root/radiance/ray/src/util/objline.csh
Sun Nov 30 19:56:02 2008 UTC (16 years, 8 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.5: +9 -7 lines
Made script more robust to different file names
Revision 2.5 - (view) (download) (as text) (annotate) - [selected]
Mon Aug 25 04:50:32 2008 UTC (16 years, 11 months ago) by greg
Made temporary files safe from malicious attackers
Wed Feb 16 05:40:12 2005 UTC (20 years, 6 months ago) by greg
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
Fri Nov 3 09:32:18 1995 UTC (29 years, 9 months ago) by greg
Changes since 2.1: +2 -4 lines
use 'i' instead of 'xf' entity
Thu Oct 26 19:23:11 1995 UTC (29 years, 9 months ago) by greg
Diff to selected 2.5
Links to HEAD: (view) (download) (as text) (annotate)
