root/radiance/ray/src/util/objview.pl
Revision: 2.3
Committed: Fri Aug 11 21:39:52 2017 UTC (8 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
# User Rev Content
1 greg 2.1 #!/usr/bin/perl
2 greg 2.3 # RCSid $Id: objview.pl,v 2.2 2016/08/19 17:51:23 greg Exp $
3 greg 2.1 #
4     # Make a nice view of an object
5     # Arguments are scene input files
6     #
7     # This is a re-write of Greg's original objview.csh.
8     # The only extra functionality is that we accept a scene on STDIN
9     # if no file name is given.
10     #
11     # Axel, Nov 2013
12
13     use strict;
14     use warnings;
15     use File::Temp qw/ tempdir /;
16
17     my $td = tempdir( CLEANUP => 1 );
18     my $octree = "$td/ov$$.oct";
19     my $lights = "$td/lt$$.rad";
20     my $rif = "$td/ov$$.rif";
21     my $ambf = "$td/af$$.amb";
22     my $raddev = "x11"; # default output device. Overwrite with -o
23     my $up = "Z";
24     my $vw = "XYZ";
25
26     my $opts = ""; # Options common to rad and glrad
27     my $rendopts = ""; # For render= line in rif file
28     my $usegl = 0; # Run glrad instead of rad (Boolean).
29     my $radopt = 0; # An option specific to rad was passed (Boolean).
30     my $glradopt = 0; # An option specific to glrad was passed (Boolean).
31
32     while (@ARGV) {
33     $_ = $ARGV[0];
34 greg 2.2 if (m/^-g\b/) { # OpenGL output
35 greg 2.1 if ( $^O =~ /MSWin32/ ) {
36     die("OpenGL view is not available under Windows.\n");
37     }
38     $usegl = 1;
39 greg 2.2 } elsif (m/^-u\b/) { # up direction
40 greg 2.1 $up = $ARGV[1];
41     shift @ARGV;
42 greg 2.2 } elsif ((m/^-s\b/) or (m/^-w/)) { # silent, no warnings
43 greg 2.1 $opts .= " $_";
44 greg 2.2 } elsif (m/^-b/) { # back face visibility
45 greg 2.1 $rendopts .= ' -bv';
46 greg 2.2 } elsif (m/^-v\b/) { # standard view "[Xx]?[Yy]?[Zz]?[vlcahs]?"
47 greg 2.1 # Let rad do any error handling...
48     $vw = $ARGV[1];
49     shift @ARGV;
50 greg 2.3 } elsif (m/^-[nN]\b/) { # No. of parallel processes
51 greg 2.1 $opts .= ' -N ' . $ARGV[1];
52     $radopt = 1;
53     shift @ARGV;
54 greg 2.2 } elsif (m/^-o\b/) { # output device (rvu -devices)
55 greg 2.1 $raddev = $ARGV[1];
56     $radopt = 1;
57     shift @ARGV;
58 greg 2.2 } elsif ((m/^-V\b/) or (m/^-e\b/)) { # print view, explicate variables
59 greg 2.1 # Think of those two as '-verbose'.
60     $opts .= " $_";
61     $radopt = 1;
62 greg 2.2 } elsif (m/^-S\b/) { # full-screen stereo
63 greg 2.1 $opts .= " $_";
64     $glradopt = 1;
65     } elsif (m/^-\w/) {
66     die("objview: Bad option: $_\n");
67     } else {
68     last;
69     }
70     shift @ARGV;
71     }
72
73     # We need at least one Radiance file or a scene on STDIN
74     if ($#ARGV < 0) {
75     open(FH, ">$td/stdin.rad") or
76     die("objview: Can't write to temporary file $td/stdin.rad\n");
77     while (<>) {
78     print FH;
79     }
80     # Pretend stdin.rad was passed as argument.
81     @ARGV = ("$td/stdin.rad");
82     }
83
84     # Make sure we don't confuse glrad and rad options.
85     if ($usegl) {
86     if ($radopt) {
87     die("objview: glrad output requested, but rad option passed.\n");
88     }
89     } else {
90     if ($glradopt) {
91     die("objview: rad output requested, but glrad option passed.\n");
92     }
93     }
94
95     open(FH, ">$lights") or
96     die("objview: Can't write to temporary file $lights\n");
97     print FH <<EndOfLights;
98     void glow dim 0 0 4 .1 .1 .15 0
99     dim source background 0 0 4 0 0 1 360
100     void light bright 0 0 3 1000 1000 1000
101     bright source sun1 0 0 4 1 .2 1 5
102     bright source sun2 0 0 4 .3 1 1 5
103     bright source sun3 0 0 4 -1 -.7 1 5
104     EndOfLights
105     close(FH);
106
107     my @scenes = @ARGV;
108     push (@scenes, $lights);
109
110     # Make this work under Windoze
111     if ( $^O =~ /MSWin32/ ) {
112     for my $i (0 .. $#scenes) {
113     # rad doesn't like Windows-style backslashes.
114     $scenes[$i] =~ s{\\}{/}g;
115     }
116     $octree =~ s{\\}{/}g;
117     $ambf =~ s{\\}{/}g;
118     $raddev = "qt";
119     }
120
121     my $scene = join(' ', @scenes);
122     open(FH, ">$rif") or
123     die("objview: Can't write to temporary file $rif\n");
124     print FH <<EndOfRif;
125     scene= $scene
126     EXPOSURE= .5
127     UP= $up
128     view= $vw
129     OCTREE= $octree
130     oconv= -f
131     AMBF= $ambf
132     render= $rendopts
133     EndOfRif
134     close(FH);
135
136     if ($usegl) {
137     system "glrad $opts $rif";
138     } else {
139     system "rad -o $raddev $opts $rif";
140     }
141
142     #EOF
