
770 return 0;
771 }
772 *a = ((M_PI/2.0) - acos(fdot(hv,pvdir)));
773 return 1;
774 }
775
776 int pict_setorigin(pict* p,FVECT orig)
777 {
778 VCOPY(p->view.vp,orig);
779 return pict_update_view(p);
780 }
781
782 int pict_setdir(pict* p,FVECT dir)
783 {
784 VCOPY(p->view.vdir,dir);
785 return pict_update_view(p);
786 }
787
788 int pict_sethview(pict* p,double ha)
789 {
790 p->view.horiz = ha;
791 return pict_update_view(p);
792 }
793
794 int pict_setvview(pict* p,double va)
795 {
796 p->view.vert = va;
797 return pict_update_view(p);
798 }
799
800 int pict_setvtype(pict* p,char vt)
801 {
802 p->view.type = vt;
803 return pict_update_view(p);
804 }
805
806 #ifdef TEST_PICTTOOL
807
808 char* progname = "pictool";
809
810 int main(int argc,char** argv)
811 {
812 pict* p = pict_create();
813 FVECT dir = {0,-1,0};
814 FVECT vdir,edir;
815 FVECT up = {0,0,1};
816 int x,y,i;
817 double sang,h,v;
818
819 if (argc < 2) {
820 fprintf(stderr,"usage: %s <pic-file>\n",argv[0]);
821 return EXIT_FAILURE;
822 }
823 fprintf(stderr,"readdd\n");
824 pict_read(p,argv[1]);
825 pict_set_comment(p,"pictool test output\n");
826 /*
827 pict_get_dir(p,100,100,edir); // YDECR
828 for(y=0;y<p->resol.yr;y++) {
829 for(x=0;x<p->resol.xr;x++) {
830 pict_get_hangle(p,x,y,dir,up,&h);
831 pict_get_vangle(p,x,y,dir,up,&v);
832 pict_get_dir(p,x,y,vdir);
833 if (acos(DOT(vdir,edir)) < DEG2RAD(3))
834 setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,1);
835 else
836 setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,0);
837 }
838 }
839 */
840 printf("resolution: %dx%d\n",pict_get_xsize(p),pict_get_ysize(p));
841 sang = 0.0;
842
843 pict_new_gli(p);
844 for(x=0;x<pict_get_xsize(p);x++)
845 for(y=0;y<pict_get_ysize(p);y++) {
846 pict_get_dir(p,x,y,dir);
847 if (DOT(dir,p->view.vdir) >= 0.0) {
848 pict_get_av_omega(p,0) += pict_get_omega(p,x,y);
849 }
850 sang = pict_get_sangle(p,x,y);
851 for(i=0;i<3;i++)
852 if (sang <= 0 && pict_is_validpixel(p,x,y)) {
853 pict_get_color(p,x,y)[i] = 1;
854 } else {
855 pict_get_color(p,x,y)[i] =0;
856 }
857 }
858 printf("s %f\n",pict_get_av_omega(p,0));
859 pict_write(p,"test.pic");
860 while(1) {
861 printf("pos\n");
862 if (scanf("%d %d",&x,&y) != 2)
863 continue;
864 pict_get_dir(p,x,y,dir);
865 printf("dir: \t\t %f %f %f\n",dir[0],dir[1],dir[2]);
866 printf("solid angle: \t %f \n",pict_get_sangle(p,x,y));
867 }
868 return EXIT_SUCCESS;
869 }
870
871 #endif
