1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pictool.c,v 2.3 2016/07/14 17:32:12 greg Exp $"; |
3 |
#endif |
4 |
#include "pictool.h" |
5 |
#include "g3sphere.h" |
6 |
#include <math.h> |
7 |
#include <string.h> |
8 |
9 |
#define index strchr |
10 |
11 |
12 |
13 |
int pict_init(pict* p) |
14 |
15 |
p->pic = NULL; |
16 |
p->use_lut = 0; |
17 |
p->lut = NULL; |
18 |
p->pjitter = 0; |
19 |
p->comment[0] = '\0'; |
20 |
#ifdef PICT_GLARE |
21 |
p->pinfo = NULL; |
22 |
p->glareinfo = g3fl_create(PICT_GLSIZE); |
23 |
#endif |
24 |
p->valid_view = 1; |
25 |
p->view = stdview; |
26 |
if (!pict_update_view(p)) |
27 |
return 0; |
28 |
p->resol.rt = PIXSTANDARD; |
29 |
return pict_resize(p,512,512); |
30 |
31 |
32 |
void pict_new_gli(pict* p) |
33 |
34 |
int i; |
35 |
36 |
g3Float* gli; |
37 |
gli = g3fl_append_new(p->glareinfo); |
38 |
for(i=0;i<PICT_GLSIZE;i++) |
39 |
gli[i] = 0.0; |
40 |
41 |
42 |
void pict_set_comment(pict* p,const char* c) |
43 |
44 |
strcpy(p->comment,c); |
45 |
46 |
47 |
pict* pict_get_copy(pict* p) |
48 |
49 |
pict* res; |
50 |
51 |
if (p->use_lut) { |
52 |
fprintf(stderr,"pict_get_copy: can't copy in lut mode"); |
53 |
return NULL; |
54 |
55 |
res = pict_create(); |
56 |
pict_resize(res,pict_get_xsize(p),pict_get_ysize(p)); |
57 |
res->view = p->view; |
58 |
res->resol = p->resol; |
59 |
res->pjitter = p->pjitter; |
60 |
return res; |
61 |
62 |
63 |
pict* pict_create() |
64 |
65 |
pict* p = (pict*) malloc(sizeof(pict)); |
66 |
67 |
if (!pict_init(p)) { |
68 |
pict_free(p); |
69 |
return NULL; |
70 |
71 |
return p; |
72 |
73 |
74 |
void pict_free(pict* p) |
75 |
76 |
if (p->pic) |
77 |
free(p->pic); |
78 |
#ifdef PICT_GLARE |
79 |
if (p->pinfo) |
80 |
free(p->pinfo); |
81 |
g3fl_free(p->glareinfo); |
82 |
p->pinfo = NULL; |
83 |
#endif |
84 |
p->pic = NULL; |
85 |
p->lut = NULL; |
86 |
free(p); |
87 |
88 |
static int exp_headline(char* s,void* exparg) { |
89 |
double* exposure; |
90 |
if(strstr(s, EXPOSSTR) != NULL ) { |
91 |
fprintf(stderr,"EXP AND tab\n"); |
92 |
93 |
94 |
exposure = (double*) exparg; |
95 |
if (isexpos(s)) { |
96 |
(*exposure) *= exposval(s); |
97 |
98 |
return 0; |
99 |
100 |
101 |
static double read_exposure(FILE* fp) |
102 |
103 |
double exposure = 1; |
104 |
105 |
106 |
if ((getheader(fp, exp_headline, &exposure)) < 0) { |
107 |
fprintf(stderr,"error reading header\n"); |
108 |
return 0; |
109 |
110 |
return exposure; |
111 |
112 |
113 |
int pict_update_view(pict* p) |
114 |
115 |
char* ret; |
116 |
if ((ret = setview(&(p->view)))) { |
117 |
fprintf(stderr,"pict_update_view: %s\n",ret); |
118 |
return 0; |
119 |
120 |
return 1; |
121 |
122 |
123 |
int pict_set_pj(pict* p,double pj) |
124 |
125 |
if ((pj < 0) || (pj > 1)) |
126 |
fprintf(stderr,"pict_set_pj: warning jitter factor out of range\n"); |
127 |
p->pjitter = pj; |
128 |
return 1; |
129 |
130 |
131 |
int pict_setvup(pict* p,FVECT vup) |
132 |
133 |
VCOPY(p->view.vup,vup); |
134 |
return pict_update_view(p); |
135 |
136 |
137 |
int pict_trans_cam(pict* p,g3ATrans t) |
138 |
139 |
g3Vec o = g3v_create(); |
140 |
g3Vec d = g3v_create(); |
141 |
g3Vec u = g3v_create(); |
142 |
143 |
fprintf(stderr,"vdpre %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); |
144 |
fprintf(stderr,"vupre %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]); |
145 |
g3v_fromrad(o,p->view.vp); |
146 |
g3v_fromrad(d,p->view.vdir); |
147 |
g3v_fromrad(u,p->view.vup); |
148 |
149 |
g3v_add(d,d,o); |
150 |
g3v_add(u,u,o); |
151 |
g3at_apply(t,o); |
152 |
g3at_apply(t,u); |
153 |
g3at_apply(t,d); |
154 |
g3v_sub(d,d,o); |
155 |
g3v_sub(u,u,o); |
156 |
g3v_torad(p->view.vp,o); |
157 |
g3v_torad(p->view.vdir,d); |
158 |
g3v_torad(p->view.vup,u); |
159 |
fprintf(stderr,"vd %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); |
160 |
fprintf(stderr,"vu %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]); |
161 |
162 |
g3v_free(o); |
163 |
g3v_free(d); |
164 |
g3v_free(u); |
165 |
166 |
167 |
168 |
int pict_resize(pict* p,int x,int y) |
169 |
170 |
p->resol.xr = x; |
171 |
p->resol.yr = y; |
172 |
173 |
if (!(p->pic = (COLOR*) realloc(p->pic,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) { |
174 |
fprintf(stderr,"Can't alloc picture\n"); |
175 |
return 0; |
176 |
177 |
if (pict_lut_used(p)) { |
178 |
if (!(p->lut = (COLOR*) realloc(p->lut,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) { |
179 |
fprintf(stderr,"Can't alloc LUT\n"); |
180 |
return 0; |
181 |
182 |
183 |
#ifdef PICT_GLARE |
184 |
if (!(p->pinfo = (pixinfo*) |
185 |
realloc(p->pinfo,(p->resol.xr)*p->resol.yr*sizeof(pixinfo)))) { |
186 |
fprintf(stderr,"Can't alloc picture info\n"); |
187 |
return 0; |
188 |
189 |
/* fprintf(stderr,"resize %d %d %d\n",p->resol.xr,p->resol.yr,sizeof(pixinfo));*/ |
190 |
#endif |
191 |
return 1; |
192 |
193 |
194 |
195 |
int pict_zero(pict* p) |
196 |
197 |
int x,y,i; |
198 |
199 |
for(x=0;x<pict_get_xsize(p);x++) |
200 |
for(y=0;y<pict_get_ysize(p);y++) |
201 |
for(i=0;i<3;i++) |
202 |
pict_get_color(p,x,y)[i] = 0; |
203 |
return 1; |
204 |
205 |
206 |
struct hinfo { |
207 |
VIEW *hv; |
208 |
int ok; |
209 |
double exposure; |
210 |
211 |
212 |
213 |
static int |
214 |
gethinfo( /* get view from header */ |
215 |
char *s, |
216 |
void *v |
217 |
218 |
219 |
if(strstr(s, EXPOSSTR) != NULL && strstr(s, "\t") != NULL) { |
220 |
221 |
fprintf(stderr,"error: header contains invalid exposure entry!!!!\n"); |
222 |
fprintf(stderr,"check exposure and correct header setting !\n"); |
223 |
224 |
225 |
fprintf(stderr,"stopping !!!!\n"); |
226 |
exit(1); |
227 |
228 |
if (isview(s) && sscanview(((struct hinfo*)v)->hv, s) > 0) { |
229 |
((struct hinfo*)v)->ok++; |
230 |
} else if (isexpos(s)) { |
231 |
/*fprintf(stderr,"readexp %f %f\n",((struct hinfo*)v)->exposure,exposval(s));*/ |
232 |
((struct hinfo*)v)->exposure *= exposval(s); |
233 |
234 |
return(0); |
235 |
236 |
237 |
int pict_read_fp(pict* p,FILE* fp) |
238 |
239 |
struct hinfo hi; |
240 |
int x,y,yy; |
241 |
242 |
243 |
hi.hv = &(p->view); |
244 |
hi.ok = 0; |
245 |
hi.exposure = 1; |
246 |
getheader(fp, gethinfo, &hi); |
247 |
/*fprintf(stderr,"expscale %f\n",hi.exposure);*/ |
248 |
249 |
if (!(pict_update_view(p)) || !(hi.ok)) |
250 |
p->valid_view = 0; |
251 |
/* printf("dir %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); */ |
252 |
if (fgetsresolu(&(p->resol),fp) < 0) { |
253 |
fprintf(stderr,"No resolution given\n"); |
254 |
return 0; |
255 |
256 |
if (!(p->resol.rt & YMAJOR)) { |
257 |
x = p->resol.xr; |
258 |
p->resol.xr = p->resol.yr; |
259 |
p->resol.yr = x; |
260 |
p->resol.rt |= YMAJOR; |
261 |
262 |
if (!pict_resize(p,p->resol.xr,p->resol.yr)) |
263 |
return 0; |
264 |
for(yy=0;yy<p->resol.yr;yy++) { |
265 |
y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy; |
266 |
if (freadscan((p->pic + y*p->resol.xr),p->resol.xr,fp) < 0) { |
267 |
fprintf(stderr,"error reading line %d\n",y); |
268 |
return 0; |
269 |
270 |
for(x=0;x<p->resol.xr;x++) { |
271 |
scalecolor(pict_get_color(p,x,y),1.0/hi.exposure); |
272 |
273 |
274 |
#ifdef PICT_GLARE |
275 |
pict_update_evalglare_caches(p); |
276 |
#endif |
277 |
return 1; |
278 |
279 |
280 |
#ifdef PICT_GLARE |
281 |
void pict_update_evalglare_caches(pict* p) |
282 |
283 |
int x,y,yy; |
284 |
float lum; |
285 |
286 |
287 |
288 |
pict_get_omega(p,x,y) = pict_get_sangle(p,x,y); |
289 |
pict_get_dir(p,x,y,pict_get_cached_dir(p,x,y)); |
290 |
pict_get_gsn(p,x,y) = 0; |
291 |
pict_get_pgs(p,x,y) = 0; |
292 |
/* make picture grey */ |
293 |
lum=luminance(pict_get_color(p,x,y))/179.0; |
294 |
pict_get_color(p,x,y)[RED]=lum; |
295 |
pict_get_color(p,x,y)[GRN]=lum; |
296 |
pict_get_color(p,x,y)[BLU]=lum; |
297 |
298 |
299 |
300 |
301 |
#endif |
302 |
303 |
int pict_read(pict* p,char* fn) |
304 |
305 |
FILE* fp; |
306 |
307 |
if (!(fp = fopen(fn,"rb"))) { |
308 |
fprintf(stderr,"Can't open %s\n",fn); |
309 |
return 0; |
310 |
311 |
if (!(pict_read_fp(p,fp))) |
312 |
return 0; |
313 |
fclose(fp); |
314 |
return 1; |
315 |
316 |
317 |
static void ch_pct(char* line) |
318 |
319 |
char* pct; |
320 |
321 |
while ((pct = index(line,','))) |
322 |
*pct = '.'; |
323 |
324 |
325 |
char* nextline(FILE* fp) |
326 |
327 |
static char* line = NULL; |
328 |
static int lsize = 500; |
329 |
int done; |
330 |
long fpos; |
331 |
332 |
if (!line) { |
333 |
if (!(line = (char*) malloc((lsize + 1)*sizeof(char)))) { |
334 |
fprintf(stderr,"allocation problem in nextline\n"); |
335 |
return NULL; |
336 |
337 |
338 |
done = 0; |
339 |
fpos = ftell(fp); |
340 |
while(!done) { |
341 |
if (!fgets(line,lsize,fp)) |
342 |
return NULL; |
343 |
if (!index(line,'\n')) { |
344 |
lsize *= 2; |
345 |
if (!(line = (char*) realloc(line,(lsize + 1)*sizeof(char)))) { |
346 |
347 |
return NULL; |
348 |
349 |
fseek(fp,fpos,SEEK_SET); |
350 |
} else { |
351 |
done = 1; |
352 |
353 |
354 |
return line; |
355 |
356 |
357 |
static int read_tt_txt(pict* p,int bufsel,int channel,char* fn) |
358 |
359 |
FILE* fp; |
360 |
361 |
int x,y,vsize,hsize; |
362 |
float* col; |
363 |
float c; |
364 |
char* curr; |
365 |
char** endp; |
366 |
COLOR* picbuf; |
367 |
368 |
if (!(fp = fopen(fn,"r"))) { |
369 |
fprintf(stderr,"pict_read_tt_txt: Can't open file %s\n",fn); |
370 |
return 0; |
371 |
372 |
if (!(line = nextline(fp))) { |
373 |
fprintf(stderr,"pict_read_tt_txt: reading from file failed\n"); |
374 |
return 0; |
375 |
376 |
if (strncmp(line,"float",strlen("float"))) { |
377 |
fprintf(stderr,"pict_read_tt_txt: Unexpected format\n"); |
378 |
return 0; |
379 |
380 |
381 |
382 |
return 0; |
383 |
384 |
sscanf(line,"%d %d %d %d",&x,&vsize,&y,&hsize); |
385 |
vsize = vsize - x; |
386 |
hsize = hsize - y; |
387 |
if (!pict_resize(p,vsize,hsize)) |
388 |
return 0; |
389 |
endp = malloc(sizeof(char*)); |
390 |
picbuf = (bufsel == PICT_LUT) ? p->lut : p->pic; |
391 |
for(x=0;x<vsize;x++) { |
392 |
393 |
fprintf(stderr,"pict_read_tt_txt: too few lines %d of %d\n",x,vsize); |
394 |
free(endp); |
395 |
return 0; |
396 |
397 |
ch_pct(line); |
398 |
curr = line; |
399 |
for(y=0;y<hsize;y++) { |
400 |
col = pict_colbuf(p,picbuf,x,y); |
401 |
c = strtod(curr,endp); |
402 |
if (channel & PICT_CH1) |
403 |
col[0] = c; |
404 |
if (channel & PICT_CH2) |
405 |
col[1] = c; |
406 |
if (channel & PICT_CH3) |
407 |
col[2] = c; |
408 |
if (curr == (*endp)) { |
409 |
fprintf(stderr,"pict_read_tt_txt: too few values in line %d\n",x); |
410 |
free(endp); |
411 |
return 0; |
412 |
413 |
curr = (*endp); |
414 |
415 |
416 |
free(endp); |
417 |
return 1; |
418 |
419 |
420 |
int pict_read_tt_txt(pict* p,char* fn) |
421 |
422 |
return read_tt_txt(p,PICT_VIEW,PICT_ALLCH,fn); |
423 |
424 |
425 |
int pict_setup_lut(pict* p,char* theta_fn,char* phi_fn,char* omega_fn) |
426 |
427 |
int xs,ys; |
428 |
429 |
p->use_lut = 1; |
430 |
if (!read_tt_txt(p,PICT_LUT,PICT_CH1,theta_fn)) { |
431 |
fprintf(stderr,"pict_setup_lut: error reading theta file\n"); |
432 |
p->use_lut = 0; |
433 |
return 0; |
434 |
435 |
xs = pict_get_xsize(p); |
436 |
ys = pict_get_ysize(p); |
437 |
if (!read_tt_txt(p,PICT_LUT,PICT_CH2,phi_fn)) { |
438 |
fprintf(stderr,"pict_setup_lut: error reading phi file\n"); |
439 |
p->use_lut = 0; |
440 |
return 0; |
441 |
442 |
if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) { |
443 |
fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n"); |
444 |
p->use_lut = 0; |
445 |
return 0; |
446 |
447 |
if (!read_tt_txt(p,PICT_LUT,PICT_CH3,omega_fn)) { |
448 |
fprintf(stderr,"pict_setup_lut: error reading omega file\n"); |
449 |
p->use_lut = 0; |
450 |
return 0; |
451 |
452 |
453 |
454 |
p->use_lut = 0; |
455 |
return 0; |
456 |
457 |
return 1; |
458 |
459 |
460 |
int pict_update_lut(pict* p) |
461 |
462 |
g3ATrans transf; |
463 |
g3Vec d; |
464 |
g3Vec u; |
465 |
int x,y; |
466 |
467 |
d = g3v_fromrad(g3v_create(),p->view.vdir); |
468 |
u = g3v_fromrad(g3v_create(),p->view.vup); |
469 |
g3at_ctrans(transf,d,u); |
470 |
471 |
for(y=0;y<p->resol.yr;y++) { |
472 |
d[G3S_RAD] = 1.0; |
473 |
d[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]); |
474 |
d[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]); |
475 |
g3s_sphtocc(d,d); |
476 |
g3at_apply(transf,d); |
477 |
g3s_cctosph(d,d); |
478 |
pict_colbuf(p,p->lut,x,y)[0] = RAD2DEG(d[G3S_THETA]); |
479 |
pict_colbuf(p,p->lut,x,y)[1] = RAD2DEG(d[G3S_PHI]); |
480 |
481 |
482 |
g3v_free(d); |
483 |
g3v_free(u); |
484 |
return 1; |
485 |
486 |
487 |
488 |
int pict_write_dir(pict* p,FILE* fp) |
489 |
490 |
int x,y; |
491 |
FVECT dir,orig; |
492 |
493 |
494 |
495 |
if (!(pict_get_ray(p,x,y,orig,dir))) { |
496 |
fprintf(fp,"%f %f %f 0.0 0.0 0.0\n",orig[0],orig[1],orig[2]); |
497 |
} else { |
498 |
fprintf(fp,"%f %f %f %f %f %f\n",orig[0],orig[1],orig[2],dir[0],dir[1],dir[2]); |
499 |
500 |
501 |
502 |
return 1; |
503 |
504 |
505 |
int pict_read_from_list(pict* p,FILE* fp) |
506 |
507 |
int x,y,sz; |
508 |
char ln[1024]; |
509 |
double val; |
510 |
511 |
sz = 0; |
512 |
513 |
514 |
if (!(fgets(ln,1023,fp))) { |
515 |
fprintf(stderr,"pict_read_from_list: Read only %d values\n",sz); |
516 |
return 0; |
517 |
518 |
if (sscanf(ln,"%lg",&val) != 1) { |
519 |
fprintf(stderr,"pict_read_from_list: errline %d\n",sz); |
520 |
} else { |
521 |
sz++; |
522 |
setcolor(pict_get_color(p,x,y),val,val,val); |
523 |
524 |
525 |
526 |
return 1; |
527 |
528 |
529 |
int pict_write(pict* p,char* fn) |
530 |
531 |
FILE* fp; |
532 |
533 |
if (!(fp = fopen(fn,"wb"))) { |
534 |
fprintf(stderr,"Can't open %s for writing\n",fn); |
535 |
return 0; |
536 |
537 |
if (!(pict_write_fp(p,fp))) { |
538 |
fclose(fp); |
539 |
return 0; |
540 |
541 |
fclose(fp); |
542 |
return 1; |
543 |
544 |
545 |
int pict_write_fp(pict* p,FILE* fp) |
546 |
547 |
char res[100]; |
548 |
int y,yy; |
549 |
newheader("RADIANCE",fp); |
550 |
fputnow(fp); |
551 |
if (strlen(p->comment) > 0) |
552 |
fputs(p->comment,fp); |
553 |
fputs(VIEWSTR, fp); |
554 |
fprintview(&(p->view), fp); |
555 |
fprintf(fp,"\n"); |
556 |
fputformat(COLRFMT,fp); |
557 |
fprintf(fp,"\n"); |
558 |
559 |
resolu2str(res,&(p->resol)); |
560 |
fprintf(fp,"%s",res); |
561 |
562 |
yy = (p->resol.rt & YDECR) ? p->resol.yr - 1 - y : y; |
563 |
if (fwritescan((p->pic + yy*p->resol.xr),p->resol.xr,fp) < 0) { |
564 |
fprintf(stderr,"writing pic-file failed\n"); |
565 |
return 0; |
566 |
567 |
568 |
return 1; |
569 |
570 |
571 |
int pict_get_dir(pict* p,int x,int y,FVECT dir) |
572 |
573 |
FVECT orig; |
574 |
575 |
if (!(p->lut)) { |
576 |
fprintf(stderr,"pict_get_dir: no lut defined\n"); |
577 |
return 0; |
578 |
579 |
dir[G3S_RAD] = 1.0; |
580 |
dir[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]); |
581 |
dir[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]); |
582 |
g3s_sphtocc(dir,dir); |
583 |
return 1; |
584 |
585 |
return pict_get_ray(p,x,y,orig,dir); |
586 |
587 |
588 |
int pict_get_dir_ic(pict* p,double x,double y,FVECT dir) |
589 |
590 |
FVECT orig; |
591 |
592 |
int res[2]; |
593 |
loc2pix(res,&(p->resol),x,y); |
594 |
return pict_get_dir(p,res[0],res[1],dir); |
595 |
596 |
return pict_get_ray_ic(p,x,y,orig,dir); |
597 |
598 |
599 |
int pict_get_ray(pict* p,int x,int y,FVECT orig,FVECT dir) |
600 |
601 |
RREAL pc[2]; |
602 |
603 |
pix2loc(pc,&(p->resol),x,p->resol.yr - 1 - y); |
604 |
605 |
if (viewray(orig,dir,&(p->view),pc[0],pc[1]) <= 0) |
606 |
return 0; |
607 |
return pict_get_dir(p,x,y,dir); |
608 |
609 |
return pict_get_ray_ic(p,pc[0],pc[1],orig,dir); |
610 |
611 |
612 |
int pict_get_ray_ic(pict* p,double x,double y,FVECT orig,FVECT dir) |
613 |
614 |
615 |
int res[2]; |
616 |
617 |
return pict_get_ray(p,res[0],res[1],orig,dir); |
618 |
619 |
x = (x + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.xr); |
620 |
y = (y + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.yr); |
621 |
if (viewray(orig,dir,&(p->view),x,y) < 0) |
622 |
return 0; |
623 |
return 1; |
624 |
625 |
626 |
627 |
static int splane_normal(pict* p,double e1x,double e1y, |
628 |
double e2x,double e2y,FVECT n) |
629 |
630 |
FVECT e1 = {0,0,0}; |
631 |
FVECT e2 = {0,0,0}; |
632 |
633 |
pict_get_dir_ic(p,e1x,e1y,e1); |
634 |
pict_get_dir_ic(p,e2x,e2y,n); |
635 |
VSUB(e2,n,e1); |
636 |
VCROSS(n,e1,e2); |
637 |
if (normalize(n) == 0.0) { |
638 |
return 0; |
639 |
640 |
return 1; |
641 |
642 |
643 |
double pict_get_sangle(pict* p,int x,int y) |
644 |
645 |
int i; |
646 |
double ang,a,hpx,hpy; |
647 |
RREAL pc[2]; |
648 |
FVECT n[4] = {{0,0,0},{0,0,0},{0,0,0},{0,0,0}}; |
649 |
650 |
651 |
return pict_colbuf(p,p->lut,x,y)[2]; |
652 |
653 |
pix2loc(pc,&(p->resol),x,y); |
654 |
hpx = (0.5/p->resol.xr); |
655 |
hpy = (0.5/p->resol.yr); |
656 |
pc[0] -= hpx; |
657 |
pc[1] -= hpy; |
658 |
659 |
i = splane_normal(p,pc[0],pc[1],pc[0],(pc[1]+2.0*hpy),n[0]); |
660 |
i &= splane_normal(p,pc[0],(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),n[1]); |
661 |
i &= splane_normal(p,(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),pc[1],n[2]); |
662 |
i &= splane_normal(p,(pc[0]+2.0*hpx),pc[1],pc[0],pc[1],n[3]); |
663 |
664 |
if (!i) { |
665 |
return 0; |
666 |
667 |
ang = 0; |
668 |
for(i=0;i<4;i++) { |
669 |
a = DOT(n[i],n[(i+1)%4]); |
670 |
a = acos(a); |
671 |
a = fabs(a); |
672 |
ang += M_PI - a; |
673 |
674 |
ang = ang - 2.0*M_PI; |
675 |
if ((ang > (2.0*M_PI)) || ang < 0) { |
676 |
fprintf(stderr,"Normal error in pict_get_sangle %f %d %d\n",ang,x,y); |
677 |
return -1.0; |
678 |
679 |
return ang; |
680 |
681 |
682 |
int pict_locate(pict* p,FVECT pt,int* x,int* y) |
683 |
684 |
FVECT pp; |
685 |
int res[2]; |
686 |
687 |
688 |
fprintf(stderr,"pict_locate: Not implemented for lut mode\n"); |
689 |
return 0; |
690 |
691 |
692 |
viewloc(pp,&(p->view),pt); |
693 |
if (pp[2] < 0) |
694 |
return 0; |
695 |
loc2pix(res,&(p->resol),pp[0],pp[1]); |
696 |
*x = res[0]; |
697 |
*y = res[1]; |
698 |
return 1; |
699 |
700 |
701 |
int pict_get_sigma(pict* p,double x,double y,FVECT vdir,FVECT vup,double* s) |
702 |
703 |
FVECT pvdir; |
704 |
705 |
if (!pict_get_dir(p,x,y,pvdir)) |
706 |
return 0; |
707 |
if (normalize(vdir) == 0.0) { |
708 |
fprintf(stderr,"get_sigma: view dir is zero\n"); |
709 |
return 0; |
710 |
711 |
if (normalize(vup) == 0.0) { |
712 |
fprintf(stderr,"get_sigma: view up is zero\n"); |
713 |
return 0; |
714 |
715 |
*s = acos(DOT(vdir,pvdir)); |
716 |
return 1; |
717 |
718 |
719 |
int pict_get_tau(pict* p,double x,double y,FVECT vdir,FVECT vup,double* t) |
720 |
721 |
FVECT hv,pvdir; |
722 |
double s; |
723 |
int i; |
724 |
if (!pict_get_sigma(p,x,y,vdir,vup,&s)) |
725 |
return 0; |
726 |
727 |
return 0; |
728 |
VCOPY(hv,pvdir); |
729 |
normalize(hv); |
730 |
for(i=0;i<3;i++){ |
731 |
hv[i] /= cos(s); |
732 |
733 |
VSUB(hv,hv,vdir); |
734 |
normalize(hv); |
735 |
*t = acos(fdot(vup,hv)); |
736 |
return 1; |
737 |
738 |
739 |
static int ortho_coord(FVECT vdir,FVECT vup,FVECT vv,FVECT hv) |
740 |
741 |
742 |
fprintf(stderr,"ortho_coord: view direction is zero\n"); |
743 |
return 0; |
744 |
745 |
746 |
747 |
return 0; |
748 |
749 |
fcross(hv,vdir,vup); |
750 |
fcross(vv,vdir,hv); |
751 |
return 1; |
752 |
753 |
754 |
int pict_get_vangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a) |
755 |
756 |
FVECT hv,vv,pvdir; |
757 |
if (!ortho_coord(vdir,vup,vv,hv)) { |
758 |
return 0; |
759 |
760 |
761 |
return 0; |
762 |
*a = acos(fdot(vv,pvdir)) - (M_PI/2.0) ; |
763 |
return 1; |
764 |
765 |
766 |
int pict_get_hangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a) |
767 |
768 |
769 |
770 |
return 0; |
771 |
772 |
if (!pict_get_dir(p,x,y,pvdir)) { |
773 |
return 0; |
774 |
775 |
*a = ((M_PI/2.0) - acos(fdot(hv,pvdir))); |
776 |
return 1; |
777 |
778 |
779 |
int pict_setorigin(pict* p,FVECT orig) |
780 |
781 |
VCOPY(p->view.vp,orig); |
782 |
783 |
784 |
785 |
int pict_setdir(pict* p,FVECT dir) |
786 |
787 |
VCOPY(p->view.vdir,dir); |
788 |
789 |
790 |
791 |
int pict_sethview(pict* p,double ha) |
792 |
793 |
p->view.horiz = ha; |
794 |
795 |
796 |
797 |
int pict_setvview(pict* p,double va) |
798 |
799 |
p->view.vert = va; |
800 |
801 |
802 |
803 |
int pict_setvtype(pict* p,char vt) |
804 |
805 |
p->view.type = vt; |
806 |
807 |
808 |
809 |
#ifdef TEST_PICTTOOL |
810 |
811 |
char* progname = "pictool"; |
812 |
813 |
int main(int argc,char** argv) |
814 |
815 |
pict* p = pict_create(); |
816 |
FVECT dir = {0,-1,0}; |
817 |
FVECT vdir,edir; |
818 |
FVECT up = {0,0,1}; |
819 |
int x,y,i; |
820 |
double sang,h,v; |
821 |
822 |
if (argc < 2) { |
823 |
fprintf(stderr,"usage: %s <pic-file>\n",argv[0]); |
824 |
return EXIT_FAILURE; |
825 |
826 |
fprintf(stderr,"readdd\n"); |
827 |
pict_read(p,argv[1]); |
828 |
pict_set_comment(p,"pictool test output\n"); |
829 |
830 |
pict_get_dir(p,100,100,edir); // YDECR |
831 |
832 |
833 |
pict_get_hangle(p,x,y,dir,up,&h); |
834 |
pict_get_vangle(p,x,y,dir,up,&v); |
835 |
pict_get_dir(p,x,y,vdir); |
836 |
if (acos(DOT(vdir,edir)) < DEG2RAD(3)) |
837 |
setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,1); |
838 |
else |
839 |
setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,0); |
840 |
841 |
842 |
843 |
printf("resolution: %dx%d\n",pict_get_xsize(p),pict_get_ysize(p)); |
844 |
sang = 0.0; |
845 |
846 |
pict_new_gli(p); |
847 |
848 |
for(y=0;y<pict_get_ysize(p);y++) { |
849 |
850 |
if (DOT(dir,p->view.vdir) >= 0.0) { |
851 |
pict_get_av_omega(p,0) += pict_get_omega(p,x,y); |
852 |
853 |
sang = pict_get_sangle(p,x,y); |
854 |
for(i=0;i<3;i++) |
855 |
if (sang <= 0 && pict_is_validpixel(p,x,y)) { |
856 |
pict_get_color(p,x,y)[i] = 1; |
857 |
} else { |
858 |
pict_get_color(p,x,y)[i] =0; |
859 |
860 |
861 |
printf("s %f\n",pict_get_av_omega(p,0)); |
862 |
pict_write(p,"test.pic"); |
863 |
while(1) { |
864 |
printf("pos\n"); |
865 |
if (scanf("%d %d",&x,&y) != 2) |
866 |
continue; |
867 |
868 |
printf("dir: \t\t %f %f %f\n",dir[0],dir[1],dir[2]); |
869 |
printf("solid angle: \t %f \n",pict_get_sangle(p,x,y)); |
870 |
871 |
return EXIT_SUCCESS; |
872 |
873 |
874 |
#endif |
