root/radiance/ray/src/util/objview.csh
Fri Aug 20 23:45:59 2004 UTC (19 years, 8 months ago) by greg
Removed redundant -r option to oconv
Thu Jun 11 08:57:37 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 2.6: +9 -5 lines
changed -b option to work for both rad and glrad
Wed Jun 10 17:50:49 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 2.5: +80 -8 lines
changed to use rad and glrad for rendering
Fri Feb 9 12:56:59 1996 UTC (28 years, 2 months ago) by greg
added error check for oconv
Revision 2.4 - (view) (download) (as text) (annotate) - [selected]
Wed Jan 6 10:46:47 1993 UTC (31 years, 4 months ago) by saba
added ability to get RVIEW command from environment
Mon Jan 4 16:37:10 1993 UTC (31 years, 4 months ago) by greg
fixed quoting of arguments
Wed Dec 23 11:56:41 1992 UTC (31 years, 4 months ago) by greg
Changes since 2.1: +13 -6 lines
modified objview to take scene files of any dimension as arguments
Tue Nov 12 17:19:28 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1 , to selected 2.4
Wed Apr 24 18:27:10 1991 UTC (33 years ago) by greg
Diff to selected 2.4
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R6P1: (view) (download) (as text) (annotate)
