root/radiance/ray/src/util/netproc.c
Revision: 2.7
Committed: Thu Oct 16 13:48:49 1997 UTC (27 years, 6 months ago) by gregl
added ifdef for INCL_SEL_H since not every system has it
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Parallel network process handling routines
9 */
10
11 #include <stdio.h>
12 #include <sys/types.h>
13 #ifdef INCL_SEL_H
14 #include <sys/select.h>
15 #endif
16 #include <signal.h>
17 #include <fcntl.h>
18 #include "netproc.h"
19 #include "paths.h"
20 #include "vfork.h"
21 /* select call compatibility stuff */
22 #ifndef FD_SETSIZE
23 #include <sys/param.h>
24 #define FD_SETSIZE NOFILE /* maximum # select file descriptors */
25 #endif
26 #ifndef FD_SET
27 #ifndef NFDBITS
28 #define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */
29 #endif
30 #define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS)))
31 #define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS)))
32 #define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS)))
33 #ifndef BSD
34 #define bzero(d,n) (void)memset(d,0,n)
35 #endif
36 #define FD_ZERO(p) bzero((char *)(p), sizeof(*(p)))
37 #endif
38
39 PSERVER *pslist = NULL; /* global process server list */
40
41 static PROC *pindex[FD_SETSIZE]; /* process index table */
42
43 static char ourhost[64]; /* this host name */
44 static char ourdir[MAXPATH]; /* our working directory */
45 static char ouruser[32]; /* our user name */
46 static char *ourshell; /* our user's shell */
47
48 static fd_set errdesc; /* error file descriptors */
49 static int maxfd; /* maximum assigned descriptor */
50
51 extern char *remsh; /* externally defined remote shell program */
52
53 extern char *malloc(), *realloc();
54 extern char *getenv();
55
56
57 PSERVER *
58 addpserver(host, dir, usr, np) /* add a new process server */
59 char *host, *dir, *usr;
60 int np;
61 {
62 register PSERVER *ps;
63 /* allocate the struct */
64 if (np < 1)
65 return(NULL);
66 ps = (PSERVER *)malloc(sizeof(PSERVER)+(np-1)*sizeof(PROC));
67 if (ps == NULL)
68 return(NULL);
69 if (!ourhost[0]) { /* initialize */
70 char dirtmp[MAXPATH];
71 register char *cp;
72 register int len;
73
74 strcpy(ourhost, myhostname());
75 getwd(dirtmp);
76 if ((cp = getenv("HOME")) != NULL) {
77 if (!strcmp(cp, dirtmp))
78 ourdir[0] = '\0';
79 else if (!strncmp(cp, dirtmp, len=strlen(cp)) &&
80 dirtmp[len] == '/')
81 strcpy(ourdir, dirtmp+len+1);
82 else
83 strcpy(ourdir, dirtmp);
84 } else
85 strcpy(ourdir, dirtmp);
86 if ((cp = getenv("USER")) != NULL)
87 strcpy(ouruser, cp);
88 if ((ourshell = getenv("SHELL")) == NULL)
89 ourshell = "/bin/sh";
90 FD_ZERO(&errdesc);
91 maxfd = -1;
92 }
93 /* assign host, directory, user */
94 if (host == NULL || !strcmp(host, ourhost) ||
95 !strcmp(host, LHOSTNAME))
96 ps->hostname[0] = '\0';
97 else
98 strcpy(ps->hostname, host);
99 if (dir == NULL)
100 strcpy(ps->directory, ourdir);
101 else
102 strcpy(ps->directory, dir);
103 if (usr == NULL || !strcmp(usr, ouruser))
104 ps->username[0] = '\0';
105 else
106 strcpy(ps->username, usr);
107 /* clear process slots */
108 ps->nprocs = np;
109 while (np--) {
110 ps->proc[np].com = NULL;
111 ps->proc[np].pid = -1;
112 ps->proc[np].efd = -1;
113 ps->proc[np].errs = NULL;
114 ps->proc[np].elen = 0;
115 ps->proc[np].cf = NULL;
116 }
117 /* insert in our list */
118 ps->next = pslist;
119 pslist = ps;
120 /* check for signs of life */
121 if (!pserverOK(ps)) {
122 delpserver(ps); /* failure -- abort */
123 return(NULL);
124 }
125 return(ps);
126 }
127
128
129 delpserver(ps) /* delete a process server */
130 PSERVER *ps;
131 {
132 PSERVER pstart;
133 register PSERVER *psp;
134 register int i;
135 /* find server in our list */
136 pstart.next = pslist;
137 for (psp = &pstart; ps != psp->next; psp = psp->next)
138 if (psp->next == NULL)
139 return; /* not in our list! */
140 /* kill any running jobs */
141 for (i = 0; i < ps->nprocs; i++)
142 if (ps->proc[i].com != NULL) {
143 kill(SIGTERM, ps->proc[i].pid);
144 wait4job(ps, ps->proc[i].pid);
145 }
146 /* remove server from list */
147 psp->next = ps->next;
148 pslist = pstart.next;
149 free((char *)ps); /* free associated memory */
150 }
151
152
153 PSERVER *
154 findjob(pnp) /* find out where process is running */
155 register int *pnp; /* modified */
156 {
157 register PSERVER *ps;
158 register int i;
159
160 for (ps = pslist; ps != NULL; ps = ps->next)
161 for (i = 0; i < ps->nprocs; i++)
162 if (ps->proc[i].pid == *pnp) {
163 *pnp = i;
164 return(ps);
165 }
166 return(NULL); /* not found */
167 }
168
169
170 int
171 startjob(ps, command, compf) /* start a job on a process server */
172 register PSERVER *ps;
173 char *command;
174 int (*compf)();
175 {
176 char udirt[MAXPATH];
177 char *av[16];
178 int pfd[2], pid;
179 register int i;
180
181 if (ps == NULL) { /* find a server */
182 for (ps = pslist; ps != NULL; ps = ps->next)
183 if ((i = startjob(ps, command, compf)) != -1)
184 return(i); /* got one */
185 return(-1); /* no slots anywhere */
186 }
187 for (i = 0; i < ps->nprocs; i++)
188 if (ps->proc[i].com == NULL)
189 break;
190 if (i >= ps->nprocs)
191 return(-1); /* out of process slots */
192 /* open pipe */
193 if (pipe(pfd) < 0) {
194 perror("cannot open pipe");
195 exit(1);
196 }
197 /* start child process */
198 if ((pid = vfork()) == 0) {
199 close(pfd[0]); /* connect stderr to pipe */
200 if (pfd[1] != 2) {
201 dup2(pfd[1], 2);
202 close(pfd[1]);
203 }
204 if (ps->hostname[0]) { /* rsh command */
205 av[i=0] = remsh;
206 av[++i] = ps->hostname;
207 av[++i] = "-n"; /* no stdin */
208 if (ps->username[0]) { /* different user */
209 av[++i] = "-l";
210 av[++i] = ps->username;
211 av[++i] = "cd";
212 udirt[0] = '~';
213 strcpy(udirt+1, ouruser);
214 av[++i] = udirt;
215 av[++i] = ";";
216 }
217 if (ps->directory[0]) { /* change directory */
218 av[++i] = "cd";
219 av[++i] = ps->directory;
220 av[++i] = ";";
221 }
222 av[++i] = command;
223 av[++i] = NULL;
224 } else { /* shell command */
225 av[0] = ourshell;
226 av[1] = "-c";
227 av[2] = command;
228 av[3] = NULL;
229 }
230 execv(av[0], av);
231 _exit(1);
232 }
233 if (pid == -1) {
234 perror("fork failed");
235 exit(1);
236 }
237 ps->proc[i].com = command; /* assign process slot */
238 ps->proc[i].cf = compf;
239 ps->proc[i].pid = pid;
240 close(pfd[1]); /* get piped stderr file descriptor */
241 ps->proc[i].efd = pfd[0];
242 fcntl(pfd[0], F_SETFD, 1); /* set close on exec flag */
243 pindex[pfd[0]] = ps->proc + i; /* assign error fd index */
244 FD_SET(pfd[0], &errdesc); /* add to select call parameter */
245 if (pfd[0] > maxfd)
246 maxfd = pfd[0];
247 return(pid); /* return to parent process */
248 }
249
250
251 static int
252 readerrs(fd) /* read error output from fd */
253 int fd;
254 {
255 char errbuf[BUFSIZ];
256 int nr;
257 register PROC *pp;
258 /* look up associated process */
259 if ((pp = pindex[fd]) == NULL)
260 abort(); /* serious consistency error */
261 nr = read(fd, errbuf, BUFSIZ-1);
262 if (nr < 0) {
263 perror("read error");
264 exit(1);
265 }
266 if (nr == 0) /* stream closed (process finished) */
267 return(0);
268 errbuf[nr] = '\0'; /* add to error buffer */
269 if (pp->elen == 0)
270 pp->errs = (char *)malloc(nr+1);
271 else
272 pp->errs = (char *)realloc(pp->errs, pp->elen+nr+1);
273 if (pp->errs == NULL) {
274 perror("malloc failed");
275 exit(1);
276 }
277 strcpy(pp->errs+pp->elen, errbuf);
278 pp->elen += nr;
279 return(nr);
280 }
281
282
283 static
284 wait4end() /* read error streams until someone is done */
285 {
286 fd_set readfds, excepfds;
287 register int i;
288 /* find end of descriptor set */
289 for ( ; maxfd >= 0; maxfd--)
290 if (FD_ISSET(maxfd, &errdesc))
291 break;
292 if (maxfd < 0)
293 return; /* nothing to read */
294 readfds = excepfds = errdesc;
295 while (select(maxfd+1, &readfds, NULL, &excepfds, NULL) > 0)
296 for (i = 0; i <= maxfd; i++) /* get pending i/o */
297 if (FD_ISSET(i, &readfds) || FD_ISSET(i, &excepfds))
298 if (readerrs(i) == 0)
299 return; /* finished process */
300 perror("select call failed");
301 exit(1);
302 }
303
304
305 static int
306 finishjob(ps, pn, status) /* clean up finished process */
307 PSERVER *ps;
308 int pn;
309 int status;
310 {
311 register PROC *pp;
312
313 pp = ps->proc + pn;
314 if (pp->cf != NULL) /* client cleanup */
315 status = (*pp->cf)(ps, pn, status);
316 close(pp->efd); /* close error stream */
317 pindex[pp->efd] = NULL;
318 FD_CLR(pp->efd, &errdesc);
319 free((char *)pp->errs);
320 pp->com = NULL; /* clear settings */
321 pp->pid = -1;
322 pp->efd = -1;
323 pp->errs = NULL;
324 pp->elen = 0;
325 pp->cf = NULL;
326 return(status);
327 }
328
329
330 int
331 wait4job(ps, pid) /* wait for process to finish */
332 PSERVER *ps;
333 int pid;
334 {
335 int status, psn, psn2;
336 PSERVER *ps2;
337
338 if (pid == -1) { /* wait for first job */
339 if (ps != NULL) {
340 for (psn = ps->nprocs; psn--; )
341 if (ps->proc[psn].com != NULL)
342 break;
343 if (psn < 0)
344 return(-1); /* no processes this server */
345 }
346 do {
347 wait4end(); /* wait for something to end */
348 if ((psn2 = wait(&status)) == -1)
349 return(-1); /* none left */
350 ps2 = findjob(&psn2);
351 if (ps2 != NULL) /* clean up job if ours */
352 status = finishjob(ps2, psn2, status);
353 } while (ps2 == NULL || (ps != NULL && ps2 != ps));
354 return(status); /* return job status */
355 }
356 psn = pid; /* else find specific job */
357 ps2 = findjob(&psn); /* find process slot */
358 if (ps2 == NULL || (ps != NULL && ps2 != ps))
359 return(-1); /* inconsistent target */
360 ps = ps2;
361 do {
362 wait4end(); /* wait for something to end */
363 if ((psn2 = wait(&status)) == -1)
364 return(-1); /* none left */
365 ps2 = findjob(&psn2);
366 if (ps2 != NULL) /* clean up job if ours */
367 status = finishjob(ps2, psn2, status);
368 } while (ps2 != ps || psn2 != psn);
369 return(status); /* return job status */
370 }
