1 |
greg |
1.1 |
#!/bin/csh -f |
2 |
greg |
2.12 |
# RCSid: $Id: objview.csh,v 2.11 2008/11/21 01:30:17 greg Exp $ |
3 |
greg |
1.1 |
4 |
# Make a nice view of an object |
5 |
greg |
2.2 |
# Arguments are scene input files |
6 |
greg |
1.1 |
7 |
greg |
2.10 |
set tmpdir=/tmp |
8 |
greg |
1.1 |
set octree=$tmpdir/ov$$.oct |
9 |
gwlarson |
2.6 |
set lights=$tmpdir/lt$$.rad |
10 |
set rif=$tmpdir/ov$$.rif |
11 |
greg |
2.12 |
set ambf=$tmpdir/af$$.amb |
12 |
set tmpfiles="$octree $lights $rif $ambf" |
13 |
gwlarson |
2.7 |
set raddev="x11" |
14 |
gwlarson |
2.6 |
set up="Z" |
15 |
set vw="XYZ" |
16 |
gwlarson |
2.7 |
set rendopts="" |
17 |
gwlarson |
2.6 |
set opts="" |
18 |
while ($#argv > 0) |
19 |
switch ($argv[1]) |
20 |
gwlarson |
2.7 |
case -g*: |
21 |
gwlarson |
2.6 |
set usegl |
22 |
breaksw |
23 |
case -u: |
24 |
shift argv |
25 |
set up=$argv[1] |
26 |
breaksw |
27 |
case -s: |
28 |
case -w: |
29 |
set opts=($opts $argv[1]) |
30 |
breaksw |
31 |
gwlarson |
2.7 |
case -b*: |
32 |
set rendopts=($rendopts -bv) |
33 |
breaksw |
34 |
gwlarson |
2.6 |
case -v: |
35 |
shift argv |
36 |
greg |
2.11 |
set vw="$argv[1]" |
37 |
breaksw |
38 |
case -N: |
39 |
shift argv |
40 |
set opts=($opts -N $argv[1]) |
41 |
set radopt |
42 |
gwlarson |
2.6 |
breaksw |
43 |
case -o: |
44 |
shift argv |
45 |
gwlarson |
2.7 |
set raddev="$argv[1]" |
46 |
gwlarson |
2.6 |
set radopt |
47 |
breaksw |
48 |
case -V: |
49 |
case -e: |
50 |
51 |
set radopt |
52 |
breaksw |
53 |
case -S: |
54 |
55 |
set glradopt |
56 |
breaksw |
57 |
case -*: |
58 |
echo "Bad option: $argv[1]" |
59 |
exit 1 |
60 |
default: |
61 |
break |
62 |
endsw |
63 |
shift argv |
64 |
end |
65 |
if ( $#argv == 0 ) then |
66 |
echo "No input files specified" |
67 |
exit 1 |
68 |
endif |
69 |
if ( $?usegl ) then |
70 |
if ( $?radopt ) then |
71 |
echo "bad option for glrad" |
72 |
glrad |
73 |
exit 1 |
74 |
endif |
75 |
else |
76 |
if ( $?glradopt ) then |
77 |
echo "bad option for rad" |
78 |
rad |
79 |
exit 1 |
80 |
endif |
81 |
endif |
82 |
83 |
greg |
1.1 |
onintr quit |
84 |
85 |
gwlarson |
2.6 |
cat > $lights <<_EOF_ |
86 |
greg |
2.2 |
void glow dim 0 0 4 .1 .1 .15 0 |
87 |
dim source background 0 0 4 0 0 1 360 |
88 |
void light bright 0 0 3 1000 1000 1000 |
89 |
bright source sun1 0 0 4 1 .2 1 5 |
90 |
bright source sun2 0 0 4 .3 1 1 5 |
91 |
bright source sun3 0 0 4 -1 -.7 1 5 |
92 |
_EOF_ |
93 |
94 |
gwlarson |
2.6 |
cat > $rif <<_EOF_ |
95 |
scene= $argv[*]:q $lights |
96 |
EXPOSURE= .5 |
97 |
UP= $up |
98 |
view= $vw |
99 |
OCTREE= $octree |
100 |
greg |
2.9 |
oconv= -f |
101 |
greg |
2.12 |
AMBF= $ambf |
102 |
gwlarson |
2.7 |
render= $rendopts |
103 |
gwlarson |
2.6 |
_EOF_ |
104 |
greg |
2.5 |
105 |
gwlarson |
2.6 |
106 |
glrad $opts $rif |
107 |
else |
108 |
gwlarson |
2.7 |
rad -o $raddev $opts $rif |
109 |
gwlarson |
2.6 |
endif |
110 |
greg |
1.1 |
111 |
quit: |
112 |
rm -f $tmpfiles |
113 |
exit 0 |
