root/Development/ray/src/util/netproc.c
Revision: 2.10
Committed: Wed Apr 23 00:52:34 2003 UTC (22 years, 8 months ago) by greg
5 * Parallel network process handling routines
6 */
7
8 #include <stdio.h>
9 #include <signal.h>
10 #include <fcntl.h>
11 #include "selcall.h"
12 #include "netproc.h"
13 #include "paths.h"
14 #include "vfork.h"
15
16 PSERVER *pslist = NULL; /* global process server list */
17
18 static PROC *pindex[FD_SETSIZE]; /* process index table */
19
20 static char ourhost[64]; /* this host name */
21 static char ourdir[MAXPATH]; /* our working directory */
22 static char ouruser[32]; /* our user name */
23 static char *ourshell; /* our user's shell */
24
25 static fd_set errdesc; /* error file descriptors */
26 static int maxfd; /* maximum assigned descriptor */
27
28 extern char *remsh; /* externally defined remote shell program */
29
30 extern char *getenv();
31
32
33 PSERVER *
34 addpserver(host, dir, usr, np) /* add a new process server */
35 char *host, *dir, *usr;
36 int np;
37 {
38 register PSERVER *ps;
39 /* allocate the struct */
40 if (np < 1)
41 return(NULL);
42 ps = (PSERVER *)malloc(sizeof(PSERVER)+(np-1)*sizeof(PROC));
43 if (ps == NULL)
44 return(NULL);
45 if (!ourhost[0]) { /* initialize */
46 char dirtmp[MAXPATH];
47 register char *cp;
48 register int len;
49
50 strcpy(ourhost, myhostname());
51 getwd(dirtmp);
52 if ((cp = getenv("HOME")) != NULL) {
53 if (!strcmp(cp, dirtmp))
54 ourdir[0] = '\0';
55 else if (!strncmp(cp, dirtmp, len=strlen(cp)) &&
56 dirtmp[len] == '/')
57 strcpy(ourdir, dirtmp+len+1);
58 else
59 strcpy(ourdir, dirtmp);
60 } else
61 strcpy(ourdir, dirtmp);
62 if ((cp = getenv("USER")) != NULL)
63 strcpy(ouruser, cp);
64 if ((ourshell = getenv("SHELL")) == NULL)
65 ourshell = "/bin/sh";
66 FD_ZERO(&errdesc);
67 maxfd = -1;
68 }
69 /* assign host, directory, user */
70 if (host == NULL || !strcmp(host, ourhost) ||
71 !strcmp(host, LHOSTNAME))
72 ps->hostname[0] = '\0';
73 else
74 strcpy(ps->hostname, host);
75 if (dir == NULL)
76 strcpy(ps->directory, ourdir);
77 else
78 strcpy(ps->directory, dir);
79 if (usr == NULL || !strcmp(usr, ouruser))
80 ps->username[0] = '\0';
81 else
82 strcpy(ps->username, usr);
83 /* clear process slots */
84 ps->nprocs = np;
85 while (np--) {
86 ps->proc[np].com = NULL;
87 ps->proc[np].pid = -1;
88 ps->proc[np].efd = -1;
89 ps->proc[np].errs = NULL;
90 ps->proc[np].elen = 0;
91 ps->proc[np].cf = NULL;
92 }
93 /* insert in our list */
94 ps->next = pslist;
95 pslist = ps;
96 /* check for signs of life */
97 if (!pserverOK(ps)) {
98 delpserver(ps); /* failure -- abort */
99 return(NULL);
100 }
101 return(ps);
102 }
103
104
105 delpserver(ps) /* delete a process server */
106 PSERVER *ps;
107 {
108 PSERVER pstart;
109 register PSERVER *psp;
110 register int i;
111 /* find server in our list */
112 pstart.next = pslist;
113 for (psp = &pstart; ps != psp->next; psp = psp->next)
114 if (psp->next == NULL)
115 return; /* not in our list! */
116 /* kill any running jobs */
117 for (i = 0; i < ps->nprocs; i++)
118 if (ps->proc[i].com != NULL) {
119 kill(SIGTERM, ps->proc[i].pid);
120 wait4job(ps, ps->proc[i].pid);
121 }
122 /* remove server from list */
123 psp->next = ps->next;
124 pslist = pstart.next;
125 free((void *)ps); /* free associated memory */
126 }
127
128
129 PSERVER *
130 findjob(pnp) /* find out where process is running */
131 register int *pnp; /* modified */
132 {
133 register PSERVER *ps;
134 register int i;
135
136 for (ps = pslist; ps != NULL; ps = ps->next)
137 for (i = 0; i < ps->nprocs; i++)
138 if (ps->proc[i].pid == *pnp) {
139 *pnp = i;
140 return(ps);
141 }
142 return(NULL); /* not found */
143 }
144
145
146 int
147 startjob(ps, command, compf) /* start a job on a process server */
148 register PSERVER *ps;
149 char *command;
150 int (*compf)();
151 {
152 char udirt[MAXPATH];
153 char *av[16];
154 int pfd[2], pid;
155 register int i;
156
157 if (ps == NULL) { /* find a server */
158 for (ps = pslist; ps != NULL; ps = ps->next)
159 if ((i = startjob(ps, command, compf)) != -1)
160 return(i); /* got one */
161 return(-1); /* no slots anywhere */
162 }
163 for (i = 0; i < ps->nprocs; i++)
164 if (ps->proc[i].com == NULL)
165 break;
166 if (i >= ps->nprocs)
167 return(-1); /* out of process slots */
168 /* open pipe */
169 if (pipe(pfd) < 0) {
170 perror("cannot open pipe");
171 exit(1);
172 }
173 /* start child process */
174 if ((pid = vfork()) == 0) {
175 close(pfd[0]); /* connect stderr to pipe */
176 if (pfd[1] != 2) {
177 dup2(pfd[1], 2);
178 close(pfd[1]);
179 }
180 if (ps->hostname[0]) { /* rsh command */
181 av[i=0] = remsh;
182 av[++i] = ps->hostname;
183 av[++i] = "-n"; /* no stdin */
184 if (ps->username[0]) { /* different user */
185 av[++i] = "-l";
186 av[++i] = ps->username;
187 av[++i] = "cd";
188 udirt[0] = '~';
189 strcpy(udirt+1, ouruser);
190 av[++i] = udirt;
191 av[++i] = ";";
192 }
193 if (ps->directory[0]) { /* change directory */
194 av[++i] = "cd";
195 av[++i] = ps->directory;
196 av[++i] = ";";
197 }
198 av[++i] = command;
199 av[++i] = NULL;
200 } else { /* shell command */
201 av[0] = ourshell;
202 av[1] = "-c";
203 av[2] = command;
204 av[3] = NULL;
205 }
206 execv(av[0], av);
207 _exit(1);
208 }
209 if (pid == -1) {
210 perror("fork failed");
211 exit(1);
212 }
213 ps->proc[i].com = command; /* assign process slot */
214 ps->proc[i].cf = compf;
215 ps->proc[i].pid = pid;
216 close(pfd[1]); /* get piped stderr file descriptor */
217 ps->proc[i].efd = pfd[0];
218 fcntl(pfd[0], F_SETFD, 1); /* set close on exec flag */
219 pindex[pfd[0]] = ps->proc + i; /* assign error fd index */
220 FD_SET(pfd[0], &errdesc); /* add to select call parameter */
221 if (pfd[0] > maxfd)
222 maxfd = pfd[0];
223 return(pid); /* return to parent process */
224 }
225
226
227 static int
228 readerrs(fd) /* read error output from fd */
229 int fd;
230 {
231 char errbuf[BUFSIZ];
232 int nr;
233 register PROC *pp;
234 /* look up associated process */
235 if ((pp = pindex[fd]) == NULL)
236 abort(); /* serious consistency error */
237 nr = read(fd, errbuf, BUFSIZ-1);
238 if (nr < 0) {
239 perror("read error");
240 exit(1);
241 }
242 if (nr == 0) /* stream closed (process finished) */
243 return(0);
244 errbuf[nr] = '\0'; /* add to error buffer */
245 if (pp->elen == 0)
246 pp->errs = (char *)malloc(nr+1);
247 else
248 pp->errs = (char *)realloc((void *)pp->errs, pp->elen+nr+1);
249 if (pp->errs == NULL) {
250 perror("malloc failed");
251 exit(1);
252 }
253 strcpy(pp->errs+pp->elen, errbuf);
254 pp->elen += nr;
255 return(nr);
256 }
257
258
259 static
260 wait4end() /* read error streams until someone is done */
261 {
262 fd_set readfds, excepfds;
263 register int i;
264 /* find end of descriptor set */
265 for ( ; maxfd >= 0; maxfd--)
266 if (FD_ISSET(maxfd, &errdesc))
267 break;
268 if (maxfd < 0)
269 return; /* nothing to read */
270 readfds = excepfds = errdesc;
271 while (select(maxfd+1, &readfds, NULL, &excepfds, NULL) > 0)
272 for (i = 0; i <= maxfd; i++) /* get pending i/o */
273 if (FD_ISSET(i, &readfds) || FD_ISSET(i, &excepfds))
274 if (readerrs(i) == 0)
275 return; /* finished process */
276 perror("select call failed");
277 exit(1);
278 }
279
280
281 static int
282 finishjob(ps, pn, status) /* clean up finished process */
283 PSERVER *ps;
284 int pn;
285 int status;
286 {
287 register PROC *pp;
288
289 pp = ps->proc + pn;
290 if (pp->cf != NULL) /* client cleanup */
291 status = (*pp->cf)(ps, pn, status);
292 close(pp->efd); /* close error stream */
293 pindex[pp->efd] = NULL;
294 FD_CLR(pp->efd, &errdesc);
295 free((void *)pp->errs);
296 pp->com = NULL; /* clear settings */
297 pp->pid = -1;
298 pp->efd = -1;
299 pp->errs = NULL;
300 pp->elen = 0;
301 pp->cf = NULL;
302 return(status);
303 }
304
305
306 int
307 wait4job(ps, pid) /* wait for process to finish */
308 PSERVER *ps;
309 int pid;
310 {
311 int status, psn, psn2;
312 PSERVER *ps2;
313
314 if (pid == -1) { /* wait for first job */
315 if (ps != NULL) {
316 for (psn = ps->nprocs; psn--; )
317 if (ps->proc[psn].com != NULL)
318 break;
319 if (psn < 0)
320 return(-1); /* no processes this server */
321 }
322 do {
323 wait4end(); /* wait for something to end */
324 if ((psn2 = wait(&status)) == -1)
325 return(-1); /* none left */
326 ps2 = findjob(&psn2);
327 if (ps2 != NULL) /* clean up job if ours */
328 status = finishjob(ps2, psn2, status);
329 } while (ps2 == NULL || (ps != NULL && ps2 != ps));
330 return(status); /* return job status */
331 }
332 psn = pid; /* else find specific job */
333 ps2 = findjob(&psn); /* find process slot */
334 if (ps2 == NULL || (ps != NULL && ps2 != ps))
335 return(-1); /* inconsistent target */
336 ps = ps2;
337 do {
338 wait4end(); /* wait for something to end */
339 if ((psn2 = wait(&status)) == -1)
340 return(-1); /* none left */
341 ps2 = findjob(&psn2);
342 if (ps2 != NULL) /* clean up job if ours */
343 status = finishjob(ps2, psn2, status);
344 } while (ps2 != ps || psn2 != psn);
345 return(status); /* return job status */
346 }
