root/Development/ray/src/util/objview.csh
Wed Feb 16 05:40:12 2005 UTC (20 years, 10 months ago) by greg
Fri Aug 20 23:45:59 2004 UTC (21 years, 4 months ago) by greg
Removed redundant -r option to oconv
Sat Feb 22 02:07:30 2003 UTC (22 years, 10 months ago) by greg
Thu Jun 11 08:57:37 1998 UTC (27 years, 7 months ago) by gwlarson
Changes since 2.6: +9 -5 lines
changed -b option to work for both rad and glrad
Wed Jun 10 17:50:49 1998 UTC (27 years, 7 months ago) by gwlarson
Changes since 2.5: +80 -8 lines
changed to use rad and glrad for rendering
Fri Feb 9 12:56:59 1996 UTC (29 years, 11 months ago) by greg
added error check for oconv
Wed Jan 6 10:46:47 1993 UTC (33 years ago) by saba
added ability to get RVIEW command from environment
Mon Jan 4 16:37:10 1993 UTC (33 years ago) by greg
fixed quoting of arguments
Wed Dec 23 11:56:41 1992 UTC (33 years ago) by greg
Changes since 2.1: +13 -6 lines
Diff to previous 2.1
modified objview to take scene files of any dimension as arguments
Tue Nov 12 17:19:28 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Wed Apr 24 18:27:10 1991 UTC (34 years, 8 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R7P1: (view) (download) (as text) (annotate)
