root/radiance/ray/src/util/objview.rb
Revision: 2.2
Committed: Wed Apr 16 20:48:07 2014 UTC (10 years, 1 month ago) by greg
State: FILE REMOVED
Removed objview Ruby script, which is no longer needed for Windows
# User Rev Content
1 greg 2.1 #!/usr/bin/env ruby
2 greg 2.2 # RCSid: $Id: objview.rb,v 2.1 2012/08/07 18:17:17 greg Exp $
3 greg 2.1 #
4     # objview.rb, v1.1 2012.07.04 RPG
5     # Ruby port of objview.csh
6     #
7     # Make a nice view of an object, or luminaire
8     # Arguments are scene input files
9     #
10
11     require 'optparse'
12     require 'ostruct'
13     require 'tempfile'
14
15     class Optparse
16     #
17     # Return a structure describing the options.
18     #
19     def self.parse(args)
20     # The options specified on the command line will be collected in *options*.
21     options = OpenStruct.new
22
23     opts = OptionParser.new do |opts|
24     opts.banner = "Usage: (ruby) objview.rb [options] [radiance scene input files]"
25
26     opts.separator ""
27     opts.separator "Options:"
28
29     options.radopt = []
30     options.glradopt = []
31
32     options.up = "Z"
33     opts.on("-u, --up", String, [:X, :Y, :Z], "View up vector (X, Y, or Z)") do |n|
34     options.up = n
35     end
36
37     #Specify display device (qt is only option for Windows)
38     if /mswin/.match(RUBY_PLATFORM) or /mingw/.match(RUBY_PLATFORM)
39     options.dev = "qt"
40     else
41     options.dev = "x11"
42     end
43     opts.on("-o, --odev", String, [:x11, :qt], "Output device (x11 or qt)") do |n|
44     options.dev = n
45     options.radopt << "-o #{options.dev}"
46     end
47
48     options.procs = "1"
49     opts.on("-N, --nprocs", String, "Number of processors (UNIX ony)") do |n|
50     options.procs = n
51     options.radopt << "-N #{options.procs}"
52     end
53
54     options.vw = "XYZ"
55     opts.on("-v", "--view", String, "View specification") do |n|
56     options.view = n
57     options.radopt << "-v #{options.view}"
58     end
59
60     options.ltv = false
61     opts.on("-l", "--ltview", "Luminaire viewer mode") do |n|
62     options.ltv = true
63     options.vw = "y"
64     end
65
66     #set "room" size for ltview, default is 4' square box (in meters)
67     options.rsiz = "0.6096"
68     opts.on("-r", "--roomsize", String, "Room scaling factor for ltview") do |n|
69     options.rsiz = n
70     end
71
72     opts.on("-d", "--debug", "Run verbosely") do |n|
73     options.verbose = true
74     end
75
76     opts.on("-g", "--ogl", "Use OpenGL (glrad)") do |n|
77     options.ogl = true
78     end
79
80     opts.on("-e", "--rad", "Set rad options") do |n|
81     options.radopt << n
82     end
83
84     opts.on("-S", "--glrad", "Set glrad options") do |n|
85     options.glradopt = "-S #{n}"
86     end
87
88     # No argument, shows at tail. This will print an options summary.
89     opts.on_tail("-h", "--help", "Show this message") do
90     puts opts
91     exit
92     end
93
94     end
95
96     opts.parse!(args)
97     options
98
99     end # parse()
100
101     end # class Optparse
102
103     options = Optparse.parse(ARGV)
104
105     # utility function: print statement and execute as system call
106     def exec_statement(s)
107     if /mswin/.match(RUBY_PLATFORM) or /mingw/.match(RUBY_PLATFORM)
108     s = s.gsub("/", "\\")
109     end
110     puts "'#{s}'"
111     result = system(s)
112     puts
113     return result
114     end
115
116     exec = "system"
117     if options.verbose == true
118     puts options
119     puts "Input file(s): #{ARGV}"
120     exec = "exec_statement"
121     end
122
123     #not needed(?)
124     #octree = Tempfile.new(['objview_', '.oct'])
125     #ambf = Tempfile.new(['objview_', '.amb'])
126
127     if options.ltv == true
128     rendopts = "-ab 1 -ds .15"
129     end
130
131     # not sure how these options are supposed to work... RPG
132     #
133     # case -s:
134     # case -w:
135     # set opts=($opts $argv[1])
136     # breaksw
137     # case -b*:
138     # set rendopts=($rendopts -bv)
139     # breaksw
140     # case -V:
141     #
142
143
144     if not ARGV[0]
145     puts "No input files specified"
146     exit 1
147     end
148
149     if options.ogl == true
150     if rendopts
151     puts "bad option for glrad"
152     exit 1
153     else
154     if options.glradopt == true
155     puts "bad option for rad"
156     exit 1
157     end
158     end
159     end
160
161     if options.ltv == false
162     # create lights input file for objview
163     lights = Tempfile.new(['lt_', '.rad'])
164     lights.write("void glow dim 0 0 4 .1 .1 .15 0\n")
165     lights.write("dim source background 0 0 4 0 0 1 360\n")
166     lights.write("void light bright 0 0 3 1000 1000 1000\n")
167     lights.write("bright source sun1 0 0 4 1 .2 1 5\n")
168     lights.write("bright source sun2 0 0 4 .3 1 1 5\n")
169     lights.write("bright source sun3 0 0 4 -1 -.7 1 5\n")
170     if options.verbose == true
171     lights.rewind
172     lightsread = lights.read
173     puts "\nlights file:"
174     puts lightsread
175     end
176     lights.close
177     end
178
179     if options.ltv == true
180     #create room input file for ltview
181     room = Tempfile.new(['lt_', '.rad'])
182     room.write("void plastic surf\n0\n0\n5\n.2 .2 .2 0 0\n\n")
183     room.write("surf polygon floor\n0\n0\n12\n")
184     room.write("-#{options.rsiz} #{options.rsiz} -#{options.rsiz}\n")
185     room.write("-#{options.rsiz} -#{options.rsiz} -#{options.rsiz}\n")
186     room.write("#{options.rsiz} -#{options.rsiz} -#{options.rsiz}\n")
187     room.write("#{options.rsiz} #{options.rsiz} -#{options.rsiz}\n\n")
188
189     room.write("surf polygon clg\n0\n0\n12\n")
190     room.write("-#{options.rsiz} #{options.rsiz} #{options.rsiz}\n")
191     room.write("-#{options.rsiz} -#{options.rsiz} #{options.rsiz}\n")
192     room.write("#{options.rsiz} -#{options.rsiz} #{options.rsiz}\n")
193     room.write("#{options.rsiz} #{options.rsiz} #{options.rsiz}\n\n")
194
195     room.write("surf polygon wall-north\n0\n0\n12\n")
196     room.write("-#{options.rsiz} #{options.rsiz} -#{options.rsiz}\n")
197     room.write("#{options.rsiz} #{options.rsiz} -#{options.rsiz}\n")
198     room.write("#{options.rsiz} #{options.rsiz} #{options.rsiz}\n")
199     room.write("-#{options.rsiz} #{options.rsiz} #{options.rsiz}\n\n")
200
201     room.write("surf polygon wall-east\n0\n0\n12\n")
202     room.write("#{options.rsiz} #{options.rsiz} -#{options.rsiz}\n")
203     room.write("#{options.rsiz} -#{options.rsiz} -#{options.rsiz}\n")
204     room.write("#{options.rsiz} -#{options.rsiz} #{options.rsiz}\n")
205     room.write("#{options.rsiz} #{options.rsiz} #{options.rsiz}\n\n")
206
207     room.write("surf polygon wall-west\n0\n0\n12\n")
208     room.write("-#{options.rsiz} #{options.rsiz} -#{options.rsiz}\n")
209     room.write("-#{options.rsiz} #{options.rsiz} #{options.rsiz}\n")
210     room.write("-#{options.rsiz} -#{options.rsiz} #{options.rsiz}\n")
211     room.write("-#{options.rsiz} -#{options.rsiz} -#{options.rsiz}\n\n")
212     if options.verbose == true
213     room.rewind
214     roomread = room.read
215     puts "\nroom file:"
216     puts roomread
217     end
218     room.close
219     end
220
221     # create .rif file
222     rif = Tempfile.new(['ov_', '.rif'])
223     if options.ltv == true
224     rif.write("scene= #{ARGV.join(' ')} #{room.path}\n")
225     else
226     rif.write("scene= #{ARGV.join(' ')} #{lights.path}\n")
227     end
228     rif.write("EXPOSURE= .5\n")
229     rif.write("UP= #{options.up}\n")
230     rif.write("view= #{options.vw}\n")
231     rif.write("oconv= -f\n")
232     rif.write("render= #{rendopts}\n")
233     #doesn't rad handle the construction and destruction of these files (below) on its own? RPG
234     #rif.write("OCTREE= #{octree.path}\n")
235     #rif.write("AMBF= #{ambf.path}\n")
236     if options.verbose == true
237     rif.rewind
238     rifread = rif.read
239     puts "\nrif file:"
240     puts rifread
241     end
242     rif.close
243
244     puts "radopt = #{options.radopt.join(" ")}"
245
246     #run executive control program of choice
247     if options.ogl == true
248     exec("glrad #{options.radopt.join(" ")} #{rif.path}")
249     else
250     exec("rad -o #{options.dev} #{options.radopt.join(" ")} #{rif.path}")
251     end
252
253     # clean up temp files
254     if coptions.ltv == true
255     room.unlink
256     else
257     lights.unlink
258     end
259     rif.unlink
260     #ambf.unlink
261     #octree.unlink
262
263     exit 0
264
