--- ray/src/util/objview.csh 1992/12/23 11:56:41 2.2 +++ ray/src/util/objview.csh 2008/11/21 01:30:17 2.11 @@ -1,15 +1,87 @@ #!/bin/csh -f -# SCCSid "$SunId$ LBL" +# RCSid: $Id: objview.csh,v 2.11 2008/11/21 01:30:17 greg Exp $ # # Make a nice view of an object # Arguments are scene input files # -set tmpdir=/usr/tmp +set tmpdir=/tmp set octree=$tmpdir/ov$$.oct -set tmpfiles="$octree" +set lights=$tmpdir/lt$$.rad +set rif=$tmpdir/ov$$.rif +set tmpfiles="$octree $lights $rif" +set raddev="x11" +set up="Z" +set vw="XYZ" +set rendopts="" +set opts="" +while ($#argv > 0) + switch ($argv[1]) + case -g*: + set usegl + breaksw + case -u: + shift argv + set up=$argv[1] + breaksw + case -s: + case -w: + set opts=($opts $argv[1]) + breaksw + case -b*: + set rendopts=($rendopts -bv) + breaksw + case -v: + shift argv + set vw="$argv[1]" + breaksw + case -N: + shift argv + set opts=($opts -N $argv[1]) + set radopt + breaksw + case -o: + shift argv + set raddev="$argv[1]" + set radopt + breaksw + case -V: + case -e: + set opts=($opts $argv[1]) + set radopt + breaksw + case -S: + set opts=($opts $argv[1]) + set glradopt + breaksw + case -*: + echo "Bad option: $argv[1]" + exit 1 + default: + break + endsw + shift argv +end +if ( $#argv == 0 ) then + echo "No input files specified" + exit 1 +endif +if ( $?usegl ) then + if ( $?radopt ) then + echo "bad option for glrad" + glrad + exit 1 + endif +else + if ( $?glradopt ) then + echo "bad option for rad" + rad + exit 1 + endif +endif + onintr quit -oconv - $* > $octree <<_EOF_ +cat > $lights <<_EOF_ void glow dim 0 0 4 .1 .1 .15 0 dim source background 0 0 4 0 0 1 360 void light bright 0 0 3 1000 1000 1000 @@ -18,9 +90,21 @@ bright source sun2 0 0 4 .3 1 1 5 bright source sun3 0 0 4 -1 -.7 1 5 _EOF_ -set vp=`getinfo -d <$octree|rcalc -e '$1=$1-3.5*$4;$2=$2-3.5*$4;$3=$3+2.5*$4'` +cat > $rif <<_EOF_ +scene= $argv[*]:q $lights +EXPOSURE= .5 +UP= $up +view= $vw +OCTREE= $octree +oconv= -f +render= $rendopts +_EOF_ -rview -av .2 .2 .2 -vp $vp -vd 1 1 -.5 -vv 15 -vh 15 $octree +if ( $?usegl ) then + glrad $opts $rif +else + rad -o $raddev $opts $rif +endif quit: rm -f $tmpfiles
