--- ray/src/util/objview.csh 1991/04/24 18:27:10 1.1 +++ ray/src/util/objview.csh 1998/06/10 17:50:49 2.6 @@ -1,19 +1,101 @@ #!/bin/csh -f -# SCCSid "$SunId$ LBL" +# SCCSid "$SunId$ SGI" # # Make a nice view of an object -# Standard input is description made to fit in unit cube in positive quadrant +# Arguments are scene input files # -set objdir=/usr/local/lib/ray/lib set tmpdir=/usr/tmp -set vw="-vp 3 3 3 -vd -1 -1 -1 -vh 20 -vv 20" -set rview="rview -av .2 .2 .2 $vw $*" set octree=$tmpdir/ov$$.oct -set tmpfiles="$octree" +set lights=$tmpdir/lt$$.rad +set rif=$tmpdir/ov$$.rif +set tmpfiles="$octree $lights $rif" +set up="Z" +set vw="XYZ" +set opts="" +while ($#argv > 0) + switch ($argv[1]) + case -g: + set usegl + breaksw + case -u: + shift argv + set up=$argv[1] + breaksw + case -s: + case -w: + set opts=($opts $argv[1]) + breaksw + case -v: + shift argv + set vw=$argv[1] + breaksw + case -o: + shift argv + set opts=($opts -o $argv[1]) + set radopt + breaksw + case -V: + case -e: + set opts=($opts $argv[1]) + set radopt + breaksw + case -S: + case -b: + set opts=($opts $argv[1]) + set glradopt + breaksw + case -*: + echo "Bad option: $argv[1]" + exit 1 + breaksw + default: + break + endsw + shift argv +end +if ( $#argv == 0 ) then + echo "No input files specified" + exit 1 +endif +if ( $?usegl ) then + if ( $?radopt ) then + echo "bad option for glrad" + glrad + exit 1 + endif +else + if ( $?glradopt ) then + echo "bad option for rad" + rad + exit 1 + endif +endif + onintr quit -oconv $objdir/testroom - > $octree -$rview $octree +cat > $lights <<_EOF_ +void glow dim 0 0 4 .1 .1 .15 0 +dim source background 0 0 4 0 0 1 360 +void light bright 0 0 3 1000 1000 1000 +bright source sun1 0 0 4 1 .2 1 5 +bright source sun2 0 0 4 .3 1 1 5 +bright source sun3 0 0 4 -1 -.7 1 5 +_EOF_ + +cat > $rif <<_EOF_ +scene= $argv[*]:q $lights +EXPOSURE= .5 +UP= $up +view= $vw +OCTREE= $octree +oconv= -f +_EOF_ + +if ( $?usegl ) then + glrad $opts $rif +else + rad -o x11 $opts $rif +endif quit: rm -f $tmpfiles
