root/radiance/ray/src/util/objview.csh
Revision: 2.6
Committed: Wed Jun 10 17:50:49 1998 UTC (26 years, 10 months ago) by gwlarson
Content type: application/x-csh
Changes since 2.5: +80 -8 lines
changed to use rad and glrad for rendering
1 #!/bin/csh -f
2 # SCCSid "$SunId$ SGI"
3 #
4 # Make a nice view of an object
5 # Arguments are scene input files
6 #
7 set tmpdir=/usr/tmp
8 set octree=$tmpdir/ov$$.oct
9 set lights=$tmpdir/lt$$.rad
10 set rif=$tmpdir/ov$$.rif
11 set tmpfiles="$octree $lights $rif"
12 set up="Z"
13 set vw="XYZ"
14 set opts=""
15 while ($#argv > 0)
16 switch ($argv[1])
17 case -g:
18 set usegl
19 breaksw
20 case -u:
21 shift argv
22 set up=$argv[1]
23 breaksw
24 case -s:
25 case -w:
26 set opts=($opts $argv[1])
27 breaksw
28 case -v:
29 shift argv
30 set vw=$argv[1]
31 breaksw
32 case -o:
33 shift argv
34 set opts=($opts -o $argv[1])
35 set radopt
36 breaksw
37 case -V:
38 case -e:
39 set opts=($opts $argv[1])
40 set radopt
41 breaksw
42 case -S:
43 case -b:
44 set opts=($opts $argv[1])
45 set glradopt
46 breaksw
47 case -*:
48 echo "Bad option: $argv[1]"
49 exit 1
50 breaksw
51 default:
52 break
53 endsw
54 shift argv
55 end
56 if ( $#argv == 0 ) then
57 echo "No input files specified"
58 exit 1
59 endif
60 if ( $?usegl ) then
61 if ( $?radopt ) then
62 echo "bad option for glrad"
63 glrad
64 exit 1
65 endif
66 else
67 if ( $?glradopt ) then
68 echo "bad option for rad"
69 rad
70 exit 1
71 endif
72 endif
73
74 onintr quit
75
76 cat > $lights <<_EOF_
77 void glow dim 0 0 4 .1 .1 .15 0
78 dim source background 0 0 4 0 0 1 360
79 void light bright 0 0 3 1000 1000 1000
80 bright source sun1 0 0 4 1 .2 1 5
81 bright source sun2 0 0 4 .3 1 1 5
82 bright source sun3 0 0 4 -1 -.7 1 5
83 _EOF_
84
85 cat > $rif <<_EOF_
86 scene= $argv[*]:q $lights
87 EXPOSURE= .5
88 UP= $up
89 view= $vw
90 OCTREE= $octree
91 oconv= -f
92 _EOF_
93
94 if ( $?usegl ) then
95 glrad $opts $rif
96 else
97 rad -o x11 $opts $rif
98 endif
99
100 quit:
101 rm -f $tmpfiles
102 exit 0
