| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: normcodec.c,v 2.2 2019/07/19 02:25:02 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines to encode/decode 32-bit normals
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "rtio.h"
| 11 |
#include "rtmath.h"
| 12 |
#include "normcodec.h"
| 13 |
| 14 |
| 15 |
/* Set codec defaults */
| 16 |
void
| 17 |
set_nc_defaults(NORMCODEC *ncp)
| 18 |
| 19 |
memset(ncp, 0, sizeof(NORMCODEC));
| 20 |
ncp->finp = stdin;
| 21 |
ncp->inpname = "<stdin>";
| 22 |
ncp->format = 'a';
| 23 |
ncp->res.rt = PIXSTANDARD;
| 24 |
if (!progname) progname = "norm_codec";
| 25 |
| 26 |
| 27 |
| 28 |
/* process header line */
| 29 |
static int
| 30 |
headline(char *s, void *p)
| 31 |
| 32 |
NORMCODEC *ncp = (NORMCODEC *)p;
| 33 |
| 34 |
if (formatval(ncp->inpfmt, s)) /* don't pass format */
| 35 |
return 0;
| 36 |
| 37 |
if (ncp->hdrflags & HF_HEADOUT)
| 38 |
fputs(s, stdout); /* copy to standard output */
| 39 |
return 1;
| 40 |
| 41 |
| 42 |
| 43 |
/* Load/copy header */
| 44 |
int
| 45 |
process_nc_header(NORMCODEC *ncp, int ac, char *av[])
| 46 |
| 47 |
if (ncp->hdrflags & HF_HEADIN &&
| 48 |
getheader(ncp->finp, headline, ncp) < 0) {
| 49 |
fputs(ncp->inpname, stderr);
| 50 |
fputs(": bad header\n", stderr);
| 51 |
return 1;
| 52 |
| 53 |
if (ncp->hdrflags & HF_HEADOUT) { /* finish header */
| 54 |
if (!(ncp->hdrflags & HF_HEADIN))
| 55 |
newheader("RADIANCE", stdout);
| 56 |
if (ac > 0)
| 57 |
printargs(ac, av, stdout);
| 58 |
if (ncp->hdrflags & HF_ENCODE) {
| 59 |
fputformat(NORMAL32FMT, stdout);
| 60 |
} else
| 61 |
switch (ncp->format) {
| 62 |
case 'a':
| 63 |
fputformat("ascii", stdout);
| 64 |
break;
| 65 |
case 'f':
| 66 |
fputformat("float", stdout);
| 67 |
break;
| 68 |
case 'd':
| 69 |
fputformat("double", stdout);
| 70 |
break;
| 71 |
| 72 |
fputc('\n', stdout);
| 73 |
| 74 |
/* get/put resolution string */
| 75 |
if (ncp->hdrflags & HF_RESIN && !fgetsresolu(&ncp->res, ncp->finp)) {
| 76 |
| 77 |
fputs(": bad resolution string\n", stderr);
| 78 |
return 1;
| 79 |
| 80 |
if (ncp->hdrflags & HF_RESOUT)
| 81 |
fputsresolu(&ncp->res, stdout);
| 82 |
| 83 |
ncp->dstart = ncp->curpos = ftell(ncp->finp);
| 84 |
return 1;
| 85 |
| 86 |
| 87 |
| 88 |
/* Check that we have what we need to decode normals */
| 89 |
int
| 90 |
check_decode_normals(NORMCODEC *ncp)
| 91 |
| 92 |
| 93 |
fputs(progname, stderr);
| 94 |
fputs(": wrong header mode for decode\n", stderr);
| 95 |
return 0;
| 96 |
| 97 |
if (ncp->inpfmt[0] && strcmp(ncp->inpfmt, NORMAL32FMT)) {
| 98 |
| 99 |
fputs(": unexpected input format: ", stderr);
| 100 |
fputs(ncp->inpfmt, stderr);
| 101 |
fputc('\n', stderr);
| 102 |
return 0;
| 103 |
| 104 |
return 1;
| 105 |
| 106 |
| 107 |
| 108 |
/* Decode next normal from input */
| 109 |
int
| 110 |
decode_normal_next(FVECT nrm, NORMCODEC *ncp)
| 111 |
| 112 |
int32 c = getint(4, ncp->finp);
| 113 |
| 114 |
if (c == EOF && feof(ncp->finp))
| 115 |
return -1;
| 116 |
| 117 |
ncp->curpos += 4;
| 118 |
| 119 |
decodedir(nrm, c);
| 120 |
| 121 |
return (c != 0);
| 122 |
| 123 |
| 124 |
| 125 |
/* Seek to the indicated pixel position */
| 126 |
int
| 127 |
seek_nc_pix(NORMCODEC *ncp, int x, int y)
| 128 |
| 129 |
long seekpos;
| 130 |
| 131 |
if ((ncp->res.xr <= 0) | (ncp->res.yr <= 0)) {
| 132 |
| 133 |
fputs(": need map resolution to seek\n", stderr);
| 134 |
return -1;
| 135 |
| 136 |
if ((x < 0) | (y < 0) ||
| 137 |
(x >= scanlen(&ncp->res)) | (y >= numscans(&ncp->res))) {
| 138 |
| 139 |
fputs(": warning - pixel index off map\n", stderr);
| 140 |
return 0;
| 141 |
| 142 |
seekpos = ncp->dstart + 4*((long)y*scanlen(&ncp->res) + x);
| 143 |
| 144 |
if (seekpos != ncp->curpos &&
| 145 |
fseek(ncp->finp, seekpos, SEEK_SET) == EOF) {
| 146 |
| 147 |
fputs(": seek error\n", stderr);
| 148 |
return -1;
| 149 |
| 150 |
ncp->curpos = seekpos;
| 151 |
return 1;
| 152 |
| 153 |
| 154 |
| 155 |
/* Read and decode normal for the given pixel */
| 156 |
int
| 157 |
decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y)
| 158 |
| 159 |
int rval = seek_nc_pix(ncp, x, y);
| 160 |
| 161 |
if (rval < 0)
| 162 |
return -1;
| 163 |
| 164 |
if (!rval) {
| 165 |
nrm[0] = nrm[1] = nrm[2] = .0;
| 166 |
return 0;
| 167 |
| 168 |
return decode_normal_next(nrm, ncp);
| 169 |
