| 1 |
/* Copyright (c) 1996 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Parallel network process handling routines
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
#include <sys/types.h>
| 13 |
#include <sys/param.h>
| 14 |
#include <signal.h>
| 15 |
#include <fcntl.h>
| 16 |
#include "netproc.h"
| 17 |
#include "vfork.h"
| 18 |
/* select call compatibility stuff */
| 19 |
#ifndef FD_SETSIZE
| 20 |
| 21 |
#define FD_SETSIZE NOFILE /* maximum # select file descriptors */
| 22 |
#endif
| 23 |
#ifndef FD_SET
| 24 |
#ifndef NFDBITS
| 25 |
#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */
| 26 |
#endif
| 27 |
#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS)))
| 28 |
#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS)))
| 29 |
#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS)))
| 30 |
#ifndef BSD
| 31 |
#define bzero(d,n) (void)memset(d,0,n)
| 32 |
#endif
| 33 |
#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p)))
| 34 |
#endif
| 35 |
| 36 |
PSERVER *pslist = NULL; /* global process server list */
| 37 |
| 38 |
static PROC *pindex[FD_SETSIZE]; /* process index table */
| 39 |
| 40 |
static char ourhost[64]; /* this host name */
| 41 |
static char ourdir[MAXPATHLEN]; /* our working directory */
| 42 |
static char ouruser[32]; /* our user name */
| 43 |
static char *ourshell; /* our user's shell */
| 44 |
| 45 |
static fd_set errdesc; /* error file descriptors */
| 46 |
static int maxfd; /* maximum assigned descriptor */
| 47 |
| 48 |
extern char *remsh; /* externally defined remote shell program */
| 49 |
| 50 |
extern char *malloc(), *realloc();
| 51 |
extern char *getenv();
| 52 |
| 53 |
| 54 |
PSERVER *
| 55 |
addpserver(host, dir, usr, np) /* add a new process server */
| 56 |
char *host, *dir, *usr;
| 57 |
int np;
| 58 |
| 59 |
register PSERVER *ps;
| 60 |
/* allocate the struct */
| 61 |
if (np < 1)
| 62 |
return(NULL);
| 63 |
ps = (PSERVER *)malloc(sizeof(PSERVER)+(np-1)*sizeof(PROC));
| 64 |
if (ps == NULL)
| 65 |
return(NULL);
| 66 |
if (!ourhost[0]) { /* initialize */
| 67 |
char dirtmp[MAXPATHLEN];
| 68 |
register char *cp;
| 69 |
register int len;
| 70 |
| 71 |
strcpy(ourhost, myhostname());
| 72 |
getwd(dirtmp);
| 73 |
if ((cp = getenv("HOME")) != NULL) {
| 74 |
if (!strcmp(cp, dirtmp))
| 75 |
ourdir[0] = '\0';
| 76 |
else if (!strncmp(cp, dirtmp, len=strlen(cp)) &&
| 77 |
dirtmp[len] == '/')
| 78 |
strcpy(ourdir, dirtmp+len+1);
| 79 |
else
| 80 |
strcpy(ourdir, dirtmp);
| 81 |
} else
| 82 |
| 83 |
if ((cp = getenv("USER")) != NULL)
| 84 |
strcpy(ouruser, cp);
| 85 |
if ((ourshell = getenv("SHELL")) == NULL)
| 86 |
ourshell = "/bin/sh";
| 87 |
FD_ZERO(&errdesc);
| 88 |
maxfd = -1;
| 89 |
| 90 |
/* assign host, directory, user */
| 91 |
if (host == NULL || !strcmp(host, ourhost) ||
| 92 |
!strcmp(host, LHOSTNAME))
| 93 |
ps->hostname[0] = '\0';
| 94 |
else
| 95 |
strcpy(ps->hostname, host);
| 96 |
if (dir == NULL)
| 97 |
strcpy(ps->directory, ourdir);
| 98 |
else
| 99 |
strcpy(ps->directory, dir);
| 100 |
if (usr == NULL || !strcmp(usr, ouruser))
| 101 |
ps->username[0] = '\0';
| 102 |
else
| 103 |
strcpy(ps->username, usr);
| 104 |
/* clear process slots */
| 105 |
ps->nprocs = np;
| 106 |
while (np--) {
| 107 |
ps->proc[np].com = NULL;
| 108 |
ps->proc[np].pid = -1;
| 109 |
ps->proc[np].efd = -1;
| 110 |
ps->proc[np].errs = NULL;
| 111 |
ps->proc[np].elen = 0;
| 112 |
ps->proc[np].cf = NULL;
| 113 |
| 114 |
/* insert in our list */
| 115 |
ps->next = pslist;
| 116 |
pslist = ps;
| 117 |
/* check for signs of life */
| 118 |
if (!pserverOK(ps)) {
| 119 |
delpserver(ps); /* failure -- abort */
| 120 |
return(NULL);
| 121 |
| 122 |
return(ps);
| 123 |
| 124 |
| 125 |
| 126 |
delpserver(ps) /* delete a process server */
| 127 |
PSERVER *ps;
| 128 |
| 129 |
PSERVER pstart;
| 130 |
register PSERVER *psp;
| 131 |
register int i;
| 132 |
/* find server in our list */
| 133 |
pstart.next = pslist;
| 134 |
for (psp = &pstart; ps != psp->next; psp = psp->next)
| 135 |
if (psp->next == NULL)
| 136 |
return; /* not in our list! */
| 137 |
/* kill any running jobs */
| 138 |
for (i = 0; i < ps->nprocs; i++)
| 139 |
if (ps->proc[i].com != NULL) {
| 140 |
kill(SIGTERM, ps->proc[i].pid);
| 141 |
wait4job(ps, ps->proc[i].pid);
| 142 |
| 143 |
/* remove server from list */
| 144 |
psp->next = ps->next;
| 145 |
pslist = pstart.next;
| 146 |
free((char *)ps); /* free associated memory */
| 147 |
| 148 |
| 149 |
| 150 |
PSERVER *
| 151 |
findjob(pnp) /* find out where process is running */
| 152 |
register int *pnp; /* modified */
| 153 |
| 154 |
| 155 |
register int i;
| 156 |
| 157 |
for (ps = pslist; ps != NULL; ps = ps->next)
| 158 |
| 159 |
if (ps->proc[i].pid == *pnp) {
| 160 |
*pnp = i;
| 161 |
return(ps);
| 162 |
| 163 |
return(NULL); /* not found */
| 164 |
| 165 |
| 166 |
| 167 |
int
| 168 |
startjob(ps, command, compf) /* start a job on a process server */
| 169 |
| 170 |
char *command;
| 171 |
int (*compf)();
| 172 |
| 173 |
char udirt[MAXPATHLEN];
| 174 |
char *av[16];
| 175 |
int pfd[2], pid;
| 176 |
register int i;
| 177 |
| 178 |
if (ps == NULL) { /* find a server */
| 179 |
| 180 |
if ((i = startjob(ps, command, compf)) != -1)
| 181 |
return(i); /* got one */
| 182 |
return(-1); /* no slots anywhere */
| 183 |
| 184 |
| 185 |
if (ps->proc[i].com == NULL)
| 186 |
break;
| 187 |
if (i >= ps->nprocs)
| 188 |
return(-1); /* out of process slots */
| 189 |
/* open pipe */
| 190 |
if (pipe(pfd) < 0) {
| 191 |
perror("cannot open pipe");
| 192 |
exit(1);
| 193 |
| 194 |
/* start child process */
| 195 |
if ((pid = vfork()) == 0) {
| 196 |
close(pfd[0]); /* connect stderr to pipe */
| 197 |
if (pfd[1] != 2) {
| 198 |
dup2(pfd[1], 2);
| 199 |
close(pfd[1]);
| 200 |
| 201 |
if (ps->hostname[0]) { /* rsh command */
| 202 |
av[i=0] = remsh;
| 203 |
av[++i] = ps->hostname;
| 204 |
av[++i] = "-n"; /* no stdin */
| 205 |
if (ps->username[0]) { /* different user */
| 206 |
av[++i] = "-l";
| 207 |
av[++i] = ps->username;
| 208 |
av[++i] = "cd";
| 209 |
udirt[0] = '~';
| 210 |
strcpy(udirt+1, ouruser);
| 211 |
av[++i] = udirt;
| 212 |
av[++i] = ";";
| 213 |
| 214 |
if (ps->directory[0]) { /* change directory */
| 215 |
av[++i] = "cd";
| 216 |
av[++i] = ps->directory;
| 217 |
av[++i] = ";";
| 218 |
| 219 |
av[++i] = command;
| 220 |
av[++i] = NULL;
| 221 |
} else { /* shell command */
| 222 |
av[0] = ourshell;
| 223 |
av[1] = "-c";
| 224 |
av[2] = command;
| 225 |
av[3] = NULL;
| 226 |
| 227 |
execv(av[0], av);
| 228 |
_exit(1);
| 229 |
| 230 |
if (pid == -1) {
| 231 |
perror("fork failed");
| 232 |
exit(1);
| 233 |
| 234 |
ps->proc[i].com = command; /* assign process slot */
| 235 |
ps->proc[i].cf = compf;
| 236 |
ps->proc[i].pid = pid;
| 237 |
close(pfd[1]); /* get piped stderr file descriptor */
| 238 |
ps->proc[i].efd = pfd[0];
| 239 |
fcntl(pfd[0], F_SETFD, 1); /* set close on exec flag */
| 240 |
pindex[pfd[0]] = ps->proc + i; /* assign error fd index */
| 241 |
FD_SET(pfd[0], &errdesc); /* add to select call parameter */
| 242 |
if (pfd[0] > maxfd)
| 243 |
maxfd = pfd[0];
| 244 |
return(pid); /* return to parent process */
| 245 |
| 246 |
| 247 |
| 248 |
static int
| 249 |
readerrs(fd) /* read error output from fd */
| 250 |
int fd;
| 251 |
| 252 |
char errbuf[BUFSIZ];
| 253 |
int nr;
| 254 |
register PROC *pp;
| 255 |
/* look up associated process */
| 256 |
if ((pp = pindex[fd]) == NULL)
| 257 |
abort(); /* serious consistency error */
| 258 |
nr = read(fd, errbuf, BUFSIZ-1);
| 259 |
if (nr < 0) {
| 260 |
perror("read error");
| 261 |
exit(1);
| 262 |
| 263 |
if (nr == 0) /* stream closed (process finished) */
| 264 |
return(0);
| 265 |
errbuf[nr] = '\0'; /* add to error buffer */
| 266 |
if (pp->elen == 0)
| 267 |
pp->errs = (char *)malloc(nr+1);
| 268 |
else
| 269 |
pp->errs = (char *)realloc(pp->errs, pp->elen+nr+1);
| 270 |
if (pp->errs == NULL) {
| 271 |
perror("malloc failed");
| 272 |
exit(1);
| 273 |
| 274 |
strcpy(pp->errs+pp->elen, errbuf);
| 275 |
pp->elen += nr;
| 276 |
return(nr);
| 277 |
| 278 |
| 279 |
| 280 |
static
| 281 |
wait4end() /* read error streams until someone is done */
| 282 |
| 283 |
fd_set readfds, excepfds;
| 284 |
register int i;
| 285 |
/* find end of descriptor set */
| 286 |
for ( ; maxfd >= 0; maxfd--)
| 287 |
if (FD_ISSET(maxfd, &errdesc))
| 288 |
break;
| 289 |
if (maxfd < 0)
| 290 |
return; /* nothing to read */
| 291 |
readfds = excepfds = errdesc;
| 292 |
while (select(maxfd+1, &readfds, NULL, &excepfds, NULL) > 0)
| 293 |
for (i = 0; i <= maxfd; i++) /* get pending i/o */
| 294 |
if (FD_ISSET(i, &readfds) || FD_ISSET(i, &excepfds))
| 295 |
if (readerrs(i) == 0)
| 296 |
return; /* finished process */
| 297 |
perror("select call failed");
| 298 |
exit(1);
| 299 |
| 300 |
| 301 |
| 302 |
static int
| 303 |
finishjob(ps, pn, status) /* clean up finished process */
| 304 |
PSERVER *ps;
| 305 |
int pn;
| 306 |
int status;
| 307 |
| 308 |
register PROC *pp;
| 309 |
| 310 |
pp = ps->proc + pn;
| 311 |
if (pp->cf != NULL) /* client cleanup */
| 312 |
status = (*pp->cf)(ps, pn, status);
| 313 |
close(pp->efd); /* close error stream */
| 314 |
pindex[pp->efd] = NULL;
| 315 |
FD_CLR(pp->efd, &errdesc);
| 316 |
free((char *)pp->errs);
| 317 |
pp->com = NULL; /* clear settings */
| 318 |
pp->pid = -1;
| 319 |
pp->efd = -1;
| 320 |
pp->errs = NULL;
| 321 |
pp->elen = 0;
| 322 |
pp->cf = NULL;
| 323 |
return(status);
| 324 |
| 325 |
| 326 |
| 327 |
int
| 328 |
wait4job(ps, pid) /* wait for process to finish */
| 329 |
PSERVER *ps;
| 330 |
int pid;
| 331 |
| 332 |
int status, psn, psn2;
| 333 |
PSERVER *ps2;
| 334 |
| 335 |
if (pid == -1) { /* wait for first job */
| 336 |
if (ps != NULL) {
| 337 |
for (psn = ps->nprocs; psn--; )
| 338 |
if (ps->proc[psn].com != NULL)
| 339 |
break;
| 340 |
if (psn < 0)
| 341 |
return(-1); /* no processes this server */
| 342 |
| 343 |
do {
| 344 |
wait4end(); /* wait for something to end */
| 345 |
if ((psn2 = wait(&status)) == -1)
| 346 |
return(-1); /* none left */
| 347 |
ps2 = findjob(&psn2);
| 348 |
if (ps2 != NULL) /* clean up job if ours */
| 349 |
status = finishjob(ps2, psn2, status);
| 350 |
} while (ps2 == NULL || (ps != NULL && ps2 != ps));
| 351 |
return(status); /* return job status */
| 352 |
| 353 |
psn = pid; /* else find specific job */
| 354 |
ps2 = findjob(&psn); /* find process slot */
| 355 |
if (ps2 == NULL || (ps != NULL && ps2 != ps))
| 356 |
return(-1); /* inconsistent target */
| 357 |
ps = ps2;
| 358 |
do {
| 359 |
| 360 |
| 361 |
| 362 |
| 363 |
| 364 |
| 365 |
} while (ps2 != ps || psn2 != psn);
| 366 |
| 367 |
