root/radiance/ray/src/util/objpict.pl
Revision: 2.1
Committed: Wed Dec 4 20:07:07 2013 UTC (11 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Error occurred while calculating annotation data.
1 #!/usr/bin/perl
2 # RCSid $Id$
3 #
4 # Make a nice multi-view picture of an object
5 # Command line arguments contain materials and object files
6 #
7 # This is a re-write of Greg's objpict.csh and should be a drop-in
8 # replacement, with no funcionality added or removed
9
10 use strict;
11 use warnings;
12
13 use File::Temp qw/ tempdir /;
14 my $td = tempdir( CLEANUP => 1 );
15
16 my $xres = 1024;
17 my $yres = 1024;
18 my $rpict_cmd = "rpict -av .2 .2 .2 -x $xres -y $yres";
19
20 my $testroom = "$td/testroom.rad";
21 my $octree = "$td/op.oct";
22
23 # We need at least one Radiance file or a scene on STDIN (but not both)
24 if ($#ARGV < 0) {
25 open(FH, ">$td/stdin.rad") or
26 die("objview: Can't write to temporary file $td/stdin.rad\n");
27 while (<>) {
28 print FH;
29 }
30 # Pretend stdin.rad was passed as argument.
31 @ARGV = ("$td/stdin.rad");
32 }
33
34 # Create some lights and a box as back drop.
35 # The objects and view points will be inside the box.
36 open(FH, ">$testroom") or
37 die("Can\'t write to temporary file $testroom");
38 print FH <<EndOfTestroom;
39 void plastic wall_mat 0 0 5 .681 .543 .686 0 .2
40 void light bright 0 0 3 3000 3000 3000
41
42 bright sphere lamp0 0 0 4 4 4 -4 .1
43 bright sphere lamp1 0 0 4 4 0 4 .1
44 bright sphere lamp2 0 0 4 0 4 4 .1
45
46 wall_mat polygon box.1540 0 0 12 5 -5 -5 5 -5 5 -5 -5 5 -5 -5 -5
47 wall_mat polygon box.4620 0 0 12 -5 -5 5 -5 5 5 -5 5 -5 -5 -5 -5
48 wall_mat polygon box.2310 0 0 12 -5 5 -5 5 5 -5 5 -5 -5 -5 -5 -5
49 wall_mat polygon box.3267 0 0 12 5 5 -5 -5 5 -5 -5 5 5 5 5 5
50 wall_mat polygon box.5137 0 0 12 5 -5 5 5 -5 -5 5 5 -5 5 5 5
51 wall_mat polygon box.6457 0 0 12 -5 5 5 -5 -5 5 5 -5 5 5 5 5
52 EndOfTestroom
53 close(FH);
54
55 my $dimstr = `getbbox -h @ARGV`;
56 chomp $dimstr;
57 # Values returned by getbbox are indented and delimited with multiple spaces.
58 $dimstr =~ s/^\s+//; # remove leading spaces
59 my @dims = split(/\s+/, $dimstr); # convert to array
60
61 # Find largest axes-aligned dimension
62 my @diffs = ($dims[1]-$dims[0], $dims[3]-$dims[2], $dims[5]-$dims[4]);
63 @diffs = reverse sort { $a <=> $b } @diffs;
64 my $size = $diffs[0];
65
66 # Define the four views
67 my $vw1 = "-vtl -vp 2 .5 .5 -vd -1 0 0 -vh 1 -vv 1";
68 my $vw2 = "-vtl -vp .5 2 .5 -vd 0 -1 0 -vh 1 -vv 1";
69 my $vw3 = "-vtl -vp .5 .5 2 -vd 0 0 -1 -vu -1 0 0 -vh 1 -vv 1";
70 my $vw4 = "-vp 3 3 3 -vd -1 -1 -1 -vh 20 -vv 20";
71
72 # Move objects so centre is at origin
73 my $xtrans = -1.0 * ($dims[0] + $dims[1]) / 2;
74 my $ytrans = -1.0 * ($dims[2] + $dims[3]) / 2;
75 my $ztrans = -1.0 * ($dims[4] + $dims[5]) / 2;
76 # Scale so that largest object dimension is unity
77 my $scale = 1 / $size;
78
79 my $cmd = "xform -t $xtrans $ytrans $ztrans -s $scale -t .5 .5 .5 @ARGV";
80 $cmd .= " |oconv $testroom - > $octree";
81 system "$cmd";
82
83 # Render four different views of the objects
84 system "$rpict_cmd $vw1 $octree > $td/right.hdr";
85 system "$rpict_cmd $vw2 $octree > $td/front.hdr";
86 system "$rpict_cmd $vw3 $octree > $td/down.hdr";
87 system "$rpict_cmd $vw4 $octree > $td/oblique.hdr";
88
89 # Compose the four views into one image
90 $cmd = "pcompos $td/down.hdr 0 $xres $td/oblique.hdr $xres $yres";
91 $cmd .= " $td/right.hdr 0 0 $td/front.hdr $xres 0";
92 $cmd .= " |pfilt -1 -r .6 -x /2 -y /2";
93 exec "$cmd";
94
95 #EOF
