root/radiance/ray/src/util/normcodec.c
Revision: 2.1
Committed: Fri Jul 19 02:18:44 2019 UTC (4 years, 10 months ago) by greg
2 static const char RCSid[] = "$Id: depthcodec.c,v 2.2 2019/07/18 22:33:34 greg Exp $";
5 * Routines to encode/decoded 16-bit depths
6 */
7
8 #include "copyright.h"
9
10 #include "rtio.h"
11 #include "rtmath.h"
12 #include "normcodec.h"
13
14
15 /* Set codec defaults */
16 void
17 set_nc_defaults(NORMCODEC *ncp)
18 {
19 memset(ncp, 0, sizeof(NORMCODEC));
20 ncp->finp = stdin;
21 ncp->inpname = "<stdin>";
22 ncp->format = 'a';
23 ncp->res.rt = PIXSTANDARD;
24 if (!progname) progname = "norm_codec";
25 }
26
27
28 /* process header line */
29 static int
30 headline(char *s, void *p)
31 {
32 NORMCODEC *ncp = (NORMCODEC *)p;
33
34 if (formatval(ncp->inpfmt, s)) /* don't pass format */
35 return 0;
36
37 if (ncp->hdrflags & HF_HEADOUT)
38 fputs(s, stdout); /* copy to standard output */
39 return 1;
40 }
41
42
43 /* Load/copy header */
44 int
45 process_nc_header(NORMCODEC *ncp, int ac, char *av[])
46 {
47 if (ncp->hdrflags & HF_HEADIN &&
48 getheader(ncp->finp, headline, ncp) < 0) {
49 fputs(ncp->inpname, stderr);
50 fputs(": bad header\n", stderr);
51 return 1;
52 }
53 if (ncp->hdrflags & HF_HEADOUT) { /* finish header */
54 if (!(ncp->hdrflags & HF_HEADIN))
55 newheader("RADIANCE", stdout);
56 if (ac > 0)
57 printargs(ac, av, stdout);
58 if (ncp->hdrflags & HF_ENCODE) {
59 fputformat(NORMAL32FMT, stdout);
60 } else
61 switch (ncp->format) {
62 case 'a':
63 fputformat("ascii", stdout);
64 break;
65 case 'f':
66 fputformat("float", stdout);
67 break;
68 case 'd':
69 fputformat("double", stdout);
70 break;
71 }
72 fputc('\n', stdout);
73 }
74 /* get/put resolution string */
75 if (ncp->hdrflags & HF_RESIN && !fgetsresolu(&ncp->res, ncp->finp)) {
76 fputs(ncp->inpname, stderr);
77 fputs(": bad resolution string\n", stderr);
78 return 1;
79 }
80 if (ncp->hdrflags & HF_RESOUT)
81 fputsresolu(&ncp->res, stdout);
82
83 ncp->dstart = ncp->curpos = ftell(ncp->finp);
84 return 1;
85 }
86
87
88 /* Check that we have what we need to decode depths */
89 int
90 check_decode_normals(NORMCODEC *ncp)
91 {
92 if (ncp->hdrflags & HF_ENCODE) {
93 fputs(progname, stderr);
94 fputs(": wrong header mode for decode\n", stderr);
95 return 0;
96 }
97 if (ncp->inpfmt[0] && strcmp(ncp->inpfmt, NORMAL32FMT)) {
98 fputs(ncp->inpname, stderr);
99 fputs(": unexpected input format: ", stderr);
100 fputs(ncp->inpfmt, stderr);
101 fputc('\n', stderr);
102 return 0;
103 }
104 return 1;
105 }
106
107
108 /* Decode next normal from input */
109 int
110 decode_normal_next(FVECT nrm, NORMCODEC *ncp)
111 {
112 int32 c = getint(4, ncp->finp);
113
114 if (c == EOF && feof(ncp->finp))
115 return -1;
116
117 ncp->curpos += 4;
118
119 decodedir(nrm, c);
120
121 return (c != 0);
122 }
123
124
125 /* Seek to the indicated pixel position */
126 int
127 seek_nc_pix(NORMCODEC *ncp, int x, int y)
128 {
129 long seekpos;
130
131 if ((ncp->res.xr <= 0) | (ncp->res.yr <= 0)) {
132 fputs(progname, stderr);
133 fputs(": need map resolution to seek\n", stderr);
134 return -1;
135 }
136 if ((x < 0) | (y < 0) ||
137 (x >= scanlen(&ncp->res)) | (y >= numscans(&ncp->res))) {
138 fputs(ncp->inpname, stderr);
139 fputs(": warning - pixel index off map\n", stderr);
140 return 0;
141 }
142 seekpos = ncp->dstart + 4*((long)y*scanlen(&ncp->res) + x);
143
144 if (seekpos != ncp->curpos &&
145 fseek(ncp->finp, seekpos, SEEK_SET) == EOF) {
146 fputs(ncp->inpname, stderr);
147 fputs(": seek error\n", stderr);
148 return -1;
149 }
150 ncp->curpos = seekpos;
151 return 1;
152 }
153
154
155 /* Read and decode depth for the given pixel */
156 int
157 decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y)
158 {
159 int rval = seek_nc_pix(ncp, x, y);
160
161 if (rval < 0)
162 return -1;
163
164 if (!rval) {
165 nrm[0] = nrm[1] = nrm[2] = .0;
166 return 0;
167 }
168 return decode_normal_next(nrm, ncp);
169 }
