root/radiance/ray/src/util/objview.csh
Tue Jan 13 22:19:25 2009 UTC (16 years, 5 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 2.11 , to selected 2.3
Added ambient file setting for rvu value sharing with -N > 1
Fri Nov 21 01:30:17 2008 UTC (16 years, 7 months ago) by greg
Changes since 2.10: +7 -2 lines
Diff to previous 2.10 , to selected 2.3
Added -N option to support multiprocessing in objview
Wed Feb 16 05:40:12 2005 UTC (20 years, 4 months ago) by greg
Diff to previous 2.9 , to selected 2.3
Fri Aug 20 23:45:59 2004 UTC (20 years, 10 months ago) by greg
Removed redundant -r option to oconv
Sat Feb 22 02:07:30 2003 UTC (22 years, 4 months ago) by greg
Thu Jun 11 08:57:37 1998 UTC (27 years ago) by gwlarson
Changes since 2.6: +9 -5 lines
changed -b option to work for both rad and glrad
Wed Jun 10 17:50:49 1998 UTC (27 years ago) by gwlarson
Changes since 2.5: +80 -8 lines
changed to use rad and glrad for rendering
Fri Feb 9 12:56:59 1996 UTC (29 years, 4 months ago) by greg
added error check for oconv
Wed Jan 6 10:46:47 1993 UTC (32 years, 5 months ago) by saba
added ability to get RVIEW command from environment
Revision 2.3 - (view) (download) (as text) (annotate) - [selected]
Mon Jan 4 16:37:10 1993 UTC (32 years, 5 months ago) by greg
fixed quoting of arguments
Wed Dec 23 11:56:41 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +13 -6 lines
modified objview to take scene files of any dimension as arguments
Tue Nov 12 17:19:28 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.3
Wed Apr 24 18:27:10 1991 UTC (34 years, 2 months ago) by greg
Diff to selected 2.3
Links to HEAD: (view) (download) (as text) (annotate)
